I'm about to publish pass2php v3 in a couple of days
Pass2PHP
- Egregius
- Domoticz version: v2024.7
Re: Pass2PHP
I suggest you create a issue ticket at Github, or respond to one of the pass2php posts on my site. I don't come here very often any more.
Re: Pass2PHP
Excellent!
- sincze
- Domoticz version: 2024.4
Re: Pass2PHP
V3???? We need release notes hahahaha.
Can't wait.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Domoticz version: V3_8394
Re: Pass2PHP
I bought a new house and it needs to be renovated, i wanted to install again my zwave+ devices and this php script; but what should you guys do if you need to redo the electrical wiring in your house?
Again domoticz with this script? Or something else?
Wired domotica instead of what im using now zwave+ ?
Give me your opinion
- sincze
Re: Pass2PHP
I bought a new house and domoticz with zwave works perfectly fine and is affordable.
And... PHP gives me full control of everything.
I would add additional group-meters to read-out usage per group.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Domoticz version: 3.66
Re: Pass2PHP
i've build a new house and everything is wired and inpout/outputs are done with mysensors & Pass2PHP
the idea is to have the visualisation in the switches wireless, but i did not yet design the pcb for this...
Re: Pass2PHP
So how are the switches for the lights done then?
With a zwave relay between it?
And what about temperature sensors? Are they wired?
Because now i have some fibaro motion detectors(battery powered) and they have temperature sensor, but i need to replace every 3months the battery and i would have something wired, so no replacing batterys anymore.
Re: Pass2PHP
Switches are connected to arduino mega with mysensors gw standalone installed.
Outputs same way with relays and driver board between relay and arduino.
Temperature is done wit a xiaomi gateway. Every room has its battery powered temp sensor.
- sincze
Re: Pass2PHP
I agree with gimic. (Mysensors is great)
I also use (multiple) Xiaomi gateways with temp and motion sensors (xiaomi gateway as doorbell and night lamp
Also leakage sensor (1 created one 1 mysensors and uses Xiaomi as well)
Zigbee seems more energy battery friendly compared to zwave, But i have 2 motion sensors from zwave performing just fine without having to change the battery yet (NEO COOLCAM).
For switching I use ZWAVE wall sensors. Xiaomi does not have the ones that fitted here.
In addition ZWAVE power meters to read consumption of pretty much all heavy users
For around 16A devices I use the Sonoff POW R2 with ESPEASY
All humidity and central ventilation is handled by mysensors, I realized pretty much the same solution @ friends house with espeasy.
https://forum.mysensors.org/topic/7180/ ... te-systems
Combining several hardware techniques/styles/freqs makes me use the best cost efficient hardware, but still being able to control everything with Domoticz / Pass2PHP.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Re: Pass2PHP
@Sincze:
so the electrical wiring for the switches is still the standard way? so the 220V way but with a zwave switch installed behind it?
like for example https://www.robbshop.nl/inbouwschakelaa ... roommeting
i check a video of the Sonoff POW R2, where do you install it?
Is this installed after every automatic fuse in your electrical cabinet?
can you show some pictures?
for the temperature in every room, i better install a motion detection then?(has also temperature sensor) or a smoke detector?
- sincze
Re: Pass2PHP
This is the POW2 for the stove.
Sent from my ONEPLUS A6003 using Tapatalk
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Re: Pass2PHP
ZWave wall switching
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Re: Pass2PHP
Roller shutter behind plate.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Re: Pass2PHP
So, the Zwave wall switch is for the lightning?
What brand is this and where you ordered?
I order must of my Zwave devices from Robbshop, but i find them expensive.
So you don't have a seperate 'switch' to control the roller blinds manually? They are configured automatically?
Thanks mate.
I got too much to do in the new house and i would love to have feedback/information as much as possible
Thanks mate.
- sincze
Re: Pass2PHP
Wall switch are NEO Coolcam.(1 or 2 channel) blue brown and black wire required!!!
Around 20 euro I buy them on AliExpress.
Roller shutters are controlled automatically with Domoticz or with simple remote
(hardly used) hahaha.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Re: Pass2PHP
Created some new scripts that I use to read INVERTERS from my friends:
OMNIK: viewtopic.php?f=65&t=7941&hilit=SMA+inv ... 00#p210984
SMA: viewtopic.php?f=4&t=27557
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Re: Pass2PHP
Just searched for this device and it seems nice.sincze wrote: ↑Friday 05 April 2019 8:07 Wall switch are NEO Coolcam.(1 or 2 channel) blue brown and black wire required!!!
Roller shutters are controlled automatically with Domoticz or with simple remote(hardly used) hahaha.
But you can only use it when you have 1 switching point (nederlands: enkel als je een enkelpolige schakelaar hebt)
For example if you need a switching point for 2 places (nederlands: wisselschakelaar)
Is it also possible?
Re: Pass2PHP
I also don't know what do yet with my light switching :s
Do it the fibaro way, so again rewiring everything in my house (like the standard wiring i a house) with everywhere fibaro modules behind it
Or from every light switch point a cable to my eletrical cabinet (like plc style) and work with a plc?
What should you do?
What should you do?
- Egregius
Re: Pass2PHP
Published the new version on https://github.com/Egregius/PHP-Floorpl ... r-Domoticz
It's a combined repository for pass2php and php floorplan, because they're very much linked to each other.
From now on the repository is updated automagically
Of course, still lot's of work to do in the wiki. Feel free to be a contributor and help with that
