Ok, don't know what I was thinking but my "better" solution what bullshit. Can you try the newest version (0.3.2)?
ELV Max! Heating control system
mvzut
Re: ELV Max! Heating control system
demon1977
Excellent! Error gone missing. But ... The valve was added (2 rooms), the sensors of the windows were added (2 rooms), thermostat, temperature, mode is only one room.
- Spoiler: show
Last edited by demon1977 on Saturday 29 September 2018 16:42, edited 2 times in total.
demon1977
Excellent !!! I deleted everything, after which everything was added. Great work! Thank you!
sakekl
Pressing the buttons on the valve to switch from manual to automatic mode always get the temperature that was previously personalized in the plan of the day.mvzut wrote: Saturday 29 September 2018 15:50 About the manual and automatic modes: isn't this the expected behavior? Don't the setpoints only change at the programmed times? Or does it immediately change to the temperature programmed for that time block when you set it to Auto on the thermostat itself? What if you wait 5 minutes, is the setpoint updated then?
For example, if the temperature in the day schedule is 21 degrees and we change it to a higher one and come to the manual mode and we will be back to automatic mode, we will have a temperature of 21 degrees
However, when using the selector at domotic, the temperature stays the same as set earlier and does not change to the temperature from the schedule, ie 21 degrees.
It seems to me that correct behavior after pressing the auto button on the selector should result in setting the valve in automatic mode at a temperature compatible with the day's schedule, ie 21 degrees.
mvzut
I have uploaded a new version (0.4.0) to Github, this one should always recreate all missing devices.
Note that if you don't need/want a certain device, it makes no sense deleting it, since it will be recreated anyway the next time you start the plugin. If you don't want to see it, just remove it from the used devices via the Devices page (blue button with white <- arrow behind the device). If you don't want Mode switches, don't select this option in the plugin.
Would be great if some of you can test this one too (don't throw away the old one so that you can always go back to the previous version
mvzut
I have created a dedicated topic for the plugin, as this topic is already very long & old, and was started when we were still using Maxbuddy etc. to control our Cubes. You can find the new topic here:
viewtopic.php?f=34&t=25081&p=192854#p192854
I suggest that we continue the discussions about the plugin there, and keep this topic open for people who are still using the other (e.g. php or Lua) methods.
I hope our moderators are ok with this.
nono212
- Domoticz version: 3.6179
Can you write us the git pull comand ... I am unable to make the update
mvzut
Hi,nono212 wrote: Sunday 30 September 2018 16:51 Can you write us the git pull comand ... I am unable to make the update
I have no idea how to do this, I have no experience with Github and how to use pull requests etc. I have been trying to find an explanation on the web, but I get stuck when I have to choose what to compare with the master in order to make a pull request.
Can't you just download a new clone? It's only one file (plugin.py) that is changing every time. Or if you explain me the procedure in Github, I'll be more than happy to follow your instructions.
nono212
In fact I did a git pull but it did not work ...
But now I follow your advise I moved the max cube directory and did another git clone
mvzut
I'm not what you did, but if you usenono212 wrote: Sunday 30 September 2018 20:52 In fact I did a git pull but it did not work ...
git reset --hard
git pull
michass
- Domoticz version: 4.10064
Great work!mvzut wrote: Thursday 27 September 2018 23:04 Hi all,
Finally I had some time to dive into the new Python plugin system. It was a steep learning curve, since I had no prior Python experience, but I think I succeeded, mostly... So here is my ELV/eQ-3 MAX! Python plugin for Domoticz!
https://github.com/mvzut/maxcube-Domoticz-plugin
Synology NAS
Heating: eq-3 MAX!
Vent: by Sonoff POW R2 & Espeasy
Cam: Foscam C1
Heating: eq-3 MAX!
Cam: Foscam C1
Umberto
Just to add my piece to the MAX scripting. I used the many lua scripts I have found on the forum to enhance it a bit (at least in my opinion) and wanted it to share it with you all.
What the script does:
- test if the MAX hardware is available in domoticz, if not: auto create it
- test if the devices are available in domoticz, if not: auto create it.
- it tests whether the Domoticz value is more recent than the intervall time of the script: if so, change domoticz or else change MAX. This is done for Mode and Setpoint seperately.
- you can enable / disable all logging in the script by setting the appropriate variable to 1 or 0 in the first part of the script
The devices are created with:
- ' ' (spaces) replaced by '_' (underscores) since I noticed that spaces in a name are mostly leading to problems;
- names are extended with 'ActTemp' for the Actual Temperature of the device, Mode for the mode, Battery for Battery and Setpoint for Setpoint. Off course all devices are auto created using the appropriate dummy device in Domoticz.
What I still need (maybe someone could help or give me a clue):
- auto change the level names of the battery and the mode switch
- check whether the communication with the cube is valid
How to install:
- follow het install instructions for the MAX lua script on the Wiki page
- open crontab ('crontab -e') and insert a line with the interval you like (I prefer 5 minutes, since the cube gets instable if it runs to often)
- the script as attachement to this post: it's named maxcon.txt, please rename to maxcron.lua
Open issues:
- sometimes the mode of the MAXCube is changed, but I have no clue why (happens so rarely that I haven't been able to catch the error, but it is somewhere hidden in the script.
- maybe some further code cleanup
- check if the calculated temperatures are valid in the Max communication part in the script (did some small changes which improved the script, but still not completely happy with it)
Bonus:
- you can use the framework in the script to make your own dummy devices and update them easily. It uses JSON to create lots of dummy devices and hold the possibility to update most of them (didn't fully test or complete them, so feel free...
