Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
raptorjr
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by raptorjr »
This look very cool so I thought I should try it.
It started pretty well, my devices was found. Two switches, a temperature and a thermostat.
Switches worked.
But if I tried to ask for temperature Alexa thought every time that I asked for a temperature in a city. So every time it ended with not finding the city, or giving me the forecast of some strange city in US that was close to the name om my device. Does temperature devices work with this skill?
Also problem with my thermostat. Asking to change temperature on my thermostat device. Always got the answer that my profile had several thermostat devices and that I should tell which one to use. But I only have one.
So I tried to set the Description to friendlier names, remove all from Alexa, and tried to discover again. And now Alexa can't find any devices at all. Tried several times.
Controlicz webpage still says that it can connect to my Domoticz, so that shouldn't be a problem.
Anything I could try to fix the problem?
Thank you for your help.
Madgeni
Post by Madgeni »
Hi - just PM me your email address.
Some of the issues will be with Alexa (hearing/mishearing) - but it should be finding devices
raptorjr
Post by raptorjr »
Try to send you another PM, but it's just stuck in the outbox. I can write here instead.
I tried to search for devices and now it works again =)
But still problems with getting temperature and thermostat.
Probably 9/10 times when asking for temperature, Alexa thinks I want the temperature for a location. But Alexa cant find a location with my device name.
Setting the thermostat works almost every time, even though it gets it wrong some times. But increase/decrease don't work. Every time I try Alexa says that the thermostat is not responding, but still sets it to 0 degrees. But no problem to set to a specific temperature. But no increase/decrease.
Also a question. Is it possible to have the same name for two different types of devices, and the skill is able to separate them? Like it is not possible to ask a switch for the temperature? I don't have it like that now, just wondering.
hrshukla
Post by hrshukla »
Thanks, Just PM’ed you.
Madgeni
Post by Madgeni »
You can now contact me via your profile page on Controlicz - if you have any questions, concerns or issues
raptorjr
Post by raptorjr »
Does anyone else also have problem with getting Alexa to understand when you want the temperature of a sensor?
Anything I could try so that Alexa don’t think I’m asking for a location?
Madgeni
Post by Madgeni »
Is it a naming issue? Sometimes Alexa does completely mishear - and renaming it as something else has worked
raptorjr
Post by raptorjr »
Madgeni wrote: Tuesday 20 February 2018 18:33 Is it a naming issue? Sometimes Alexa does completely mishear - and renaming it as something else has worked
I wont mind on the theremostat, it’s not that important. But switches and temperature I would like to work.
I have a fish pond that have two switches and one temperature. The switches is used to fill water or turn on a heater. They are called Fish Pond Water and Fish Pond Heat. They work almost every time. The times they miss it is probably because of noise or my english.
The temperature meter I have called just Fish Pond. And it almost never work. Instead I get a weather forcast for West Lake.
If it would be a naming problem the switches wouldn’t work that good?
Chakkie
Post by Chakkie »
Hi Madgeni,
I have created a Virtual switch with a dimmer function. However Alexa only recognised as a simple ON and Off switch. I was wondering if it is possible that Alexa can see it as dimmer type lamp.
lshield
Domoticz version: 2023.1
Post by lshield »
Hi Madgeni,
I think I made an account on the website but I can't log in or anything.
Madgeni
Post by Madgeni »
did you get an email from Controlicz? If you've forgotten your password, you can reset it
Madgeni
Post by Madgeni »
Chakkie wrote: Sunday 25 February 2018 18:59 Hi Madgeni,
Can you forget that device and do a re-discovery?
lshield
Post by lshield »
Madgeni wrote: Tuesday 27 February 2018 21:44 did you get an email from Controlicz? If you've forgotten your password, you can reset it
I didn't. I tried the signup again and it went through so I'm not sure what I did wrong before.
Chakkie
Post by Chakkie »
Madgeni wrote: Tuesday 27 February 2018 22:00
You are awesome. The switch is now recognized as dimmer. Thank you for your work. Just make a donation :).
deennoo
Post by deennoo »
Hi there,
I'm one of the lucky french user who recieved Amazon Echo in french Language (this works so great, and that to much user friendly to call alexa instead of Ok Google...)
Controlicz Skill isn't available on beta french sklills store, how to add it ?
http://domo-attitude.fr
Madgeni
Post by Madgeni »
I've been asking to get Controlicz onto the beta - i'll let you know
Madgeni
Post by Madgeni »
I've submitted Alexa for French - will let you know when it's live :)
remb0
Post by remb0 »
I have a vacuum cleaner which I can control with a selector: clean, stop, find
is it possible to use a selector in alexa? Or should I create a virtual switch that is simpler: on/off and a script to control the selector?
Madgeni
Post by Madgeni »
Hi - Selector switches are still not available in Alexa - they should be available in Google Home soon
thruhge
Post by thruhge »
I have a question about blinds, mine have a open/stop/close option. does controlicz support this?
