Page 5 of 9
Re: Domoticz RPC for NIBE Uplink
Posted: Saturday 23 December 2017 17:55
by BakSeeDaa
dofhus wrote: Saturday 23 December 2017 17:51
There is no problem accessing the webpage of domoticz via the ip and port so that part is correct.
python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.pyc -v
Domoticz RPC for NIBE Uplink Version 1.2.0 running on TTY console...
Unexpected status code from Domoticz: 401
output from running the script.
Have you configured Domoticz to require username and password from clients in your LAN?
HTTP Status Code 401: The request has not been applied because it lacks valid authentication credentials for the target resource.
Posted: Saturday 23 December 2017 18:15
by dofhus
BakSeeDaa wrote: Saturday 23 December 2017 17:55
I've excluded the LAN IP addresses from password. But from what i can tell after installing the following package It now works just fine.
sudo apt-get install python3-dev
Thank you for quick replay.
Posted: Saturday 23 December 2017 20:24
by devros
Thanks for plugin just instaled and works great with my new NIBE system (SMO20). But also have same problem with slave device not detected in domoticz.
Cant find power consumption parametr in my list?
Btw display on SMO20 module has no sleep function? Looks like is allways on.
another question
Script created two buttons,
Smo 20 external adjustmens
Smo 20 blocked
Any idea for what these buttons are usefull, or they are useless?
Posted: Sunday 31 December 2017 13:56
by BakSeeDaa
This software has now been released according to the
GNU General Public License.
It's free.
Source code in initial post.
Posted: Sunday 31 December 2017 14:00
by granne
Great, will try it.
Sent from my ONEPLUS A3003 using Tapatalk
Posted: Monday 01 January 2018 23:46
by devros
checked code and modifed code to get my slave ...
change line 693 to this...
r = requests.get(baseEndPointUrl + "/api/v1/systems/" + str(systemid) + "/serviceinfo/categories?systemUnitId=1¶meters=true", headers=authorization_header)
but now my master sensors are not included..., should be quite easy to add them
Posted: Tuesday 16 January 2018 11:34
by devros
hello, i use nibe uplink for about week, and i have problems with crash almost every two days. Redirected all my logs to ram drive (because i use SSD card) but i have still crashes...
Why plugin cant write NIBE logs to /dev/nul/ and store Authorization Code with config in local directory in json ? Because now when i restart domoticz computer ram is cleared and auth. code is gone.
thanks
Posted: Sunday 11 February 2018 21:53
by Wiljums
Any chance this can work with an Alpha Innotec heatpump?
Posted: Tuesday 06 March 2018 12:28
by moi427
Domoticz RPC for NIBE Uplink 2.0.0
Domoticz Version: 3.8975
Nibe F1255-6 PC
Great plugin for Domoticz. Your instructions are even for me as a beginner very clear, so my compliments!
I used the beta version since in this version also my Winddelen do work (only not yet the proper quantity). I first installed the stable version where these didn’t work at all. After a Noob-error of changing all authorizations the entire RPi installation was gone
So since I had to install the entire RPi again because of that I decided to install this beta version hereafter. And the Winddelen now also work
The only wish I’ve for this moment (just started Domoticz and RPi) is to be able to somehow see the current output of the three phases in (Kilo)Watts instead of Amps, although you can’t derive that from the output from Nibe Uplink since you need the exact Voltage to calculate that exactly (or use fixed voltage like 230V to get a not-exact value). The Amps are what Free Nibe Uplink/the current transformers provide but somehow Watts give me a better feeling of “how much” is being used.
B.t.w. the graphs show V(Volts) and in Dutch “Spanning” , that should be A (Amps) and “Stroom”, don’t know how that can be adapted (not a big issue of course).
Anyway, real great work, very usable and a nice motivating kickoff for me to collect data and start trying to build other sensors to collect more data.
Posted: Tuesday 06 March 2018 16:24
by username
Thank you for this nice plugin! Very handy indeed.
I have a Nibe F1155 X7 connector active, which is used to indicate whether it is in heating or cooling state. With your script it is now in an alarm/alert state, which actually in my situation only means it is in heating state. Just a small thing though..
Posted: Saturday 07 April 2018 8:19
by phobosman
Great script, works really well! Any progress on setting parameters? Would be great to be able to set parameters like hot_water_boost, ventilation_boost...
Posted: Monday 21 May 2018 12:01
by moi427
Yesterday I received a message that the connection with Nibe Uplink was gone. That's happened once before and then it appeared (after contacting Nibe) to be a problem with Nibe's own server/Uplink software. This time I guess it was the same, since this morning 0:08 there was another mail from Nibe Uplink telling me it works again and is monitored as before. Domoticz shows the correct values from the heatpump, so apparently the Domoticz RPC for NIBE Uplink works OK.
