HowTo: monitor Synology NAS
MAidEN
Re: HowTo: monitor Synology NAS
Post by MAidEN »
Yes we can add this tip on Wiki. How do that?
@zaadstra : I think if you monitor your synology (cpu, mem, temp, ping) from your domoticz, synology can't be sleep mode...
Anybody has a idea for my problem with HDD space monitor? :|
Luuc_a
Post by Luuc_a »
MAidEN wrote:
I have the solution for the Disk monitoring of my NAS with the screenshot above. The OID of Volume1 is 38.
The code for Free Space in GB
 # Free space volume1 (GB)
                                HDUnit=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.38`
                                HDTotal=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.38`
                                HDUsed=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.38`
                                HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
                                # Send data
                                curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=$0&svalue=$HDFree"
The code for Free Space in Percent
 # Free space volume1 (Percentage)
                                HDFreePerc=$((($HDUsed * 100) / $HDTotal))
                                # Send data
                                curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_PERC_IDX&nvalue=0&svalue=$HDFreePerc"
roblom
Post by roblom »
The above seems to work indeed.
roblom
Post by roblom »
MAidEN wrote:Yes we can add this tip on Wiki. How do that?
Just login here and you can edit the wiki page.
MAidEN
Post by MAidEN »
Luuc_a wrote: I have the solution for the Disk monitoring of my NAS with the screenshot above. The OID of Volume1 is 38.
                                # Send data
                                # Send data
Thanks is ok now, but I don't understand why I have a value "7" on title :
The good value is 5901 Go.
The percent monitor is ok.
MAidEN
Post by MAidEN »
It's good I had update the wiki page with this news :
Cpu monitor
Memory monitor
Disk usage in %
And I add a coment with new OID for disk usage to DSM 5.1 (.38)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Hello, i'm new with this, using domoticz for a few days know.
So I have questing, how do i make a virtual Switch en the virtual temperature sensors?
I have the script running on the Pi. But when I test it i get this.
roblom
Post by roblom »
SwordFish wrote:So I have questing, how do i make a virtual Switch en the virtual temperature sensors?
  • Go to "Hardware"
  • Choose for type "Dummy (does nothing, use for virtual switches only"
  • Give it a name, like "NAS"
  • Click on "add"
  • Now in the device list there is a new hardware created. In this line of "NAS" is a button with "create virtual sensors"
  • When you click on this, choose what kind of device you need. For the NAS Script you need a counter for example.
  • Click "ok"
  • Now in the devices tab there is a new device created. Click on the green arrow behind it and give it a name.
  • Now there is a device created on the tab "Several" (or other if you choose a different type of device).
Look in the device tab in the column IDX for the IDX number of the device, then change this in the NAS script. Create more devices if you need more.
sincze
Domoticz version: 2024.4
Post by sincze »
Excellent . ;-)
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
SwordFish
Post by SwordFish »
  • Go to "Hardware"
  • Click on "add"
  • Click "ok"
Thanks for the quick reply. I will give it a try
SwordFish
Post by SwordFish »
I've managed to get the virtual switches but when i test the script i'll still get this?
roblom
Post by roblom »
Did you make the script executable:
sudo chmod +x nas.sh
Is this a windows machine?
SwordFish
Post by SwordFish »
I've managed to get it work. But there are a few things that i don't get to work.
- Memory use is allways 1%?
- Its seems that the crontab is not working, because it doesn't update?
But when I run nas.sh in the terminal its working. ( I've another crontab running what is working)
- On dashboard the free HD space doesn't show the right free space.
