Page 5 of 7
Re: Traffic with Google Maps in Domoticz
Posted: Monday 18 April 2016 11:05
by Westcott
Use the "value" which is in seconds and divide by 60?
Your route won't work here in the UK, the A4 and A7 are 450km apart...
Posted: Monday 18 April 2016 11:22
by woody4165
bran2000 wrote:Hi, i tried your new script !
it's working but the instructions about the traffic is in italian ?
anyway it can be in French for example ?
You mean the Message in Text box or in Telegram?
You can change as you want, just translate text in the script...
Posted: Monday 18 April 2016 11:42
by woody4165
EBOOZ wrote:There's a bug when the time exceeds one hour.
Google API output:
Sensors in Domoticz:
Log in Domoticz:
I couldn't find a solution yet. If anyone else has an idea? Much appreciated!
Correct and thanks.
I was grabbing the text thinking only on traffic minutes, not hours!
I've changed the code like this, taking the value instead of text and rounding the duration
-- Read from the data table, and extract duration and distance in value. Divide distance by 1000 and duration_in_traffic by 60
distance = gmaps.routes[1].legs[1].distance.value/1000
duration = gmaps.routes[1].legs[1].duration_in_traffic.value/60
summary = gmaps.routes[1].summary
mins=math.ceil(duration)
-- mins round the duration
Here is the complete script modified.
--Script to calculate duration and distance between two points using Google Maps
--Author : woody4165 based on Neutrino Traffic with Waze, updated by G3rard
--Date : 9 April 2016
commandArray={}
time = os.date("*t")
day = tonumber(os.date("%w"))
--idx of devices for capturing the travel minutes in both direction
idxtraffic='xx'
idxroute='xx'
--usual traveltime (mins)
usualtimehomework = 25
usualtimeworkhome = 25
-- Coordinates starting point
fromx="xx.xxxxx"
fromy="xx.xxxx"
-- Coordinates destination point
tox="xx.xxxx"
toy="xx.xxxx"
--Google Api Key
key='xxxxxxxxxxx'
--determine workday (Mo-Fri)
if (day > 0 and day < 6) then
week=true; weekend=false
week=false; weekend=true
--determine time (7:00-9:00, 16:00-19:00)
if ((time.hour > 6 and time.hour < 9) or (time.hour == 9 and time.min < 1)) then
mattina=true; sera=false
elseif ((time.hour > 15 and time.hour < 19) or (time.hour == 19 and time.min < 1)) then
mattina=false; sera=true
mattina=false; sera=false
--calculate traveltime
function traveltime(fromx,fromy,tox,toy)
--import JSON.lua library
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
-- get data from Google Maps and decode it in gmaps
local jsondata = assert(io.popen('curl "https://maps.googleapis.com/maps/api/directions/json?origin='..fromx..','..fromy..'&destination='..tox..','..toy..'&departure_time=now&key='..key..'"'))
local jsondevices = jsondata:read('*all')
jsondata:close()
local gmaps = json:decode(jsondevices)
return mins
--weekday (Mo-Fri) and time between 7:00-9:00
if (week and mattina) then
--every 15 minutes
if((time.min % 15)==0) then
traffic=traveltime(fromx,fromy,tox,toy)
message=tostring(traffic)..'min per andare in ufficio alle '..("%02d:%02d"):format(time.hour, time.min)..' percorso '..tostring(summary)
print(message)
--send message if traveltime is longer than usual
if(traffic > usualtimehomework) then
os.execute('curl --data chat_id=xxxxxxxx --data-urlencode "text='..message..'" "https://api.telegram.org/botxxxxxxxxxxxxx/sendMessage" ')
-- commandArray['SendNotification']=message
--return a text to the device (eg. 12 mins)
commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(traffic)}
commandArray[2]={['UpdateDevice'] =idxroute..'|0|' .. tostring(message)}
--weekday (Mo-Thu) and time between 16:00-19:00
elseif (week and sera) then
--every 15 minutes
traffic=traveltime(tox,toy,fromx,fromy)
message=tostring(traffic)..'min per andare a casa alle '..("%02d:%02d"):format(time.hour, time.min)..' percorso '..tostring(summary)
print(message)
-- if(traffic > usualtimeworkhome) then
-- os.execute('curl --data chat_id=xxxxxx --data-urlencode "text='..message..'" "https://api.telegram.org/botxxxxxxxxx/sendMessage" ')
-- end
-- set device to 0 to prevent device get the last value after working hour
zero=0
commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(zero)}
commandArray[2]={['UpdateDevice'] =idxroute..'|0|' .. tostring(zero)}
Posted: Monday 18 April 2016 12:35
by blackdog65
I've been trying this handy script... well done and thanks!
