Page 36 of 49
Re: Dashticz - Module - Garbage collector
Posted: Sunday 20 September 2020 16:54
by HansieNL
1st try without garbage settings and see if it works. You can later add the mappings and renaming parts.
You can change config['garbage_use_names'] = false to disable mappings
Posted: Sunday 20 September 2020 17:57
by martin82
ok it works now without the garbage settings.
now put in the right config garbage settings?
can you help me with the right ones?
Posted: Sunday 20 September 2020 19:19
by HansieNL
- Spoiler: show
martin82 wrote: Sunday 20 September 2020 17:57
Can you try with the following config settings (and enable garbage_use_names):
config['garbage_mapping'] = {
rest: ['sortibak'],
gft: ['biobak'],
papier: ['papier', 'karton'],
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
Posted: Sunday 20 September 2020 20:05
by martin82
it is working but only now i can not read the text, i need a another color now.
can i change that?
Posted: Sunday 20 September 2020 20:55
by HansieNL
martin82 wrote: Sunday 20 September 2020 20:05
can i change that?
You have to change the code #x123abc in the config['garbage'] to an other hex color code. For hex color codes there are a lot of websites with examples.
Posted: Monday 21 September 2020 20:36
by martin82
thnx a lot for the help
Posted: Thursday 24 September 2020 12:22
by EdwinK
Since today (at least I noticed it today) the garbage info isn't displayed anymore.
This is what the console tells me:
js/garbage.js:139 Uncaught TypeError: Cannot read property 'UniqueId' of undefined
at Object.success (js/garbage.js:139)
at fire (bundle.js?t=5:305)
at Object.fireWith [as resolveWith] (bundle.js?t=5:305)
at done (bundle.js?t=5:305)
at XMLHttpRequest.<anonymous> (bundle.js?t=5:305)
Posted: Thursday 24 September 2020 17:30
by Lokonli
EdwinK wrote: Thursday 24 September 2020 12:22
Can you send me your zipcode, housenumber and garbage provider? (You can do it by PM)
Then I'll check.
Posted: Thursday 24 September 2020 17:40
by Lokonli
I guess you are using bar-afvalbeheer. Their site (
https://www.bar-afvalbeheer.nl/afvalkalender) seems to provide no calendar data at all at the moment. Do you maybe have a working url?
Posted: Thursday 24 September 2020 20:50
by EdwinK
Your guess was correct
, but no, I don't have a working url. When enter my zipcode and housenumber, I get a calendar. In developertools it shows this:
Refused to load the script 'data:application/javascript;base64,KGZ1bmN0aW9uKCkgewoJLy8gaHR0cHM6Ly9kZXZlbG9wZXJzLmdvb2dsZS5jb20vYW5hbHl0aWNzL2Rldmd1aWRlcy9jb2xsZWN0aW9uL2FuYWx5dGljc2pzLwoJdmFyIG5vb3BmbiA9IGZ1bmN0aW9uKCkgewoJCTsKCX07Cgl2YXIgbm9vcG51bGxmbiA9IGZ1bmN0aW9uKCkgewoJCXJldHVybiBudWxsOwoJfTsKCS8vCgl2YXIgVHJhY2tlciA9IGZ1bmN0aW9uKCkgewoJCTsKCX07Cgl2YXIgcCA9IFRyYWNrZXIucHJvdG90eXBlOwoJcC5nZXQgPSBub29wZm47CglwLnNldCA9IG5vb3BmbjsKCXAuc2VuZCA9IG5vb3BmbjsKCS8vCgl2YXIgdyA9IHdpbmRvdywKCQlnYU5hbWUgPSB3Lkdvb2dsZUFuYWx5dGljc09iamVjdCB8fCAn...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' because it violates the following Content Security Policy directive: "script-src * 'unsafe-inline' 'unsafe-eval'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
I hope they will fix it soon.
Posted: Saturday 26 September 2020 21:51
by herbod
My garbage collector has stopped working. It only mentions loading. I have no idea why.
Someone who has an idea how to get it working again?
See attachments for more info.
Posted: Sunday 27 September 2020 0:00
by Lokonli
herbod wrote: Saturday 26 September 2020 21:51
Did you already try Dashticz 3.6?
Afvalwijzer changed it's interface a few weeks ago. A fix has been implemented already.
If it's not working, please send me your zipcode and housenumber (you can do that by PM) and I'll test.
Posted: Sunday 27 September 2020 7:36
by herbod
Thanks for the tip. I have updated to 3.6 but the problem remains.
My zip is **** and housenumber *** (unfortunatly I can''t send PM)
Posted: Sunday 27 September 2020 10:16
by madpatrick
What is the option "calendar_parse_locally"
i don't have this in my config.
Maybe this is something to look at
Posted: Sunday 27 September 2020 10:40
by Lokonli
herbod wrote: Sunday 27 September 2020 7:36
My zip is 7004LA and housenumber 133 (unfortunatly I can''t send PM)
You have to remove the setting config['garbage_use_cors_prefix'] or set it to true.
You also must have PHP enabled.
Garbage for your address is working on my system.
Posted: Sunday 27 September 2020 11:31
by HansieNL
madpatrick wrote: Sunday 27 September 2020 10:16
This is an old setting and not used anymore.
Posted: Sunday 27 September 2020 18:08
by EdwinK
bar_afvalbeheer seems to be working again.
Posted: Sunday 27 September 2020 20:26
by herbod
Thank you! it is working again. I have sett ['garbage_use_cors_prefix'] to true but wat does it do? I am trying to understand what i did.
What is the option "calendar_parse_locally" - This is an old setting and not used anymore.
So I can remove it?
The days are mentioned in English, can I get them in Dutch?
I have : var config = {}
config['language'] = 'nl_NL';
So I expected them to be in dutch.
Thanks again!
Lokonli wrote: Sunday 27 September 2020 10:40
Posted: Sunday 27 September 2020 21:48
by HansieNL
@herbod
Answer: You can find a description here:
https://dashticz.readthedocs.io/en/mast ... cors-proxy
So I can remove it?
Answer: Yes
Answer: try adding
config['calendarlanguage'] = 'nl_NL';
to your config.js
Posted: Sunday 27 September 2020 22:16
by herbod
HansieNL wrote: Sunday 27 September 2020 21:48
@herbod
So I can remove it?
Answer: Yes
Answer: try adding
to your config.js
Thanks!! Sometimes it can be so simple. Was looking for this for a while.
Can I change the date 06-10-2020 in the garbage collector dinsdag (tuesday) 06-10-2020, so adding the day?
