Page 40 of 184
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Thursday 13 April 2017 20:06
by robgeerts
formadvi wrote:robgeerts wrote:
Try chaning the name from 'Regen Verwacht' to 'Regen verwacht'
(Yes, not very handy this way but will do this different soon!)
I have the same issue. Changed to Regen verwacht but still only Regen Aan
Do you have the latest version of the dashboard?
What is de output of your device?
Posted: Thursday 13 April 2017 20:12
by robgeerts
CUSTOM ICONS
You can now define other icons, in config.js:
blocks[1] = {}
blocks[1]['icon'] = 'fa-eye';
Find an icon at
http://fontawesome.io/cheatsheet/
OR, if you want to use an image, place it in img/ folder and specify as:
blocks[1] = {}
blocks[1]['image'] = 'bulb_off.png';
Posted: Thursday 13 April 2017 20:36
by SwordFish
Great job with the custum icons.
I just downloaded the latest version and its seems that the train info is gone, i only have traffic?
In the previous version it is still working.
Posted: Thursday 13 April 2017 20:39
by formadvi
Ik heb eind van de middag de laatste versie geinstalleerd. Net laatste versie gepakt van 30 min geleden. Deze werkt correct.
Thanks.
Posted: Thursday 13 April 2017 20:51
by EdwinK
robgeerts wrote:CUSTOM ICONS
For statusblocks (like rain expected, other text-types,lux, sound level, rain, wind, motherboard sensors, air quality) you can now define other icons, in config.js:
Awesome.
Still trying to get this looking better
Posted: Thursday 13 April 2017 20:58
by robgeerts
SwordFish wrote:Great job with the custum icons.
Kun je de laatste versie eens proberen?
Posted: Thursday 13 April 2017 21:00
by robgeerts
EdKo66 wrote:robgeerts wrote:CUSTOM ICONS
Awesome.
What was the output of your rain evice? (Or did I ask that already earlier?
En your screen width, so I can test it..
Posted: Thursday 13 April 2017 21:02
by SwordFish
robgeerts wrote:SwordFish wrote:Great job with the custum icons.
Will try it tomorrow, not at home.
Posted: Thursday 13 April 2017 21:04
by EdwinK
Device output:
"ActTime" : 1492110156,
"ServerTime" : "2017-04-13 21:02:36",
"Sunrise" : "06:50",
"Sunset" : "20:35",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Geen regen verwacht binnen komende 30 minuten",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 24,
"HardwareName" : "Weer",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveTimeout" : false,
"ID" : "00082113",
"LastUpdate" : "2017-04-13 21:02:00",
"Name" : "Regen verwacht",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : false,
"SignalLevel" : "-",
"SubType" : "Text",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "text",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "113"
"status" : "OK",
"title" : "Devices"
Not sure about screen width. Now on my MacBook. I believe it's a 13" inch version.
ould be nice if the tile could be a bit bigger, like the train-info.
Posted: Thursday 13 April 2017 21:05
by robgeerts
Device output:
"Sunset" : "20:35",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Description" : "",
"Favorite" : 0,
"HardwareID" : 24,
"ID" : "00082113",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Text",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "text",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "113"
"status" : "OK",
"title" : "Devices"
in that case, add to your config.js, just below blocks = {}
Posted: Thursday 13 April 2017 21:19
by Blueone
I'm using the raspberry touchscreen with the dashboard, I'm already glad there is a stand-by mode. The problem is the touchscreen is very still very bright.
There is a command to adjust the brightness:
echo n > /sys/class/backlight/rpi_backlight/brightness
n is the brightness level 0-255
Also found some sort of API for it:
https://github.com/linusg/rpi-backlight
Is there a way I can run this command somewhere in the code when it goes to standby? I also notice the stand-by view isn't completly black and white, see the screenshot, the text is a bit gray but the dot is really white which makes it a better contrast
- 2017-04-13 21_35_26-10.100.10.119 (Domoticz-Dashboard) - VNC Viewer.png (27.43 KiB) Viewed 2435 times
Posted: Thursday 13 April 2017 21:21
by rbo0567
robgeerts wrote:rbo0567 wrote:Hi Rob,
I'm following this thread a couple of days now and I appreciate your work in this thread a lot.
For me it became more interesting when the camera's got your attention. Tried it after downloading the latest version of Dashticz but can only get 1 camera working at the same time. I made a screen specially for 4 cams but I see only the image of 1 cam (4 times).
Am I doing something wrong?
I didnt test with multiple cams yet... will do this soon!
If there is something I can help you with, please let me know.
Posted: Thursday 13 April 2017 21:37
by robgeerts
Blueone wrote:I'm using the raspberry touchscreen with the dashboard, I'm already glad there is a stand-by mode. The problem is the touchscreen is very still very bright.
Well, I can only call URL's, (local or internet), so if you can create something wich activates via de browser, I can make a function for this.
Posted: Thursday 13 April 2017 21:43
by robgeerts
Blueone wrote:I also notice the stand-by view isn't completly black and white, see the screenshot, the text is a bit gray but the dot is really white which makes it a better contrast
Try latest version
Posted: Thursday 13 April 2017 21:44
by Blueone
Thanks! Maybe I can create a switch in domoticz which runs a python script or someting
, I'm going to sort this out
Thanks for the quick reply again!
robgeerts wrote:
Try latest version
cool, I'm going to try it.
Posted: Thursday 13 April 2017 22:09
by l00pz
Very nice update with the custom icons
, but is it also possible to get bigger icons as they are a little small on my Tablet (Retina China Tablet).
