Tested beta Machinon theme with Version: 2020.2 (build 12706) and it works OK. Any specifics you would like me to test?DewGew wrote: Friday 27 November 2020 16:48 Last beta should work with both domoticz stable and beta. I just need some feedback on this.
- waaren
Re: machinon theme
- madpatrick
- Domoticz version: 2026.1
Re: machinon theme
Tried the update, but the problem still remainsmadpatrick wrote: Sunday 22 November 2020 11:02 Hi
I think i've found the problem![]()
I've check a previous copy of the theme with the lastest version and i'm missing a piece in custom.js
In line 25:When i copy this back, the theme is working againCode: Select all
$.ajax({ url: "acttheme/js/moment.js", async: false, dataType: "script", });
Copies back my old custom.js and it is working
- DewGew
- Domoticz version: V4.10618
Re: machinon theme
Did you try beta branch?madpatrick wrote: Friday 27 November 2020 18:54Tried the update, but the problem still remainsmadpatrick wrote: Sunday 22 November 2020 11:02 Hi
- DewGew
Re: machinon theme
I cant get graph zoom work correct when select only one graph.waaren wrote: Friday 27 November 2020 18:28Tested beta Machinon theme with Version: 2020.2 (build 12706) and it works OK. Any specifics you would like me to test?DewGew wrote: Friday 27 November 2020 16:48 Last beta should work with both domoticz stable and beta. I just need some feedback on this.
- madpatrick
Re: machinon theme
Yes. Still on Beta version
- DewGew
Re: machinon theme
Domoticz version?
- madpatrick
Re: machinon theme
Domoticz v2020-2
The problem is in /settings/theme is not available anymore with the update
- DewGew
Re: machinon theme
I need buildno eg domoticz 2020.2 (build 11995)madpatrick wrote: Friday 27 November 2020 20:08 Domoticz v2020-2
- madpatrick
Re: machinon theme
Version: 2020.2
Build Hash: 0
Build Hash: 0
- DewGew
Re: machinon theme
Domoticz stable?
- madpatrick
Re: machinon theme
Yes. I'm not able to go to beta due compiled repo package
- DewGew
Re: machinon theme
Ok you need to do a git pull or download latest machinon beta to mak it work. Since you have modified custom.js you have to do a git reset —hard then git pullmadpatrick wrote: Friday 27 November 2020 20:17 Yes. I'm not able to go to beta due compiled repo package
- madpatrick
Re: machinon theme
My Machinon theme was the latest Beta version.
My Domoticz is Stable version and I can not update this to a Beta
I've made a fresh install of the Machinon theme
git clone https://github.com/domoticz/machinon.git machinon-beta
cd machinon-beta
git checkout beta
git pull
Still same.
My setting are lost (dark theme is back to default) and missing the Theme option in Settings
This version of custom.js is still working good for me
cd machinon-beta
git checkout beta
git pull
Still same.
- DewGew
Re: machinon theme
Ah, you compiled domoticz your self thats why you dont get any buildno. Machinon get the build number to match your version. As before you need to modify your custom.js.madpatrick wrote: Friday 27 November 2020 20:29 My Machinon theme was the latest Beta version.
cd machinon-beta
git checkout beta
git pull
Still same.
custom.js
- madpatrick
Re: machinon theme
Ok. That makes sense.
So version checker in Machinon theme is the reason.
I’m using a package from my distro which is compiled on stable version only
https://www.clearos.com/marketplace/ser ... Automation
- waaren
Re: machinon theme
Works like a charm on my system. Tested with temperature, custom sensor and percentageDewGew wrote: Friday 27 November 2020 19:54 I cant get graph zoom work correct when select only one graph.
- DewGew
Re: machinon theme
Check this issue on github https://github.com/domoticz/Machinon/issues/58
- waaren
Re: machinon theme
OK. See the same but is not a Machinon issue. Same behavior with default theme.DewGew wrote: Friday 27 November 2020 23:17 Check this issue on github https://github.com/domoticz/Machinon/issues/58
Plantje
Re: machinon theme
Got notified that version 16.3 and 17.1 are available. But on the website I only see 16.2
Are these bètas?
Are these bètas?
- madpatrick
Re: machinon theme
I've updated the MAchinon theme to 1.17.1 with github, but I still get the popoup messaga that there is an update to 1.17.1
In theme.json is see
In setting/theme is see
"type": "theme",
"name": "Machinon",
"description": "Machinon custom theme, simple and light",
"license": "GNU General Public License v3.0",
"version":"1.17.1",
"author": "EdddieN",
"homepage": "https://www.github.com/domoticz/Machinon",
"wiki": "https://www.domoticz.com/wiki/Machinon_Theme",
Machinon theme V.1.16.2-= HP server GEN11 =- ZwaveJS-=- Domoticz v2026.2 -=- Dashticz =-
