HansieNL wrote: Sunday 27 September 2020 21:48
@herbod
Thank you! it is working again. I have sett ['garbage_use_cors_prefix'] to true but wat does it do? I am trying to understand what i did. Answer: You can find a description here: https://dashticz.readthedocs.io/en/mast ... cors-proxy
What is the option "calendar_parse_locally" - This is an old setting and not used anymore.
So I can remove it? Answer: Yes
The days are mentioned in English, can I get them in Dutch?
I have : var config = {}
config['language'] = 'nl_NL';
So I expected them to be in dutch. Answer: try adding
Thanks!! Sometimes it can be so simple. Was looking for this for a while.
Can I change the date 06-10-2020 in the garbage collector dinsdag (tuesday) 06-10-2020, so adding the day?
As far as I know is this not possible.
If the garbage pickup is within a week/day, the date will be changed to the weekday, tomorrow. If it’s today, today will be shown.
The recycleapp website is working again after being down for some days. However the dashticz garbage doesn't get any data on 3.6.0 and 3.6.2 beta.
Probably the API that's still down...
sammyke007 wrote:The recycleapp website is working again after being down for some days. However the dashticz garbage doesn't get any data on 3.6.0 and 3.6.2 beta.
No, it was my mistake. I filtered the data until September. I'll create a fix tomorrow.
sammyke007 wrote: Wednesday 30 September 2020 22:48
Just updated to 3.6.5 beta, the garbage doesn't work with recycleapp (BE), looking (very) quickly in garbage.js I could not find any url to fetch the data, is this a known issue ?
when I checked the previous posts I found a ['default_cors_url'] setting set to 1.
I thought that might have been the problem so I removed it.
This morning, checking the config line by line again, I did indeed find another instance of ['default_cors_url'] which was set to 0
Garbage collection working as expected now, thanks!
Is it possible to make a custom block of the Garbage output.
Now the only way is to are the line to the columns, but not configure it as a block.
I like to reduce the width to 6 instead of the stand 12 (complete width of the column)
I'm rewriting the garbage module at the moment. It will then just behave like any other custom block. I'll also use it for auto testing as well. Currently I'm more or less half way testing all the garbage providers. See below for an intermediate result:
As soon as I've finalized the conversion, I'll add afvalstoffendienstkalender.nl
smaus wrote: Tuesday 03 November 2020 19:55
since a month I no longer receive a notification about residual waste, and I get the following notification in my log.
@AFOpzet Error: Waste type not defined in the "waste type_cfg" table for found Waste type: Residual waste.
concerns the city of Purmerend
I don't recognize your log. Is it related to Dashticz?
Support for purmerend garbage collection has been added to latest beta.
Previsously I used this module with a custom 'ical' calender. After the recent update, I now get an "Error loading garbage data" on start-up. Would love to use the new block method. But can you add support for Grondstoffen- en Afvalstoffendienst regio Gooi en Vechtstreek (https://inzamelkalender.gad.nl)?
