Page 35 of 36
Re: Blockly examples
Posted: Thursday 04 March 2021 14:17
by waaren
rolandtwilt wrote: Thursday 04 March 2021 13:36 I understand what you mean and I have adjusted this. but unfortunately the script still doesn't work
Can you try this one (import code block in event editor and change device ID's to names)
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_ifelseif" id="2K$G[sT^I,Ke2-LU{3?)" x="-601" y="238"><mutation elseif="4"></mutation><value name="IF0"><block type="logic_operation" id="LY2J+I2odJz|@j][+jl]"><field name="OP">AND</field><value name="A"><block type="logic_operation" id="z?Bu3w(_1z+$Mw.-A0SA"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="N.kE,xqA9WyRg|8F*7($"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="(E77M$43KTQS-z(srWSB"><field name="Switch">3520</field></block></value><value name="B"><block type="logic_states" id="$QAI`r2|B7;bn}Hr2Rl$"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="v15X^ZWxN|+J;(5|+0@3"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="PwNlm:FVZSA;OA+aBCJ#"><field name="Switch">3519</field></block></value><value name="B"><block type="logic_states" id="|Rqic~2y|W2uOtHFKj6!"><field name="State">On</field></block></value></block></value></block></value><value name="B"><block type="logic_compare" id="?f4*5K?m3*zyTc}p;^q)"><field name="OP">EQ</field><value name="A"><block type="switchvariablesSZ" id="`cC6gAzkrn5K*ZM(,8q="><field name="Switch">3521</field></block></value><value name="B"><block type="logic_states" id="D,5p+m^3=M1SoU+2@h!P"><field name="State">Off</field></block></value></block></value></block></value><statement name="DO0"><block type="writetolog" id="+d`WM_3k][?eIoH${)%D"><value name="writeToLog"><block type="text" id="9aNd1tCXm]16oqs1-7:d"><field name="TEXT">All conditions true; switching schijnwerper on for 1 minute.</field></block></value><next><block type="logic_setdelayed" id="eIF^{X!royl~6}IDVY2J"><value name="A"><block type="switchvariablesSZ" id="sUz]k*wPQ`*V42qX-~f("><field name="Switch">3521</field></block></value><value name="B"><block type="logic_states" id="5y@ryJ9/)W}t0L?,_:;;"><field name="State">On</field></block></value><value name="C"><block type="math_number" id="mlQ?J]ixflRG=fDq7-D2"><field name="NUM">1</field></block></value></block></next></block></statement><value name="IF1"><block type="logic_operation" id=".`Os6DS@g$8FlCDmk6!="><field name="OP">AND</field><value name="A"><block type="logic_compare" id="2w]=))Kko6rb!Cx,@#;5"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id=",9%Cfm0w9nxitrGxei-*"><field name="Switch">3520</field></block></value><value name="B"><block type="logic_states" id="HsiM*`_xkRp*q-BJ]Jx{"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="3{Mgdhel1:gmxsOAiDKW"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="$0ps4Ct^I#Z3?hrqDQrQ"><field name="Switch">3519</field></block></value><value name="B"><block type="logic_states" id="^KS8]{x]Xz:NVd!@^886"><field name="State">On</field></block></value></block></value></block></value><statement name="DO1"><block type="writetolog" id="G{Tc`k`dv-;u#Pj0Z,Dj"><value name="writeToLog"><block type="text" id="+6}6UYulQvs^EIuO{MLB"><field name="TEXT">Motion and time conditions true; schijnwerper already on</field></block></value></block></statement><value name="IF2"><block type="logic_operation" id="J4`h0j^5RK;6$.6}?V:/"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="*`K7EgfkY#SIR)`ouFJ,"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="M?xlPdbjm*emj@IXO1]Q"><field