When I updated to the latest script my original dummy/custom sensors where "time to work" and "time to home" both with axis label minutes. With the new script, I set the 1st as idxtraffic and 2nd idxroute but both just show "18 mins" but I get
2016-04-18 11:15:00.878 LUA: 18min to go to the office at 11:15 route Lynn Rd
in the log.
Any ideas?
Posted: Monday 18 April 2016 12:46
by woody4165
Are you getting traffic data from and to work at the same time? Meaning that you changed some working hours in the script?
The script was intended to get data from home to work at a certain hours and from work to home at other ones.
Don't know if this is the case.
Posted: Monday 18 April 2016 13:09
by blackdog65
Hi Woody,
Thanks for the quick reply.
Yeah I did alter the times as my travel times are different, but also I'd like to temporarily extend the hours for testing.
How should I set the
So that I could run it (for testing) 07:00-12:00, 13:00-19:00 without breaking it?
I currently have
--determine time (7:00-12:00, 13:00-16:00)
if ((time.hour > 6 and time.hour < 12) or (time.hour == 12 and time.min < 1)) then
morning=true; will_be=false
elseif ((time.hour > 12 and time.hour < 16) or (time.hour == 16 and time.min < 1)) then
morning=false; will_be=true
morning=false; will_be=false
Thanks,
Sean
Posted: Monday 18 April 2016 13:36
by woody4165
The Google API call is made within a function that is called in both case, home->work and work->home, and in both cases it return to the same variable.
Try to change this
--every 5 minutes
if((time.min % 5)==0) then
os.execute('curl --data chat_id=2285843 --data-urlencode "text='..message..'" "https://api.telegram.org/bot196378808:AAFq49rg69CYODb2CBMBfLmKskseZCAvemA/sendMessage" ')
-- commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(traffic) .. '-->'}
--every 5 minutes
-- os.execute('curl --data chat_id=2285843 --data-urlencode "text='..message..'" "https://api.telegram.org/bot196378808:AAFq49rg69CYODb2CBMBfLmKskseZCAvemA/sendMessage" ')
-- end
-- commandArray[2]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(traffic) .. '<--'}
into this
--every 5 minutes
traffic_Home2Work=traveltime(fromx,fromy,tox,toy)
message=tostring(traffic_Home2Work)..'min per andare in ufficio alle '..("%02d:%02d"):format(time.hour, time.min)..' percorso '..tostring(summary)
if(traffic_Home2Work > usualtimehomework) then
commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(traffic_Home2Work)}
--every 5 minutes
traffic_Work2Home=traveltime(tox,toy,fromx,fromy)
message=tostring(traffic_Work2Home)..'min per andare a casa alle '..("%02d:%02d"):format(time.hour, time.min)..' percorso '..tostring(summary)
-- if(traffic_Work2Home > usualtimeworkhome) then
-- end
commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(traffic_Work2Home)}
In changed the variable "traffic" into "traffic_Home2Work" in the morning part, and "traffic" into "traffic_Work2Home" in the afternoon part.
Try this. If it's ok, I will made this change in the script and post it fully.
Posted: Monday 18 April 2016 15:39
by bran2000
woody4165 wrote:bran2000 wrote:Hi, i tried your new script !
thanks i just did
Posted: Monday 18 April 2016 16:57
by blackdog65
Hi Woody,
The script runs, noted in log, but seems to be frozen at "18Mins" with no further route info.
Posted: Monday 18 April 2016 18:05
by woody4165
blackdog65 wrote:Hi Woody,
Where is freezing, can you show the log and the part of the script you think is causing this?
Posted: Tuesday 19 April 2016 9:02
by EBOOZ
woody4165 wrote:EBOOZ wrote:There's a bug when the time exceeds one hour.
Thanks, woody! Works like a charm
Posted: Tuesday 19 April 2016 18:03
by blackdog65
Hi again Woody,
Sorry for the delay, I had an emergency trip to London
hate the place
So, here's my log output, note there is now no route info as before.
