Page 32 of 114
Posted: Saturday 06 January 2018 15:22
by alanlsmith
OK, after a bit more checking:
LightwaveRF dimmers cause an error when saying 'Set lamp to nn% and require 'Brighten lamp to..' and 'Dim lamp to..' whereas MiLight lamps will work with 'Set lamp to..'
However with both types when asked to 'Brighten lamp to..' or 'Brighten lamp by..' Google responds appropriately but always sets the light to that percentage rather than adjusting in by that percentage.
When asked to 'Dim lamp to..' or Dim lamp by..' now Google answers accordingly but seems to reliably switch the light off.
Although as I said in my previous post, the very first time I requested 'Dim by 10% to the MiLights, which were currently at 100%, I'm sure they did actually dim by that amount.
I know this sounds a bit contradictory and inconsistent but add voice recognition into the mix and it's a bit like trying to diagnose an occasional rattle in a car.
Posted: Saturday 06 January 2018 15:49
by Fasthook
Madgeni,
Thank you for the link, took me a few hours to get it to work but that had to do with my GHM. I moved the GHM to a different room in my house for setting up the link with Controlicz, and in that room it connected to a different AP with the same name.
When I moved the GHM back into the living room BAM it worked first try.
Will have to organise Domoticz a little bit for an extended testdrive.
Posted: Saturday 06 January 2018 16:55
by totof60
Hi Madgeni thanks for your job .
I have registered and tested connection OK, can you add me tot the Beta programme ?
And could you explain me how use it .
thanks
Chris
Posted: Saturday 06 January 2018 17:00
by Madgeni
totof60 wrote: Saturday 06 January 2018 16:55
thanks
Chris
Hi - if you can give me a bit of your email address, I'll find you and add you to the beta. See other posts here for examples.
Posted: Saturday 06 January 2018 17:46
by totof60
c**y@s*r
thanks !!
Chris
Posted: Saturday 06 January 2018 17:52
by davogr
Fantastic job Madgeni!! .
I have registered with dav**gmailDOTcom and tested connection OK, can you add me to the Beta programme please?
Posted: Saturday 06 January 2018 18:31
by totof60
thanks Madgeni
I'll test it
Posted: Sunday 07 January 2018 0:25
by guidopater
Hi Madgeni, do you still have some room for a testuser? Because I just registered to the forum, I don't have the right yet to send you a PM at the moment, but lets try to give a hint
(my <username> gmail_period_com), just to be clear: g****pater. I've already registered to Controlicz, so I should be "findably"
Greatz G
Posted: Sunday 07 January 2018 7:48
by christophe2836
Hello from France Madgeni,
Can you interject me in your beta project?
[email protected]
Posted: Sunday 07 January 2018 9:54
by boris91530
Hello madegeni Can you had me
[email protected] please
Posted: Sunday 07 January 2018 9:55
by boris91530
Hello madegeni Can you had me please?
[email protected]
Posted: Sunday 07 January 2018 17:33
by stress1ner
Hey Madgeni i started getting Controlicz is unable to connect - please check your config, it turns out that using reverse proxy with htpasswd is blocking controlicz from communicating with domoticz I was using it as an extra layer for outside access.
How are you guys using or configuring controlicz as far as security and accessing domoticz remotely, are you guys just using port foward with user name and pass word?
Posted: Sunday 07 January 2018 18:18
by alanlsmith
@madgeni
Just went to test whether 'Dim by nn%' would work from a lamp who's status was 'On' rather than 'Set Level'.
I found that not only did that work but I can now report that 'Dim by nn%' and 'Brighten by nn%' are now working reliably for both LightwaveRF dimmers and MiLight LED lamps.
Well done sir! (I'm assuming that it's you that must have sorted it)
Posted: Sunday 07 January 2018 18:19
by Madgeni
yay! yes, been testing most of the day.. really want the Google testing to work
Posted: Sunday 07 January 2018 19:11
by alanlsmith
Madgeni wrote: Sunday 07 January 2018 18:19
Well I think you've got a pretty good chance of that.
Oh... Also 'Set to nn%' now works as well as 'Dim to..' and 'Brighten to..' so I think you should have covered all the possibilities. Good luck and thanks for your perseverance.
Posted: Sunday 07 January 2018 19:20
by boris91530
Does it s possible to read the température
Posted: Sunday 07 January 2018 19:27
by matzeb74
Im also new to Domoticz and wanna try controlic. Im already registered to controlic but it say it can not connect. If i Try the host and port in Browser i reach my domotic.
Where is my error.
My mail by controlic is mat***74@gmail****.
Gesendet von meinem SM-G935F mit Tapatalk
Posted: Sunday 07 January 2018 19:44
by Tyturion
Madgeni wrote: Saturday 06 January 2018 10:07
ok, and can someone try 'white' now?
You are the man! Work well with the word "white".
I made a funny observation though: I control all devices in German, but for this particular command it only accepts the color in English.
Would you have an idea why that is?
Thanks a lot for all the efforts you put into this.
Best,
Thomas
Posted: Sunday 07 January 2018 20:34
by Madgeni
Tyturion wrote: Sunday 07 January 2018 19:44
Best,
Thomas
Ahaha that would be because I hard coded it to route white through colour, rather than Kelvin. I'm rather ashamed of the hardcoding, but some times you have to. Will add weiß also - update - try now?
Posted: Sunday 07 January 2018 22:51
by HallezJB
Bonjour Tout le Monde ça fonctionne. Donc voici un récap Pour les Français:
- (voir FAQ de controlicz) Assurez-vous que votre Domoticz utilise HTTPS !!!
- Dans Domoticz Aller dans Réglage, plus d'options, modifier les utilisateurs, ajouter un identifiant CONTROLICZ avec un mot de passe que vous retiendrez pour le point suivant. Cochez Plans, Interrupteurs, Températures. Puis paramétrez les dispositifs en ajoutant les boutons que vous souhaitez activer sous google home.
- Puis, Il faut impérativement que lorsque vous créer votre compte sur Controlicz que vous y rentriez le même Email que sur votre Google Home, généralement c'est par
[email protected]. dans le formulaire de remplissage, mettez le nom que vous avez donnée précédemment pour l'utilisateur CONTROLICZ et son mot de passe associé puis... Au Testez la connexion si tout est bon on poursuit:
Quand Madgeni vous enverra le lien, il faudra cliquer sur le premier lien... Et c'est tout !!!!
Quand vous lancerez Google Home... vous irez dans Contrôle de la maison, cliquez sur le +N en bas à droite puis vous trouverez [test] Home Controlicz et suivre les instructions... voilà...
Toutes les commandes de votre domoticz vont apparaître sur le Google Home "Contrôle de la Maison"... A vous de modifier sur ce dernier le nom et l'emplacement des pièces...
Merci beaucoup pour ce beau travail !!!!!
