NUT Mini BATTERY SERVICE
Artursd
Re: NUT Mini BATTERY SERVICE
Found a mistake. Now Nut is at home, but the variable does not change to Home
https://yadi.sk/i/iyyMFzR0Flu3Dw
https://yadi.sk/i/tzPvOQXUby5FQA
https://yadi.sk/i/nLZqNIHPnZpOdw
- emme
- Domoticz version: latest
how did you fix it?
just curious
just curious
"We always done this way"
Artursd
there was a space in the name, but the space does not understand
Artursd
And now I don’t understand what the problem is, it’s like seeing my NUT, but it doesn’t change the meaning.
- emme
do not use spaces or special chars at all
use the CamelCase to name your variables
call them
nutEgita and
nutAlarm
then deploy the flow and should start (same name in domoticz Variable/switch names)
call them
nutEgita and
nutAlarm
Artursd
and how to stop the execution of Flow ??
- emme
flow won't stop unless you disable it
simply change and deplay
Artursd
what am I doing wrong? does not find my NUT
- emme
is your nut already configured (paired) with its app?
Artursd
Which application? How configured?
Artursd
if I manually correct the variable on HOME, it is corrected automatically on AWAY
- emme
welll... it looks like it does not discover the address
try place a debug node right out the scan BLE anch find the telegram with the correct mac address...
it has to be written EXACTELY in the same way
AA:BB:CC:DD:EE is different than Aa:Bb:Cc:Dd:Ee
Artursd
https://yadi.sk/i/KpbJM4GcnieG8g
I correctly entered the data ???? Malenkte and capital letters differ ???
- emme
the last screen is the device that has been turned on by the toggler
I need to see the device telegram... the one who has the macaddress as UUID
