Thanks!!!!
I'm not a programmer but tell me if I could help you with something.
Maybe we'll request read only access to your Domoticz server but first I'll ask several Alpha users to test for us since I don't seem to have the problem as is galadril
Thanks!!!!
pvm wrote:Any news on the device compatibility questions?
We have some changes ready in the beta to let Google Play Store know we support all screen sizes.
We don't actively block screen sizes or devices though.
One possibly noteworthy thing: I only see the 'Domoticz Lite' app, not the premium version. I don't know whether something should have changed already? I deleted the playstore cache, did not help
I've tried to find information regarding whether this app supports notifications from Domoticz on my Raspberry. Does it?
My wish is to be alarmed if fire breaks out or somebody enters my house when the alarm is armed.
RickDB wrote:Thanks for adding EvoHome supports!
Per zone permanent override is now implemented. I also fixed the issue with the Evohome device being too high. The set button overlapping the title is still a problem, though.
Temporary override is a bit trickier. We need to develop a widget to set both a temperature AND an end date and time. The Honeywell comfort app sets the end time to the next scheduled set point by default, but Domoticz doesn't provide access to the Evohome schedules (yet?).
The camerafunction is also now working, but the refresh of pictures inside the app seems to strange.
When I start the app I get new images, (I see that on the timestamp) but opening a specific camera or change tab and go back to the cameras don´t trigger an updated picture?
so
Possible to explain when and how the pictures are updated or maybe even autoupdate 1s interval (or setting X seconds) and/or an "update" picture button?
Also -> Have fixed the outside WIFI function? meaning using 3g/4g without VPN?
i have a scene with :
blind A- close
Blind B- open
Blind C- Close
Blinde D- Open
if they are all close only open B/D but if all open, the A/C goes closed, then if i want close/open all when are mixed?
i had a group with all blind that in domoticz i can click on or off when they are mixed, that not happen on app because if the status of group on app are off and the blind are mixed how can i close? have to open group and then close? or close every blind individual?
other think is:
my blind system not have stop button, so if blinds are close and want to all stay at middle i have to click ON (group) to open,wait 10s and that click On again to stop at middle. this happen with close too, OFF to close and OFF again to stop.
thanks
Changed/fixed in Alpha version.
Will make it to production after testing.
Could you keep an eye on this please?
If it's not fixed with the next release, could you hit me up again?
jjvdveen wrote:Per zone permanent override is now implemented. I also fixed the issue with the Evohome device being too high. The set button overlapping the title is still a problem, though.
Oh, thank this guy for adding and enhancing Evo Home support guys!
Daniel
We're working hard with Gizmocus on implementation of native Google Cloud Messaging
blind A- close
Blind B- open
Blind C- Close
Blinde D- Open
other think is:
thanks
Thx for the great app.
But have a issue when i want to look into my energy logs which are measured by a YouLess.
When i hit the log (day,Month,Year) i see the following error and can't look into the logs.
All other logs are working fine only the YouLess doesn't work...
App: Domoticz 0.1.222 Premium System: Domoticz [beta] 2.4298
Raspberry 2b Phone: HTC One M9 - Lollipop Sense 7
2016-01-24 21.46.04.png (60.25 KiB) Viewed 2636 times
2016-01-24 21.48.03.png (172.33 KiB) Viewed 2636 times
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Recently tried the app, but at this point it is not working for me, this is because of one thing, SmartWares radiator valves.
I've installed SmartWare valves throughout my house, in Domoticz they show as both a switch and a utility. In the web interface I can set the valves to any temperature, but in the app they can't be set in the "Other" tab, just seen. I can't set them.
