Page 40 of 120
Re: Domoticz app 2.0
Posted: Monday 29 February 2016 14:25
by RoadXY
Jango wrote:Yeah same switch order as on server! [GRINNING FACE WITH SMILING EYES]
There is one problem, the client crashes when I want to see graphs.
Beta version
0.1.239
Noted, thank you for your report
by RoadXY
ceedebee wrote:How does the notification function work? I'm running the stable version of Domoticz, there isn't an option to push notifications to the app in the settings.
No, there are no settings in the Domoticz server.
The settings in Domoticz server needs to be implemented by the server developers.
Posted: Monday 29 February 2016 14:41
by Scoobydoo
Latest update 29/2 displays a sort of graph on my temperature but then app still crashes
Posted: Monday 29 February 2016 15:04
by jannl
Same here
Posted: Monday 29 February 2016 17:01
by four2six
four2six wrote:
well, it did work with connecting a nfc tag to a switch, but i can't use it in the app. Whenever i use the tag while the dashboard of the app shows, it just offers me to open other apps to read the tag. Domoticz is not among them.
obviously i'm going to sound impatient, but: has anyone actually successfully used an rfid tag in the app with android 6.0.1?
Posted: Monday 29 February 2016 19:50
by ceedebee
RoadXY wrote:ceedebee wrote:How does the notification function work? I'm running the stable version of Domoticz, there isn't an option to push notifications to the app in the settings.
So, it doesn't function at this moment because it isn't implemented yet? Or is there an other way?
Posted: Monday 29 February 2016 20:17
by bash
Hi four2six,
I have it working on android 5.0.1 but only with a NFC of a type that my phone doesn't support. (MIFARE)
I bought some tags on the Internet, but same result as you. It turns up in Domoticz app, can connect it to a switch, but it doesn't work.
And my phone registers it as a new empty tag.
Maybe someone knows what to write to the formatted tag with a NFC tool?
It looks like Domoticz is only using the tag ID?
For the developers of the app, keep up the good work!
Posted: Monday 29 February 2016 22:26
by four2six
thanks, good to know i'm not the only one.
does it do anything when you leave the settings and just have the app running? i have another app installed that does read nfc chips. android offers to open that app with me. but not domoticz.
yes! didn't i say so?
Posted: Monday 29 February 2016 23:27
by Richard
I would like to use the app, but i get an error: Time-out unexpected status line ssh-2-0- OpenSSH_6 Op 1 Debian-4+ deb7u2. I use a raspberry with Rasberian & domoticZ and the server address i use is my ip adres. Domotisz works well on the web. What do i wrong|?
Posted: Tuesday 01 March 2016 9:33
by galadril
I've ordered some new NFC tags to continue testing this issue..!
Posted: Tuesday 01 March 2016 9:35
by galadril
ceedebee wrote:So, it doesn't function at this moment because it isn't implemented yet? Or is there an other way?
At this moment, if you enable notifications in the app, you get all the notifications from the Domoticz server.
You can then specify in the settings which notification you like to suppress or to receive.
They are going to create a device screen in Domoticz, but it's not done yet..
But notifications works!
by galadril
Richard wrote:I would like to use the app, but i get an error: Time-out unexpected status line ssh-2-0- OpenSSH_6 Op 1 Debian-4+ deb7u2. I use a raspberry with Rasberian & domoticZ and the server address i use is my ip adres. Domotisz works well on the web. What do i wrong|?
Can you PM me the details, so I can check if I can connect to your server?
Posted: Tuesday 01 March 2016 10:15
by sweup
Im trying to switch my Aeon labs led lamp but got "Failed: error sending switch command, check device hardware". This happend after the NFC update-version.
Posted: Tuesday 01 March 2016 15:43
by galadril
I've found the issues with the graph screen and uploaded a new version to the play store.
Thanks for the bug reports, it was related to Android devices with version (Pre) >6.0
Changelog:
- Fixes voor older Android versions (on Graph, etc)
- Added Dark Theme in Settings
- Updated translations
- Various fixes
(_ still need to look into the NFC tag issue!! _)
Posted: Tuesday 01 March 2016 16:52
by mickmack
Thx! Graphs now working fine.
Is it intended that you dont see any menu pictures anymore if you switch to the dark theme? For example: in the white theme you see a camera icon in the menu followed by the text. In the dark theme i cant see any icons.
Posted: Tuesday 01 March 2016 17:00
by galadril
mickmack wrote:Thx! Graphs now working fine.
Thats not the case in Android 6.0.
We use a color filter to set the color on the icons. but that method is not available in older Android versions
Posted: Tuesday 01 March 2016 19:07
by MarcelMAH
Today my cable connection got upgraded again, which broke my connection until I rebooted my router.
I connect using Domoticz app on me and my wife's phone using NAT loopback (so I use my external URL also when I'm on my internal WiFi).
Me and my wifi both use geofencing to control is someone is home / nearby which controls my central heating.
She left before I did when the local Internet was still down. She did not trigger the virtual switch that she left home.
When I woke up I first rebooted my router so when I left my virtual switch did switch but I noticed the heating not turning off.
I would expect Domoticz app to keer retrying to switch (with increased interval, to maximum of every hour?) so when this happens it would rectify itself when both are online again (and the interval timer triggers a resend).
Posted: Tuesday 01 March 2016 19:39
by jannl
The app does not crash on the graphs anymore, but I still can not see the complete (daily) graph (I think). Not sure about the week graph. Domoticz shows a 7 day graph, but the app does not.
It looks like the line runs out of the screen, without the x-ax being at the end. Scrolling does not work/help.
Posted: Wednesday 02 March 2016 11:13
by piokuc
galadril wrote:I've found the issues with the graph screen and uploaded a new version to the play store.
Changelog:
- Various fixes
For set temp should be from 4*C to 28*C. This is example for Danfoss thermostat. Now is from 10 to 30*C.
One of bug is that for Switch Conntact show status ON/OFF but should show OPEN/CLOSED.
Second bug is that graph for temp for week is not show. Click on week do nothing.
Good option will be add LAST SEEN also for TEMPERATURE.
App is very good thanks.
Posted: Friday 04 March 2016 23:17
by Skippiemanz
Chucky69 wrote:When I click on up/down I always get stopped
I can confirm this. Last weekend I connected my Brel blinds motor to Domoticz which works fine from the Domoticz webpage.
In the android app I get on all 3 buttons "Stop", just like jannl mentioned.
Guys, Any progress on this?
I could give remote acces if wanted. Please let me know.
Keep up the good work!
