Page 33 of 48
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Posted: Friday 06 December 2019 12:10
by moroen
iTDB wrote: ↑Friday 06 December 2019 10:51
moroen wrote: ↑Friday 06 December 2019 1:09
I would recommend trying out the "new" plugin-version. It's easier to install and most importantly, doesn't require running a tradfri service.
So /moroen/IKEA-Tradfri-plugin is not the newest plugin? Where can I find the new one?
Thx
It's in the same repository, it's just in a separate branch. You'll find it here:
https://github.com/moroen/IKEA-Tradfri- ... ree/pycoap
Just make sure that you checkout the pycoap branch after cloning the repo into the plugins-folder of domoticz!
Regards,
M
Posted: Friday 06 December 2019 16:56
by wvdweerd
If your starting a fresh install of the IKEA-tradfri plugin, I would recommend trying out the "new" plugin-version. It's easier to install
I was doing a fresh install (after getting weird problems with my previous 2.0 install) when I got errors with the config file. So when I saw your comment about easier install, I started again with the pycoap version.
However, first I had a decent struggle to install the necessary golang compiler (latest, version 1.13.5) with the correct PATH settings.
And now I am stuck at the command:
python3 tradfricoap.py config IP KEY
because I am getting this error:
File "tradfricoap.py", line 11, in <module>
import pycoap
File "/usr/local/lib/python3.5/dist-packages/pycoap/__init__.py", line 1, in <module>
from .pycoap import Request, setDebugLevel, GET, PUT, POST
File "/usr/local/lib/python3.5/dist-packages/pycoap/pycoap.py", line 1, in <module>
import _pycoap
ImportError: dynamic module does not define module export function (PyInit__pycoap)
Any ideas how I can fix this?
Note: I am running an updated version of Raspbian on a Raspberry Pi, with my own account (not "pi" account).
python --version --> Python 2.7.13
python3 --version --> Python 3.5.3
I have Python 3.7 installed, but read that setting this as default for python3 will give problems running pip3 commands...
Posted: Friday 06 December 2019 17:26
by iTDB
Also gives me errors:
pi@mydomoticz:~/domoticz/plugins/IKEA-Tradfri $ git checkout pycoap
Branch 'pycoap' set up to track remote branch 'pycoap' from 'origin'.
Switched to a new branch 'pycoap'
pi@mydomoticz:~/domoticz/plugins/IKEA-Tradfri $ pip3 install --upgrade pip
Looking in indexes:
https://pypi.org/simple,
https://www.piwheels.org/simple
Requirement already up-to-date: pip in /usr/local/lib/python3.7/dist-packages (19.3.1)
pi@mydomoticz:~/domoticz/plugins/IKEA-Tradfri $ pip3 install --upgrade setuptools
Looking in indexes:
Requirement already up-to-date: setuptools in /usr/local/lib/python3.7/dist-packages (42.0.2)
pi@mydomoticz:~/domoticz/plugins/IKEA-Tradfri $ pip3 install -r requirements.txt
Looking in indexes:
https://www.piwheels.org/simple,
https://test.pypi.org/simple/
Requirement already satisfied: appdirs in /usr/local/lib/python3.7/dist-packages (from -r requirements.txt (line 2)) (1.4.3)
Collecting pycoap
Using cached
https://test-files.pythonhosted.org/pac ... 5.3.tar.gz
Building wheels for collected packages: pycoap
Building wheel for pycoap (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uh3lf4te/pycoap/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uh3lf4te/pycoap/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-qll_7prh --python-tag cp37
cwd: /tmp/pip-install-uh3lf4te/pycoap/
Complete output (11 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.7
creating build/lib.linux-armv7l-3.7/pycoap
copying pycoap/pycoap.py -> build/lib.linux-armv7l-3.7/pycoap
copying pycoap/__init__.py -> build/lib.linux-armv7l-3.7/pycoap
running build_ext
$ GOPATH=/tmp/tmpt5d_7rjw go get -d
error: [Errno 2] No such file or directory: 'go': 'go'
ERROR: Failed building wheel for pycoap
Running setup.py clean for pycoap
Failed to build pycoap
Installing collected packages: pycoap
Running setup.py install for pycoap ... error
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uh3lf4te/pycoap/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uh3lf4te/pycoap/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5udpyb6c/install-record.txt --single-version-externally-managed --compile
running install
running build
running build_py
creating build
running build_ext
$ GOPATH=/tmp/tmpgetxj0aa go get -d
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-uh3lf4te/pycoap/setup.py'"'"'; __file__='"'"'/tmp/pip-install-uh3lf4te/pycoap/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5udpyb6c/install-record.txt --single-version-externally-managed --compile Check the logs for full command output.
