Page 5 of 9
Re: Python Plugin: Samsung TV
Posted: Friday 15 December 2017 17:03
by denman091
Jostice wrote: Thursday 14 December 2017 22:58
denman091 wrote: Thursday 14 December 2017 22:51
I have exactly the same problem.
Do you you have it already fixed?
Yes, check the forum post right after that one! There is the solution.
so, first you have downgrade samsungctl to version 0.6.0, right?
How dit you did that?
and then everything works with commandline but not in domoticz, right? therefore you have moved six.py to the right directory?
and then everything should work from command line and domoticz?
Posted: Friday 15 December 2017 18:03
by Jostice
I am not sure if the downgrade was necessary, but the six.py is! If not installed then do that, or move from different python folder.
To downgrade: do an install remove of samsungctl
Then again do install samsungctl with pip but add the version number! I can't remember how, but Google is your friend....
Posted: Wednesday 20 December 2017 22:20
by denman091
Jostice wrote: Friday 15 December 2017 18:03
I have copied the six.py file.
But when i "Enable the hardware in domticz i get the following error in the log:
2017-12-20 22:17:53.514 (Samsung TV) No ini file :/home/pi/domoticz/plugins/SamsungTV/plugin_remote_6.ini
Also when i try to connect via command line i still get the error: Connection Refushed.
Posted: Wednesday 20 December 2017 22:39
by zak45
denman091 wrote: Wednesday 20 December 2017 22:20
you're in Debug mode, this not indicate error, only the fact that custom command for Remote is not managed.
The first time you send a command, you should aknowledge on your TV.
Posted: Wednesday 20 December 2017 22:41
by dextm80
It’s more difficult for a normal or newbie user install that plugin whitout a definitive simple guide....this is what i think.
I abandoned this project for now
Posted: Thursday 21 December 2017 9:03
by desertdog
zak45 wrote: Wednesday 20 December 2017 22:39
I think I might have missed that notification on my tv. It might have been there but I never saw it or looked at the tv at that time. At least the tv is not showing a confirmation screen (anymore). Is there a way to get this screen again on the tv?
Posted: Saturday 30 December 2017 11:17
by timberwolf
One more installation problem...
I have got the plugin working from the command line. In the hardware list i can add the Samsung TV, but i don't get any settings fields.
When i add the hardware i get this in the log:
2017-12-30 11:07:42.967 Error: () failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-12-30 11:07:42.967 Error: (tv) Module Import failed, exception: 'ImportError'
2017-12-30 11:07:42.967 Error: (tv) Module Import failed: ' Name: samsungctl'
2017-12-30 11:07:42.967 Error: (tv) Error Line details not available.
2017-12-30 11:09:00.867 Error: tv hardware (4) thread seems to have ended unexpectedly
I have spent two days on this now reading everything i can find, but no luck. I guess it's just some stupid misstake, but i just can't find it.
Running Domoticz (Version: 3.8797)on a Raspberry Pi.
Posted: Saturday 30 December 2017 14:31
by dextm80
Same problem, because there isn t a clear guide unfortunately
Posted: Sunday 31 December 2017 0:01
by zak45
@timberwolf
this is due to the fact you have more than one python version on your system.
if you take a look at your error :
python could not find your samsungctl module. you need to copy it under one of these directories:
Some others even copy it under the plugin directory, but I would avoid to do that.
All of that depend of your OS and python installation, this need to be adapted to your installation.
Posted: Sunday 31 December 2017 15:30
by Calzor Suzay
Having issues getting this working
On a Raspberry Pi at the basic samsungctl level I can't get the command like to work.
I have a KS7000 which has been mentioned in this thread as working but get
samsungctl -i --host 192.168.1.42 --method websocket
Error: Operation now in progress
I tried a port scan and 8000, 8001, 8002 are listening so tried
samsungctl -i --host 192.168.1.42 --port 8000 --method websocket
Any ideas?
The next stage is getting plugin.py working which I think it is as it's in the log trying to talk to it and says
(SamsungTV) Calling message handler 'onHeartbeat'.
(SamsungTV) Device has disconnected - Maybe PowerOff
From the supported models it has
Series K Yes Socket Tizen 2016
Implying I need websocket but when I try it without I get
Error: Connection closed!
samsungctl -i --host 192.168.1.42 --port 8001
samsungctl -i --host 192.168.1.42 --port 8002
samsungctl -i --host 192.168.1.42 --port 8003
Error: Connection refused
samsungctl -i --host 192.168.1.42 --port 8005
Is there anything I need to turn on via the tv, it never pops up and prompts for anything.
