/usr/bin/homebridge -> /usr/lib/node_modules/homebridge/bin/homebridge
[email protected] install /usr/lib/node_modules/homebridge/node_modules/mdns
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.3.1"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp"
make: Entering directory '/usr/lib/node_modules/homebridge/node_modules/mdns/build'
CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
In file included from ../src/mdns.hpp:12:0,
from ../src/dns_sd.cpp:1:
../node_modules/nan/nan.h:43:3: error: #error This version of node/NAN/v8 requires a C++11 compiler
In file included from /usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp/6.3.1/include/node/node.h:42:0,
from ../src/mdns.hpp:11,
/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp/6.3.1/include/node/v8.h:341:1: error: expected unqualified-id before ‘using’
/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp/6.3.1/include/node/v8.h:477:1: error: expected unqualified-id before ‘using’
/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp/6.3.1/include/node/v8.h:871:1: error: expected unqualified-id before ‘using’
In file included from ../node_modules/nan/nan.h:190:0,
from ../src/mdns.hpp:12,
../node_modules/nan/nan_maybe_43_inl.h:13:1: error: expected unqualified-id before ‘using’
../node_modules/nan/nan_maybe_43_inl.h:16:1: error: expected unqualified-id before ‘using’
../node_modules/nan/nan_maybe_43_inl.h:19:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:24:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:31:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:36:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:41:1: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:46:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:51:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:59:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:64:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:69:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:76:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:83:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:91:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:98:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:108:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:114:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:118:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:125:1: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:130:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:135:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:139:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:145:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:150:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:156:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:162:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:168:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:174:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:180:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:186:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:194:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:201:1: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:205:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:209:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:213:8: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:217:8: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_maybe_43_inl.h:237:8: error: ‘MaybeLocal’ does not name a type
In file included from ../node_modules/nan/nan.h:195:0,
../node_modules/nan/nan_converters.h:14:11: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_converters.h:16:56: error: ‘Maybe’ does not name a type
../node_modules/nan/nan_converters.h:26:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:27:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:28:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:29:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:30:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:31:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:32:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:42:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:43:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:44:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:45:1: error: ‘return_t’ does not name a type
../node_modules/nan/nan_converters.h:46:1: error: ‘return_t’ does not name a type