name="Switch">3520</field></block></value><value name="B"><block type="logic_states" id="|IDu@Y5Ii|q.Z1NCe6P/"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="%nqLXAYjOP]YPuOE)E|C"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="]e,OQmGBw]nrjk/u{Xs#"><field name="Switch">3519</field></block></value><value name="B"><block type="logic_states" id="Bx+@rrgWQb$@!1TtpkmV"><field name="State">Off</field></block></value></block></value></block></value><statement name="DO2"><block type="writetolog" id="7)w(~BwIU1e?rvHLQ,5%"><value name="writeToLog"><block type="text" id="xS(V.F6e--:wpc:hQ~Nt"><field name="TEXT">Time condition true but no motion detected; no action needed</field></block></value></block></statement><value name="IF3"><block type="logic_operation" id="Kz,.$Ei|AGJ,?IO=;DZA"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="~MN.-Kw{%[eW[yal2Ep;"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="fzrHFIE:tHz:!oVDg,#="><field name="Switch">3520</field></block></value><value name="B"><block type="logic_states" id="ctTjnWT|T!_h82OV|aBF"><field name="State">Off</field></block></value></block></value><value name="B"><block type="logic_compare" id="AUwEB7[lzk#g@%=Q?93*"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="1p4mTA|~KK$a-7mX5yWV"><field name="Switch">3519</field></block></value><value name="B"><block type="logic_states" id="qXo/zDpZ=1}=TZ8N@1O#"><field name="State">On</field></block></value></block></value></block></value><statement name="DO3"><block type="writetolog" id="S~r1n]fbtM=u3Pm${;{X"><value name="writeToLog"><block type="text" id="S7dxLHC1R1e;MOa}qWxT"><field name="TEXT">Motion active but time condition false; no action needed</field></block></value></block></statement><value name="IF4"><block type="logic_operation" id="qXv68U}hr*UAj|}C*9DW"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="+g7AFJ2mm@E}aQy55aFm"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="cYW2HEDMIs{@GOnPL+;Q"><field name="Switch">3520</field></block></value><value name="B"><block type="logic_states" id="N|TF=h5JUW|,,6s3!O]~"><field name="State">Off</field></block></value></block></value><value name="B"><block type="logic_compare" id="n0pP+30R`*C{heM^t17!"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="jwMb2P4~a9NGQOV.a{!="><field name="Switch">3519</field></block></value><value name="B"><block type="logic_states" id="^-H]*]$~#@:7Q5?UFO^d"><field name="State">Off</field></block></value></block></value></block></value><statement name="DO4"><block type="writetolog" id="Z8Xu3c,Ow#XNQ^N8[z~4"><value name="writeToLog"><block type="text" id="-f?#)6TtNG~}p7bTo0~`"><field name="TEXT">All conditions false; no action needed</field></block></value></block></statement></block></xml>
Posted: Thursday 04 March 2021 18:51
by rolandtwilt
thanks i'm going to try
Posted: Friday 05 March 2021 10:29
by rolandtwilt
It functions! sometimes with quite a bit of delay, but it works. thanks!
Posted: Thursday 09 December 2021 11:51
by MikeyMan
Thought i had a simple idea to set the dim level dependent of time with blockly.
But somehow its not working as i thought.
I created this one:
However, this is not doing anything. I'm not even seeing something happening in the logs. What have i done wrong?
Posted: Thursday 09 December 2021 12:51
by Ron
This worked for me:
The "Nacht" (night) function was added just to turn the light on only during the day.
The "Sensor 2 beweging" is a Fibaro sensor which has to turn on the light on movement.