running nas.sh
running nas.sh
running sh.PNG (24.79 KiB) Viewed 7913 times
dashboard
dashboard
crontab
crontab
#!/bin/bash
# Settings
NASIP="192.168.1.11" # NAS IP Address
PASSWORD="public" # SNMP Password
DOMO_IP="192.168.1.216" # Domoticz IP Address
DOMO_PORT="8080" # Domoticz Port
NAS_IDX="28" # NAS Switch IDX
NAS_HD1_TEMP_IDX="29" # NAS HD1 Temp IDX
NAS_HD_SPACE_IDX="30" # NAS HD Space IDX in Go
NAS_CPU_IDX="35" # NAS CPU IDX
NAS_MEM_IDX="36" # NAS MEM IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
if [ $? -eq 0 ] ; then
echo "NAS already ON"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
# Free space volume in Go
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.4.36` # Change OID to .38 on DSM 5.1
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.5.36` # Change OID to .38 on DSM 5.1
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.6.36` # Change OID to .38 on DSM 5.1
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space volume in percent
HDTotal=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.36` # Change OID to .38 on DSM 5.1
HDUsed=`snmpget -c $PASSWORD -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.36` # Change OID to .38 on DSM 5.1
# Send data
# CPU utilisation
CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
CpuUse=$(($CpuUser + $CpuSystem))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
# Free Memory Available in %
MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0`
MemAvailableinMo=$(($MemAvailable / 1024))
MemUsepercent=$((($MemAvailableinMo * 100) / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=On"
# Temperature HD1
# Send data
HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024 / 1000))
# Send data
# Send data
# CPU utilisation
# Send data
# Send data
fi
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
echo "NAS already OFF"
exit
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=Off"
fi
fi
roblom
Post by roblom »
When you paste some code here it's better to use the code tags.
I think the problem is in your cronjob, the "(= every 5 minutes)" is not allowed because it don't understands what it means so it gives an error.
SwordFish
Post by SwordFish »
Thanks, will remove that.
Sorry for not using the code tags, didn't know .
JacquesMulders
Post by JacquesMulders »
I was having the same issue as Swordfish, because is have a username and password installed.
i've edit the script (for synology) to:
 #!/bin/bash
 # Settings
 NASIP="0.0.0.0"             # NAS IP Address
 PASSWORD="password"         # SNMP Password
 DOMO_IP="0.0.0.0"           # Domoticz IP Address
 DOMO_PORT="0000"            # Domoticz Port
 DOMO_PASS="PASSWORD"        # Domoticz password
 DOMO_USER="USERNAME"           # Domoticz user
 NAS_IDX="1"                 # NAS Switch IDX
 NAS_HD1_TEMP_IDX="2"        # NAS HD1 Temp IDX
 NAS_HD2_TEMP_IDX="3"        # NAS HD2 Temp IDX
 NAS_HD_SPACE_IDX="4"        # NAS HD Space IDX in Go
 NAS_HD_SPACE_PERC_IDX="5"   # NAS HD Space IDX in %
 NAS_CPU_IDX="6"             # NAS CPU IDX
 NAS_MEM_IDX="7"             # NAS MEM IDX
 echo $PINGTIME
 then
   curl -s "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
        # Temperature HD1
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
        # Temperature HD2
        HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.1`
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=0&svalue=$HDFree"
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_PERC_IDX&nvalue=0&svalue=$HDFreePerc"
	# CPU utilisation
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
        # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
        echo "NAS ON"
        # Send data
        curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=On"
        # Temperature HD1
        # Send data
        # Temperature HD2
        # Send data
        # Send data
        # Send data
	# CPU utilisation
        # Send data
        # Send data
      fi
        curl -s "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
                exit
                echo "NAS OFF"
                # Send data
                curl -s -i -H "Accept: application/json" "http://$DOMO_USER:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=Off"
        fi
 fi
Jan
Post by Jan »
In the script something is wrong. To calculate the free memory percent, the MemAvailable will be divided by 1024. For a synology with 1024MB RAM, this is right. But not for a synology with 512MB RAM. Maybe the script can be updated!
The old script contains:
   # Send data
Maybe this can be the solution:
	MemTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.5.0`
	MemUsepercent=$((($MemAvailable * 100) / MemTotal))
	# Send data
When I look in my DSM of my Synology the percent will be 48%. The script shows 3%. I don't know why both values are different. Hopefully somebody can explain this?
My hardware:
- Raspberry Pi
- Rfxtrx433 transceiver
- RaZberry
- Nuon Smart Plug 6 (2x)
- Nuon Smart Plug (5x)
- Fibaro Universal Sensor
- Fibaro Smoke Sensor
- Aeon Door Sensor
- Bluetooth dongle
MAidEN
Post by MAidEN »
i Jan,
Is right, we have a problem with this formul.
On my Synology i have that :
On Domoticz :
I don't understand how synology obtain 33% memory use...is egal to 337,92 Mo. :roll:
On my screen memory free (libre) = 106 Mb (10,5%) !
You have a same problem ?
globalassist
Post by globalassist »
Is there a way to monitor this in a windows-installation of Domoticz?
MAidEN
Post by MAidEN »
The script is for linux installation of domoticz only : http://www.domoticz.com/wiki/NAS_Monitoring
