homebridge-edomoticz Plugin
- Marci
- Domoticz version: 3.8153
Re: homebridge-edomoticz Plugin
- deejc
- Domoticz version: 3.5641
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
simon_rb
- Target OS: -
Well there you go! Lol. Might add to my collection lol, deejc, is the PIR working well? Marci, no worries mate - work comes first
what an interesting job
fennec62
hi
i search a plugin to have a motion sensor on homebridge and have push alert with image
i find homebridge-filesensor but don't work
I have zoneminder so i can save a image on folder when i have a motion detection
in homekit is it posssible to send image ?
Thanks a lot
Thanks a lot
- TheRamon
- Domoticz version: BETA
Alright guys, back again. Soz was away for a while, having my vacation and all
Any hot issues that need fixing?
I've seen that there's a LOT of work been done, nice one Marci! So nice.
- Marci
Nope, not until iOs10 is released and KhaosT has sorted support for it in HAP-NodeJS & Homebridge, which won't happen til end of the year.fennec62 wrote:hi
Thanks a lot
RduPre
I installed a fresh version of Domoticz and installed the HomeKit integration as described in the first post.
I just get an error "Illegal instruction"
pi@raspberrypi:/$ homebridge
Illegal instruction
pi@raspberrypi:/$
I saw some post on this error, but did not found a solution
Any help would be appreciated.
Illegal instruction
pi@raspberrypi:/$
- deejc
It's all been quiet lol you should have stayed on holidayTheRamon wrote: Any hot issues that need fixing?
- deejc
Not exactly lol, I set it up to send a prowl msg and email me if it goes off and the back door is closed, today in the sunshine I got 240 emails !!!simon_rb wrote:deejc, is the PIR working well?
- Marci
What happens when you run...RduPre wrote:Hi,
Illegal instruction
pi@raspberrypi:/$
I saw some post on this error, but did not found a solution![]()
node -vExtended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
RduPre
Same error..Marci wrote:What happens when you run...RduPre wrote:Hi,
Illegal instruction
pi@raspberrypi:/$
Any help would be appreciated.Code: Select all
node -v
- Marci
Sounds like you haven't recompiled node for Arm6, using an Arm7 image...
What version Pi are you running on, with what version of Raspbian?
RduPre
Linux raspberrypi 4.1.18+ #846 Thu Feb 25 14:11:56 GMT 2016 armv6l GNU/LinuxMarci wrote:Sounds like you haven't recompiled node for Arm6, using an Arm7 image...
pi@raspberrypi:/$ cat /proc/cpuinfo
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 2.00
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 000e
Serial : 0000000065b6354e
- Marci
sudo apt-get remove nodejs
sudo rm -rf /usr/local/{lib/node{,/.npm,_modules},bin,share/man}/{npm*,node*,man1/node*}
sudo rm -rf /var/db/receipts/org.nodejs.*
hash -r
wget https://nodejs.org/dist/latest-v6.x/node-v6.3.1-linux-armv6l.tar.gz
tar -xvf node-v6.3.1-linux-armv6l.tar.gz
cd node-v6.3.1-linux-armv6l
sudo cp -R * /usr/local/Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
RduPre
I did that (with a newer version;6.5.0) but I guess something went wrong.Marci wrote:Did you perform the above steps as per first post...?Code: Select all
sudo apt-get remove nodejs sudo rm -rf /usr/local/{lib/node{,/.npm,_modules},bin,share/man}/{npm*,node*,man1/node*} sudo rm -rf /var/db/receipts/org.nodejs.* hash -r wget https://nodejs.org/dist/latest-v6.x/node-v6.3.1-linux-armv6l.tar.gz tar -xvf node-v6.3.1-linux-armv6l.tar.gz cd node-v6.3.1-linux-armv6l sudo cp -R * /usr/local/
Did it again and now where getting somewhere
Now I get these errors when I start HomeBridge.
homebridge
/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:35
throw ex;
Error: Module version mismatch. Expected 48, got 46.
at Error (native)
at Object.Module._extensions..node (module.js:583:18)
at Module.load (module.js:473:32)
at tryModuleLoad (module.js:432:12)
at Function.Module._load (module.js:424:3)
at Module.require (module.js:483:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/node_modules/mdns/lib/dns_sd.js:24:20)
at Module._compile (module.js:556:32)
at Object.Module._extensions..js (module.js:565:10)- Marci
Delete and reinstall everything you'd installed prior to fixing node... Ie: reinstall homebridge from scratch.
flippamikee
New to the Domoticz world. Before i get in to this i wanted to know if its possible to work with the new homekit app on the iphone with this plugin?
- Marci
Yup, works with all apps that interact with the HomeKit protocol.
- deejc
Sooooooo iOS 10 and home app seem to be working for most of my stuff watch os3 seems to work ok with all as well
RduPre
Got it working nowMarci wrote:Delete and reinstall everything you'd installed prior to fixing node... Ie: reinstall homebridge from scratch.
Thanks.