In file included from ../node_modules/nan/nan_converters.h:59:0,
from ../node_modules/nan/nan.h:195,
../node_modules/nan/nan_converters_43_inl.h:18:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::Boolean>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:19:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::Number>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:20:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::String>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:21:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::Object>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:22:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::Integer>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:23:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::Uint32>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:24:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<v8::Int32>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:34:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<bool>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:35:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<double>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:36:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<long long int>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:37:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<unsigned int>’ does not name a type
../node_modules/nan/nan_converters_43_inl.h:38:1: error: ‘return_t’ in ‘struct Nan:
:ToFactory<int>’ does not name a type
In file included from ../node_modules/nan/nan.h:196:0,
../node_modules/nan/nan_new.h: In function ‘v8::Local<T> Nan:
:To(v8::Local<v8::Integer>) [with T = v8::Integer]’:
../node_modules/nan/nan_new.h:21:32: error: no matching function for call to ‘To(v8::Local<v8::Integer>&)’
../node_modules/nan/nan_new.h:21:32: note: candidate is:
../node_modules/nan/nan_converters.h:53:38: note: template<class T> typename Nan:
:ToFactory::return_t Nan::To(v8::Local<v8::Value>)
:To(v8::Local<v8::Integer>) [with T = v8::Int32]’:
../node_modules/nan/nan_new.h:28:30: error: no matching function for call to ‘To(v8::Local<v8::Integer>&)’
../node_modules/nan/nan_new.h:28:30: note: candidate is:
:To(v8::Local<v8::Integer>) [with T = v8::Uint32]’:
../node_modules/nan/nan_new.h:35:31: error: no matching function for call to ‘To(v8::Local<v8::Integer>&)’
../node_modules/nan/nan_new.h:35:31: note: candidate is:
../node_modules/nan/nan_new.h: At global scope:
../node_modules/nan/nan_new.h:43:11: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan_new.h:75:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:141:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:147:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:148:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:160:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:161:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:162:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:163:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:165:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:166:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:182:17: error: ‘return_t’ does not name a type
../node_modules/nan/nan_new.h:183:17: error: ‘return_t’ does not name a type
In file included from ../node_modules/nan/nan_new.h:189:0,
from ../node_modules/nan/nan.h:196,
../node_modules/nan/nan_implementation_12_inl.h:61:1: error: ‘return_t’ in ‘struct Nan:
:Factory<v8::Date>’ does not name a type
../node_modules/nan/nan_implementation_12_inl.h: In static member function ‘static Nan:
:FactoryBase<v8::Function>::return_t Nan:
:Factory<v8::Function>::New(Nan::FunctionCallback, v8::Local<v8::Value>)’:
../node_modules/nan/nan_implementation_12_inl.h:95:46: error: ‘NewInstance’ was not declared in this scope
:FactoryBase<v8::FunctionTemplate>::return_t Nan:
:Factory<v8::FunctionTemplate>::New(Nan::FunctionCallback, v8::Local<v8::Value>, v8::Local<v8::Signature>)’:
../node_modules/nan/nan_implementation_12_inl.h:123:48: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan_implementation_12_inl.h: At global scope:
../node_modules/nan/nan_implementation_12_inl.h:202:1: error: ‘return_t’ in ‘struct Nan:
:Factory<v8::RegExp>’ does not name a type
../node_modules/nan/nan_implementation_12_inl.h:221:1: error: ‘return_t’ in ‘struct Nan:
:Factory<v8::Script>’ does not name a type
../node_modules/nan/nan_implementation_12_inl.h:227:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_implementation_12_inl.h:259:1: error: ‘return_t’ in ‘struct Nan:
:Factory<v8::String>’ does not name a type
../node_modules/nan/nan_implementation_12_inl.h:267:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_implementation_12_inl.h:273:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_implementation_12_inl.h:280:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_implementation_12_inl.h:286:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_implementation_12_inl.h:291:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_implementation_12_inl.h:352:1: error: ‘return_t’ in ‘struct Nan:
:Factory<v8::UnboundScript>’ does not name a type
../node_modules/nan/nan_implementation_12_inl.h:359:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:293:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:299:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:305:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:311:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:317:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:323:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:329:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan_new.h:335:1: error: ‘return_t’ in ‘struct Nan:
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::Error(const char*)’:
../node_modules/nan/nan.h:655:3: error: ‘Nan:
:FactoryBase<v8::Boolean>::return_t’ has no member named ‘ToLocalChecked’
../node_modules/nan/nan.h: In function ‘void Nan::ThrowError(const char*)’:
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::RangeError(const char*)’:
../node_modules/nan/nan.h:656:3: error: ‘Nan:
../node_modules/nan/nan.h: In function ‘void Nan::ThrowRangeError(const char*)’:
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::ReferenceError(const char*)’:
../node_modules/nan/nan.h:657:3: error: ‘Nan:
../node_modules/nan/nan.h: In function ‘void Nan::ThrowReferenceError(const char*)’:
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::SyntaxError(const char*)’:
../node_modules/nan/nan.h:658:3: error: ‘Nan:
../node_modules/nan/nan.h: In function ‘void Nan::ThrowSyntaxError(const char*)’:
../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::TypeError(const char*)’:
../node_modules/nan/nan.h:659:3: error: ‘Nan:
../node_modules/nan/nan.h: In function ‘void Nan::ThrowTypeError(const char*)’:
../node_modules/nan/nan.h: At global scope:
../node_modules/nan/nan.h:667:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:689:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:705:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:718:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:735:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:741:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:749:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:756:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:762:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h: In member function ‘void Nan::Callback::SetFunction(const v8::Local<v8::Function>&)’:
../node_modules/nan/nan.h:1398:40: error: ‘Set’ was not declared in this scope
../node_modules/nan/nan.h:1398:40: note: suggested alternative:
/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp/6.3.1/include/node/v8.h:3067:17: note: ‘v8::Set’
../node_modules/nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char*, const v8::Local<v8::Value>&)’:
../node_modules/nan/nan.h:1518:41: error: ‘Nan:
../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::AsyncWorker::GetFromPersistent(const char*) const’:
../node_modules/nan/nan.h:1536:45: error: ‘Nan:
../node_modules/nan/nan.h: In member function ‘virtual void Nan::AsyncWorker::HandleErrorCallback()’:
../node_modules/nan/nan.h:1570:58: error: no matching function for call to ‘New(const char*)’
../node_modules/nan/nan.h:1570:58: note: candidates are:
../node_modules/nan/nan_implementation_12_inl.h:395:21: note: template<class T, class M> v8::Local<T> Nan::New(const v8::Persistent<S, M>&)
../node_modules/nan/nan_implementation_12_inl.h:400:21: note: template<class T, class M> v8::Local<T> Nan::New(const Nan::Persistent<T, M>&)
../node_modules/nan/nan_implementation_12_inl.h:405:21: note: template<class T> v8::Local<T> Nan::New(const Nan::Global<T>&)