The code, you can import this in Blocky:
<xml xmlns="http://www.w3.org/1999/xhtml"><block type="domoticzcontrols_ifelseif" id="4s5jSAl2.Dmx*RK!{^V}" x="-659" y="-83"><mutation elseif="4"></mutation><value name="IF0"><block type="logic_operation" id="O8M4?(Tf;fa!a)Gk!^;/"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="/;U`^60P/)W-3z7:~Kq]"><field name="OP">EQ</field><value name="A"><block type="switchvariablesSZ" id="6L#iDdAS|^_E)0wNH%{7"><field name="Switch">10927</field></block></value><value name="B"><block type="logic_states" id="ng6$[Z]l(dQWO||uE)iE"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="t)r$et~iVtHljE`UQ$$p"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="wUMEI1wvSyn$VF]0*ZxO"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="I%WTcm][%!zZZO9nS4S["><field name="State">Off</field></block></value></block></value></block></value><statement name="DO0"><block type="logic_setdelayed" id="^int*+Uz^/tJBstgWrQJ"><value name="A"><block type="switchvariablesAF" id="wnX-$G%!afGTZiTwYACe"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="4?M14TEf(wAW/.2u]p)z"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="KXA!A61CCwXR:a]4D%Um"><field name="TEXT">5:00</field></block></value></block></statement><value name="IF1"><block type="logic_operation" id="I[C~8hQ{r;VTFHT@aP!="><field name="OP">AND</field><value name="A"><block type="logic_compare" id="1?KWn4J9;YH!8_|az#[Q"><field name="OP">EQ</field><value name="A"><block type="switchvariablesSZ" id="|OS|e4_.taDj.CZ~{m#T"><field name="Switch">10927</field></block></value><value name="B"><block type="logic_states" id="G54)la1^M|p0,v(Rw:Vl"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="Sn72v:!x_qqAjvj?`Dxz"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="VG5IZuqXW]d2`LS;lM)m"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="`wp[p[JV}KcP!f?j9xc5"><field name="State">On</field></block></value></block></value></block></value><statement name="DO1"><block type="logic_setdelayed" id="n:5SooS8mQ2:-NTSFl.^"><value name="A"><block type="switchvariablesAF" id="JU}18=NYVI5bGU4/9~2?"><field name="Switch">10948</field></block></value><value name="B"><block type="logic_states" id="%,(JfKv#7U/a4S6fa7#n"><field name="State">On</field></block></value><value name="C"><block type="logic_timevalue" id="TPS~9YcxY2eSY|U!ws,%"><field name="TEXT">3:00</field></block></value><next><block type="logic_set" id="PP#8q/[R/aNi4@WJu=@G"><value name="A"><block type="switchvariablesAF" id="/6fyk(}Cn0A]aqeS}8}W"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="m20dlaek!_+H_yEXY-@{"><field name="State">Off</field></block></value></block></next></block></statement><value name="IF2"><block type="logic_operation" id="*6squ60MES(U(?v_At%9"><field name="OP">AND</field><value name="A"><block type="logic_operation" id="t!WmAH91ij5[H%3~y?9_"><field name="OP">OR</field><value name="A"><block type="logic_compare" id="wAJrYECW%;=3w-8yL6B}"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="rLsqoQHUwRg|g46jR[X)"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="oW,(4i~_IeFwds|~n!/2"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="MwR^1!gB9[gOcU(ITXY@"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="6ck3wb+DY,75joF)_[;i"><field name="Switch">10948</field></block></value><value name="B"><block type="logic_states" id="A.*D!1{1ku`1E[BTLyKx"><field name="State">On</field></block></value></block></value></block></value><value name="B"><block type="logic_operation" id="%n.aqJ;_UK[GB_4{9168"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="OWv!|i6(-ZyCKDV-?![T"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="+*]f{-;-%2%`K:?4}L^E"><field name="Switch">70</field></block></value><value name="B"><block type="logic_states" id="qt5vV!cJuxRRwT[p9dkT"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="#B@_6:i+XFK?l$1cu/iZ"><field name="OP">EQ</field><value name="A"><block type="switchvariablesMR" id="Lz![Ck(gLCsl7Q58=FRX"><field name="Switch">71</field></block></value><value name="B"><block type="logic_states" id="xOmfnmPEy|JQ2;aPe$,i"><field name="State">Off</field></block></value></block></value></block></value></block></value><statement name="DO2"><block type="logic_set" id="^[5)Yc8EDRmM.9z.=@)9"><value name="A"><block type="switchvariablesAF" id="vY^RMsZyjb;/+6AeboDR"><field name="Switch">8541</field></block></value><value name="B"><block type="logic_setlevel" id="}P:c8qxIurV[I7pY}i+9"><field name="NUM">25</field></block></value><next><block type="writetolog" id="vK=x.