So, I'm gonna make a setting for that
robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design v2, custom positioning and multiple screens
Ok, but for example, I dont want it to go automatically back to a certain slide.
maluko
you are the boss..., the good bossrobgeerts wrote:Ok, but for example, I dont want it to go automatically back to a certain slide.
l00pz
I'm unable to get the latests versions working. I configured the CONFIG_DEFAULT.js File and copied / renamed it to CONFIG.js, but when I open the Dashboard it only seems to show the Weather and Language / Clock Settings I configured. I'm 100% sure that the Domoticz URL is correct, because the old version of the Dashboard is working fine.
I attached some Screenshots from my Config, and the Developer Output from Chrome. Someone else with this problem?
robgeerts
Ah, let me fix this...
You get this error because you have no screens or blocks defined... I have to take this into account
Blueone
Is it possible to have a selector switch without the dropdown but with buttons within a block?
Something like this in the same style as the other blocks, it makes it more touch friendly. (without the notification blocks etc.) Also an other suggestion for the future, a setpoint block adjust the setpoint with an + and -, and when it's possible with the burning states, if you use the OTGW the burner states are switches in Domoticz so maybe that's even possible. I don't know really where to start but maybe there is something were I can help with this
robgeerts
Should be fixed in latest version!l00pz wrote:I'm unable to get the latests versions working. I configured the CONFIG_DEFAULT.js File and copied / renamed it to CONFIG.js, but when I open the Dashboard it only seems to show the Weather and Language / Clock Settings I configured. I'm 100% sure that the Domoticz URL is correct, because the old version of the Dashboard is working fine.
robgeerts
Will add this to my todo-list at https://trello.com/b/qsNqHtie/dashboardBlueone wrote:Is it possible to have a selector switch without the dropdown but with buttons within a block?
axelbaas
I (really) do not want to rush you.. But is it possible that you didn't save your Trello board?Just added this to the Trello board so I wont forget..axelbaas wrote:Unfortunately i miss the option to changes colors at my Philips Hue an Milight lights. Can i address this as a feature request?
This kind of things are less easy so could take while (some days or so)
robgeerts
You are right
Saved it now
Saved it now
SwordFish
- Domoticz version: V4.11375
Is it possible to ad more space between the arrows and stop icons for somfy. It is now hard to push the right arrow or stop
And maybe more space between the word somfy and the arrows/stop.
- Screenshot_2017-04-12-15-51-42.png (291.49 KiB) Viewed 2872 times
robgeerts
Yes, added to my todo list
Nautilus
This looks very nice! I cloned the repo to ../domoticz/www/dashboard/ and configured the variables sections. The rest is still commented out (_use_auto_positioning and _use_favorites = true). I get just the wu weather and buttons / widgets on the right-hand column. I tried commenting out the custom postitioning section and added some of my device / sensor idx but after that the whole dashboard is blank. Must be something really simple, but any idea what I'm missing?
- Spoiler: show
SwordFish
Did you fill in your ip adres of domoticz 'var _HOST_DOMOTICZ" ?Nautilus wrote:This looks very nice! I cloned the repo to ../domoticz/www/dashboard/ and configured the variables sections. The rest is still commented out (_use_auto_positioning and _use_favorites = true). I get just the wu weather and buttons / widgets on the right-hand column. I tried commenting out the custom postitioning section and added some of my device / sensor idx but after that the whole dashboard is blank. Must be something really simple, but any idea what I'm missing?
- Spoiler: show
Do you have filled in idx mark as favorites in domoticz?
Nautilus
koowee
I have again a few wish
Some new type of devices.. no hurry
PIR sensor via domoticz slave
Door sensor via domoticz slave
PIR sensor
Door sensor
Do you have any plan to add feature to that user can define what image is displayed for every per block (lamp, water drop...)? And do you have any idea why some of the devices gives graph that makes sense and some not
examples
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 13,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 5,
"HardwareName" : "Mokkislave",
"HardwareType" : "Domoticz - Remote Server",
"HardwareTypeVal" : 3,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00000C00",
"Image" : "Alarm",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-08 14:25:38",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "Workroom PIR sensor",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "131"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 13,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 5,
"ID" : "00000E34",
"Image" : "Alarm",
"LastUpdate" : "2017-04-02 13:58:41",
"Level" : 0,
"LevelInt" : 0,
"Name" : "Workroom door",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "142"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 91,
"CustomImage" : 13,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Razberry",
"HardwareTypeVal" : 21,
"ID" : "00000700",
"Image" : "Alarm",
"LastUpdate" : "2017-04-02 14:01:52",
"Level" : 0,
"LevelInt" : 0,
"Name" : "Summerhouse PIR",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "171"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 68,
"CustomImage" : 13,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"ID" : "00000E34",
"Image" : "Alarm",
"LastUpdate" : "2017-04-02 14:01:30",
"Level" : 0,
"LevelInt" : 0,
"Name" : "Summerhouse door sensor",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "251"
examples
json.htm?type=graph&sensor=counter&idx=237&range=day
"ValueQuantity" : "",
"ValueUnits" : "",
"result" : [
"d" : "2017-04-11 17:00",
"v" : "4.000"
"d" : "2017-04-11 18:00",
"v" : "628.000"
json.htm?type=graph&sensor=counter&idx=198&range=day
"ValueUnits" : "",
"status" : "OK",
"title" : "Graph counter day"
robgeerts
When did you download it?Nautilus wrote:This looks very nice! I cloned the repo to ../domoticz/www/dashboard/ and configured the variables sections. The rest is still commented out (_use_auto_positioning and _use_favorites = true). I get just the wu weather and buttons / widgets on the right-hand column. I tried commenting out the custom postitioning section and added some of my device / sensor idx but after that the whole dashboard is blank. Must be something really simple, but any idea what I'm missing?