Credits: to all the contributors to the wiki and all the previous posts related to MAX and Lua
Best regards, Umberto
How to install:
Open issues:
Bonus:
- maxcron.txt
- maxcron script
- (26.49 KiB) Downloaded 136 times
mvzut
Wow, you took the Lua script quite a bit further than any of us ever have, impressive work! You found a good way to circumvent the DID device create&update method which doesn't work anymore for a while. I was planning to do something similar myself for a long time, but in the end I decided to spend that time on a Python plugin, of which you have probably seen the result. Turned out to be less work than I thought, I found a good Max API and the plugin architecture makes certain tasks much easier compared to (external) Lua.Umberto wrote: Saturday 06 October 2018 9:11 Hi all,
Anyway, very good that there is an improved (external) Lua version available now. Because that's the beauty of Domoticz: there is always more than one way to achieve something!
Umberto
Thx for your feedback. I noticed that the script had some issues lately, therefor I decided to rewrite quite a bit (including sharing the functions which easily create and update a domoticz sensor just based on it's name, thought that would be interesting for someone).
However: I need some help!!
As mentioned: I would like to change the names of the levels I use for the mode and battery switch (can then be reused in the framework). Is there anyway that I can change the level names via JSON (have been searching some time now, couldn't find it). So: PLEASE HELP NEEDED.
mvzut
Short answer: this is easy in the Python plugin system. But that's not what you wanted to hear I guessUmberto wrote: Saturday 06 October 2018 15:11 Thx for your feedback. I noticed that the script had some issues lately, therefor I decided to rewrite quite a bit (including sharing the functions which easily create and update a domoticz sensor just based on it's name, thought that would be interesting for someone).
As mentioned: I would like to change the names of the levels I use for the mode and battery switch (can then be reused in the framework). Is there anyway that I can change the level names via JSON (have been searching some time now, couldn't find it). So: PLEASE HELP NEEDED.![]()
Ok, I dived into it a bit. The trick is to perform the action of renaming the levels of your selector switch from a Chrome browser, with Developer tools on, and look at the JSON command that appears when you click "save" . After all, the web interface does noting else than send JSON commands to Domoticz when you change settings!
I did a test, and the following command changes the level names to "Auto", "Manual", " Vacation" and "Boost" (I guess that's what you were trying to do right?).
http://x.x.x.x:8080/json.htm?addjvalue=0&addjvalue2=0&customimage=0&description=&idx=915&name=Test&options=TGV2ZWxOYW1lczpBdXRvfE1hbnVhbHxWYWNhdGlvbnxCb29zdDtMZXZlbEFjdGlvbnM6fHx8O1NlbGVjdG9yU3R5bGU6MDtMZXZlbE9mZkhpZGRlbjpmYWxzZQ%3D%3D&protected=false&strparam1=&strparam2=&switchtype=18&type=setused&used=trueCode: Select all
LevelNames:Auto|Manual|Vacation|Boost;LevelActions:|||;SelectorStyle:0;LevelOffHidden:falseHope this helps!
Umberto
Hi mvzut,
That's what I'm looking for. Thx. Will incorporate it into the lua part somewhere in the next days.
One question: how to encode texts myself? I also want to change the battery level names and have some other scripts that work similar. (if anyone interested: I have a Itho control system build which regulates the humidity of my bathroom.)
Thx in advance.
Thx in advance.
mvzut
There are two ways to do this:Umberto wrote: Saturday 06 October 2018 16:21 Hi mvzut,
Thx in advance.
- Use an online encoder, such as https://www.base64encode.org
- Do it in your script, you already included the library for it (basexx). I think the command is something like "encoded_text = Basexx.to_base64(text)". For more info see https://github.com/aiq/basexx
Umberto
Thx. As one once said 'I'll be back'.
Umberto
As mentioned: I'll be back.
In the attachement the newest version of the LUA script. Thanks to mvzut I was able to add the names of the different modes ('Manual', 'Automatic', 'Vacation' and 'Boost') as well as the Battery ('Bat NOK' and 'Bat OK').
Just to add: I don't have a MAX switch, so I wasn't able to test it.
Enjoy.
There is an enhancement to be made (still): the script retrieves very often the complete devices list (at least: depending on the number of MAX items one has). I'm thinking of rebuilding that part and reducing the number of retrievals to a minimum (1?). But... that's for a later moment.
Enjoy.
- maxcron.txt
- (29.6 KiB) Downloaded 114 times
Hi I have some problem with script.
I had configure all component eq-3 MAX! in my home by official app.
I bought Rasperry Pi 3 B+ and installed Domotowicz.
Now I put your script into /home/pi/domoticz/scripts/lua/maxscript.lua, change all variables for my and first I try run manually without cron to check working.
And I got some error:
I try debug this code but I only start learn this languages.
I have one more question, I found one place where id url with hard IP without use top variables:
192.168.1.21 this IP is correct ? I think should be my IP domoticz this same which is write in top variables ?
pi@RasberryPi:~/domoticz/scripts/lua $ lua maxscript.lua
10/22/18 09:54:20 MAX! Script started...
lua: maxscript.lua:127: bad argument #1 to 'pairs' (table expected, got nil)
stack traceback:
[C]: in function 'pairs'
maxscript.lua:127: in function 'get_ID'
maxscript.lua:713: in main chunk
[C]: in ?
http.request('http://192.168.1.21:'..DomoticzPort..'/json.htm?type=command¶m=addhardware&htype=15&port=1&name=MAX!&enabled=true')