../node_modules/nan/nan_new.h:201:1: note: template<class T> typename Nan:
:Factory::return_t Nan::New()
../node_modules/nan/nan_new.h:207:1: note: template<class T, class A0> typename Nan:
:Factory<T>::return_t Nan::New(A0)
../node_modules/nan/nan_new.h:213:1: note: template<class T, class A0, class A1> typename Nan:
:Factory<T>::return_t Nan::New(A0, A1)
../node_modules/nan/nan_new.h:219:1: note: template<class T, class A0, class A1, class A2> typename Nan:
:Factory<T>::return_t Nan::New(A0, A1, A2)
../node_modules/nan/nan_new.h:225:1: note: template<class T, class A0, class A1, class A2, class A3> typename Nan:
:Factory<T>::return_t Nan::New(A0, A1, A2, A3)
../node_modules/nan/nan_new.h:237:1: note: template<class T> typename Nan:
:Factory::return_t Nan::New(Nan::FunctionCallback, v8::Local<v8::Value>)
../node_modules/nan/nan_new.h:245:1: note: template<class T, class A2> typename Nan:
:Factory<T>::return_t Nan::New(Nan::FunctionCallback, v8::Local<v8::Value>, A2)
:SetMethodAux(T, v8::Local<v8::String>, v8::Local<v8::FunctionTemplate>, ...)’:
../node_modules/nan/nan.h:1872:34: error: there are no arguments to ‘GetFunction’ that depend on a template parameter, so a declaration of ‘GetFunction’ must be available [-fpermissive]
../node_modules/nan/nan.h:1872:34: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
../node_modules/nan/nan.h: In function ‘void Nan::SetMethod(HandleType<T>, const char*, Nan::FunctionCallback)’:
../node_modules/nan/nan.h:1884:45: error: ‘Nan:
../node_modules/nan/nan.h: In function ‘void Nan::SetPrototypeMethod(v8::Local<v8::FunctionTemplate>, const char*, Nan::FunctionCallback)’:
../node_modules/nan/nan.h:1899:45: error: ‘Nan:
../node_modules/nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan:
:Sig)’:
../node_modules/nan/nan.h:1924:47: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan.h: In function ‘bool Nan::SetAccessor(v8::Local<v8::Object>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute)’:
../node_modules/nan/nan.h:1967:51: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan.h: In function ‘void Nan::SetNamedPropertyHandler(v8::Local<v8::ObjectTemplate>, Nan::PropertyGetterCallback, Nan::PropertySetterCallback, Nan::PropertyQueryCallback, Nan::PropertyDeleterCallback, Nan::PropertyEnumeratorCallback, v8::Local<v8::Value>)’:
../node_modules/nan/nan.h:2026:47: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan.h: In function ‘void Nan::SetIndexedPropertyHandler(v8::Local<v8::ObjectTemplate>, Nan::IndexGetterCallback, Nan::IndexSetterCallback, Nan::IndexQueryCallback, Nan::IndexDeleterCallback, Nan::IndexEnumeratorCallback, v8::Local<v8::Value>)’:
../node_modules/nan/nan.h:2096:47: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan.h: In function ‘void Nan::SetCallHandler(v8::Local<v8::FunctionTemplate>, Nan::FunctionCallback, v8::Local<v8::Value>)’:
../node_modules/nan/nan.h:2151:47: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan.h: In function ‘void Nan::SetCallAsFunctionHandler(v8::Local<v8::ObjectTemplate>, Nan::FunctionCallback, v8::Local<v8::Value>)’:
../node_modules/nan/nan.h:2173:47: error: ‘NewInstance’ was not declared in this scope
../node_modules/nan/nan.h: In function ‘void Nan::Export(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE, const char*, Nan::FunctionCallback)’:
../node_modules/nan/nan.h:2200:35: error: no matching function for call to ‘New(const char*&)’
../node_modules/nan/nan.h:2200:35: note: candidates are:
../node_modules/nan/nan.h:2201:47: error: ‘GetFunction’ was not declared in this scope
../node_modules/nan/nan.h:2201:65: error: ‘Set’ was not declared in this scope
../node_modules/nan/nan.h:2201:65: note: suggested alternative:
../node_modules/nan/nan.h: In constructor ‘Nan::Tap::Tap(v8::Local<v8::Value>)’:
../node_modules/nan/nan.h:2208:30: error: no matching function for call to ‘To(v8::Local<v8::Value>&)’
../node_modules/nan/nan.h:2208:30: note: candidate is:
../node_modules/nan/nan.h: In member function ‘void Nan::Tap::ok(bool, const char*)’:
../node_modules/nan/nan.h:2221:33: error: ‘Nan:
../node_modules/nan/nan.h: In member function ‘void Nan::Tap::pass(const char*)’:
../node_modules/nan/nan.h:2227:30: error: ‘Nan:
../node_modules/nan/nan.h:2251:10: error: ‘MaybeLocal’ does not name a type
../node_modules/nan/nan.h:2256:40: error: ‘MaybeLocal’ was not declared in this scope
../node_modules/nan/nan.h:2256:40: note: suggested alternative:
/usr/lib/node_modules/homebridge/node_modules/mdns/.node-gyp/6.3.1/include/node/v8.h:113:7: note: ‘v8::MaybeLocal’
../node_modules/nan/nan.h:2256:52: error: template argument 1 is invalid
../node_modules/nan/nan.h:2256:54: error: expected unqualified-id before ‘>’ token
../node_modules/nan/nan.h:2265:1: error: ‘MaybeLocal’ does not name a type
In file included from ../src/dns_sd.cpp:5:0:
../src/mdns_utils.hpp: In function ‘v8::Local<v8::Value> node_mdns::stringOrUndefined(const char*)’:
../src/mdns_utils.hpp:50:40: error: no matching function for call to ‘New(const char*&)’
../src/mdns_utils.hpp:50:40: note: candidates are:
In file included from ../src/dns_sd.cpp:7:0:
../src/txt_record_ref.hpp: At global scope:
../src/txt_record_ref.hpp:11:36: error: ‘v8::Handle’ has not been declared
../src/txt_record_ref.hpp:11:42: error: expected ‘,’ or ‘...’ before ‘<’ token
../src/txt_record_ref.hpp:16:44: error: ‘v8::Handle’ has not been declared
../src/txt_record_ref.hpp:16:50: error: expected ‘,’ or ‘...’ before ‘<’ token
../src/txt_record_ref.hpp: In static member function ‘static bool node_mdns::TxtRecordRef::HasInstance(int)’:
../src/txt_record_ref.hpp:17:20: error: ‘value’ was not declared in this scope
../src/txt_record_ref.hpp:18:44: error: ‘value’ was not declared in this scope
In file included from ../src/dns_sd.cpp:9:0:
../src/socket_watcher.hpp: At global scope:
../src/socket_watcher.hpp:10:36: error: ‘v8::Handle’ has not been declared
../src/socket_watcher.hpp:10:42: error: expected ‘,’ or ‘...’ before ‘<’ token
../src/dns_sd.cpp: In function ‘void node_mdns::init(v8::Local<v8::Object>)’:
../src/dns_sd.cpp:56:38: error: no matching function for call to ‘node_mdns::TxtRecordRef::Initialize(v8::Local<v8::Object>&)’
../src/dns_sd.cpp:56:38: note: candidate is:
../src/txt_record_ref.hpp:11:21: note: static void node_mdns::TxtRecordRef::Initialize(int)
../src/txt_record_ref.hpp:11:21: note: no known conversion for argument 1 from ‘v8::Local<v8::Object>’ to ‘int’
../src/dns_sd.cpp:58:39: error: no matching function for call to ‘node_mdns::SocketWatcher::Initialize(v8::Local<v8::Object>&)’
../src/dns_sd.cpp:58:39: note: candidate is:
../src/socket_watcher.hpp:10:21: note: static void node_mdns::SocketWatcher::Initialize(int)
../src/socket_watcher.hpp:10:21: note: no known conversion for argument 1 from ‘v8::Local<v8::Object>’ to ‘int’
../src/dns_sd.cpp: In function ‘void node_mdns::defineFunction(v8::Local<v8::Object>, const char*, Nan::FunctionCallback)’:
../src/dns_sd.cpp:94:5: error: ‘Set’ is not a member of ‘Nan’
../src/dns_sd.cpp:94:5: note: suggested alternatives:
../src/dns_sd.cpp:94:37: error: ‘Nan:
../src/dns_sd.cpp:95:13: error: ‘GetFunction’ is not a member of ‘Nan’
../src/dns_sd.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE node_mdns::buildException(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/dns_sd.cpp:107:57: error: no matching function for call to ‘To(v8::Local<v8::Value>)’
../src/dns_sd.cpp:107:57: note: candidate is:
../node_modules/nan/nan.h:655:3: warning: control reaches end of non-void function [-Wreturn-type]
dns_sd_bindings.target.mk:140: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
make: Leaving directory '/usr/lib/node_modules/homebridge/node_modules/mdns/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
gyp ERR! stack at emitTwo (events.js:106:13)
gyp ERR! stack at ChildProcess.emit (events.js:191:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:204:12)
gyp ERR! System Linux 4.1.19-v7+
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! cwd /usr/lib/node_modules/homebridge/node_modules/mdns
gyp ERR! node -v v6.3.1
gyp ERR! node-gyp -v v3.3.1
gyp ERR! not ok
/usr/lib
└── (empty)
npm ERR! Linux 4.1.19-v7+
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "homebridge"
npm ERR! node v6.3.1
npm ERR! npm v3.10.3
npm ERR! code ELIFECYCLE
npm ERR!
[email protected] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the
[email protected] install script 'node-gyp rebuild'.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the mdns package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get information on how to open an issue for this project with:
npm ERR! npm bugs mdns
npm ERR! Or if that isn't available, you can get their info via:
npm ERR! npm owner ls mdns
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR! /home/pi/npm-debug.log
npm ERR! code 1