Posted: Friday 06 December 2019 22:46
by wvdweerd
@iTDB:
I had the same error.
Did you install the (recent version of the) Go compiler?
And if you did: is the install location of this Go compiler in your Path environment variable? To check :
What is the output if you enter:
Posted: Friday 06 December 2019 23:08
by moroen
wvdweerd wrote: ↑Friday 06 December 2019 22:46
@iTDB:
It seems that it's not easy to build Arm compatible wheels using Azure. I'll dig up one of my Raspberries and try to build a wheel and upload to the pypi index, or at least make sure it's doable and update the readme with instructions for installing on a Raspberry...
Regards,
M
Posted: Saturday 07 December 2019 15:16
by wvdweerd
As a .Net / C# / Windows developer all this is very new and strange for me
I am used to build and include all that is needed to run something. And not to 'force' users to download and compile things themselves, but I guess that is standard in Lunix world because of all the platforms and different versions?!
I'll keep an eye on this thread, as soon as you have something to test and try, just post a message here (or send me a pm).
Thanks for all your efforts moroen!
Regards,
Wouter
Posted: Sunday 08 December 2019 2:24
by moroen
wvdweerd wrote: ↑Saturday 07 December 2019 15:16
Yes, even though there are quite a few different ways of creating setup/install systems for Linux, the wide variations of platforms and versions makes creating a "works everywhere" install system for linux somewhat difficult.
The build and include everything needed is arguably one positive thing about the monolithic approach of Windows, but once you get used to using package managers and compiling software from scratch, the amount of freedom and control is quite nice! And usually you don't end up with a system having a multitude of different versions of the same libraries, since all programs are more or less expected to use the same system libraries.
But then again, I've been using variants of Unix more or less since 1992, so I'm probably somewhat biased...
Anyway, I digress...
I've not been able to quite figure out why using pip to install pycoap from the test pypi-index fails on Raspbian, but using latest raspbian (buster) image, it seems to work when using pip to install directly from the github-repo. Take a look at the readme for Raspberry (
https://github.com/moroen/IKEA-Tradfri- ... ADME-PI.md) for instructions. And btw, you don't need to install the latest golang compiler by hand, the version packaged with buster should do the trick nicely!
Regards,
M
Posted: Sunday 08 December 2019 13:50
by wvdweerd
moroen wrote: ↑Sunday 08 December 2019 2:24
Regards,
M
Unfortunately I am still using Stretch, and my Raspbian and Domotcz skills are not well enough to try to upgrade
(I had to Google just now what Buster and Stretch are exactly and how I could figure out which version I am using)
I deleted the pycoap stuff in my "/usr/local/lib/python3.5/dist-packages" and then I followed your new PI instructions.
Unfortunately I got the same error about "go" again:
OUTPUT from:
...$ sudo -H pip3 install -r requirements-pi.txt:
Requirement already satisfied: appdirs in /usr/local/lib/python3.5/dist-packages (from -r requirements-pi.txt (line 1)) (1.4.3)
Collecting pycoap
Cloning git://github.com/moroen/pycoap.git to /tmp/pip-install-cmt4thc8/pycoap
Running command git clone -q git://github.com/moroen/pycoap.git /tmp/pip-install-cmt4thc8/pycoap
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-cmt4thc8/pycoap/setup.py'"'"'; __file__='"'"'/tmp/pip-install-cmt4thc8/pycoap/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-7ghd1u2o --python-tag cp35
cwd: /tmp/pip-install-cmt4thc8/pycoap/
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/pycoap
copying pycoap/pycoap.py -> build/lib.linux-armv7l-3.5/pycoap
copying pycoap/__init__.py -> build/lib.linux-armv7l-3.5/pycoap
running build_ext
$ GOPATH=/tmp/tmpv5vq7s2m go get -d
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-cmt4thc8/pycoap/setup.py'"'"'; __file__='"'"'/tmp/pip-install-cmt4thc8/pycoap/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ps2bl1zg/install-record.txt --single-version-externally-managed --compile
running install
running build
running build_py
creating build
running build_ext
$ GOPATH=/tmp/tmpbtibayo2 go get -d
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-cmt4thc8/pycoap/setup.py'"'"'; __file__='"'"'/tmp/pip-install-cmt4thc8/pycoap/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-ps2bl1zg/install-record.txt --single-version-externally-managed --compile Check the logs for full command output.
