Pass2PHP
gimic
Domoticz version: 3.66
Re: Pass2PHP
Post by gimic »
Upgrade finished, had some trouble with getting statusses from other devices as i needed to re-write them as you told.
only thing that does not work is my screens :(
i get azimuth of the sun by running a script (dzvents) grabbing from darkcloud and updating a general custom sensortype every 5 minutes. it seems like pass2php does not see the update every 5 min so it does not do anything with the sensor.
maybe i'l do the execution in cron instead of in the custom sensortype php file.
gimic
Re: Pass2PHP
Post by gimic »
Installation on debian stretch:
New version 04/2019
With my sql:
wget http://repo.mysql.com/mysql-apt-config_0.8.9-1_all.deb
dpkg -i mysql-apt-config_0.8.9-1_all.deb
apt update
apt install mysql-server
mysql_secure_installation
Root password: domoticz
mysql -u root -p
Create user:
GRANT ALL PRIVILEGES ON *.* TO 'domotica'@'localhost' IDENTIFIED BY 'domotica';
Create db
CREATE DATABASE domotica;
Restore database
mysql -u domotica -p domotica < Create-Update SQL Database.txt
Install phpmyadmin
apt-get install phpmyadmin
Domoticz
Copy config.php to \var\www\
Copy all scripts to the correct location \var\www\html\
Adjust the _fetchdomoticz.php script:
require '/var/www/config.php';
require 'functions.php';
$domoticzurl='http://127.0.0.1:8080';
Set the correct rights in the log files
Chown www-data:www-data /var/log/domoticz.txt for example
Browse to the _fecthcomoticz.php script and look in the db if the idx is added
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
gimic wrote: Saturday 13 April 2019 13:28 Installation on debian stretch:
New version 04/2019
Tnx @gimic
It is installing however i received some key warnings.
pi@domoticz-pi:~ $ sudo apt update
Get:1 http://repo.mysql.com/apt/debian stretch InRelease [19.2 kB]
Hit:3 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:4 http://archive.raspberrypi.org/debian stretch InRelease
Err:1 http://repo.mysql.com/apt/debian stretch InRelease
  The following signatures were invalid: EXPKEYSIG 8C718D3B5072E1F5 MySQL Release Engineering <[email protected]>
Get:2 https://dl.ubnt.com/unifi/debian stable InRelease [3,024 B]
Reading package lists... Done
W: GPG error: http://repo.mysql.com/apt/debian stretch InRelease: The following signatures were invalid: EXPKEYSIG 8C718D3B5072E1F5 MySQL Release Engineering <[email protected]>
E: The repository 'http://repo.mysql.com/apt/debian stretch InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
gimic
Re: Pass2PHP
Post by gimic »
I am not working on pi, i am on thin cliënt with debian stretch on it. I'l look at it tonight if i missed any commands between, but dont think so.
gimic
Re: Pass2PHP
Post by gimic »
i did not do any other commands, did not get errors either
google mysql raspberry pi and you will find a howto, its bascially only apt-get install mysql
the commands for the db should be the same.
sincze
Re: Pass2PHP
Post by sincze »
gimic wrote: Saturday 13 April 2019 19:55 i did not do any other commands, did not get errors either
I guess it has something to do with:
https://dbahire.com/how-to-install-mysq ... n-stretch/
MariaDB is also installed on the Pi.... for my Unifi stuff.
Seems a bit tricky to have them both installed according to the article.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
Mariadb is the same as mysql, isn't it?
I even think mariadb is the default mysql server in debian 9.
Anyway, I'm running mariadb so it shouldn't be a problem.
Edit: It is: https://mariadb.com/resources/blog/mari ... -debian-9/
sincze
Re: Pass2PHP
Post by sincze »
Let me just try to use mariadb and create an extra dB for pass2php
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
gimic
Re: Pass2PHP
Post by gimic »
Indeed my DB is also Mariadb
sincze
Re: Pass2PHP
Post by sincze »
I'm back in the game.. reverted.... and started over using:
https://r00t4bl3.com/post/how-to-instal ... spberry-pi
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install mysql-server
sudo mysql_secure_installation
pi@domoticz-pi:~ $ mysql -u root -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 13
Server version: 10.1.37-MariaDB-0+deb9u1 Raspbian 9.0
Copyright (c) 2000, 2018, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]>
That post contained the answer to my issue:
Enter password:
ERROR 1698 (28000): Access denied for user 'root'@'localhost'
Let's continue. ;)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
As I am working on the WAF approved a.k.a. live system ;-) I have to be careful.
For the installation wiki on RASPBERRY with MARIA DB.. in addition to the installation manual.
Importing the Database, first exit MYSQL
mysql -u domotica -p domotica < 'Create-Update SQL Database.txt'
Check if Database was created
mysql -u root -p
MariaDB [(none)]> show databases;
| Database           |
| domotica           |
| information_schema |
| mysql              |
| performance_schema |
4 rows in set (0.00 sec)
I addded the store($device,$status) function to my existing Pass2PHP and it is filling the database :lol:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
Is it correct that I am missing the IDX value ??
mising idx.JPG (26.28 KiB) Viewed 9168 times
Haha Can be solved with _fetchdomoticz.php
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
function rgb($name,$hue,$level,$check=false)
    global $user,$d,$domoticzurl;
    lg(' (RGB) | '.$user.' =>	'.$name.'	'.$level);
    if ($d[$name]['i']>0) {
        if ($check==false) {
            file_get_contents($domoticzurl.'/json.htm?type=command&param=setcolbrightnessvalue&idx='.$d[$name]['i'].'&hue='.$hue.'&brightness='.$level.'&iswhite=false');
        } else {
            if ($d[$name]['s']!=$$level) {
    } else {
        store($name, $level);
@Egregius: Is the $$level) Correct double $$ ??
