Page 32 of 36
Re: machinon theme
Posted: Friday 27 November 2020 18:28
by waaren
DewGew wrote: Friday 27 November 2020 16:48 Last beta should work with both domoticz stable and beta. I just need some feedback on this.
Tested beta Machinon theme with Version: 2020.2 (build 12706) and it works OK. Any specifics you would like me to test?
Re: machinon theme
Posted: Friday 27 November 2020 18:54
by madpatrick
madpatrick wrote: Sunday 22 November 2020 11:02 Hi
I think i've found the problem :roll: :roll:
I've check a previous copy of the theme with the lastest version and i'm missing a piece in custom.js
In line 25:
$.ajax({
    url: "acttheme/js/moment.js",
    async: false,
    dataType: "script",
When i copy this back, the theme is working again
Tried the update, but the problem still remains
Copies back my old custom.js and it is working
Re: machinon theme
Posted: Friday 27 November 2020 19:52
by DewGew
madpatrick wrote: Friday 27 November 2020 18:54
In line 25:
$.ajax({
    async: false,
    dataType: "script",
Did you try beta branch?
Re: machinon theme
Posted: Friday 27 November 2020 19:54
by DewGew
waaren wrote: Friday 27 November 2020 18:28
I cant get graph zoom work correct when select only one graph.
Re: machinon theme
Posted: Friday 27 November 2020 20:01
by madpatrick
DewGew wrote: Friday 27 November 2020 19:52
Yes. Still on Beta version
Re: machinon theme
Posted: Friday 27 November 2020 20:06
by DewGew
madpatrick wrote: Friday 27 November 2020 20:01
Domoticz version?
Re: machinon theme
Posted: Friday 27 November 2020 20:08
by madpatrick
Domoticz v2020-2
The problem is in /settings/theme is not available anymore with the update
Re: machinon theme
Posted: Friday 27 November 2020 20:11
by DewGew
madpatrick wrote: Friday 27 November 2020 20:08 Domoticz v2020-2
I need buildno eg domoticz 2020.2 (build 11995)
Re: machinon theme
Posted: Friday 27 November 2020 20:13
by madpatrick
Version: 2020.2
Build Hash: 0
Re: machinon theme
Posted: Friday 27 November 2020 20:15
by DewGew
madpatrick wrote: Friday 27 November 2020 20:13 Version: 2020.2
Build Hash: 0
Domoticz stable?
Re: machinon theme
Posted: Friday 27 November 2020 20:17
by madpatrick
Yes. I'm not able to go to beta due compiled repo package
Re: machinon theme
Posted: Friday 27 November 2020 20:19
by DewGew
madpatrick wrote: Friday 27 November 2020 20:17 Yes. I'm not able to go to beta due compiled repo package
Ok you need to do a git pull or download latest machinon beta to mak it work. Since you have modified custom.js you have to do a git reset —hard then git pull
Re: machinon theme
Posted: Friday 27 November 2020 20:29
by madpatrick
My Machinon theme was the latest Beta version.
My Domoticz is Stable version and I can not update this to a Beta
I've made a fresh install of the Machinon theme
git clone https://github.com/domoticz/machinon.git machinon-beta
cd machinon-beta
git checkout beta
git pull
Still same.
My setting are lost (dark theme is back to default) and missing the Theme option in Settings
This version of custom.js is still working good for me
custom.js
(8.43 KiB) Downloaded 107 times
Re: machinon theme
Posted: Friday 27 November 2020 20:41
by DewGew
madpatrick wrote: Friday 27 November 2020 20:29 My Machinon theme was the latest Beta version.
cd machinon-beta
git checkout beta
git pull
Still same.
custom.js
Ah, you compiled domoticz your self thats why you dont get any buildno. Machinon get the build number to match your version. As before you need to modify your custom.js.
Re: machinon theme
Posted: Friday 27 November 2020 20:46
by madpatrick
Ok. That makes sense.
So version checker in Machinon theme is the reason.
I’m using a package from my distro which is compiled on stable version only
https://www.clearos.com/marketplace/ser ... Automation
Re: machinon theme
Posted: Friday 27 November 2020 21:22
by waaren
DewGew wrote: Friday 27 November 2020 19:54 I cant get graph zoom work correct when select only one graph.
Works like a charm on my system. Tested with temperature, custom sensor and percentage
Re: machinon theme
Posted: Friday 27 November 2020 23:17
by DewGew
waaren wrote: Friday 27 November 2020 21:22
Check this issue on github https://github.com/domoticz/Machinon/issues/58
Re: machinon theme
Posted: Saturday 28 November 2020 0:07
by waaren
DewGew wrote: Friday 27 November 2020 23:17 Check this issue on github https://github.com/domoticz/Machinon/issues/58
OK. See the same but is not a Machinon issue. Same behavior with default theme.
Re: machinon theme
Posted: Monday 30 November 2020 17:26
by Plantje
Got notified that version 16.3 and 17.1 are available. But on the website I only see 16.2
Are these bètas?
Re: machinon theme
Posted: Monday 30 November 2020 18:49
by madpatrick
I've updated the MAchinon theme to 1.17.1 with github, but I still get the popoup messaga that there is an update to 1.17.1
In theme.json is see
    "type": "theme",
    "name": "Machinon",
    "description": "Machinon custom theme, simple and light",
    "license": "GNU General Public License v3.0",
    "version":"1.17.1",
    "author": "EdddieN",
    "homepage": "https://www.github.com/domoticz/Machinon",
    "wiki": "https://www.domoticz.com/wiki/Machinon_Theme",
In setting/theme is see
Machinon theme V.1.16.2
