Locked
robgeerts
Domoticz version: 3.7067
Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
formadvi wrote:
robgeerts wrote:
mAiden88 wrote:Image
Change |0| already to 2. No effect
Try chaning the name from 'Regen Verwacht' to 'Regen verwacht' ;)
(Yes, not very handy this way but will do this different soon!)
I have the same issue. Changed to Regen verwacht but still only Regen Aan
Do you have the latest version of the dashboard?
What is de output of your device?
robgeerts
Post by robgeerts »
CUSTOM ICONS
You can now define other icons, in config.js:
blocks[1] = {}
blocks[1]['icon'] = 'fa-eye';
Find an icon at http://fontawesome.io/cheatsheet/
OR, if you want to use an image, place it in img/ folder and specify as:
blocks[1] = {}
blocks[1]['image'] = 'bulb_off.png';
Last edited by robgeerts on Thursday 13 April 2017 20:58, edited 2 times in total.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Great job with the custum icons.
I just downloaded the latest version and its seems that the train info is gone, i only have traffic?
In the previous version it is still working.
formadvi
Domoticz version: V3.7320
Post by formadvi »
Ik heb eind van de middag de laatste versie geinstalleerd. Net laatste versie gepakt van 30 min geleden. Deze werkt correct.
Thanks.
EdwinK
Post by EdwinK »
robgeerts wrote:CUSTOM ICONS
For statusblocks (like rain expected, other text-types,lux, sound level, rain, wind, motherboard sensors, air quality) you can now define other icons, in config.js:
Awesome.
Still trying to get this looking better
robgeerts
Post by robgeerts »
SwordFish wrote:Great job with the custum icons.
Kun je de laatste versie eens proberen?
robgeerts
Post by robgeerts »
Awesome.
What was the output of your rain evice? (Or did I ask that already earlier?
En your screen width, so I can test it..
SwordFish
Post by SwordFish »
Will try it tomorrow, not at home.
EdwinK
Post by EdwinK »
robgeerts wrote: En your screen width, so I can test it..
Device output:
   "ActTime" : 1492110156,
   "ServerTime" : "2017-04-13 21:02:36",
   "Sunrise" : "06:50",
   "Sunset" : "20:35",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Geen regen verwacht binnen komende 30 minuten",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 24,
         "HardwareName" : "Weer",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "ID" : "00082113",
         "LastUpdate" : "2017-04-13 21:02:00",
         "Name" : "Regen verwacht",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : false,
         "SignalLevel" : "-",
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "113"
   "status" : "OK",
   "title" : "Devices"
Not sure about screen width. Now on my MacBook. I believe it's a 13" inch version.
ould be nice if the tile could be a bit bigger, like the train-info.
robgeerts
Post by robgeerts »
Device output:
   "Sunset" : "20:35",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 24,
         "ID" : "00082113",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "113"
   "status" : "OK",
   "title" : "Devices"
in that case, add to your config.js, just below blocks = {}
blocks[113]['width']=12;
Blueone
Post by Blueone »
I'm using the raspberry touchscreen with the dashboard, I'm already glad there is a stand-by mode. The problem is the touchscreen is very still very bright.
There is a command to adjust the brightness:
echo n > /sys/class/backlight/rpi_backlight/brightness
n is the brightness level 0-255
Also found some sort of API for it: https://github.com/linusg/rpi-backlight
Is there a way I can run this command somewhere in the code when it goes to standby? I also notice the stand-by view isn't completly black and white, see the screenshot, the text is a bit gray but the dot is really white which makes it a better contrast :)
2017-04-13 21_35_26-10.100.10.119 (Domoticz-Dashboard) - VNC Viewer.png (27.43 KiB) Viewed 2430 times
rbo0567
Domoticz version: v4.9701
Post by rbo0567 »
robgeerts wrote:
rbo0567 wrote:Hi Rob,
I'm following this thread a couple of days now and I appreciate your work in this thread a lot.
For me it became more interesting when the camera's got your attention. Tried it after downloading the latest version of Dashticz but can only get 1 camera working at the same time. I made a screen specially for 4 cams but I see only the image of 1 cam (4 times).
Am I doing something wrong?
I didnt test with multiple cams yet... will do this soon!
If there is something I can help you with, please let me know.
robgeerts
Post by robgeerts »
Blueone wrote:I'm using the raspberry touchscreen with the dashboard, I'm already glad there is a stand-by mode. The problem is the touchscreen is very still very bright.
Well, I can only call URL's, (local or internet), so if you can create something wich activates via de browser, I can make a function for this.
robgeerts
Post by robgeerts »
Blueone wrote:I also notice the stand-by view isn't completly black and white, see the screenshot, the text is a bit gray but the dot is really white which makes it a better contrast :)
Try latest version
Blueone
Post by Blueone »
Thanks! Maybe I can create a switch in domoticz which runs a python script or someting :), I'm going to sort this out :) Thanks for the quick reply again!
robgeerts wrote: Try latest version
cool, I'm going to try it.
l00pz
Post by l00pz »
Very nice update with the custom icons :), but is it also possible to get bigger icons as they are a little small on my Tablet (Retina China Tablet).
EdwinK
Post by EdwinK »
When I do that, this is what I get
robgeerts
Post by robgeerts »
What does console (F12) say?
Looks like you got an error..
