Page 33 of 36
Re: Blockly examples
Posted: Tuesday 07 May 2019 5:17
by salopette
I can do it, how can I convert it to a code like you did above?
Posted: Tuesday 07 May 2019 6:05
by tozzke
salopette wrote: Tuesday 07 May 2019 5:17 I can do it, how can I convert it to a code like you did above?
don't, just make a screenshot. I made the blockly "in code" because I don't have your devices
Posted: Tuesday 07 May 2019 15:50
by salopette
This is my Blokly export
https://pastebin.com/bRiJSYLS
Posted: Friday 25 October 2019 22:49
by Mrtn83
I am just getting started using blockly and i need some help.
I want to turn-off the heater when the door is open for longer than 30 seconds.
If the door is closed I would like the heater to return to the state that it was in before opening the door.
There is an option On / Off but no resume. What can I do?
Posted: Saturday 26 October 2019 8:00
by salopette
Which values does the heater still have? Only on and off, or even temperature?
Posted: Saturday 26 October 2019 15:05
by Mrtn83
Only on or off, maybe a temperature. I would like to use the automation year round. During the summer the heater is off and shoud stay off.
But during the winter the heater should resume what it is doing.
Posted: Saturday 26 October 2019 19:03
by salopette
You can try to create a Virtual Thermostat.
There you can enter the IDX for schlater and temperature.
https://www.domoticz.com/wiki/Plugins/S ... ostat.html
Posted: Sunday 24 November 2019 17:06
by mpx2
How to use Push off button in Blocky.
I have two on/off buttons which work. I have a remote with All Off button. This off button is "Type: Light/Switch, AC, Push Off Button" in Domoticz. If I press All Off on remote or Push Off button in Domoticz swhitches turn off but the state in Domoticz is still on.
How Can I use that Push Off button to whitch off also the switches in Domoticz? I have tries if that Push off Button is off, on, 1 and 0 but nothing happens.
Posted: Monday 09 December 2019 19:55
by DaniKojnok
Hi, I am trying to resolve a task with blockly: If a PIR is off FOR some time do action. Is it just me finding this impossible to solve?
Posted: Monday 09 December 2019 23:12
by Geitje
I use this plugin for that purpose:
https://www.domoticz.com/forum/viewtopic.php?t=23813
Countdown is triggered by my PIR sensor. If countdown is still counting, and PIR is going on, countdown is starting over again (I think this is different from using a switch with delay?).
Posted: Sunday 15 December 2019 18:34
by DaniKojnok
Geitje wrote: Monday 09 December 2019 23:12 I use this plugin for that purpose:
Thank you, seems to be addressing the task, not an easy to resolve in blockly otherwise.
Posted: Friday 03 January 2020 20:13
by Devious
is it possible in blockly to trigger on user variables?
if i make a example:
The Alarm variable changes to 1.
But the alarm switch stays off, and the variable doesn't change back to 0.
even if i split up the 2 parts en set the trigger of the second part to "User variable"
The second part doesn't seem to be triggered.
Posted: Saturday 04 January 2020 1:57
by waaren
Devious wrote: Friday 03 January 2020 20:13 is it possible in blockly to trigger on user variables?
Yes
Loglines
2020-01-04 01:55:46.157  EventSystem: Event triggered: Blockly uservariable_1
2020-01-04 01:55:46.157  Status: Variable triggered
Posted: Saturday 04 January 2020 8:33
by mosjonathan
That does not work.
Blokly and lua and dzVents wil not trigger in a variable that is changed via scripts of blockly.
They will only trigger if the variable is changed via the web interface of via json.
That is to prevent loops
Posted: Saturday 04 January 2020 10:17
by waaren
mosjonathan wrote: Saturday 04 January 2020 8:33 That does not work.
Blockly and lua and dzVents wil not trigger in a variable that is changed via scripts of blockly.
Sorry but your information is not correct for dzVents.
This dzVents script changes the content of a variable and is triggered by that change.
