Page 32 of 35
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
Posted: Tuesday 27 September 2022 9:49
by Thorgal789
I m not sure to understant what you are doing but:
- You can't have 2 deconz instance running, so you need to close the headless before launching the GUI version.
- Depend on OS, but some "VNC mode" launch a new session, so service are only executed when you run the VNC session, mean GUI services are not working, but only launch when you start the VNC session.
You can use thoses lines to see deconz services
sudo systemctl status deconz
sudo systemctl status deconz-gui
You need to have an error on one of them.
Mode Headless :
sudo systemctl disable deconz-gui
sudo systemctl stop deconz-gui
sudo systemctl enable deconz
Mode with GUI :
sudo systemctl enable deconz-gui
How many time your installation is working ? If its after 1 hour, I think it 's more a zigbee connexion issue, are you using the USB cable extension ?
Have you take a look in phoscon ?
Your problem is not websocket, because you have error when trying to change a switch state (websocket impact only return), this error happen generaly when the device have disconnected, but it's a light ...
If you have access to GUI, you can find deconz log on the application / help / debug view, use flag "error" "error_l2" "info" and "info_l2".
Posted: Tuesday 27 September 2022 11:29
by Pacman42
I am not using VNC, I use RDP to avoid such problems. But maybe these problems do occur with RDP as well?
I have manuall stopped/started the services, so it is not that. I have connectivity for everything else in deConz, but not for setting the state of the switches. Polling the state from deConz plugin is not working, state change from deConz is working.
Based on your list of proposals I would need to use HDMI and keyboard on the Raspberry (no remote login) and see if it works after a reboot then. But as I am not at home this week, I will have to wait with that 'til the weekend. But as I think wrote earlier, headless deConz and and then rebooting was not helping either. But this seems to be the most likely reason.
Posted: Tuesday 27 September 2022 16:57
by Thorgal789
It s more complex than that, and I m not skilled enought to explain ^^.
On raspbian you can use a desktop environnement, without keyboard and video output, no problem (I have this setup), but the OS run in desktop mode, you can use a VNC to just connect to it.
I have the issue on some linux headless environnement, the OS is headless and when the user run VNC, he go on a new session with graphical stuff.
I have too this issue on Raspbian, the VNC mode need to be enabled with raspi-config, not added on the headless base OS else it's same result.
There is too issue on other VNC clients (for exemple TightVNC ), only the native one included with raspbian is 100% sure.
But it seem the problem is elsewhere
You have connexion with deconz, when there is configuration issue you have "not connected" instead of a firmware number in phoscon, and the API is working.
You can change the device state using the GUI, but not working using phoscon/domoticz ? (make action, not poll/websocket stuff), it that that trigger this kind of error
{'error': {'address': '/lights/3/state', 'description': 'resource, /lights/3/state, is not modifiable. Device is not reachable.', 'type': 202}}
On phoscon or the domoticz front end, you can check the device json state, in Phoscon / help / API Information / lights / 3
BTW, what is your deconz version ? (Not asking for firmware)
Posted: Friday 30 September 2022 11:07
by Pacman42
I have now identified the problem. The switches are existing in deConz, but not in Phoscon. I will remove them and re-pair them during the weekend and see if that solves the problem. I didn't know that deConz and Phoscon could get out of sync...
Posted: Friday 30 September 2022 18:03
by Thorgal789
Deconz is the application that manage the zigbee network
The API is just a plugin in it, you can have a device in the zigbee network, so visible in deconz, but not reconised by the API, so not usable by third app.
But it's strange, a not reconised device is not in the API at all, you can't have error message like the previous one.
If the device is disconnected, you can see it grayed in deconz (and have this kind of message), and on the device json you will see reachable = false.
If the node name is like 0xXXXX it mean it s in the zigbee network but not in the API.
By curisoity it's not a Legrand device ?
Posted: Thursday 03 November 2022 20:54
by andersbz
Thanks for this excellent plugin!! Are there any plans to support the Aqara Roller Shade Driver E1? I have managed to connect it and I can control it with the on/off light switch but not with the Switch type for blinds
Thanks Anders
Posted: Saturday 05 November 2022 9:29
by Thorgal789
andersbz wrote: Thursday 03 November 2022 20:54
Thanks Anders
It's not this one ?
https://github.com/dresden-elektronik/d ... ssues/6469
I don't remember all the issue, but if Im right, the motor is working, but still missing sensors (light, temperature, battery, ect ...)
You just need to instal the DDF in the issue to test it.
Posted: Sunday 06 November 2022 15:36
by andersbz
Yes the motor is working if you change from suggested Venetian Blinds EU to a on/off switch. So you cant use the stop funktion and there is no value for battery level in the battery level icon. But I'm thankful that the basic function works. Thanks again for the plugin Thorgal789!!
Posted: Monday 07 November 2022 15:53
by Thorgal789
Ha ? I don't know this method, it's the same device than on the previous link ? If yes you need to install the DDF.
Else I don't see why it work better with an on/off than a Venetian Blinds EU, you can't take a look on debug return to see the request differences ?
Posted: Saturday 12 November 2022 13:10
by Thorgal789
andersbz wrote: Sunday 06 November 2022 15:36
@andersbz and other, I have finally understand what you are saying.
The plugin is updated and now widget with covering are working again (no need to use switch widget). They are broken after the last domoticz version.
You can update the plugin going in the plugin folder and making
Them restart the plugin using domoticz/setting/hardware/deconz/update.
If you are using the plugin manager, the correction is online.
And if you want more information or if you are on windows and want to download direclty files
Plugin zigbee deconz for domoticz
Posted: Sunday 13 November 2022 21:38
by andersbz
Thanks Thorgal, I will update as soon as possible.