{P{|C=_,,T/qmCX"><value name="writeToLog"><block type="text" id="E=s$wRssB!s4$;u}1i[O"><field name="TEXT">Badkamer verlichting aan 25%</field></block></value></block></next></block></statement><value name="IF3"><block type="logic_operation" id="E%actva}=weelpl1`t[]"><field name="OP">AND</field><value name="A"><block type="logic_operation" id="n:]Mzo{p68Q3;f5ZjGk~"><field name="OP">OR</field><value name="A"><block type="logic_compare" id="|FWOT#S/|)y;o@:@r5%6"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="=8Gu(!UOl/T6PQD,XGgr"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="OT_M|9wMVy3f+)`(jkSG"><field name="State">On</field></block></value></block></value><value name="B"><block type="logic_compare" id="NqXU/hvy3{(dIRkw;Ir:"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="mgMmkF11s2?_EyM1qvps"><field name="Switch">10948</field></block></value><value name="B"><block type="logic_states" id="m@dx!nR!~y~pl_|K/ga}"><field name="State">On</field></block></value></block></value></block></value><value name="B"><block type="logic_operation" id="B6-GG_vPWhGbu(~P[My:"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="43SrkeM3ES6@j7;0w]CD"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="$e-%CjQu26i~[~Mg1Z)a"><field name="Switch">70</field></block></value><value name="B"><block type="logic_states" id="e@[i#3.|E`4ABf`)Nzo:"><field name="State">Off</field></block></value></block></value><value name="B"><block type="logic_compare" id="]*JK4KDlp7({tfyWp=b{"><field name="OP">EQ</field><value name="A"><block type="switchvariablesMR" id="WqZeb7?-[{NA~f:HTf~s"><field name="Switch">71</field></block></value><value name="B"><block type="logic_states" id="H,~B+.q;E-^8p$P/WdjQ"><field name="State">Off</field></block></value></block></value></block></value></block></value><statement name="DO3"><block type="logic_set" id="/c9|d{aU?LFD0M(E[hS@"><value name="A"><block type="switchvariablesAF" id="fF:hI8b3C/.Z37Tb+IRY"><field name="Switch">8541</field></block></value><value name="B"><block type="logic_setlevel" id="XOIAv5^Dku;Hf-AY6(y-"><field name="NUM">45</field></block></value><next><block type="writetolog" id="Z{@~HbINzIEh%|?b8GJK"><value name="writeToLog"><block type="text" id="W$PO1F86GHJ8KHE4?om:"><field name="TEXT">Badkamer verlichting aan 45%</field></block></value></block></next></block></statement><value name="IF4"><block type="logic_operation" id="*_OLXjIDF+@s;%k7MrfF"><field name="OP">AND</field><value name="A"><block type="logic_compare" id="4tE-(OMu{L`I[Cb;aWhT"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="fG%.8rWE5m`9;qY`Dcf$"><field name="Switch">10949</field></block></value><value name="B"><block type="logic_states" id="|Jdma#c/1?2yfNgBS5rf"><field name="State">Off</field></block></value></block></value><value name="B"><block type="logic_compare" id="h%V/YpN/1=!^n%Ee:})E"><field name="OP">EQ</field><value name="A"><block type="switchvariablesAF" id="Vt|Sjj.j%#4H5arjwXSf"><field name="Switch">10948</field></block></value><value name="B"><block type="logic_states" id="07uv!QN~UG%h;/1@=l4!"><field name="State">Off</field></block></value></block></value></block></value><statement name="DO4"><block type="logic_set" id=":htCCR6pwq)`KpVKKc7R"><value name="A"><block type="switchvariablesAF" id="?xtFBXXy;2+c6pUUMu#K"><field name="Switch">8541</field></block></value><value name="B"><block type="logic_states" id="3W^.A6SM#Y;DAm/7=Pg)"><field name="State">Off</field></block></value><next><block type="writetolog" id="?=-;LfkuH,6{uj,;vYi."><value name="writeToLog"><block type="text" id="k)9%EjTW59y(*}|MFnhl"><field name="TEXT">Badkamer verlichting uit</field></block></value></block></next></block></statement></block></xml>
Posted: Thursday 09 December 2021 13:34
by Benneton
In the first if statement it should be or instead of and as this is not on the same day (at least that is how I have it).
Bernard
Posted: Thursday 09 December 2021 13:51
by MikeyMan
Tried it the other way around, and it sometimes works... However, not stable:
Posted: Thursday 09 December 2021 14:06
by Benneton
HI
Does the write to log function work? I tried this a while back to get some details on what is going on but nothing got written to log.
In my blocky's I always have the device = on (or off) then the time I want it to do a time specific thing.
Posted: Thursday 09 December 2021 14:09
by MikeyMan
Benneton wrote: Thursday 09 December 2021 14:06 HI
When I use a time triggered event it does. In the script above it doesn't though.