But if I look at the PATH environment var there is a entry to the go compiler location, and getting the version also works?!
...$ echo $PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/go/bin:/usr/local/games:/usr/games
...$ go version
go version go1.13.5 linux/arm
Posted: Sunday 08 December 2019 15:14
by moroen
wvdweerd wrote: ↑Sunday 08 December 2019 13:50
Regards,
M
...$ echo $PATH
...$ go version
Go is probably not in the path when using sudo. Try using the package version of GO:
It's version 1.7, I haven't tried it, but it's probably sufficient...
Regards,
M
Posted: Sunday 08 December 2019 17:03
by wvdweerd
moroen wrote: ↑Sunday 08 December 2019 15:14
Regards,
M
Super, this worked!
After installing golang, I now got
no errors when running:
And creating the config with "sudo python3 tradfricoap.py config IP KEY" worked (""INFO:root:config created").
I had to use "sudo su" to get "sudo python3 tradfricoap.py list" working, probably because the config was created at 'root' level?
But after rebooting my Raspberry Pi and enabling the IKEA-TRADFRI plugin in Domoticz all my devices are present again.
And I can control them again from within Domoticz.
For now I happy again, hopefully everthing keeps working, even if I add some timers for my lights
Thanks again for all your efforts and quick replies!
Posted: Sunday 08 December 2019 18:40
by wvdweerd
wvdweerd wrote: ↑Sunday 08 December 2019 17:03
Mmm, everything is still working (I can stil switch a light on and off), but in the log I see the following errors:
2019-12-08 17:56:44.209 Error: (IKEA Tradfri) 'onHeartbeat' failed 'AttributeError':''device' object has no attribute 'device''.
2019-12-08 17:56:44.209 Error: (IKEA Tradfri) ----> Line 346 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onHeartbeat
2019-12-08 17:56:44.210 Error: (IKEA Tradfri) ----> Line 302 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function onHeartbeat
2019-12-08 17:56:44.210 Error: (IKEA Tradfri) ----> Line 65 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function indexRegisteredDevices
2019-12-08 17:56:44.210 Error: (IKEA Tradfri) ----> Line 83 in '/home/pi/domoticz/plugins/IKEA-Tradfri/plugin.py', function updateDevice
2019-12-08 17:56:44.210 Error: (IKEA Tradfri) ----> Line 163 in '/home/pi/domoticz/plugins/IKEA-Tradfri/tradfricoap.py', function Level
2019-12-08 17:56:44.210 Error: (IKEA Tradfri) ----> Line 283 in '/home/pi/domoticz/plugins/IKEA-Tradfri/tradfricoap.py', function Members
So, something is not working correct?
Posted: Sunday 08 December 2019 22:19
by moroen
wvdweerd wrote: ↑Sunday 08 December 2019 18:40
Glad it worked out so far... I need some more information, could you please enable debug for the plugin (from the IKEA Tradfri hardware page) and post the relevant parts of the log? It has something to with groups, do you have any groups without any member devices?
