Have you tried to set them in the config line for Domoticz server URL? http://<username:password@>domoticz-ip<:port>Snowtiger wrote:My Domoticz install has user/password required - Reactiz can not connect to it because of this - how do I specify this on reactiz.t0m.fr?
Reacticz dashboard: no install, no hassle
ptitneo
Re: Reacticz dashboard: no install, no hassle
Snowtiger
Answer my own question - specify local networks in Domoticz settings - no password requiredSnowtiger wrote:My Domoticz install has user/password required - Reactiz can not connect to it because of this - how do I specify this on reactiz.t0m.fr?
Snowtiger
I have a group in my Domoticz setup - include in Reacticz no problem, reaction on push of button oke but the button does not change into the opposite state - from on to off - after the push - I have to reload or press another action and then the group button gets the right colour, is this as designed?
ptitneo
This might be a bug. Do you have at least one switch that's part of this group in the Reacticz dashboard?Snowtiger wrote:I have a group in my Domoticz setup - include in Reacticz no problem, reaction on push of button oke but the button does not change into the opposite state - from on to off - after the push - I have to reload or press another action and then the group button gets the right colour, is this as designed?
Snowtiger
No, I have notptitneo wrote:This might be a bug. Do you have at least one switch that's part of this group in the Reacticz dashboard?
ptitneo
That's probably why. Try adding one if possible and see if it works as expected. I'll file an issue on github for your case.Snowtiger wrote:No, I have not
ptitneo
An update to let you know that I've added a "select by room plan" feature in the devices list section.
I seriously need to update the readme with all the new stuff that's been added recently (theming options, selector widgets, thermostat devices, energy widget, alert widget, percent widget, text widget, inverted blinds, etc.)
Snowtiger
Maybe it's a better idea to start a Wiki on Github or wherever ? Others can contribute to it if you likeptitneo wrote:An update to let you know that I've added a "select by room plan" feature in the devices list section.
Snowtiger
I added one to my Dashboard and it works as expectedptitneo wrote:That's probably why. Try adding one if possible and see if it works as expected. I'll file an issue on github for your case.Snowtiger wrote:No, I have not
ptitneo
Ah, excellent ideaSnowtiger wrote:Maybe it's a better idea to start a Wiki on Github or wherever ? Others can contribute to it if you like
https://github.com/t0mg/reacticz/wiki is now open, and completely empty. Please contribute!
Snowtiger
Nice, but i can not create pages ???ptitneo wrote:Ah, excellent idea![]()
ptitneo
You should be able to, nowSnowtiger wrote:Nice, but i can not create pages ???
blauwebuis
- Domoticz version: current
How can I best install this on the Synology version of Domoticz? Is it even possible?
ptitneo
If you don't already have a MQTT broker you can install the synology version of MQTT (tutorial link is in the readme on github). Then either use the public server of Reacticz and you're done, or build Reacticz and host it on the webserver of the synology too.blauwebuis wrote:How can I best install this on the Synology version of Domoticz? Is it even possible?
ptitneo
Hi everyone,
I've followed Snowtiger's sound advice and started a small wiki for Reacticz here: https://github.com/t0mg/reacticz/wiki
Any contribution would be highly appreciated
For example:
- fill out the device list page skeleton that I've started with more screenshots and information
- start a FAQ with tips on how to setup websockets on MQTT (common mistake), how to build for the www folder of domoticz, how to add reacticz as a dashboard shortcut on mobile, or on what type of hardware it has been tested (happy to report that it works fine on an 2011 android tablet
Snowtiger
I did a tonight and found out that some features have been implemented in Reacticz - I like the new Light Blue theme - select it on Information tab
See https://github.com/t0mg/reacticz/wiki/Supported-devices for all supported devices!
Note to @ptitneo - no minor version jump, still 0.1.3
Edit - I was to fast, git pull today shows 0.1.4
git pullSee https://github.com/t0mg/reacticz/wiki/Supported-devices for all supported devices!
ptitneo
Snowtiger wrote:Edit - I was to fast, git pull today shows 0.1.4
(FYI currently I only bump the version number when I push a new build to the public server)
blauwebuis
@ptitneo: but I can't access the folder of Domoticz on my Synology. Well, not normally anyway. I know I can get root and make it visible somehow. But I tried it before and it didn't work.
I'm just curious about all the steps on Synology, from beginning till end. Probably something like:
- Get access to Synology as root through SSH. Make the Applications directory no longer hidden.
- Install MQTT server on your Synology
- Download the files somewhere? In my understanding it's just adding/replacing some files in a folder right? Or is it more than that and do I need to compile?
- Change some settings somewhere so it uses MQTT.
- Other magic?
- Done
- Other magic?
- Done
ptitneo
@blauwebuis I have MQTT installed on my Synology, I used the article that's referenced the Reacticz readme. In my case the package refuses to start normally so I have to run it manually, I do that from the Synology task scheduler:
Other than that it's exactly like in the article. Don't forget to modify the config file to add a websockets listener because that's what Reacticz uses (while Domoticz on its side uses the regular mqtt protocol on port 1883).
Then you have to add the MQTT client gateway device in Domoticz (see here) and that's it for the mandatory steps. With that you can use Reacticz from its public server.
Now if you want to host your own build of Reacticz you need to build it with the proper homepage configured in the package.json (see here, especially the note), and then move the files on a local webserver. One common solution is the www folder of Domoticz since most people in this forum already have that
But if that's not easy to do when using the Synology package, then any other webserver in your local network would do. For example you can most likely use Synology WebStation - turn it on (enable "personal website") and then move the files to the 'www' folder it creates in the user home directory (which should also appear as a shared folder in your network). Default port is 80 so if you drop the Reacticz folder in your www folder, you should then be able to access if from http://diskstation-ip/reacticz
Hope this helps! If you get it working, it would be really cool to share the steps on the Reacticz wiki on Github
/usr/local/mosquitto/sbin/mosquitto -c
/usr/local/mosquitto/var/mosquitto.conf -dThen you have to add the MQTT client gateway device in Domoticz (see here) and that's it for the mandatory steps. With that you can use Reacticz from its public server.
- blackdog65
I have managed to get node-red and mqtt installed and running as well as a mqtt client in domoticz... so far so good.
If I clone reactictz directly into the domoticz www folder it cannot install as it is looking for package.json in the home folder. So do I install build etc in my home folder and then move the entire package to domoticz? I was going round in circles last night until very late... but still want to attack it and win today
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