Posted: Thursday 13 April 2017 22:10
by EdwinK
When I do that, this is what I get
Posted: Thursday 13 April 2017 22:32
by robgeerts
What does console (F12) say?
Looks like you got an error..
Posted: Thursday 13 April 2017 22:46
by EdwinK
robgeerts wrote:What does console (F12) say?
jquery.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4
ajax @ jquery.min.js:4
(anonymous) @ main.js?v=108:16
And then a load of urls from meteogroup/buienradar
debug called: MG.map.wrapper.OpenLayers.setZoom(2)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug created map wrapper: OpenLayers
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug OpenLayers.MapMoved
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setCenter(5.5,51.52)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(2)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(1)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(4)
5VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug MapLoaded
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug OpenLayers.MapLoaded
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug increased that.animationSpeedFactor: 13500
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug Time interval computed: Thu Jan 01 1970 01:00:00 GMT+0100 (CET) - Thu Jan 01 1970 01:00:00 GMT+0100 (CET), hours: 0.0002777777777777778
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug totalAnimationDurationSeconds: 0.000001, frameBuckets: 1
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug Time interval computed: Sat Apr 15 2017 11:00:00 GMT+0200 (CEST) - Sat Apr 15 2017 11:00:00 GMT+0200 (CEST), hours: 0.0002777777777777778
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug blocked playback attempt since animationInterval or loopTimeout are defined
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug Time interval computed: Thu Apr 13 2017 20:00:00 GMT+0200 (CEST) - Thu Apr 13 2017 20:00:00 GMT+0200 (CEST), hours: 0.0002777777777777778
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 error Error while parsing JSON-feed: /fileadmin/wme/feed_widget_wind.php?poi=&lat=51.52&lon=5.5
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 error error
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(4.49)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setCenter(5.6,53)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 error Error while parsing JSON-feed: /fileadmin/wme/feed_page_home.php?activeLayer=rad_nl&locale=nl_nl&date=now&context=home%2F6%2F31
adsbygoogle.js:18 Uncaught Q {name: "TagError", message: "adsbygoogle.push() error: Page-level tag does not work inside iframes.", stack: "TagError: adsbygoogle.push() error: Page-level tag…esyndication.com/pagead/js/adsbygoogle.js:22:207)"}
Gc @ adsbygoogle.js:18
Pc @ adsbygoogle.js:22
Lf @ adsbygoogle.js:80
(anonymous) @ adsbygoogle.js:82
2utilsMobile.min.js?v=1.0.14&1478204244:2 getCurrentPosition() and watchPosition() no longer work on insecure origins. To use this feature, you should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
(anonymous) @ utilsMobile.min.js?v=1.0.14&1478204244:2
c @ VM863 jquery.min.js:4
fireWith @ VM863 jquery.min.js:4
ready @ VM863 jquery.min.js:4
q @ VM863 jquery.min.js:4
main.min.js?v=1.0.14&1478204244:1 morpheoInitializeMap
main.min.js?v=1.0.14&1478204244:23 Uncaught TypeError: Cannot read property 'images' of null
at Object.updateRainChartAtLocation (main.min.js?v=1.0.14&1478204244:23)
at updateChart (main.min.js?v=1.0.14&1478204244:2)
at placeMarker (main.min.js?v=1.0.14&1478204244:2)
at Morpheo.setMarker (main.min.js?v=1.0.14&1478204244:3)
at ForecastRainRadar.render ((index):648)
at Object.success ((index):543)
at c (VM863 jquery.min.js:4)
at Object.fireWith [as resolveWith] (VM863 jquery.min.js:4)
at k (VM863 jquery.min.js:6)
at XMLHttpRequest.r (VM863 jquery.min.js:6)
updateRainChartAtLocation @ main.min.js?v=1.0.14&1478204244:23
updateChart @ main.min.js?v=1.0.14&1478204244:2
placeMarker @ main.min.js?v=1.0.14&1478204244:2
Morpheo.setMarker @ main.min.js?v=1.0.14&1478204244:3
ForecastRainRadar.render @ (index):648
success @ (index):543
k @ VM863 jquery.min.js:6
r @ VM863 jquery.min.js:6
main.min.js?v=1.0.14&1478204244:1 gl context: [object WebGLRenderingContext]
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: initGL
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: init viewport: 0 0 290 200
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: initRadar nl
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: onDownloadImagesStarted: 25
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: initModel radarCount: 25
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 11 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132035.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 11 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132035.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 12 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132040.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 12 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132040.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 13 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132045.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 13 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132045.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 14 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132050.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 14 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132050.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 15 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132055.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 15 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132055.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 16 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132100.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 16 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132100.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 17 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132105.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 17 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132105.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 18 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132110.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 18 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132110.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 19 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132115.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 19 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132115.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 20 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132120.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 20 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132120.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 21 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132125.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 21 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132125.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 22 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132130.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 22 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132130.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 23 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132135.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 23 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132135.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 24 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132140.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 0 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131940.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 0 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131940.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 1 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131945.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 1 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131945.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 2 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131950.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 2 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131950.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 3 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131955.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 3 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131955.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 4 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132000.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 4 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132000.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 5 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132005.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 5 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132005.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 6 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132010.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 6 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132010.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 7 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132015.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 7 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132015.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 8 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132020.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 8 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132020.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 9 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132025.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 9 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132025.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 10 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132030.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 10 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132030.jpg
main.min.js?v=1.0.14&1478204244:1 download elapsed time: 5.78 s
Posted: Thursday 13 April 2017 22:55
by robgeerts
Hmmm there should be anotber one. Right after loading the page..
