Domoticz App
Andree
Re: Domoticz App
Post by Andree »
FIRST OF ALL - Congratulations,very nice work and i love to see italian localization!
Tested on iPhone 6s iOS 10.2 and iPhone 7 iOS 11b2
- The status bar should be white,black to black it's not good
- In the graph page there is a big button :D
and IMHO and request!
- "Search" in italian language will be "Cerca". "Filtro" it means "Filter".
- You can consider,for principal panel,an option like "minimal" so arrange in a little space more switch possible!
galadril
Domoticz version: latest
Re: Domoticz App
Post by galadril »
Thanks for the feedback!
galadril
Re: Domoticz App
Post by galadril »
Uploading some quick fixes just before my holidays:
- Weird scaled graph filter icon
- Connection issues to HTTPS connections (make port settings optional)
- Add next/previous buttons to the welcome setup screen
- Add a close button to all popups
marcotrumpet
Re: Domoticz App
Post by marcotrumpet »
galadril wrote:Uploading some quick fixes just before my holidays:
Waiting the update
Inviato dal mio iPhone utilizzando Tapatalk
bdormael
Re: Domoticz App
Post by bdormael »
First feedback on beta testing:
- As mentioned above, make minimal layout to prevent too much scrolling
- I have lots of contact sensors to detect if a door/window is open or not, it shows the status correct in your app, but it also shows a big "ON" button, which is confusing for the user, can't this just show "Open" or Closed" as read only ?
- Temperature : Is it possible it shows the temperature also bigger on the right iso only at the status line so it's easier to have an overview ?
- Thermostats : maybe this is already in progress, but it would be nice to change the setpoint more userfriendly then free text field
- When changing settings (eg. in the dashboard), this is not refreshed or applied without roced closing the app and re-opening
- Security Panel : when changing status it pops-up for which status you want to change -> "Favorite" looks like it is part of the options, which is confusing for the user, can't "Favorite" be shown less emphasised ? (because once you're favorites are set, normally you don't change a lot
- Security Panel : Can the status be more emphasised (like also on the right side), so it's directly obvious which status it has been set to ?
All in all, a very nice first beta version, thx for all the effort
galadril
Re: Domoticz App
Post by galadril »
bdormael wrote: - As mentioned above, make minimal layout to prevent too much scrolling
There is a setting allready for more or less information
bdormael wrote:- I have lots of contact sensors to detect if a door/window is open or not, it shows the status correct in your app, but it also shows a big "ON" button, which is confusing for the user, can't this just show "Open" or Closed" as read only ?
This is also the case with the web ui at this moment. it's a 'readyonly' pushon/off device.
But ill add this to the list.. maybe i can set the door contacts on default readonly devices..
bdormael wrote:- Temperature : Is it possible it shows the temperature also bigger on the right iso only at the status line so it's easier to have an overview ?
Ill add this to the list
bdormael wrote: - Thermostats : maybe this is already in progress, but it would be nice to change the setpoint more userfriendly then free text field
Not yet, there is not a nice arc seekbar control available at this moment.. but probably somewhere in the future!!
bdormael wrote: - When changing settings (eg. in the dashboard), this is not refreshed or applied without roced closing the app and re-opening
you can also pull down the list to refresh, or what settings are you talking about?
bdormael
Re: Domoticz App
Post by bdormael »
Thx for the swift answer, much appreciated.
With settings I mean change something in the settings page like eg. show stats or hide stats, then going back to the dashboard, the old setting is still shown until the app is force quit and restarted.
- I noticed there is a setting to show less stats to have a condensed layout, but there is still a lot of white space per device, it would be nice if the space is optimized.
- Another thing I noticed is that the app doesn’t refresh the current state when going to the iPhone home screen and go back in the app, the only way to refresh is to pull down, it would be nice if it refreshes each time the app is opened in the foreground
Verzonden vanaf mijn iPad met Tapatalk
galadril
Re: Domoticz App
Post by galadril »
New version is available via testflight
marcotrumpet
Re: Domoticz App
galadril wrote:New version is available via testflight
It's me or now everything seems bigger, zoomed? Like an ios app not optimized..
G3rard
Domoticz version: No
Re: Domoticz App
Post by G3rard »
marcotrumpet wrote: It's me or now everything seems bigger, zoomed? Like an ios app not optimized..
Yep, there is indeed a difference with the previous version. Made a screenshot before upgrading after I saw your post and indeed it's looking zoomed now.
Not using Domoticz anymore
Nautilus
Re: Domoticz App
Post by Nautilus »
Nice work! I'm on iPhone SE (yeah, our company policy sucks ;)) with iOS 10.3.2. Most of the points I had already mentioned here. For some reason the Dashboard shows two of my utility sensors at the very top although the mode is "use server sorting" and there they are in the last section. Also, it would be very nice to be able to sort them manually (in each screen).
The "last seen" is also still showing the last seen time in format "10 hours 20 minutes" which is easy to confuse it has been seen this long ago. So as suggested, I'd vote for either showing just a timestamp (10:20:22) or then calculate the actual "time ago" and add "ago" at the end ("10 hours 20 minutes ago").
What kind of extras have you been thinking about for the paid version?
Keep up the good work!
marcotrumpet
Re: Domoticz App
Tested the app also on my ipad pro 9,7 with ios 11 beta 2. I agree with someone before me, too dark background and text coloro on the top bar
rgroothuis
Re: Domoticz App
Post by rgroothuis »
can i participate in the beta testing as well. i can and will test the app on a iPhone 7 plus and a iPad Pro.
Dahl1632
Target OS: OS X
Re: Domoticz App
Post by Dahl1632 »
I would also like to test :)
Thank you in advance
Thelion
Domoticz version: 2022.1
Re: Domoticz App
Post by Thelion »
Any chance of becoming another beta user?
LanWolf
Re: Domoticz App
Post by LanWolf »
Hi. Would love to test.
I was beta tester fir Pilot and Domotix before too.
*/ Just A Byte /*
G3rard
Re: Domoticz App
Post by G3rard »
Some more findings after testing v0.05 on iPhone 7, iOS 10.3.1.
* Version is zoomed (like an old app which is not made for larger screens of new iPhones)
* Temperature devices show the temperature twice, at status and temperature
* Rain sensor shows data from field Data, better is to use fields Rain and RainRate as that is shown in Domoticz as well
* When select a protected switch and pressing Cancel, the switch is changed in the view although it isn't actually switched
G3rard
Re: Domoticz App
Post by G3rard »
* When a dimmer value is changed, that value is not updated in the app.
* It's not possible to toggle a group in the Scenes tab, when pressing on a group, you only get the possibility to add it to the Favorites or show the Log
@galadril, keep up the good work and enjoy your holidays!
TroisSix
Domoticz version: 2025.2
Re: Domoticz App
Post by TroisSix »
Hello
I was waiting for an IOS version for a so long time, I would be very interested to test the beta version. Can I have this beta version for helping you to test it? Thx 8-)
VM Debian - Domoticz stable v2025.2, RFXtrx433, Aeotec Z-Stick Gen5, Zigbee, Two APC
- rts: dio, oregon, somfy
- zwave: fibaro fgs212, aeotec smart switch, vision ZG8101
- IO Homecontrol: Velux Connexoon
- philips hue, Pilot app.
galadril
Re: Domoticz App
Post by galadril »
@G3rard Thanks, all valid points!
Verstuurd vanaf mijn SM-T713 met Tapatalk
