dzVents 1.0 released
dhanjel
Domoticz version: 3.5146
Re: dzVents 1.0 released
Post by dhanjel »
ah yes, must be this one, right?
2016-06-16 13:45:09.426 LUA: =====================================================
2016-06-16 13:45:09.426 LUA: >>> Handler: virtualdevice_wiiu
2016-06-16 13:45:09.426 LUA: .....................................................
2016-06-16 13:45:10.374 Error: EventSystem: Warning!, lua script /home/daniel/domoticz/scripts/lua/script_time_main.lua has been running for more than 10 seconds
2016-06-16 13:45:12.434 LUA: .....................................................
2016-06-16 13:45:12.434 LUA: <<< Done
2016-06-16 13:45:12.434 LUA: -----------------------------------------------------
dannybloe
Post by dannybloe »
Well, that script takes 3 seconds. So there must be more. Btw, 3 seconds is enormous, time-wise. What are you doing in that script?
dhanjel
Post by dhanjel »
did a ping to check if a device was online, but did not have a timeout. added a 1s timeout and it seems to work.
is the 10 s limit for all scripts in total, or one separate script?
dannybloe
Post by dannybloe »
Well, there is a hardware plugin for this. Use that to set the state of a switch and link a script to that switch.
dhanjel
Post by dhanjel »
Really, which one? You learn something new every day :)
dannybloe
Post by dannybloe »
System Alive Checker. It creates switches for devices that you want to ping. What I would do is create a dzVents script using a persistent variable that counts consecutive ping timeouts and only when there have been a couple in a row perform some action.
System Alive Checker > $hiddenMyDevice > dzVents script > counter > myDevice.switchOn/Off
Something like that. Thing is that sometimes you get an occasional time-out while the device is still online. By counting consecutive timeouts you can prevent false negatives.
dhanjel
Post by dhanjel »
dannybloe wrote:System Alive Checker. It creates switches for devices that you want to ping. What I would do is create a dzVents script using a persistent variable that counts consecutive ping timeouts and only when there have been a couple in a row perform some action.
the ping device does not seem to end up in devices.lua (I deleted the file and checked in the recreated file, and it is not there)
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 6,
         "HardwareName" : "System Alive Checker",
         "HardwareType" : "System Alive Checker (Ping)",
         "HardwareTypeVal" : 51,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0000003",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2016-06-16 15:21:37",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Vardagsrum, Sony TV Ping",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 0,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "214"
dannybloe
Post by dannybloe »
Are you sure? That file is the direct result of getting the device information from Domoticz. If you do a manual fetch you see the same data.
What do you see when you do: http://..../json.htm?type=devices&displayhidden=1&filter=all&used=true
But, what do you get when you do domoticz.devices['Vardagsrum, Sony TV Ping'] or [214]. Isn't that enough to be useful?
blackdog65
Post by blackdog65 »
Hi guys,
I'm new to dzVents and finding it easier than trying to learn "lua full fat" :D
I have a question Ref. sounds for example domoticz.SOUND_SIREN seems like a simple enough request/command but what siren? Where is it? :?
I have 4 Siemens mp3 doorbells in my house each with 10 sounds that can be triggered by Domoticz (including siren) these chimes work as a switch... pretty straight forward, but what are the dzVents sounds all about?
Many thanks
Sean
PS calling all 4 of my sirens with "Siren*" is so much easier than calling all 4 separately :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
dannybloe
Post by dannybloe »
Good question, I really have no idea ;-)
These are notify() options. Someone added them.
blackdog65
:lol: I like your honesty :lol:
I'll dig a little deeper into the code as it may be possible to modify either the code or my sounders to meet in the middle :D
Thanks for the quick reply Danny
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
I wonder if Dzvents can manage the execution of a lua script 30 seconds after an execution of a first script ? Here is my need :
First script triggered by a PIR
- check some uservariables and conditions
- VocalSynthesis "Domoticz will sound the Alarm in 30 seconds. You have 30 seconds to disarm it."
2nd script: 30 seconds after
- trigger some switchs
Regards ,
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
NetEye
Post by NetEye »
Dear Danny,
I' am impressed, maybe you can help cq coache me with my topic? ( 8e onder die van jou: Lua script for pressure sensor).