		variables = {
			'my(integer)UserVariable'
	execute = function(dz, item)
		dz.log('Variable ' .. item.name .. ' is now: ' .. item.value)
		item.set(item.value + 1).afterSec(10)
The resulting log
2020-01-04 10:10:23.374  Status: dzVents: Info: Handling variable-events for: "my(integer)UserVariable", value: "1"
2020-01-04 10:10:23.374  Status: dzVents: Info: ------ Start internal script: dz uservariable: Variable: "my(integer)UserVariable" Index: 16
2020-01-04 10:10:23.375  Status: dzVents: Info: Variable my(integer)UserVariable is now: 1
2020-01-04 10:10:23.375  Status: dzVents: Info: ------ Finished dz uservariable
2020-01-04 10:10:33.398  Status: Set UserVariable my(integer)UserVariable = 2
2020-01-04 10:10:33.516  Status: dzVents: Info: Handling variable-events for: "my(integer)UserVariable", value: "2"
2020-01-04 10:10:33.517  Status: dzVents: Info: ------ Start internal script: dz uservariable: Variable: "my(integer)UserVariable" Index: 16
2020-01-04 10:10:33.518  Status: dzVents: Info: Variable my(integer)UserVariable is now: 2
2020-01-04 10:10:33.519  Status: dzVents: Info: ------ Finished dz uservariable
2020-01-04 10:10:43.539  Status: Set UserVariable my(integer)UserVariable = 3
2020-01-04 10:10:43.593  Status: dzVents: Info: Handling variable-events for: "my(integer)UserVariable", value: "3"
2020-01-04 10:10:43.593  Status: dzVents: Info: ------ Start internal script: dz uservariable: Variable: "my(integer)UserVariable" Index: 16
2020-01-04 10:10:43.593  Status: dzVents: Info: Variable my(integer)UserVariable is now: 3
2020-01-04 10:10:43.594  Status: dzVents: Info: ------ Finished dz uservariable
2020-01-04 10:10:43.594  Status: EventSystem: Script event triggered: /opt/domoticz/dzVents/runtime/dzVents.lua
2020-01-04 10:10:53.599  Status: Set UserVariable my(integer)UserVariable = 4
2020-01-04 10:10:53.652  Status: dzVents: Info: Handling variable-events for: "my(integer)UserVariable", value: "4"
2020-01-04 10:10:53.652  Status: dzVents: Info: ------ Start internal script: dz uservariable: Variable: "my(integer)UserVariable" Index: 16
2020-01-04 10:10:53.652  Status: dzVents: Info: Variable my(integer)UserVariable is now: 4
2020-01-04 10:10:53.653  Status: dzVents: Info: ------ Finished dz uservariable
2020-01-04 10:11:03.659  Status: Set UserVariable my(integer)UserVariable = 5
2020-01-04 10:11:03.757  Status: dzVents: Info: Handling variable-events for: "my(integer)UserVariable", value: "5"
2020-01-04 10:11:03.757  Status: dzVents: Info: ------ Start internal script: dz uservariable: Variable: "my(integer)UserVariable" Index: 16
2020-01-04 10:11:03.758  Status: dzVents: Info: Variable my(integer)UserVariable is now: 5
2020-01-04 10:11:03.760  Status: dzVents: Info: ------ Finished dz uservariable
2020-01-04 10:11:03.761  Status: EventSystem: Script event triggered: /opt/domoticz/dzVents/runtime/dzVents.lua
2020-01-04 10:11:13.800  Status: Set UserVariable my(integer)UserVariable = 6
2020-01-04 10:11:13.853  Status: dzVents: Info: Handling variable-events for: "my(integer)UserVariable", value: "6"
2020-01-04 10:11:13.853  Status: dzVents: Info: ------ Start internal script: dz uservariable: Variable: "my(integer)UserVariable" Index: 16
2020-01-04 10:11:13.854  Status: dzVents: Info: Variable my(integer)UserVariable is now: 6
2020-01-04 10:11:13.854  Status: dzVents: Info: ------ Finished dz uservariable
..etc
Posted: Saturday 04 January 2020 11:38
by mosjonathan
Hi waaren i did not know that dzVents triggered on user variabels changed in scripts.
Is that changed somewhere along the line?
Now i can make Some scripts simpler 😃
Thanks for the correction
Posted: Saturday 04 January 2020 18:46
by Devious
so not possible in Blockly, but possible in dzVents.
other option in Blockly is using virtual switches instead of user variables. (functional but not clean)
Posted: Wednesday 15 January 2020 12:54
by Franzie
Hi there, need some help with Blockly.
I made a script that when Me and my wife (phones) leave the building all the switches must turn off.
That works fine, thanks to iDetect.
But. Every evening my UniFi Switch "does not see" my phones for 2 or 3 seconds once or twice an evening and then it gets dark.
I tried to change the script so that there is a timer countdown 10 seconds and then check again if the phones are off but I don't know anymore how to make a timer which is counting off :oops:
Can someone help me please.
Posted: Wednesday 15 January 2020 20:19
by Geitje
I think you need to change some settings in your iDetect plugin. Make the grace period longer and/or more polls in the grace period. It will prevent false negatives...
Posted: Thursday 16 January 2020 16:19
by Franzie
Geitje wrote: Wednesday 15 January 2020 20:19 I think you need to change some settings in your iDetect plugin. Make the grace period longer and/or more polls in the grace period. It will prevent false negatives...
Thank you Geitje
My grace/poll period is now 30/15; you mean to increase to 60/15 or even 60/30?
