Page 35 of 86
Re: homebridge-edomoticz Plugin
Posted: Saturday 10 September 2016 13:11
by Marci
Posted: Saturday 10 September 2016 20:16
by deejc
Posted: Sunday 11 September 2016 2:13
by simon_rb
Well there you go! Lol. Might add to my collection lol, deejc, is the PIR working well? Marci, no worries mate - work comes first
what an interesting job
Posted: Sunday 11 September 2016 10:30
by fennec62
hi
i search a plugin to have a motion sensor on homebridge and have push alert with image
i find homebridge-filesensor but don't work
I have zoneminder so i can save a image on folder when i have a motion detection
in homekit is it posssible to send image ?
Thanks a lot
Posted: Monday 12 September 2016 15:07
by TheRamon
Alright guys, back again. Soz was away for a while, having my vacation and all
Any hot issues that need fixing?
I've seen that there's a LOT of work been done, nice one Marci! So nice.
Posted: Monday 12 September 2016 18:38
by Marci
fennec62 wrote:hi
Thanks a lot
Nope, not until iOs10 is released and KhaosT has sorted support for it in HAP-NodeJS & Homebridge, which won't happen til end of the year.
Posted: Monday 12 September 2016 21:24
by RduPre
I installed a fresh version of Domoticz and installed the HomeKit integration as described in the first post.
I just get an error "Illegal instruction"
pi@raspberrypi:/$ homebridge
Illegal instruction
pi@raspberrypi:/$
I saw some post on this error, but did not found a solution
Any help would be appreciated.
Posted: Monday 12 September 2016 21:28
by deejc
It's all been quiet lol you should have stayed on holiday
Posted: Monday 12 September 2016 21:45
by deejc
simon_rb wrote:deejc, is the PIR working well?
Not exactly lol, I set it up to send a prowl msg and email me if it goes off and the back door is closed, today in the sunshine I got 240 emails !!!
Posted: Monday 12 September 2016 22:09
by Marci
RduPre wrote:Hi,
Illegal instruction
pi@raspberrypi:/$
What happens when you run...
Posted: Monday 12 September 2016 22:51
by RduPre
Marci wrote:RduPre wrote:Hi,
Illegal instruction
pi@raspberrypi:/$
Same error..
Posted: Monday 12 September 2016 23:03
by Marci
Sounds like you haven't recompiled node for Arm6, using an Arm7 image...
What version Pi are you running on, with what version of Raspbian?
Posted: Tuesday 13 September 2016 7:33
by RduPre
Marci wrote:Sounds like you haven't recompiled node for Arm6, using an Arm7 image...
Linux raspberrypi 4.1.18+ #846 Thu Feb 25 14:11:56 GMT 2016 armv6l GNU/Linux
pi@raspberrypi:/$ cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 2.00
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 0000000065b6354e
Posted: Tuesday 13 September 2016 8:20
by Marci
sudo apt-get remove nodejs
sudo rm -rf /usr/local/{lib/node{,/.npm,_modules},bin,share/man}/{npm*,node*,man1/node*}
sudo rm -rf /var/db/receipts/org.nodejs.*
hash -r
wget https://nodejs.org/dist/latest-v6.x/node-v6.3.1-linux-armv6l.tar.gz
tar -xvf node-v6.3.1-linux-armv6l.tar.gz
cd node-v6.3.1-linux-armv6l
sudo cp -R * /usr/local/
Did you perform the above steps as per first post...?
Posted: Tuesday 13 September 2016 9:44
by RduPre
Marci wrote:Code: Select all
hash -r
I did that (with a newer version;6.5.0) but I guess something went wrong.
Did it again and now where getting somewhere
Now I get these errors when I start HomeBridge.
homebridge
/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:35
throw ex;
Error: Module version mismatch. Expected 48, got 46.
at Error (native)
at Object.Module._extensions..node (module.js:583:18)
at Module.load (module.js:473:32)
at tryModuleLoad (module.js:432:12)
at Function.Module._load (module.js:424:3)
at Module.require (module.js:483:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:24:20)
at Module._compile (module.js:556:32)
at Object.Module._extensions..js (module.js:565:10)
Thanks for your help so far..
Posted: Tuesday 13 September 2016 17:54
by Marci
Delete and reinstall everything you'd installed prior to fixing node... Ie: reinstall homebridge from scratch.
Posted: Wednesday 14 September 2016 8:14
by flippamikee
New to the Domoticz world. Before i get in to this i wanted to know if its possible to work with the new homekit app on the iphone with this plugin?
Posted: Wednesday 14 September 2016 8:32
by Marci
Yup, works with all apps that interact with the HomeKit protocol.
Posted: Wednesday 14 September 2016 14:52
by deejc
Sooooooo iOS 10 and home app seem to be working for most of my stuff watch os3 seems to work ok with all as well
Posted: Thursday 15 September 2016 21:39
by RduPre
Marci wrote:Delete and reinstall everything you'd installed prior to fixing node... Ie: reinstall homebridge from scratch.
Got it working now
Thanks.