EdwinK
Post by EdwinK »
robgeerts wrote:What does console (F12) say?
jquery.min.js:4 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send	@	jquery.min.js:4
ajax	@	jquery.min.js:4
(anonymous)	@	main.js?v=108:16
And then a load of urls from meteogroup/buienradar
debug called: MG.map.wrapper.OpenLayers.setZoom(2)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug created map wrapper: OpenLayers
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug OpenLayers.MapMoved
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setCenter(5.5,51.52)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(2)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(1)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(4)
5VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug MapLoaded
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug OpenLayers.MapLoaded
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug increased that.animationSpeedFactor: 13500
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug Time interval computed: Thu Jan 01 1970 01:00:00 GMT+0100 (CET) - Thu Jan 01 1970 01:00:00 GMT+0100 (CET), hours: 0.0002777777777777778
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug totalAnimationDurationSeconds: 0.000001, frameBuckets: 1
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug Time interval computed: Sat Apr 15 2017 11:00:00 GMT+0200 (CEST) - Sat Apr 15 2017 11:00:00 GMT+0200 (CEST), hours: 0.0002777777777777778
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug blocked playback attempt since animationInterval or loopTimeout are defined
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug Time interval computed: Thu Apr 13 2017 20:00:00 GMT+0200 (CEST) - Thu Apr 13 2017 20:00:00 GMT+0200 (CEST), hours: 0.0002777777777777778
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 error Error while parsing JSON-feed: /fileadmin/wme/feed_widget_wind.php?poi=&lat=51.52&lon=5.5
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 error error
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setZoom(4.49)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 debug called: MG.map.wrapper.OpenLayers.setCenter(5.6,53)
VM907 MG.WebMapEngine.debug.js?v=1.0.14&1478204245:30 error Error while parsing JSON-feed: /fileadmin/wme/feed_page_home.php?activeLayer=rad_nl&locale=nl_nl&date=now&context=home%2F6%2F31
adsbygoogle.js:18 Uncaught Q {name: "TagError", message: "adsbygoogle.push() error: Page-level tag does not work inside iframes.", stack: "TagError: adsbygoogle.push() error: Page-level tag…esyndication.com/pagead/js/adsbygoogle.js:22:207)"}
Gc @ adsbygoogle.js:18
Pc @ adsbygoogle.js:22
Lf @ adsbygoogle.js:80
(anonymous) @ adsbygoogle.js:82
2utilsMobile.min.js?v=1.0.14&1478204244:2 getCurrentPosition() and watchPosition() no longer work on insecure origins. To use this feature, you should consider switching your application to a secure origin, such as HTTPS. See https://goo.gl/rStTGz for more details.
(anonymous) @ utilsMobile.min.js?v=1.0.14&1478204244:2
c @ VM863 jquery.min.js:4
fireWith @ VM863 jquery.min.js:4
ready @ VM863 jquery.min.js:4
q @ VM863 jquery.min.js:4
main.min.js?v=1.0.14&1478204244:1 morpheoInitializeMap
main.min.js?v=1.0.14&1478204244:23 Uncaught TypeError: Cannot read property 'images' of null
    at Object.updateRainChartAtLocation (main.min.js?v=1.0.14&1478204244:23)
    at updateChart (main.min.js?v=1.0.14&1478204244:2)
    at placeMarker (main.min.js?v=1.0.14&1478204244:2)
    at Morpheo.setMarker (main.min.js?v=1.0.14&1478204244:3)
    at ForecastRainRadar.render ((index):648)
    at Object.success ((index):543)
    at c (VM863 jquery.min.js:4)
    at Object.fireWith [as resolveWith] (VM863 jquery.min.js:4)
    at k (VM863 jquery.min.js:6)
    at XMLHttpRequest.r (VM863 jquery.min.js:6)
updateRainChartAtLocation @ main.min.js?v=1.0.14&1478204244:23
updateChart @ main.min.js?v=1.0.14&1478204244:2
placeMarker @ main.min.js?v=1.0.14&1478204244:2
Morpheo.setMarker @ main.min.js?v=1.0.14&1478204244:3
ForecastRainRadar.render @ (index):648
success @ (index):543
k @ VM863 jquery.min.js:6
r @ VM863 jquery.min.js:6
main.min.js?v=1.0.14&1478204244:1 gl context: [object WebGLRenderingContext]
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: initGL
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: init viewport: 0 0 290 200
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: initRadar nl
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: onDownloadImagesStarted: 25
main.min.js?v=1.0.14&1478204244:1 emscipten c-code says: initModel radarCount: 25
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 11 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132035.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 11 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132035.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 12 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132040.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 12 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132040.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 13 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132045.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 13 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132045.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 14 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132050.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 14 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132050.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 15 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132055.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 15 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132055.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 16 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132100.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 16 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132100.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 17 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132105.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 17 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132105.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 18 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132110.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 18 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132110.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 19 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132115.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 19 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132115.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 20 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132120.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 20 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132120.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 21 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132125.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 21 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132125.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 22 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132130.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 22 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132130.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 23 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132135.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 23 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/vel_201704132135.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 24 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/forecast_201704132035/for_201704132140.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 0 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131940.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 0 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131940.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 1 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131945.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 1 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131945.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 2 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131950.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 2 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131950.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 3 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704131955.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 3 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704131955.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 4 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132000.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 4 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132000.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 5 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132005.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 5 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132005.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 6 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132010.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 6 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132010.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 7 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132015.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 7 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132015.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 8 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132020.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 8 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132020.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 9 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132025.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 9 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132025.jpg
main.min.js?v=1.0.14&1478204244:1 downloading radar image: 10 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/rad_201704132030.jpg
main.min.js?v=1.0.14&1478204244:1 downloading velocity image: 10 http://cdn.meteogroup.de/images/mapengine/rain2.0/rad_nl/observation/vel_201704132030.jpg
main.min.js?v=1.0.14&1478204244:1 download elapsed time: 5.78 s
robgeerts
Post by robgeerts »
Hmmm there should be anotber one. Right after loading the page..
Locked