2016-04-19 15:20:01.956 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:25:01.396 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:30:01.323 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:35:02.251 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:40:01.664 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:45:01.816 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:50:01.206 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 15:55:03.046 EventSystem: Script event triggered: script_time_traffic.lua
2016-04-19 16:00:01.445 EventSystem: Script event triggered: script_time_traffic.lua
But I have found that my sensors were not frozen but since the code change at 1300 yesterday there has been minimal movement.
- graph.png (26.3 KiB) Viewed 4578 times
My big worry is that my sensors look like this,
- sensors.png (17.02 KiB) Viewed 4578 times
with no reference to "route"
Am I doing something wrong?
Sean
Posted: Tuesday 19 April 2016 18:28
by woody4165
Hi Sean
I think we have to distinguish two things.
Are these sensors text or what?
I'm using beta Domoticz and using a Custom sensor to get minutes number (and get graph) and a Text sensor to have the same text I'm going to send via Telegram, with the route.
So, if you want to get both information you get two choices:
you are on stable version (and you don't have Custom Sensor) or you don't need/want graph, you need to create two text Sensor and put there the complete text using something like these that you can find in my script published before:
message=tostring(traffic_Home2Work)..'min to go to office at '..("%02d:%02d"):format(time.hour, time.min)..' route '..tostring(summary)
if you want Custom Sensors to have also graph you can create either only two sensors, one Custom and one Text and use it for Home2Work and Work2Home, since they are in different hours, or either create two couple of sensor like before and get information separated.
Hope I haven't confused you more...
In any case, if you post your script I can take a look into it...
Posted: Wednesday 20 April 2016 12:17
by blackdog65
Yay! I have it! I had 2 custom sensor. I changed it to one custom and one txt and it works perfectly.
Many thanks Woody, I hope I can help you one day
Posted: Saturday 23 April 2016 17:33
by woody4165
No, problem. We are here to help each other!
Posted: Saturday 23 April 2016 18:43
by sj3fk3
Google API output:
Yes, don't use the text but use the value and just divide by 60 to get minutes..
Posted: Wednesday 04 May 2016 11:48
by sjefk
I am struggling a bit with this script..
Getting the following error:
2016-05-04 11:40:00.552 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_google.lua: /home/pi/domoticz/scripts/lua/script_time_google.lua:55: attempt to index field '?' (a nil value)
Problem seems to be line 55 .. which is..
So i suspected something is wrong with the url on line 49.. so i executed this in the browser and without any error..
https://maps.googleapis.com/maps/api/di ... le-api-key
The output of the url seems also ok..
"copyrights" : "Kaartgegevens ©2016 Google",
"legs" : [
"distance" : {
"text" : "65,0 km",
"value" : 65016
"duration" : {
"text" : "43 min.",
"value" : 2579
"end_address" : "Atoomweg 60, 3542 AB Utrecht, Nederland",
"end_location" : {
"lat" : 52.1106402,
"lng" : 5.062270199999999
"start_address" : "Van Leeuwenhoeklaan 53-55, 4904 KP Oosterhout, Nederland",
"start_location" : {
"lat" : 51.6200264,
"lng" : 4.8544003
Can somebody point me in the right direction ?
Best regards,
Sjef
Posted: Wednesday 04 May 2016 12:00
by Westcott
Is that the complete output?
The outer 'routes' section seems to be missing.
If I try it with my key I get (with 'routes') -
geocoded_waypoints: [
geocoder_status: "OK",
place_id: "EjhWYW4gTGVldXdlbmhvZWtsYWFuIDUzLTU1LCA0OTA0IEtQIE9vc3RlcmhvdXQsIE5lZGVybGFuZA",
types: [
"street_address"
place_id: "ChIJ-zDCwLhvxkcREbu0NLbbhRI",
types: [
"street_address"
routes: [
bounds: {
northeast: {
lat: 52.1154437,
lng: 5.1058217
southwest: {
lat: 51.6188531,
lng: 4.8544003
copyrights: "Map data ©2016 Google",
legs: [
distance: {
text: "65.0 km",
value: 65016
Posted: Wednesday 04 May 2016 12:10
by sjefk
No, this is not the complete output..
The complete output is a lot.. also with directions but let's check if i can find the 'outer' section of the route.
I removed the steps from the output below.
