Python plugin: Sonos [old version]
tester22
Re: Python plugin: Sonos
Post by tester22 »
HomeAutomation wrote:
mvzut wrote:
HomeAutomation wrote:How to control Sonos by LUA script
Does anybody have a example how to control the Sonos plugin with a LUA script?
Jan
It's just as if you are controlling a lamp: You can use LUA on/off commands (commandArray['<status device name>'] = 'On') to start/pause a player with the current playlist, and you can use the volume device as if it was a dimmer (using e.g. commandArray['<volume device name>']= 'Set Level 30').
As far as I know the plugin can't be used to e.g. skip to the next song or to start a particular playlist. The virtual remote doesn't work (yet).
Works perfect.
Integreated Sonos in my WakeUp alarm.
Now, based on one time setting, I'm able to control my bedroom light (WakeUp), central heating and Sonos.
Still looking for a timer pluging however. :idea: ?
Timer plugin?
Create an dummy switch and conenct it to blocky.
Define the Sonos to start playing directly and stop after x minutes.
HomeAutomation
Domoticz version: V3.6838
Post by HomeAutomation »
mvzut wrote: It's just as if you are controlling a lamp: You can use LUA on/off commands (commandArray['<status device name>'] = 'On') to start/pause a player with the current playlist, and you can use the volume device as if it was a dimmer (using e.g. commandArray['<volume device name>']= 'Set Level 30').
Works perfect.
Timer plugin?
Sorry, I ment an Alarm Clock.
Currently I use the "Time = " function in Blocky to start for instance the WakeUp script.
Scenes however can't be reached with myAnroid tablet.
Even though, I prefer a plugin in which it's possible to fill in a time (clock) value.
Jan
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
It would be nice to be able to set the media source (Sonos favourite for instance), if possible.
I currently use a nodejs middle tier for doing that, and it would be nice to get rid of external dependencies.
I use it to automatically play some lounge music in the bathroom when there is motion :)
tester22
Post by tester22 »
RayAmsterdam wrote:TTS would be great!
OK, this is super Alpha (pre Beta) but the latest version on Github supports TTS:
https://github.com/tester22/Domoticz-Sonos
bdormael
Post by bdormael »
It's definitly super alpha, when replacing the previous plugin file with the new one, Domoticz won't start anymore.
Going back to the previous plugin file, all works fine.
tester22
Post by tester22 »
Strange, did you copy all the files including the zip files to the plugin folder?
bdormael
Post by bdormael »
Yes, the zip file is there as well, unfortunatly since domoticz does not start, I don't have any logging available either.
Is there any way I can add extra logging ?
tester22
Post by tester22 »
Try this version: https://github.com/tester22/Domoticz-So ... /plugin.py
I introduced custom icons about an week ago and maybe thats what causing it.
bdormael
Post by bdormael »
Tried the new file, still crashing Domoticz I'm afraid
tester22
Post by tester22 »
Are you on the latest Domoticz Beta? Icons were introduced a couple of weeks ago.
Or switch to this version, without icons: https://github.com/tester22/Domoticz-So ... /plugin.py
bdormael
Post by bdormael »
The version I'm on is 6683, tried it with the file without icons, now it's working fine again :-)
I'm wondering now how I can test TTS, as I don't see any difference
tester22
Post by tester22 »
Your need the latest version of the plugin, I think it is fexed now. Was an broken zip file.
So update to latest version here: https://github.com/tester22/Domoticz-Sonos
bdormael
Post by bdormael »
Newest version installed, crashing directly:
2017-03-08 14:22:54.664 (Sonos Eetkamer) Initialized version 1.0, author 'tester22'
2017-03-08 14:22:54.719 Error: Domoticz received fatal signal 11 !...
2017-03-08 14:22:54.732 Error: /home/pi/domoticz/domoticz() [0x1be334]
2017-03-08 14:22:54.732 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1be3ec]
2017-03-08 14:22:54.732 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76add180]
2017-03-08 14:22:54.732 Error: /home/pi/domoticz/domoticz(_ZNSs6assignERKSs+0x98) [0x6a7e70]
2017-03-08 14:22:54.732 Error: /home/pi/domoticz/domoticz(_ZN7Plugins11CImage_initEPNS_6CImageEP7_objectS3_+0x21c) [0x46a5f8]
tester22
Post by tester22 »
Ok that seems clear. Have removed the custom icons and will report this.
Try the latest commit on github.
bdormael
Post by bdormael »
Thx, all working again.
Now I have the voice fields, so I have added my key and language for each of my devices, but what do I need to do now to test it ?
(how can I send a line of text to a certain device ?)
RayAmsterdam
Post by RayAmsterdam »
bdormael wrote: Now I have the voice fields, so I have added my key and language for each of my devices, but what do I need to do now to test it ?
I've got the same question. Another question: Does it restore to the same state as before playing the tts?
RayAmsterdam
RayAmsterdam wrote: Now I have the voice fields, so I have added my key and language for each of my devices, but what do I need to do now to test it ?
Already found out by experience it speaks out the notifications and keeps repeating it. No restoring of the previous setting unfortunately.
Last edited by RayAmsterdam on Friday 10 March 2017 17:48, edited 1 time in total.
tester22
Post by tester22 »
Right now it does not resume state. But I think I will reverse this since I have found an problem without any possible solution. If the players load data straight from Voicerss it interprets is as radio, hence it repeats the message indefinitely. Node-Sonos have solved that by downloading the data and expose it using an internal http server. This is not posdible ewith the current Domoticz python framework and all workaround includes adding additional components and that is something I want to avoid.
RayAmsterdam
tester22 wrote: Right now it does not resume state. But I think I will reverse this since I have found an problem without any possible solution. If the players load data straight from Voicerss it interprets is as radio, hence it repeats the message indefinitely. Node-Sonos have solved that by downloading the data and expose it using an internal http server. This is not posdible ewith the current Domoticz python framework and all workaround includes adding additional components and that is something I want to avoid.
Heursqem
Post by Heursqem »
dhanjel wrote:It would be nice to be able to set the media source (Sonos favourite for instance), if possible.
Is it (already) possible to do this with core plugin? Would be really great feauture.
Cheers
Heursqem
