Pilot: Home Automation Control (iOS app)
mvveelen
Re: Pilot: Home Automation Control (iOS app)
Post by mvveelen »
patoo77 wrote: Thursday 01 February 2018 20:46 Version 2.3.0 is out!
Enjoy~
Installed it using Testflight, but it tells me it will expire in 87 days. Do we (testers) have to uninstall and reinstall (using the App store) ?
patoo77
Post by patoo77 »
mvveelen wrote: Thursday 01 February 2018 21:24
Enjoy~
I think you can simply install the appstore version. It will overwrite the testflight one, and you'll keep your setup. :)
anasazi
Post by anasazi »
Is there support for room plans or have this been removed?
At one of the pictures in the first post there are some rooms so I tried to add some rooms in Domotics under Setup - More options - Plans - Roomplan.
Am I doing something wrong or is it no longer supported or is it a paid feature?
htilburgs
Post by htilburgs »
anasazi wrote: Friday 02 February 2018 7:11 Hi,
You can add Rooms to Pilot if that is what you meen.
Start Pilot, select tab Data, choose edit and then +
Now you can create a Room and select the devices that belong to that room.
Hardware:
anasazi
Post by anasazi »
htilburgs wrote: Friday 02 February 2018 14:42
Yes, that's what I mean ;)
But when I am in the Data tab and press Edit, no + button is displayed.
See the attached picture.
I have tried to delete the app and re-install it but with the same result.
patoo77
Post by patoo77 »
anasazi wrote: Friday 02 February 2018 15:21
Rooms are only available with Pilot Premium ;)
anasazi
Post by anasazi »
patoo77 wrote: Friday 02 February 2018 15:22
The explains why I did not see the + sign :)
If I may come with a suggestion to the app:
One feature I think would be great to add to the app is support for iOS Dynamic Type.
Is this something you would consider to implement?
K3rryBlue
Domoticz version: V4.10xx
Post by K3rryBlue »
Hi running the premium version V2.3.0 on a iPhone 6s.
After upgrading IOS to V11.2.6 I am no longer able to connect to my Domoticz via its remote address and 4G.
Using the remote address via wifi still works. (local server settings are disabled)
I can also access Domoticz via an external ip.
Any ideas how to get 4G working again?
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
patoo77
Post by patoo77 »
K3rryBlue wrote: Thursday 22 February 2018 23:45 Hi running the premium version V2.3.0 on a iPhone 6s.
This is a rather weird issue. I can't see any reason why updating iOS would have broken it.
Are you sure your server is available from the web?
htilburgs
Post by htilburgs »
patoo77 wrote: Sunday 25 February 2018 17:41
I updated today to IOS 11.2.6, but no issues with Pilot v2.3.0. Everything still works as it should be.
Hardware:
K3rryBlue
Post by K3rryBlue »
Played again with the app and installation.........
Seems i got the worng user account setup in the app :oops:
After changing it to the correct the connection was made again.
Still i have some minor issues.
- Unable to see my custom variables via the pilot app, when i open them pilot crashes.
- Geofence works very random. 9 out of 10 times it displays something like "unable to connect to server"
htilburgs
Post by htilburgs »
K3rryBlue wrote: Monday 26 February 2018 9:21 - Geofence works very random. 9 out of 10 times it displays something like "unable to connect to server"
I had the same, than I discovered I changed my switch that I had configured in Pilot set to protected.
Removed the protected flag and issue solved.
Hardware:
K3rryBlue
Post by K3rryBlue »
Thanks fot the suggestion, switch is not protected. Even cretaed a new switch and reassigned it in Pilot.
Issues is still there.
febalci
Post by febalci »
Iphone 7 plus, IOS 11.2.5, Pilot Beta with Testflight:
Using widgets on (both favorites and scenes), sometimes the notification screen of IOS disappears. When i swipe down or on lock screen, the notification screen is all empty with the ios Wallpaper, nothing else. I hear whatsapp messages coming through but it shows nothing neither notifications nor widget screen. The only possible way is to reboot IOS. When i disabled Pilot widgets, everything is back to normal. It doesn't do this instantly but after some time.
felix63
Domoticz version: 2020.1
Post by felix63 »
2 iPhones: an iPhone SE running 11.2.6 and an iPhone X running 11.3. Bot iPhones are running the latest Pilot version 2.3. The SE can connect to my Domoticz server over both WiFi and 4G using SSL. The iPhone X gets an error with SSL on. No problem connecting on port 80 with SSL off.
So apparently 11.3 'breaks' something... :(
Nautilus
Post by Nautilus »
Feature suggest: automatic screen updating. Currently the normal web interface is not working for me on an old iPad (which is used a in-wall control panel) but Pilot is working well so I thought I'd use it as the interface at least as long as the web UI is working again. But the thing I miss is the possibility to make the screen update automatically, e.g. every 10-30 seconds. I hope something like this would be easy to add :)
Of course, an alternative dashboard like UI (kinda like the Home app on iOS) would be a nice addition as well but understandably that takes time...
ericvr
Post by ericvr »
Hi, I don't know if this is the right place to post, but I'm having a problem with the app crashing when setting location services to use ibeacon.
I'm running pilot on an iphone 7 with ios 11.3
1) Go into navigation services and add a new location using the + sign
2) Give it a name
3) Select a virtual switch (one I've also connected to another location that uses Geofence)
4) select iBeacon and fill in UID, Major and Minor number
5) Hit save and the app will crash. All entered data is lost.
I have an iBeacon setup. The app will crash if I use the beacon's UID and if I use a random UID.
Is anybody else having this problem?
MikeF
Domoticz version: V2022.2
Post by MikeF »
Version 2.3.0 Premium iPhone 6S iOS 11.0.1
App always crashes whenever I select Server logs within Settings. Otherwise OK - including Location services.
gielie
Domoticz version: latest β
Post by gielie »
pilot version 2.3.0, iOs version 11.4, Iphone 8 plus, ipad 2017, iphone 6s.
The widget is not working anymore. loading not possible.
Is this a known bug? Do you have a beta version to test?
Geo location works fine on all devices.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
patoo77
Post by patoo77 »
gielie wrote: Monday 04 June 2018 14:27 pilot version 2.3.0, iOs version 11.4, Iphone 8 plus, ipad 2017, iphone 6s.
Hi :)
Which version of Domoticz are you using?
Also, do you have selectors in your widget?