Posted: Thursday 09 December 2021 14:22
by Treve
I think te the problem could be the first time comparison “20:00 and 8:00” this passed midnight ’00:00’.
Posted: Thursday 09 December 2021 14:28
by MikeyMan
Treve wrote: Thursday 09 December 2021 14:22 I think te the problem could be the first time comparison “20:00 and 8:00” this passed midnight ’00:00’.
Tried an even simpler one:
No luck
Even this one is not working:
Posted: Thursday 09 December 2021 14:36
by Treve
The use in one ‘if-then’ of two same “badkamer” cause the problem.
If badkamer is on, then set badkamer 30% and switch badkamer to something else because is not on anymore.
Posted: Thursday 09 December 2021 14:40
by Benneton
To set different levels for different events I have created dummy switches which get turned on.
Posted: Thursday 09 December 2021 14:55
by MikeyMan
Somehow this only returns logging on the off switch.
Even though the switch is set:
2021-12-09 14:53:25.480 Status: User: Admin (IP: 10.0.0.32) initiated a switch command (211/Badkamer/Off)
2021-12-09 14:53:28.792 Status: User: Admin (IP: 10.0.0.32) initiated a switch command (211/Badkamer/On)
2021-12-09 14:53:34.267 Status: User: Admin (IP: 10.0.0.32) initiated a switch command (211/Badkamer/Off)
2021-12-09 14:54:09.548 Status: User: Admin (IP: 10.0.0.32) initiated a switch command (211/Badkamer/On)
2021-12-09 14:54:12.455 Status: User: Admin (IP: 10.0.0.32) initiated a switch command (211/Badkamer/Off)
2021-12-09 14:56:17.426 Status: User: Admin (IP: 10.0.0.32) initiated a switch command (211/Badkamer/On)
Same if i do it the other way around.
Somehow the "on" command doesnt trigger anything.
Posted: Thursday 09 December 2021 16:28
by rrozema
MikeyMan wrote: Thursday 09 December 2021 14:28
No luck
I shouldn't be answering this here, as this thread is meant to post examples, not discuss problems with one that doesn't work for you. So if you could move this discussion into a new thread that would be very welcome.
I don't know what exactly causes the behavior you're seeing, or how to fix it. But I do know that you are creating an endless loop here: For a dimmer everything above 0 is considered "On", so once you switch the badkamer light to anything but "Off", you're having Domoticz set the level to 30%, which is a command to switch the badkamer "On", which triggers your script, which ....
So I don't think this is the way to achieve what you want. Others have tried the same thing before and I don't think I've seen a solution that actually works, other than having two separate devices -one being a switch and the other the dimmer- then only have the switch controlled by the 'user' and have a script trigger control the dimmer based on the switches state. The problem is that once your script gets the trigger for the "On" state change, the light is already on; at whatever percentage the dimmer starts (usually the last brightness it was set to). The dimmer doesn't have separate level and state attirbutes, they both control the same property of the dimmer. This the nature of how z-wave dimmers are implemented. The only way I know to avoid that problem is to have a separate switch and you can set the dimmer to whichever level you like when the switch gets toggled like i described above.
Posted: Friday 10 December 2021 12:01
by MikeyMan
It's working!
Posted: Saturday 11 December 2021 16:18
by Treve
MikeyMan wrote:It's working!
What is the function of the Variable?
Posted: Saturday 11 December 2021 16:23
by MikeyMan
Treve wrote: Saturday 11 December 2021 16:18
Making sure it won't continuously trigger.
Allows to use the wall switch to dim.
Posted: Saturday 11 December 2021 16:29
by Treve
Ok, I didn’t noticed the unequal sign.
Posted: Monday 13 December 2021 0:43
by BennY
This is a Blockly i'm using for my lights.
You need two Dummy Switches: "Trigger" and "Delay".
In this case there is one Motion Sensor ("Bewegung"), two Door Contact ("Tür"), one bright light ("Beleuchtung") and one low light "Richtbeleuchtung".
The light ist switching on if a door is open or motion is detected, and stays on until no motion is detected and the delay is over.
It only send a Z-Wave Signal once to switch on the low light, to keep the network traffic low.