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
For some reason, sometimes my lights don't receive a status.. messing the whole system up.
No Status.JPG (15.65 KiB) Viewed 9149 times
I modified the status function a bit so that I can still use the existing rules without having to rewrite everything. :lol:
function status($name)
    global $d;
//    lg('Status requested for: '.$name.' with status: '.$d[$name]['s']);
    $status = $d[$name]['s'];
    if ($status === '100') return 'On';
    elseif ($status === '0') return 'Off';
    elseif (empty($status)) return 'Empty';             // Sometimes no status.... strange..
    else return $d[$name]['s'];
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
You could add some logging in pass2php when the status is empty to figure out why this is happening.
sincze
Re: Pass2PHP
Post by sincze »
Egregius wrote: Tuesday 16 April 2019 11:55 You could add some logging in pass2php when the status is empty to figure out why this is happening.
It has something to do with:
function yeelight($name,$command,$info='')
{    //Available commands: nightlight, fulllight, warmer, cooler, brightnessup, brightnessdown
    $idx=idx($name);
    if($idx>0)
    	$comment='(Pass2PHP Yeelight | '.$name.' => '.$command.' => '.$info;
	lg($comment);
        sl($name,100); // Switch light on first. Ater that apply the mood command.
        curl(domoticz.'json.htm?type=command&param='.$command.'&idx='.$idx);
mmm Parsing one of the available scenes results in empty value in DB.
yeelight('Lamp LED Study Left',100,'Nightlight');
Does work. And value in DB
yeelight('Lamp LED Study Left','nightlight','Nightlight');
Does not work. And NO value in DB.
Drilling down further.. adding a log in pass2php.php
2019-04-16 14:26:09.537 Status: --->> Starting with: Lamp LED Study Left Received status is: Set Level !
I looked at a different light and domoticz reports the state as follows:
No Status2.JPG (11.69 KiB) Viewed 9141 times
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
For easy migration still tons and tons of code to review.. I modified the Pass2php legacy cset and cget functions so that I can store the values I want in 'cache' in the DB as well. I think this is correct. cache=='mysql
function cset($key,$value){
    global $d;
	if(cache=='apcu'){
		apcu_store($key,$value);
	}elseif(cache=='apc'){
		apc_store($key,$value);
	}elseif(cache=='memcached'){
		if(!$m=xsMemcached::Connect('127.0.0.1',11211)){return;}$m->Set($key,$value);
	}elseif(cache=='mysql'){
        storemode($key, $value,true);
function cget($key){
    global $d;
	if(cache=='apcu'){
		return apcu_fetch($key);
		return apc_fetch($key);
		if(!$m=xsMemcached::Connect('127.0.0.1',11211)){return 0;}return $m->Get($key);
        return $d[$key]['m'];
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
I don’t have rgb stuff...
But I’m sure you’ll figure it out ;)
sincze
Re: Pass2PHP
Post by sincze »
Egregius wrote: Tuesday 16 April 2019 18:58 I don’t have rgb stuff...
Got it. Will show fix tomorrow :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
Issue was previously seen here: https://www.domoticz.com/forum/viewtopi ... hp#p135033
As not all devices will provide a "Set Level: 35%" but just "Set Level". I think it is a Domoticz device bug. "Set Level: 35%" will work with default Pass2PHP, "Set Level" definitely not. To Solve it Pass2PHP.php needs a little modification. :lol:
if(in_array($device,array('Lamp (Kastenkamer) (RF)','Lamp (CV Ruimte) (RF)','Lamp (Keukentafel)','Lamp (Keukentafel) (RF)','Lamp (Bank)','Lamp (Bank) (RF)',
							  'Lamp LED TV','Lamp LED Vensterbank','Lamp LED Tafel (Woonkamer)','Lamp LED Trap','Lamp LED Hal','Lamp LED Keukenkast',
							  'Xiaomi RGB Gateway','Xiaomi RGB Gateway (Keuken)','Lamp LED Study Left','Lamp LED Study Right','Lamp (Kastenkamer) (RF)' ))) {
		if($status=='Off'){
			store($device, 0);												// 14-04-2019 Pass2PHP 3.0 If one of the above items (dimmers is updated store different values)
		}elseif($status=='On'){
			store($device, 100);											// 14-04-2019 Pass2PHP 3.0 If one of the above items (dimmers is updated store different values)
		}elseif( $status==='Set Level' || $status==='Set Color' || empty($status) ) {
		 	store($device, nvalue($device,'Level'));						// 14-04-2019 Pass2PHP 3.0 If one of the above items (dimmers is updated store different values)
		}else{
			$status=filter_var($status,FILTER_SANITIZE_NUMBER_INT);
			store($device,$status);											// 14-04-2019 Pass2PHP 3.0 If one of the above items (dimmers is updated store different values, dimmer value)
	else {
			store($device,$status);											// 14-04-2019 Pass2PHP 3.0 If not one of the above items (dimmers is updated store different values)
	//lgsql('Domoticz',$device,$status);
	@include rootdir.'pass2php/'.$device.'.php';
	//lg('Pass2php: Called '.$device.' = Received "'.$status.'" status');
Within functions I created an additional function nvalue() to retrieve the missing info from the DB.
function nvalue($name,$nvalue)				// Added: 06-11-2018
    $idx=idx($name);
    $json_string=curl(domoticz.'json.htm?type=devices&rid='.$idx);          // retrieve current level
    $parsed_json = json_decode($json_string, true);
    $parsed_json = $parsed_json['result'][0];
    if(array_key_exists($nvalue, $parsed_json)) {
    $value=$parsed_json[$nvalue];
    else $value='NA';
    return $value;
The patient... a.k.a. the House is running fine for over 12 hours now and no WAF complaints.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
