Page 34 of 36
Re: machinon theme
Posted: Wednesday 26 May 2021 20:30
by waltervl
skom wrote: Wednesday 26 May 2021 15:05
On the Machinon Dashboard I would like to move some widgets from Light / Switches Devices and Utility Sensors to Security Devices (there is only a Security Panel) to "clean up" the widgets that monitor various security and alarm elements. Is it possible, because unfortunately I fail?
That is not possible in Domoticz (in no theme). You have to install Dashticz to do this.
Another possibility is to use rooms to filter devices based on function. Give the room a function name like "security".
Re: machinon theme
Posted: Monday 11 October 2021 22:05
by DarkAllMan
Suddenly an update from Machinon! Github is alive again?
https://github.com/domoticz/Machinon
Re: machinon theme
Posted: Thursday 14 October 2021 10:42
by Nephylim
Is the update still on git hub?
My Domoticz reminds me to update but the version on github still seems to be 1.16.2 from august 2020
Re: machinon theme
Posted: Thursday 14 October 2021 13:27
by DarkAllMan
Are you taking from the same github as me
It shows version: 1.17.3
Re: machinon theme
Posted: Thursday 14 October 2021 14:01
by heggink
For me, machinon on the latest beta is still not working well. Anyone having any luck? Cleared everything I could clear
Re: machinon theme
Posted: Sunday 24 October 2021 3:35
by bartolomeo
After updating Domoticz to the latest Beta version disappeared those three dots on the switches tile that allows to enter the editing options.
So i thougt, that also upgradind the machinon plugin to Beta may help. Cleaning cache, etc. done, but nothing helps. On the default theme Domoticz everything works fine. What can I do?
Re: machinon theme
Posted: Sunday 24 October 2021 9:31
by heggink
My issue was that the fixes require the directory name to be machinon. Mine was called Machinon (capital M). Cleared cache and things worked again.
Re: machinon theme
Posted: Wednesday 27 October 2021 11:56
by galadril
its actually stupid that the theme needs to hardcoded the install folder within the theme.. because everybody could install the theme in a different folder...
The theme should be able to use a variable for the install folder of the theme.
As it was previously with 'acttheme' the theme didn't had to know the location..
Re: machinon theme
Posted: Wednesday 27 October 2021 17:56
by najtram
Some self made icon's.
GU10
Person
Tuinspot
Daynight (sun/moon)
Daylight (sun/greyed sun)
MagicMirror
Timer
Doorbell
Woman
DimmerRond
Blinds (same as normal but no arrow)
Umbrella
Download link:
https://www.dropbox.com/s/9lgx3mmu6741z ... s.zip?dl=0
Re: machinon theme
Posted: Tuesday 04 January 2022 13:36
by JanZorz
If you have issues with Machinon theme on latest beta - no "Edit" buttons and so on - you need to link machinon directory to acttheme directory.
ln -s /opt/domoticz/www/styles/machinon /opt/domoticz/www/acttheme
otherwise that directory is not there and not much works.
Cheers, Jan
Re: machinon theme
Posted: Tuesday 04 January 2022 17:12
by kiddigital
JanZorz wrote:If you have issues with Machinon theme on latest beta - no "Edit" buttons and so on - you need to link machinon directory to acttheme directory.
Cheers, Jan
@JanZorz , that (symbolic)link should not be necessary. There has been some changes to the theme processing but also Machinon theme has been updated also. Make sure you have the latest versions.
Re: machinon theme
Posted: Tuesday 04 January 2022 18:17
by JanZorz
kiddigital wrote: Tuesday 04 January 2022 17:12
Without that link I get many errors on "Developer tools console" in Chrome and half things in MAchinon doesn't work. I have latest Machinon and Machinon beta, neither of them work. I also have latest Domoticz beta.
Cheers, Jan
Re: machinon theme
Posted: Wednesday 05 January 2022 13:27
by JanZorz
Cheers, Jan
Sorry, you are right. I was updating Machinon theme from wrong github address. All works now as expected!
Cheers, Jan
Re: machinon theme
Posted: Wednesday 05 January 2022 14:13
by DarkAllMan
JanZorz wrote: Wednesday 05 January 2022 13:27
Cheers, Jan
Cheers, Jan
So what is the one and only updated machinon Github?
Re: machinon theme
Posted: Wednesday 05 January 2022 14:28
by waltervl
DarkAllMan wrote: Wednesday 05 January 2022 14:13
See wiki
https://www.domoticz.com/wiki/Machinon_Theme
but it is
https://github.com/domoticz/machinon
Re: machinon theme
Posted: Tuesday 11 January 2022 10:45
by JanZorz
Indeed... I'm now updating from
https://github.com/domoticz/machinon.git, but I used to update from the old address.
Cheers, Jan
Re: machinon theme
Posted: Wednesday 22 June 2022 22:32
by PeJeWe
i dont see the theme edit menu in my domoticz tabs
Re: machinon theme
Posted: Wednesday 22 June 2022 23:56
by waltervl
PeJeWe wrote: Wednesday 22 June 2022 22:32
I believe it is a tab in the settings menu. So menu setup - settings - tab theme
Re: machinon theme
Posted: Thursday 23 June 2022 9:45
by PeJeWe
waltervl wrote: Wednesday 22 June 2022 23:56
i only find the following tabs in the settings:
System
Log History
Notifications
Email
Meters/Counters
Floorplan
Other
Backup/Restore
Re: machinon theme
Posted: Thursday 23 June 2022 9:48
by madpatrick
Do you see the same in your view as this ?
- 2022-06-23 09_46_54-Domoticz - Instellingen.png (114.13 KiB) Viewed 10603 times
- 2022-06-23 09_49_08-Domoticz - Instellingen.png (21.86 KiB) Viewed 10603 times
