DarkAllMan
Re: machinon theme
Machinon is not showing my electricity chart (gas is working fine)
All charts are empty.
When switching to default theme, I do have graphs.
Is this a known issue?
DarkAllMan
Re: machinon theme
I had this too... clear cache and it's solved!madpatrick wrote: Monday 30 November 2020 18:49 I've updated the MAchinon theme to 1.17.1 with github, but I still get the popoup messaga that there is an update to 1.17.1
In theme.json is seeIn setting/theme is seeCode: Select all
"type": "theme", "name": "Machinon", "description": "Machinon custom theme, simple and light", "license": "GNU General Public License v3.0", "version":"1.17.1", "author": "EdddieN", "homepage": "https://www.github.com/domoticz/Machinon", "wiki": "https://www.domoticz.com/wiki/Machinon_Theme",Code: Select all
Machinon theme V.1.16.2
vwtune
Re: machinon theme
As i'm i still on Machinon theme V.1.15.3, i wan't to update to latest version. With a git pull a got the message: already on latest version. But this is not true ofcourse.
I already deletes everythin and install machinon again. but then after a fresh install, i still on version 1.15.3!!
I cleared my cache also.
What to do?
What to do?
DarkAllMan
Re: machinon theme
Did you try with another browser or in private window?
- EdwinK
- Domoticz version: BETA
Re: machinon theme
Same problem here. Can't update to latest. Tried to clear cache, appcache, git pull and tried private broweser/incognito mode on Chrome, but nothing works. Using beta version
Also no luck with Safari or Firefox.
DarkAllMan
Re: machinon theme
I do not see much developments anymore. Any idea when beta bugs will be solved?
Plantje
Re: machinon theme
Agreed.... if I want to see graphs, I have to switch to the old theme.
Plantje
Re: machinon theme
Got a notification that EdwinK responded to this thread, but there is nothing to see.
- EdwinK
Re: machinon theme
Yes.. I did, but then deleted it, as I had found the location of the themePlantje wrote: Wednesday 24 February 2021 22:19 Got a notification that EdwinK responded to this thread, but there is nothing to see.
- Domoticz version: 2026.3
Re: machinon theme
That triggered me to update the wiki to the new Github location for this theme (that I personally also use!).EdwinK wrote: Wednesday 24 February 2021 22:28 Yes.. I did, but then deleted it, as I had found the location of the theme
Done!
Plantje
Re: machinon theme
Is this theme still alive and being updated?
- EdwinK
Re: machinon theme
don't think so.
DarkAllMan
Re: machinon theme
Last activity of EddieN:
Last active: Sunday 21 February 2021 0:41-
Plantje
Re: machinon theme
Would be a pity as I think they had/have something nice going!
With this as the basis: https://www.machinon.com/ It seems like plug and play Domoticz based like this is to Home Assistant: https://www.home-assistant.io/blue
- EdwinK
Re: machinon theme
it looks all great theme's are disabonded. Didn't see much of updates on the aurora theme either.
- madpatrick
- Domoticz version: 2026.1
Re: machinon theme
All plugins and support is made available by volunteers in their free time.
Maybe it good to support the people by paying for their hard work and hopely they will keep supporting us with the great plugins
Plantje
Re: machinon theme
Where can I donate for the Machinon theme? I did notice the Domoticz donate button and perhaps I should!
- felix63
- Domoticz version: 2020.1
Re: machinon theme
I really hope this theme will see a continued development. I have little skill and little time to donate unfortunately.
- heggink
- Domoticz version: 12451
Re: machinon theme
Is @DewGew still on here? He is (was?) one of the co developers...
P1 meter & solar panel
skom
- Domoticz version: 2022.2
Re: machinon theme
On the Machinon Dashboard I would like to move some widgets from Light / Switches Devices and Utility Sensors to Security Devices (there is only a Security Panel) to "clean up" the widgets that monitor various security and alarm elements. Is it possible, because unfortunately I fail?