Posted: Sunday 31 December 2017 19:00
by dextm80
same problem, i ve ks7000 too
Posted: Sunday 31 December 2017 20:44
by Calzor Suzay
Ok managed to get it further...
I have it working via the command line but specify a port, in my case 8001 and have to add a timeout option, even 1 works, so...
samsungctl -i --host 192.168.1.42 --port 8001 --method websocket --timeout 1
Brings me up a menu from a quick test can send commands.
Also in the network settings in the TV there's something called Mobile Device Manager, I have access notification to off so it lets devices in, this was off anyway as I already had an app controlling the tv and can see, mine, my wifes and the iPad listed here.
I transferred the options over to Domoticz, it sees the tv 'alive' but now have this problem
2017-12-31 19:35:17.480 (SamsungTV) isAlive status :True
2017-12-31 19:35:17.480 (SamsungTV) Devices are connected - Initialisation
2017-12-31 19:35:17.482 Error: (SamsungTV) 'onStart' failed 'ImportError'.
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 134 in /home/osmc/domoticz/plugins/SamsungTV/plugin.py, function onStart
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 287 in /home/osmc/domoticz/plugins/SamsungTV/plugin.py, function SamsungSend
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 10 in /usr/lib/python3.4/samsungctl/remote.py, function __init__
2017-12-31 19:35:17.482 Error: (SamsungTV) ----> Line 13 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function __init__
2017-12-31 19:35:17.482 (SamsungTV) Heartbeat interval set to: 15.
It obviously creates no devices and fails, any ideas?
Posted: Tuesday 02 January 2018 0:18
by zak45
@Calzor Suzay
All of that is related to python and depend of your OS and installation/version.
if the command line is working, that's great, this mean you should have all requirement in place.
Now, if this not work in the Domoticz python framework, this is mainly due to the fact that the framework do not search in the right directory for your system and you need to help it to find the module by copying it.
For your television, you need websocket-client installed and to found where you have installed it, just do this command:
sudo pip3 show websocket-client
this should give you this output ( take care , this is only example from my system)
Metadata-Version: 2.0
Version: 0.46.0
Summary: WebSocket client for python. hybi13 is supported.
Home-page:
https://github.com/websocket-client/web ... client.git
Author: liris
Author-email:
[email protected]
Installer: pip
License: LGPL
Requires: six
Classifiers:
Development Status :: 4 - Beta
License :: OSI Approved :: GNU Library or Lesser General Public License (LGPL)
Programming Language :: Python
Programming Language :: Python :: 2
Programming Language :: Python :: 3
Operating System :: MacOS :: MacOS X
Operating System :: POSIX
Operating System :: Microsoft :: Windows
Topic :: Internet
Here, you can see that this has been installed under /usr/local/lib/python3.5/dist-packages
You need to copy it from this directory(websocket) under the directory you have already copy samsungctl.
Take care also for the python module dependencies; here your can see that this requires "six", so do the same for this module if necessary.
Posted: Wednesday 03 January 2018 12:18
by timberwolf
zak45 wrote: Sunday 31 December 2017 0:01
@timberwolf
'ImportError'
So i copied the samsungctl to the suggested directories and the initial error disappeared. Now i get this error instead when i try to add the Samsung TV hardware:
2018-01-03 12:09:48.985 Error: () failed to load 'plugin.py', Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2018-01-03 12:09:48.985 Error: (TV) Module Import failed, exception: 'ImportError'
2018-01-03 12:09:48.985 Error: (TV) Module Import failed: ' Name: plugin'
2018-01-03 12:09:48.986 Error: (TV) Error Line details not available.
if i copy module.py to /usr/lib/python3.4/ i get these errors instead:
2018-01-03 12:17:17.466 Error: Initialise: Error 'Error document empty.' at line 0 column 0 in XML ''.
2018-01-03 12:17:17.478 Error: (TV) 'onStart' failed 'ValueError':'invalid literal for int() with base 10: '''.
2018-01-03 12:17:17.478 Error: (TV) ----> Line 124 in /usr/lib/python3.4/plugin.py, function onStart
2018-01-03 12:17:26.994 Error: (TV) 'onHeartbeat' failed 'NameError'.
2018-01-03 12:17:26.994 Error: (TV) ----> Line 205 in /usr/lib/python3.4/plugin.py, function onHeartbeat
2018-01-03 12:17:26.994 Error: (TV) ----> Line 330 in /usr/lib/python3.4/plugin.py, function isAlive
2018-01-03 12:17:41.977 Error: (TV) 'onHeartbeat' failed 'NameError'.
2018-01-03 12:17:41.978 Error: (TV) ----> Line 205 in /usr/lib/python3.4/plugin.py, function onHeartbeat
2018-01-03 12:17:41.978 Error: (TV) ----> Line 330 in /usr/lib/python3.4/plugin.py, function isAlive
Still no luck...