- Spoiler: show
I fixed one issue regarding this, this afternoon..
robgeerts
koowee wrote:I have again a few wishSome new type of devices.. no hurry
PIR sensor via domoticz slaveDoor sensor via domoticz slaveCode: Select all
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 13, "Data" : "Off", "Description" : "", "Favorite" : 1, "HardwareID" : 5, "HardwareName" : "Mokkislave", "HardwareType" : "Domoticz - Remote Server", "HardwareTypeVal" : 3, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "00000C00", "Image" : "Alarm", "IsSubDevice" : false, "LastUpdate" : "2017-04-08 14:25:38", "Level" : 0, "LevelInt" : 0, "MaxDimLevel" : 100, "Name" : "Workroom PIR sensor", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Off", "StrParam1" : "", "StrParam2" : "", "SubType" : "Switch", "SwitchType" : "On/Off", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "lightbulb", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "131" },PIR sensorCode: Select all
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 13, "Data" : "Off", "Description" : "", "Favorite" : 1, "HardwareID" : 5, "HardwareName" : "Mokkislave", "HardwareType" : "Domoticz - Remote Server", "HardwareTypeVal" : 3, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "00000E34", "Image" : "Alarm", "IsSubDevice" : false, "LastUpdate" : "2017-04-02 13:58:41", "Level" : 0, "LevelInt" : 0, "MaxDimLevel" : 100, "Name" : "Workroom door", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Off", "StrParam1" : "", "StrParam2" : "", "SubType" : "Switch", "SwitchType" : "On/Off", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "lightbulb", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "142" },Door sensorCode: Select all
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 91, "CustomImage" : 13, "Data" : "Off", "Description" : "", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Razberry", "HardwareType" : "OpenZWave USB", "HardwareTypeVal" : 21, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "00000700", "Image" : "Alarm", "IsSubDevice" : false, "LastUpdate" : "2017-04-02 14:01:52", "Level" : 0, "LevelInt" : 0, "MaxDimLevel" : 100, "Name" : "Summerhouse PIR", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Off", "StrParam1" : "", "StrParam2" : "", "SubType" : "Switch", "SwitchType" : "On/Off", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "lightbulb", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "171" },Do you have any plan to add feature to that user can define what image is displayed for every per block (lamp, water drop...)? And do you have any idea why some of the devices gives graph that makes sense and some notCode: Select all
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 68, "CustomImage" : 13, "Data" : "Off", "Description" : "", "Favorite" : 1, "HardwareID" : 4, "HardwareName" : "Razberry", "HardwareType" : "OpenZWave USB", "HardwareTypeVal" : 21, "HaveDimmer" : true, "HaveGroupCmd" : true, "HaveTimeout" : false, "ID" : "00000E34", "Image" : "Alarm", "IsSubDevice" : false, "LastUpdate" : "2017-04-02 14:01:30", "Level" : 0, "LevelInt" : 0, "MaxDimLevel" : 100, "Name" : "Summerhouse door sensor", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "Status" : "Off", "StrParam1" : "", "StrParam2" : "", "SubType" : "Switch", "SwitchType" : "On/Off", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "Light/Switch", "TypeImg" : "lightbulb", "Unit" : 1, "Used" : 1, "UsedByCamera" : false, "XOffset" : "0", "YOffset" : "0", "idx" : "251" },
examplesCode: Select all
json.htm?type=graph&sensor=counter&idx=237&range=day { "ValueQuantity" : "", "ValueUnits" : "", "result" : [ { "d" : "2017-04-11 17:00", "v" : "4.000" }, { "d" : "2017-04-11 18:00", "v" : "628.000" },...Code: Select all
json.htm?type=graph&sensor=counter&idx=198&range=day { "ValueQuantity" : "", "ValueUnits" : "", "status" : "OK", "title" : "Graph counter day" }
Basically, the type and suptype are the same.
download the latest version, I check if image is alarm, if yes,the icon is not a bulb but a warning sign (red when ON).
do you have a screenshot of the graph in domoticz and the same graph in this dashboard?
JoshDinsdale
Hey Guys
Im very new to this, discovered this project just yesterday. Im having some issues getting devices to show. If i have var _USE_AUTO_POSITIONING and var _USE_FAVORITES set as true, i get some favorites show, however if i try and do it manually i cant get anything to show. Weather and clock stuff is fine.
Any suggestions?
Any suggestions?
koowee
Fast action again!robgeerts wrote:Basically, the type and suptype are the same.koowee wrote:I have again a few wishSome new type of devices.. no hurry
Now images are warning signs, not bulb anymore
Here are screenshots (this device have temperature and humidity in same graph)
robgeerts
Do you get any console (F12) errors? Did you use the right IDX numbers?