Groet
dannybloe
Post by dannybloe »
jmleglise wrote:Hi,
Regards ,
Maybe something like this:
	active = true, -- set to true to activate this script
		'pir',
		'disarmer', -- some switch that indicates the alarm is disarmed
		'alarmActivator' -- dummy switch
	data = {
		triggerAlarm = { initial = false }
		if (device.name == 'pir' and device.state == 'Motion') then
			domoticz.data.triggerAlarm = true
			domoticz.devices['alarmActivator'].switchOn().after_sec(30) -- will trigger this script after 30 seconds (hopefully)
			domoticz.sendCommand('') -- command for the vocal stuff
		elseif (device.name == 'disarmer') then
			domoticz.data.triggerAlarm = false
			domoticz.devices['alarmActivator'].switchOff()
			domoticz.devices['alarm'].switchOff()
		elseif (device.name == 'alarmActivor' and device.state == 'On' and domoticz.data.triggerAlarm) then
			domoticz.devices['alarm'].switchOn()
			-- do whatever
I use the persistent variable triggerAlarm just to make sure that the after_sec() command isn't executed after all even if do you switchOff(). Maybe you don't need this extra check. I'm not sure. Of course the 'disarmer' switch represents whatever device reports that the alarm is turned off.
Update: fixed a typo in the script
jmleglise
Post by jmleglise »
But of course !!! The script activates a switch 30 sec After, and detects the change of it , all this in the same script !
It's brilliant !
Thank you danny,
KMTronic USB relay
Eduard
Post by Eduard »
Atmosphere wrote:
dannybloe wrote:
Did you find anything yet?
Hi Danny, It's still happening...
 2016-06-06 03:40:03.465 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 05:25:02.595 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 10:55:03.267 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 14:35:03.204 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
2016-06-06 17:25:03.270 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:445: attempt to index local 'device' (a nil value)
I have the same issues:
2016-06-12 08:30:01.682  LUA: devices.lua cannot be loaded
2016-06-12 08:30:01.682  LUA: error loading module 'devices' from file '/home/pi/domoticz/scripts/lua/devices.lua':
	/home/pi/domoticz/scripts/lua/devices.lua:5604: unfinished string near <eof>
2016-06-12 08:30:01.732  Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_main.lua: /home/pi/domoticz/scripts/lua/dzVents/Domoticz.lua:446: attempt to index local 'device' (a nil value)
Looks like at some point that the http-fetch was not successful and created an empty devices.lua. Parsing the devices into the array will give an error then.
Maybe add a check to see if the devices.lua is empty before trying to parse the data...
elmortero
Domoticz version: 3.9639
Post by elmortero »
Hi Danny,
I am loving dzvents, all my switches have already been migrated to it.
Now I started to try and migrate some other scripts but I am a bit lost.
In this one case I want to get the humidity value from a (physical) sensor named soil1 and write it to a virtual sensor, called humsoil 1 with id 340.
Until now I read it from the sensor and wrote it to the virtual sensor by updating it using json.
Have been trying for some hours to try to get it in dzvents but without luck.
This is the original (in non-magical LUA):
	bodem = 'soil1'
	domoticzserver = 'http://192.168.1.6:8080'
	smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues[bodem]:match("([^;]+);([^;]+);([^;]+)")
	smoistsensorHumidity = tonumber(smoistsensorHumidity);
	print("xt300: Humidity soil1  is " .. smoistsensorHumidity .. " ");
    commandArray['OpenURL'] = domoticzserver .. '/json.htm?type=command&param=udevice&idx=340&nvalue=' .. smoistsensorHumidity
Can you help me get started please?
dannybloe
Post by dannybloe »
elmortero wrote:Hi Danny,
	bodem = 'soil1'
Have you tried this:
	domoticz.devices[340].updateHumidity(smoistsensorHumidity, domoticz.HUM_NORMAL)
It should work.
elmortero
Post by elmortero »
It should work.
It did! Works like a charm.
Thanks a lot.
dannybloe
Post by dannybloe »
Nice.
Read the docs ;)