"geocoded_waypoints" : [
"geocoder_status" : "OK",
"place_id" : "EjhWYW4gTGVldXdlbmhvZWtsYWFuIDUzLTU1LCA0OTA0IEtQIE9vc3RlcmhvdXQsIE5lZGVybGFuZA",
"types" : [ "street_address" ]
"place_id" : "ChIJ-zDCwLhvxkcREbu0NLbbhRI",
"routes" : [
"bounds" : {
"northeast" : {
"lat" : 52.1154437,
"lng" : 5.1058217
"southwest" : {
"lat" : 51.6188531,
"lng" : 4.8544003
"legs" : [
"distance" : {
"text" : "65,0 km",
"value" : 65016
"duration" : {
"text" : "43 min.",
"value" : 2579
"end_location" : {
"lat" : 52.1106402,
"lat" : 51.6200264,
"lng" : 4.8544003
"via_waypoint" : []
"overview_polyline" : {
"points" : "e`azH_cs\\xBuGhByEFQWGcAoAoDgEmCaD_CqCW]J[Zq@r@mBTm@MMiBqBaEqEsFyGoAgAsE_FYYaEsESa@gCgCyAaAl@_FhAsEbBgFy@q@mB}@gA}@kEgE_@KwAcBcBqBaPqRgPmRqDcD{FgDkDkAcDi@{DUsIPkWv@gXx@eWdA}d@lDa{@vGkFPmH?yI_@oIcAgJgB{^}HsYgG_GoAoj@mLka@qIaEk@{Ee@mDQw_@eAu`@cAmGi@mG}@oH_BmOoEkF{AuBw@eBs@{HwDaG{DmDsCsCoCqDaEeDkE}FmJaRq`@iKcUuDoHoG_KsGiIaJ{JgGoGyHuHaIgHiEaDoF}C{FgCqHuCcNgFmZgLiGmBqFiAeEi@e`@uDeEU}CEgLTeKXgYv@eLZwC?oG[cMsAm^cEkiAiMwFs@eIgBkiAca@eQcG}PaFsO{Dur@qQsEoAeMcEoLgEi}@y[u}@_\\wFsB_JyDsL_Gsj@oXcP_IkRuJuLsGsDmB_x@mb@qNuHqFkC{IcDyEuAgWsHo\\sJki@{O_OqEoHcDsUkLcy@oa@uUoLkH_EmAw@oEaDqE}Dos@ws@ei@ki@{FsGcDyEmBgDcCaF_B}DkAaDsB_HaBsHoAgHcAgHsAmMoAeTk@mUOqMAcHCeK@oUFgcA@_E?km@M}J]qKe@{HmAgN{AgLuAcIwDiPaByF_BaF_DoIoF}LmIaPwL}R{MsR}JwMkA{AOe@oFkIuAgCo@}AqA}E[iBw@_FWkEu@sG{@}CaAcBy@{@iAo@oA_@eAGeCf@}BzB}@xA_BfEeBpGwAjEiAbC{DjGoC|D{@bBMt@aDxFeBtDcCtF_JxSaLlWsBdEoAnBsBpCeBhBaFtD{PbKuKvF{PhIkUfKkE|AaI~BkLbDmJnDcJ`EiOhHcRlJqNzHuHfDsS~HsE|AuEjAoFz@sBPgHViIE{\\a@}z@wAcm@s@aDO{C[sEq@kDu@{H{ByMiEcCu@c@a@aDoA{JkDiNeEyNsEaBs@sAeAeDgDuBmAsA]uAOgFAiB[cDa@iGoB{MsDkE_A_IcCaCk@aGaAiDOkFGkGP}FPgMtByGvB{GxCoEdCaTlOiK|HcMnI{K`KwH|HaDrD{CvDmH`LoC~D}EvIQJeDhFiDdEsC`G[h@c@x@OAc@a@{H{IuCqBwA{@YIiBWmBMwBg@SIX{@lAgBpGaHrAgBxEsFvGeH"
"summary" : "A27",
"warnings" : [],
"waypoint_order" : []
"status" : "OK"
Posted: Wednesday 04 May 2016 13:06
by woody4165
It's really strange...
I just test it moving just the json part to another script and I have like this:
jsondata:close()
-- Read from the data table, and extract duration and distance in text
distancet = gmaps.routes[1].legs[1].distance.text
duration = gmaps.routes[1].legs[1].duration_in_traffic.text
print("distance "..distance.." distancet "..distancet.." duration "..duration)
And all is working fine...
what if you print just jsondevices to see if there is something before decoding, just like this