But... the only thing is it remains sending me a mail every 5 minutes (the crontab execution of the script I guess) that I can't sent mail.
Content of the mails
Header: Onbestelbaar: Cron <pi@raspberrypi> /usr/bin/python /home/pi/domoticz/scripts/NibeUplink/nibeuplink.py
Mail Delivery Subsystem <[email protected]>
Adres niet gevonden
Je bericht is niet bezorgd aan pi@raspberrypi omdat het domein raspberrypi niet kan worden gevonden. Controleer het op typefouten of onnodige spaties en probeer het opnieuw.
De reactie was:
DNS Error: 25586239 DNS type 'mx' lookup of raspberrypi responded with code NXDOMAIN Domain name not found: raspberrypi
I don't have any idea how to solve this: updated and rebooted the packages and the Pi, but that makes no difference.
Does anybody has an idea?
Thanks in advance!
Posted: Wednesday 23 May 2018 9:31
by moi427
Nobody got a clue/hint?
That's a pitty: I can't find it out despite searching a lot and every 5 minute a mails is a bit frustrating. Will comment out the RPC cronjob and later on try to insert it again: perhaps that will somehow change this bad behavior. Nothing changed really, that's the weird thing: this is only caused by Nibe Uplink (so on Nibe's own server) stopping and many hours laters starting again. Since these mails keep being send every 5 minutes, but the RPC script itself properly functions by putting the data in Domoticz.
Weird science....
Posted: Wednesday 23 May 2018 9:40
by devros
moi427 wrote: Wednesday 23 May 2018 9:31
Weird science....
did you tried to remove and add again script ? My script works fine so far...
Posted: Wednesday 23 May 2018 9:55
by moi427
Thanks for reaction Devros!
That's indeed the next thing on my to-do/try list. I now checked /var/spool/cron/crontabs/pi and (despite it's mentioned only to edit the main cron) deleted the same entry for NibeUplink.py. So the regular entry is still in the main cronjob and up until this moment Domoticz runs normal with the Nibe updates PLUS I haven't yet received new 5-minute mails. Very curious to me.
Will now reboot the pi and see it this now seemingly again proper behaviour remains. Latest data in Domotics of Nibe is Hotgas at 9:45:11, so will check if more actual data will be shown without the mails starting again. Otherwise I'll indeed remove the script and add it again.
Posted: Wednesday 23 May 2018 10:38
by moi427
Ok, an update since this might happen to others.
After deleting that entry for NibeUplink.py in /var/spool/cron/crontabs/pi the mails indeed stopped. After reboot of the pi thát remained ok, but the Domoticz dashboard wouldn't start anymore at my PC or mobile.
For certainty I then ran the next commands at the pi:
- sudo cp domoticz.sh /etc/init.d
- sudo chmod +x /etc/init.d/domoticz.sh
- sudo update-rc.d domoticz.sh defaults
After that I checked the Domoticz starting parameters with sudo nano /etc/init.d/domoticz.sh: they still were OK (USERNAME=pi, DAEMON=/home/$USERNAME/domoticz/$NAME and DAEMON_ARGS="-daemon -www 8080").
After stopping and starting Domoticz plus once again rebooting the pi, the Domoticz dashboard showed up normally on both PC and mobile. There were only a few RED meters from the Nibe, what should mean there wasn't actual RPC-data but after some minutes that was OK too (all by itself).
So at this moment everything still works perfect again.
What exactly was the cause I don't know, but above actions finally worked for me after having received about a thousand 5-minute error-mails.
So hopefully it remains like this
Posted: Friday 29 June 2018 12:32
by maskfaen
Just wanna say thank you!
Looks awsome! Will test it out today
Posted: Tuesday 28 August 2018 15:56
by Mirkoser
Hello I’m absolutely new on this board.
I’m running Domoticz on a synology dsm 6.2 System and have a NIBE f750 heatpump. I’ve installed the rpc 2.0 and it seems to be ok at the first view...but... after the first start the virtual sensors aren’t refreshing themselves. I guess the problem is my Domoticz version 4.97. Has anybody already tested this combination Dom 4.97 with rpc2.0. It seems that the programm doesn’t save the authentication key..
Any ideas what I can do? Thanks for your support
Posted: Friday 31 August 2018 6:11
by Mirkoser
Solved the problem, by doing a complete new installation and additional i removed the old logfiles and config files
Posted: Saturday 20 October 2018 19:29
by vwg4
devros wrote: Monday 01 January 2018 23:46
Were you able to receive all master + slave data?
I have the same problem: SMO40 controlling F2040.
SMO40 is showing mostly, but F2040 not showing at all
