Pilot: Home Automation Control (iOS app)
patoo77
Re: Pilot: Home Automation Control (iOS app)
Post by patoo77 »
rgroothuis wrote:
G3rard wrote:
patoo77 wrote:If anyone is interested to beta-test the incoming 2.1 release, PM me your apple ID email.
Cheers~
I have installed version 2.1 and have some small layout things.
When a dimmer is at 100% the circle is not centered.
In the scene widget maybe you can move the word Domoticz to the top? Now the second row with buttons is not fully visible.
How/where do you get this widgets from? I've search in the entire app but cannot find the Widgets config screen. Am I missing something?
in the notifications center?
Andree
Post by Andree »
Good Work!with new beta work fine in the AWatch!
The new scene widget is simply clearly and i like so much!There is a plan for make Favourites widget like scene widget?
patoo77
Post by patoo77 »
Andree wrote:Good Work!with new beta work fine in the AWatch!
Glad you like it, it involved so much code refactoring, but it was definitely worth it :)
Andree wrote:The new scene widget is simply clearly and i like so much!There is a plan for make Favourites widget like scene widget?
Yes ;)
rgroothuis
Post by rgroothuis »
Stil a bit lost, where can I find the config menu for:
Not in the notifications menu.
patoo77
Post by patoo77 »
rgroothuis wrote:Stil a bit lost, where can I find the config menu for:
https://www.forbes.com/sites/anthonykar ... ac8e4c54eb
Follow this tutorial to add the widget.
There is nothing to setup, it simply displays all your scenes in the same order than the pilot app.
rgroothuis
I know about Widgets on a iPhone, that is not the problem. But my Pilot Widgets look like:
And not like the screenshot above. Or is this because I don't have scenes in my Widget list?
patoo77
Post by patoo77 »
rgroothuis wrote:I know about Widgets on a iPhone, that is not the problem. But my Pilot Widgets look like:
Pilot now has 2 widgets: Favorites and Scenes.
The one you put as screenshot is the existing one: Favorites.
Are you using the latest beta?
The Scenes widget should be available for all in the widget list. Is it not the case?
rgroothuis
Yes, I'm using the latest beta. Also the "HuiskamerLampen" is an existing scene in my setup. Still it is displayed as normal. Or do I need to create a new Scene to be able to make use of the new functionality?
patoo77
Post by patoo77 »
rgroothuis wrote: Yes, I'm using the latest beta. Also the "HuiskamerLampen" is an existing scene in my setup. Still it is displayed as normal. Or do I need to create a new Scene to be able to make use of the new functionality?
Have you found the widget then?
The widget should display the same info as the "Scenes" section in the iOS app. Is it not the case?
CaesarPL
Post by CaesarPL »
Works fine for me - I have both of them
rgroothuis
Indeed found them now as a (new) separate Widget. I was searching for scenes within the "My Favorites" section. Thanks for the support I can play around with the new feature now.
PCRover
Post by PCRover »
I have an iPhone 6+ that works great with Locations. My wife's iPhone 5 does not ever trigger a location change. I checked all her settings and they are the same as my phone. Any ideas on how to get it working on the iPhone 5?
patoo77
Post by patoo77 »
Trying new designs.
What do you think?
http://d.pr/i/ZjkHjh
Nautilus
Post by Nautilus »
patoo77 wrote:Trying new designs.
What do you think?
Interesting, inspired by the Home app I presume? :) Could the layout be controlled with a user setting? In any case, I think the more controls you can fit to one screen so that usability does not suffer the better.
Also, could you look into one "issue" I (think I) reported earlier. I would like to be able to click the "active" selector level in the today widget like it is possible in the Domoticz GUI. I have certain selector switches that e.g. send a volume up command to my receiver and I'd like to be able to do this repeatedly. Now I need to click on another level first to be able to click it again.
Looking forward to new versions! :)
bing69
Post by bing69 »
What do you think?
Looks nice!!
Andree
Post by Andree »
What do you think?
YESSS Please,YESSS!!
patoo77
Post by patoo77 »
What do you think?
My plan is to make this new interface so great you won't miss the old one. :p
For now though, only the "Favorites" tab will have the new interface. The regular "Data" tab will still have the current Pilot interface. This way, users get a smoother transition from old to new.
As this is the first major interface revamp for Pilot since I first started working on it, it's kind of a big deal and I don't wanna ruin it :P
What I am trying to achieve is a more modular, customizable, modern interface, in line with the iOS 11 UX language.
I am definitely taking clues from the iOS home app, but not only ;)
As for the selector issue, I won't really have to fix it, because the interface i am showing you will also be available in the Favorites widget. ;)
It will be a 2-tap process^^
Andree
Post by Andree »
patoo77 wrote:
What do you think?
We can expect a brief update with this new things on beta in fligh test?!
Dynamic
Post by Dynamic »
What do you think?
I'm very interested as an early Pilot-user, but the screenshot doesn't work anymore?
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
I have been using this not for a while and i thought lets use it again. But i have everything setup but it won't send me notification when a leave the house or coming home and the switch also don't get triggerd. I have the paid version and can access domoticz from the outside whit Pilot.
Is there something i'm doining wrong?