Regards,
M
Posted: Sunday 08 December 2019 22:57
by Nopea
Running a fresh install of Buster on a Raspberry Pi 3 and following the guidelines in this thread I get the following. Any suggestions how to proceed? What version of python should one be using?
root@raspberrypi:/home/pi/domoticz/plugins/IKEA-Tradfri# python -V
Python 3.8.0
root@raspberrypi:/home/pi/domoticz/plugins/IKEA-Tradfri# python tradfricoap.py config xxxxxxxxxxxxxxxxx yyyyyyyyyyyyyyyyyyyyyy
File "tradfricoap.py", line 5, in <module>
from tradfri.config import get_config, host_config
File "/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri/config.py", line 1, in <module>
import appdirs, logging, os, json
ModuleNotFoundError: No module named 'appdirs'
root@raspberrypi:/home/pi/domoticz/plugins/IKEA-Tradfri# python3 -V
Python 3.7.3
root@raspberrypi:/home/pi/domoticz/plugins/IKEA-Tradfri# python3 tradfricoap.py config xxxxxxxxxxxxx yyyyyyyyyyyyyyyyy
2019/12/08 21:53:57 COAP DTLS Error: Handshake timeout
File "tradfricoap.py", line 357, in <module>
create_ident(args.IP, args.KEY, CONFIGFILE)
File "/home/pi/domoticz/plugins/IKEA-Tradfri/tradfri/gw.py", line 17, in create_ident
uri, payload=payload, method=pycoap.POST, ident="Client_identity", key=key
File "/usr/lib/python3.7/json/__init__.py", line 341, in loads
raise TypeError(f'the JSON object must be str, bytes or bytearray, '
TypeError: the JSON object must be str, bytes or bytearray, not NoneType
Posted: Monday 09 December 2019 0:19
by moroen
Nopea wrote: ↑Sunday 08 December 2019 22:57
Version 3.5.x to Version 3.7.x is tested, support for version 3.8 is work in progress. You need to install all requirements, I recommend checking out the readme (
https://github.com/moroen/IKEA-Tradfri- ... ADME-PI.md), but the important part:
Regards,
M
Posted: Monday 09 December 2019 1:40
by moroen
moroen wrote: ↑Sunday 08 December 2019 22:19
Regards,
M
@wvdweerd, actually, it doesn't need to have anything to do with groups, it might be an unrecognised device? Do you have tradfri curtains installed?
I've pushed a new version to github, so if you be as kind as to pull it, enable debug and post the log? If you don't mind, would you also post the output of tradfricoap.py list?
Regards,
M
Posted: Monday 09 December 2019 7:28
by Nopea
moroen wrote: ↑Monday 09 December 2019 0:19
Regards,
M
That is the instructions that I followed and which resulted in the error.
Posted: Monday 09 December 2019 12:30
by moroen
Nopea wrote: ↑Monday 09 December 2019 7:28
Regards,
M
Strange, appdirs should be installed when using the requirements-file. Could you post the output of "sudo -H pip3 install -r requirements-pi.txt"? And perhaps try to install appdirs by hand:
Regards,
M
Posted: Monday 09 December 2019 21:46
by Nopea
As requested, here is the output of "sudo -H pip3 install -r requirements-pi.txt"
Looking in indexes:
Requirement already satisfied: appdirs in /usr/lib/python3/dist-packages (from -r requirements-pi.txt (line 1)) (1.4.3)
Requirement already satisfied: pycoap from git+git://github.com/moroen/pycoap.git#egg=pycoap in /usr/local/lib/python3.7/dist-packages (from -r requirements-pi.txt (line 2)) (0.5.3)
and "sudo -H pip3 install appdirs" gives
Posted: Monday 09 December 2019 21:48
by wvdweerd
moroen wrote: ↑Monday 09 December 2019 1:40
Regards,
M
I don't have any groups.
Following your request I am now running the new version: 2019-12-09 21:27:43.342 Status: (IKEA Tradfri) Initialized version 0.4.2, author 'moroen'
Output of the list command:
/home/pi/domoticz/plugins/IKEA-Tradfri$ python3 tradfricoap.py list
INFO:tradfri.config:Loading config
65536: Afst. bediening Wouter (None - None)
65553: Afstandsbediening Carin (None - None)
65549: Afstandsbediening slaapkamer (None - None)
65546: TRADFRI on/off switch (None - None)
65547: Buitenlamp voordeur (1 - None)
65548: Buitenlamp voorkant huis (1 - None)
65554: Lamp Carin (1 - efd275)
65550: Slaapkamer lamp 1 (bureau) (0 - efd275)
65552: Slaapkamer lamp 3 (kast) (0 - efd275)
65551: Slaapkamer lamp 2 (bed) (0 - efd275)
65537: Lamp Wouter boven (1 - f1e0b5)
65538: Lamp Wouter onder (1 - efd275)
Translation and IKEA article numbers
Afstandsbediening = remote control - 304.431.24
On/off switch - wireless dimmer - 704.085.95
Buitenlamp = light bulb - 904.087.97
Lamp - GU10 lights - 904.086.03
Now I think about it: I recently bought and installed an "on/off switch": 65546: TRADFRI on/off switch (None - None)
Could this be the cause of the problems?