Posted: Friday 18 November 2022 19:17
by andersbz
Now it works as intended, thank you very much
Posted: Friday 02 December 2022 10:05
by hanszel
I had to reinstall phoscon due to a broken sd card in my raspberry pi. I managed to get the system up and running (fortunately I had recently made a backup). However, I am unable to connect from domoticz (on another PC). If I go to the deconz tab from domoticz and create a new api key under tools, it is neatly displayed. If I then enter this key in the deCONZ plugin, my devices are not retrieved. The logs therefore state: 2022-12-02 09:00:39.062 Error: zigbee dongle: Connection problem (3) with Gateway, check your API key, or Use Request lib > V2.4.2
If I create the API key via postman plugin in Chrome, an API key is also neatly generated. When I then request a list of my lights, I get the following, while there are a lot of lights are present:
"success": {
"/lights": "Searching for new devices",
"/lights/duration": 180
Also with this API key in Domotics no connection is made.
Any idea what I've missed?
Posted: Friday 02 December 2022 17:19
by Thorgal789
I don't think the problem is from deconz or domoticz because all seem working, you just miss the connection beetween domoticz and deconz.
Can come from the OS if it's a new OS, have you updated it ?
Check at least the python request lib version (used by the plugin)
sudo -H pip3 install requests
sudo -H pip install requests
Posted: Tuesday 06 December 2022 20:55
by hanszel
Thanks for the tip, but unfortunately no difference. Some additional packages have been installed but still no connection is made. Does Phoscon also keep a log file? Any idea what else I can try?
Posted: Tuesday 06 December 2022 21:17
by hanszel
Log domoticz:
2022-12-06 20:13:15.080 zigbee dongle: onHeartbeat called
2022-12-06 20:13:15.081 zigbee dongle: ### Initialisation > config
2022-12-06 20:13:15.081 zigbee dongle: ### Request config
2022-12-06 20:13:15.081 zigbee dongle: Send Command /api/702390EF7E/config/ with None (0 in buffer)
2022-12-06 20:13:15.081 zigbee dongle: Making Request: http://192.168.68.120:80/api/702390EF7E/config/ with params None2022-12-06 20:14:46.065 Error: zigbee dongle: Connection problem (3) with Gateway, check your API key, or Use Request lib > V2.4.2
Posted: Wednesday 07 December 2022 17:16
by Thorgal789
Sure the plugin try to connect to this url
You can try it in a browser, you need to see a json file.
This url need to work, even with a bad api key, you will just have less information.
If the url is working, will try to test the python Request library, wich one version have you ?
pi@raspberrypi:~ $ sudo -H pip3 install requests
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
BTW if you have deconz and domoticz in the same machine, better to use the local host 127.0.0.1
Posted: Thursday 08 December 2022 21:25
by hanszel
When i open in a browser (made a new api key):
http://192.168.68.120/api/7804402877/config/
I get:
UTC "2022-12-07T21:19:52"
apiversion "1.16.0"
backup
errorcode 0
status "idle"
bridgeid "00212EFFFF05CDBD"
datastoreversion "93"
devicename "ConBee II"
dhcp true
disablePermitJoinAutoOff false
factorynew false
fwversion "0x26720700"
gateway "192.168.68.1"
internetservices
internet "connected"
remoteaccess "disconnected"
swupdate "connected"
time "connected"
ipaddress "192.168.68.120"
lightlastseeninterval 60
linkbutton false
localtime "2022-12-07T21:19:52"
mac "40:a5:ef:06:19:db"
modelid "deCONZ"
name "Phoscon-GW2"
netmask "255.255.255.0"
networkopenduration 180
ntp "synced"
panid 27358
portalconnection "disconnected"
portalservices false
portalstate
communication "disconnected"
incoming false
outgoing false
signedon false
proxyaddress "none"
proxyport 0
replacesbridgeid null
rfconnected true
starterkitid ""
swupdate
checkforupdate false
devicetypes
bridge false
lights []
sensors []
notify false
text ""
updatestate 0
url ""
swupdate2
autoinstall
on false
updatetime ""
bridge
lastinstall "2022-12-02T18:30:54"
state "noupdates"
lastchange ""
state "noupdates"
swversion "2.19.3"
timeformat "24h"
timezone "Europe/London"
uuid "1c45c16d-3e69-4d17-a6a5-01ebddda18b0"
websocketnotifyall true
websocketport 443
whitelist
I have version 2.21.0 installed
Posted: Friday 09 December 2022 15:57
by Thorgal789
All seem fine ...
Can try if python is working
pi@raspberrypi:~ $ python3
Python 3.7.3 (default, Jan 22 2021, 20:04:44)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
Then
>>> import requests
>>> requests.get('https://api.github.com')
<Response [200]>
to exit.
Can try too with
Can you try if the plugin is still not working ?
Do you know why you have not the same ip here
Posted: Tuesday 13 December 2022 20:00
by hanszel
The Domoticz controller is on the wired network, The deConz bridge on a Deco wifi network. I forwarded port 80 and Dooticz came alive for a moment. After I removed the configuration of the deConz plugin in Domoticz and set it up again, the zigbee devices became visible in Domoticz. However, I am still unable to control most of the devices. Some lights respond but the switches do not. I get the following messages in the logs:
2022-12-13 19:58:10.069 Error: zigbee dongle: WebSocket Disconnected, reconnecting...
2022-12-13 19:58:10.069 Error: zigbee dongle: CConnection_connect, connect request from 'zigbee dongle' ignored. Transport is connecting.
this message is repeated every 10 seconds.