Posted: Wednesday 03 January 2018 13:35
by zak45
timberwolf wrote: Wednesday 03 January 2018 12:18
2018-01-03 12:09:48.985 Error: () [b]failed to load 'plugin.py'[/b], Python Path used was ':/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
1: plugin.py do not exist on the plugin directory, you need to have it there.
2:do not know what is "module.py" ???? and not necessary for this plugin.
Posted: Wednesday 03 January 2018 15:39
by timberwolf
zak45 wrote: Wednesday 03 January 2018 13:35
Sorry, typing mistake, no module.py. The plugin.py does exist in the plugins directory:
pi@raspberrypi:~/domoticz/plugins/samsungtv $ ls
plugin.py
BR
Timberwolf
Posted: Wednesday 03 January 2018 17:44
by zak45
@timberwolf
so check rights on the plugin.py and restart domoticz.
Posted: Thursday 04 January 2018 17:21
by Calzor Suzay
Ok this seems to kill Domoticz...
Restored my Raspberry Pi (OSMC) back to an image.
Ran through the install
sudo apt-get install python3-pip
Installing collected packages: samsungctl
Running setup.py install for samsungctl
Installing samsungctl script to /usr/local/bin
Successfully installed samsungctl
sudo pip3 install samsungctl
sudo pip3 install websocket-client
Requirement already satisfied (use --upgrade to upgrade): six in /usr/lib/python3/dist-packages (from websocket-client)
Installing collected packages: websocket-client
Successfully installed websocket-client
Created folder /home/osmc/domoticz/plugins/samsungtv
copied plugin.py to it and set chmod 777
Tested from command line and works
Rebooted, was getting weird error and from comments on board then installed this which got rid of error (I'm on 3.8153)
Error "EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform."
sudo apt-get install python3-dev
Now no errors in log
Python EventSystem: Module not found - Trying to initialize.
Python EventSystem: Initalizing event module.
EventSystem: Started
Added hardware to Domoticz but have error
Error: (SamsungTV) failed to load 'plugin.py', Python Path used was '/home/osmc/domoticz/plugins/samsungtv/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
Error: (SamsungTV) Module Import failed, exception: 'ImportError'
Error: (SamsungTV) Module Import failed: ' Name: samsungctl'
So copied samsungctl over
sudo cp -r /usr/local/lib/python3.4/dist-packages/samsungctl /usr/lib/python3.4/
Now get the following in the logs
Error: (SamsungTV) ----> Line 134 in /home/osmc/domoticz/plugins/samsungtv/plugin.py, function onStart
Error: (SamsungTV) ----> Line 287 in /home/osmc/domoticz/plugins/samsungtv/plugin.py, function SamsungSend
sudo cp -r /usr/local/lib/python3.4/dist-packages/websocket /usr/lib/python3.4/samsungctl
sudo cp ./six.py /usr/local/lib/python3.4/dist-packages
Still no luck with same last error
Posted: Thursday 04 January 2018 17:59
by zak45
if you have done this :
this should have killed your samsungctl installation.
this should be :
sudo cp -r /usr/local/lib/python3.4/dist-packages/websocket /usr/lib/python3.4/websocket
Posted: Thursday 04 January 2018 18:31
by Calzor Suzay
I think that was a typo to be honest as samsungctl folder was still intact.
Didn't realise websocket needed to be in the folder above not samsungctl so running this below has got it working
Saying that I sent a few volume up commands then it kills Domoticz
Have to restart service
User: Admin initiated a switch command (85/SamsungTV - Volume/Set Level)
(SamsungTV) Calling message handler 'onCommand'.
(SamsungTV) onCommand called for Unit 3: Parameter 'Set Level', Level: 10, Connected: True
Error: (SamsungTV) 'onCommand' failed 'ValueError'.
Error: (SamsungTV) ----> Line 169 in /home/osmc/domoticz/plugins/samsungtv/plugin.py, function onCommand
Error: (SamsungTV) ----> Line 24 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function __init__
Error: (SamsungTV) ----> Line 62 in /usr/lib/python3.4/samsungctl/remote_websocket.py, function _read_response
Error: (SamsungTV) ----> Line 318 in /usr/lib/python3.4/json/__init__.py, function loads
Error: (SamsungTV) ----> Line 343 in /usr/lib/python3.4/json/decoder.py, function decode
Error: (SamsungTV) ----> Line 361 in /usr/lib/python3.4/json/decoder.py, function raw_decode
About here the site falls over and I have to sudo service domoticz restart for it work again.