PS: the last 15 minutes no errors in the debug log yet. Just a lot of messages like the following:
2019-12-09 21:42:43.554 (IKEA Tradfri) Pushing 'onHeartbeatCallback' on to queue
2019-12-09 21:42:43.576 (IKEA Tradfri) Processing 'onHeartbeatCallback' message
2019-12-09 21:42:43.576 (IKEA Tradfri) Calling message handler 'onHeartbeat'.
2019-12-09 21:42:43.598 (IKEA Tradfri - Buitenlamp voordeur) Updating device from 1:'58' to have values 1:'58'.
2019-12-09 21:42:43.630 (IKEA Tradfri - Buitenlamp voorkant huis) Updating device from 1:'58' to have values 1:'58'.
2019-12-09 21:42:43.659 (IKEA Tradfri - Lamp Carin) Updating device from 1:'5' to have values 1:'5'.
2019-12-09 21:42:43.695 (IKEA Tradfri - Lamp Carin - Color) Updating device from 1:'30' to have values 1:'30'.
2019-12-09 21:42:43.734 (IKEA Tradfri - Slaapkamer lamp 1 (bureau)) Updating device from 0:'89' to have values 0:'89'.
2019-12-09 21:42:43.756 (IKEA Tradfri - Slaapkamer lamp 1 (bureau) - Color) Updating device from 0:'30' to have values 0:'30'.
2019-12-09 21:42:43.777 (IKEA Tradfri - Slaapkamer lamp 3 (kast)) Updating device from 0:'82' to have values 0:'82'.
2019-12-09 21:42:43.798 (IKEA Tradfri - Slaapkamer lamp 3 (kast) - Color) Updating device from 0:'30' to have values 0:'30'.
2019-12-09 21:42:43.826 (IKEA Tradfri - Slaapkamer lamp 2 (bed)) Updating device from 0:'83' to have values 0:'83'.
2019-12-09 21:42:43.849 (IKEA Tradfri - Slaapkamer lamp 2 (bed) - Color) Updating device from 0:'30' to have values 0:'30'.
2019-12-09 21:42:43.875 (IKEA Tradfri - Lamp Wouter boven) Updating device from 1:'31' to have values 1:'31'.
2019-12-09 21:42:43.899 (IKEA Tradfri - Lamp Wouter boven - Color) Updating device from 1:'20' to have values 1:'20'.
2019-12-09 21:42:43.930 (IKEA Tradfri - Lamp Wouter onder) Updating device from 1:'31' to have values 1:'31'.
2019-12-09 21:42:43.953 (IKEA Tradfri - Lamp Wouter onder - Color) Updating device from 1:'30' to have values 1:'30'.
2019-12-09 21:42:53.556 (IKEA Tradfri) Pushing 'onHeartbeatCallback' on to queue
2019-12-09 21:42:53.578 (IKEA Tradfri) Processing 'onHeartbeatCallback' message
Posted: Tuesday 10 December 2019 0:11
by moroen
wvdweerd wrote: ↑Monday 09 December 2019 21:48
That actually makes sense. I've spent some time trying to trace and reproduce the error, but failed to achieve either... Then it suddenly dawned upon me, that I had forgotten to ask you one crucial piece of information, if the error was consistent (i.e. on every updateDevice) or intermittent.
I don't think it has something to do with the on/off switch, it's should (at the moment at least) just be ignored by the plugin. If the error is intermittent, as it appears from your latest post, I believe it is a timeout-issue, and as far as I can tell, just throws an error and then happily chugs along, until the next update is called... Doesn't mean that I won't fix it, though, but at least it sort of makes sense and I know what to fix...
The verbose log is expected when enabling debug, so you can just turn debug back off!
Regards,
M
