Page 35 of 120
Re: Domoticz app 2.0
Posted: Tuesday 09 February 2016 15:57
by Jango
Nice but any clue why it doesn't work?
Posted: Wednesday 10 February 2016 16:11
by RoadXY
[edit]
Double post
by RoadXY
Jango wrote:Week graphs for temperature are not working. Please could you improve readability for the graphs. Is that on the todo list?
V 0.1.230
Yes.
Posted: Wednesday 10 February 2016 16:12
by RoadXY
Jango wrote:Magnetic open / close relays now showed as switches with on/off function selection. This is not necessary for these types.
V 0.1.230
Could I get read only access to your server to test?
Send me an PM if so.
Posted: Wednesday 10 February 2016 16:18
by RoadXY
[edit]
Double post
Posted: Wednesday 10 February 2016 16:21
by RoadXY
bvduijv wrote:Temp Setpoint still not working in version 0.1.23. 3 screenshots below. First at opening the app. Second is after hitting 'set' en de third is after hitting the '+'. So the temp is initially set on 17, after hitting set it shows 16.5 instead of the 17 it was initially on. and after +0.5 the temp is suddenly 17.5.
Can you please have a look at it?
Yes, it's a known issue.
We are working on it.
Posted: Thursday 11 February 2016 10:35
by LouiS22
Guys, the built in server updater seems not working. It downloads the update, install is fine, but after opening the web interface, there's the popup about the very same update I installed from the app.
Posted: Thursday 11 February 2016 13:43
by RoadXY
LouiS22 wrote:Guys, the built in server updater seems not working. It downloads the update, install is fine, but after opening the web interface, there's the popup about the very same update I installed from the app.
Something changed in the code on the server, I'm still unable to figure out why server is rebooting but not updating.
That's why we added a switch to disable the update check.
Posted: Sunday 14 February 2016 10:38
by bitjeverkeerd
RoadXY wrote:bitjeverkeerd wrote:Great app. I have one small "bug" with my Somfy screens (RFXCOM). In the "schakelaars" tabpage you can see the actual status (open or closed) but in the Dashboard tabpage (and also the "Ruimtes" tabpage) the actual status of the screens is invisible.
You can show or hide this in settings
Even with "instellingen/extra gegevens op.." "AAN" it's still not visible if the screens are open or closed.
Posted: Sunday 14 February 2016 12:32
by RoadXY
Gotcha. Will create an issue for it.
Posted: Sunday 14 February 2016 17:02
by marktn
How to make a switch with on and off switch for a light switch.
Like switch lampen aan.
When my kaku does not respond it is not possible to give a extra light off function.
Verstuurd vanaf mijn SM-T800 met Tapatalk
Posted: Sunday 14 February 2016 19:36
by RoadXY
marktn wrote:Hello,
Sorry, we can't help you with that.
Re: RE: Re: Domoticz app 2.0
Posted: Sunday 14 February 2016 19:44
by marktn
RoadXY wrote:marktn wrote:Hello,
Is it possible in a feature version?
How is the switch "lampen aan" made?
send from tapatalk app.
Posted: Sunday 14 February 2016 19:52
by RoadXY
marktn wrote:Is it possible in a feature version?
Maybe if we get the request more.
Posted: Monday 15 February 2016 21:05
by bvduijv
Hi all, just downloaded the new beta and looked particular to the Setpoint functionality. Looks a lot better! But is not completely working as expected.. [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT] I have created a screencast of it. It looks like the *.5 temperatures are not working fine and the animation at low temperatures is not looking very nice (not smooth).
See below for the screencast. If I can do something to help you solve it, please let me know.
https://dl.dropbox.com/s/cfbzlxpv39ml7e ... _42_07.mp4
Posted: Monday 15 February 2016 23:03
by lucaskywalker
It's a great App!
I am new in domoticz, i have a problem to open and to close my blinds with the apps.
I use Mysensors , and message type is S_COVER.
When try to open or close blind the senssor receive a message to stop it.
regards
Posted: Monday 15 February 2016 23:21
by RoadXY
bvduijv wrote:Hi all, just downloaded the new beta and looked particular to the Setpoint functionality. Looks a lot better! But is not completely working as expected.. [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT] I have created a screencast of it. It looks like the *.5 temperatures are not working fine and the animation at low temperatures is not looking very nice (not smooth).
Thanks for the screen cast.
Yes, there is some rounding issue when the temp has half a degree.
Still searching and trying to figure out why this is.
Posted: Tuesday 16 February 2016 9:26
by galadril
We're doing great in Italy!
Can someone maybe translate the app to Italian? Or do you know someone that could do it?
https://crowdin.com/project/domoticz-for-android/it#
Posted: Tuesday 16 February 2016 10:16
by LouiS22
Hi folks,
With the latest beta, I've lost Humidity on Temperature tab, instead of that all of my Temp sensors have Setpoint. What's more strange: there are a few Favourite temp/hum sensors placed on Dashboard, they now have Temp and hum, dew point, another temp (with round values (for ex 21C)), and humidity with text format (for ex wet).
Posted: Wednesday 17 February 2016 11:13
by Scoobydoo
Had an issue with the app taking ages to load up last night. A good 20 seconds or so.
I noticed that the forum was down for a while last night too..is the app linked to.the forum.somehow? It seems like because the forum was off line then the app was timing out?
It's fine again this morning as the forum is back online.
Maybe this check could be removed so the app doesn't do this?
Apart from that it's a great app.
