Page 31 of 49
Re: Dashticz - Module - Garbage collector
Posted: Saturday 07 March 2020 19:45
by Lokonli
git checkout beta
git pull
Posted: Saturday 07 March 2020 19:51
by peet3kabo
Lokonli wrote:
klaaspiet wrote: Wednesday 29 January 2020 21:25
peet3kabo wrote: Saturday 25 August 2018 11:15 Rob, is it possible to implement the Omrin afvalkalender?
There is an app available from them, maybe to get the info you need? App called "Omrin Afval"
Otherwise it's only a PDF that you get and then I will try to implement it as an Ical into Dashicz but have to figure out how that goes,
is there some progress for this item
Merged into beta.
Thanks a lot, will check
Verstuurd vanaf mijn ONEPLUS A6013 met Tapatalk
Posted: Sunday 08 March 2020 11:14
by Alfagek
Lokonli wrote: Thursday 20 February 2020 19:16
Merged into beta.
I updated to 3.4.0. (nice with the pics in the newsfeed 8-) )
I tried to use Omrin. But i only get a black stripe on the column. So he does something, but he doesn't show something.
What i'm doing wrong?
config['garbage_company'] = 'omrin';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 'My zipcode';
config['garbage_street'] = 'My street';
config['garbage_housenumber'] = '9';
config['garbage_maxitems'] = '3';
columns[6] = {};
columns[6]['blocks'] = [['garbage']];
columns[6]['width'] = 4;
Posted: Sunday 08 March 2020 11:16
by Lokonli
Try with:
columns[6]['blocks'] = ['garbage'];
Posted: Sunday 08 March 2020 11:24
by Alfagek
Lokonli wrote: Sunday 08 March 2020 11:16 Try with:
Then i get a real nice mess :lol: . He is putting all the things off screen 1 and 2 on 1 screen.
But still a black stripe, with no info.
Even if i empty the complete config.js and only put the next in it, i only get a black stipe
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://xxx.xxx.xxx.xxx:8080';
config['domoticz_refresh'] = '3';
config['auto_positioning'] = 0; // Use 0 thisifyou have defined your own columns
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd D MMM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['hide_topbar'] = 1;
config['last_update'] = 0;
//config['standby_after'] = 5;
config['default_news_url'] = 'http://www.nu.nl/rss/Algemeen';
columns[6] = {} ;
columns[6]['width'] = 12;
var screens = {}
screens[1] = {}
screens[1]['columns'] = [6]
Posted: Sunday 08 March 2020 19:56
by klaaspiet
Alfagek wrote: Sunday 08 March 2020 11:24
var config = {}
columns[6] = {} ;
var screens = {}
screens[1] = {}
I got the same problem
Posted: Monday 09 March 2020 0:04
by Gianni
why do you use double [[
Posted: Monday 09 March 2020 0:06
by Gianni
Lokonli wrote: Thursday 23 January 2020 20:19
evandenbroek wrote: Thursday 23 January 2020 19:44 I cannot retrieve data for Uden. I got the message "Laden...". I'm using version 3.3.4 beta.
Fixed in latest beta.
still keep saying 'laden' on my version
Posted: Monday 09 March 2020 0:22
by Gianni
looking in my apache error log i see this error
[Mon Mar 09 00:03:22.403972 2020] [:error] [pid 3681] [client xxx.xxx.xxx.Xxx:xxxx] PHP Warning:  file_get_contents(https://www.ophaalkalender.be/calendar/findstreets/?query=xxxxxxxxxxxxxxxxxxxxxx): failed to open stream: operation failed in /var/www/html/homecontrol/vendor/dashticz/cors.php on line 3, referer: http://10.10.40.3/homecontrol/
this is line 3
echo file_get_contents($_SERVER["QUERY_STRING"]);
Posted: Monday 09 March 2020 8:11
by Lokonli
Gianni wrote: Monday 09 March 2020 0:22 looking in my apache error log i see this error
this is line 3
I see you are using ophaalkalender.be. Probably something changed at their side. Can you provide a valid streetname, housenumber and zipcode? Then I'll test.
Posted: Monday 09 March 2020 11:15
by Gianni
pb @Lokonli
Posted: Monday 09 March 2020 11:29
by klaaspiet
Gianni wrote: Monday 09 March 2020 0:04 why do you use double [[
Aantekening 2020-03-09 112723.png (20.42 KiB) Viewed 2289 times
this is what i got
config['google_api_key'] = 0;
config['garbage_calendar_id'] = 0;
config['garbage_zipcode'] = 'xxxxxx';
config['garbage_street'] = 'xxxx';
config['garbage_housenumber'] = 'xx';
config['garbage_housenumberadd'] = 0;
columns[3] = {}
columns[3]['blocks'] = [buttons.buienradar,'garbage']
columns[3]['width'] = 2;
Posted: Monday 09 March 2020 13:01
by Lokonli
klaaspiet wrote: Monday 09 March 2020 11:29
this is what i got
columns[3] = {}
Did you already update to the latest beta? :
git checkout beta
git pull
Can you remove the following line from your CONFIG.js:
Can you send me your zipcode and housenumber by PM, then I'll test tonight.
Posted: Monday 09 March 2020 16:29
by Alfagek
:oops: Stupid me.
That was the problem, now he is working.
@lokonli: Thanks for putting Omrin to it
Posted: Monday 09 March 2020 19:37
by Lokonli
klaaspiet wrote: Sunday 08 March 2020 19:56
var config = {}
columns[6] = {} ;
var screens = {}
screens[1] = {}
There was a small bug in the Omrin garbage module for housenumbers > 9.
This has been fixed in latest beta.
Posted: Thursday 19 March 2020 10:43
by JanvdW
When I implement the garbage collector I get a Dashticz message in red at the bottom of the screen: "Domoticz error! Garbage requires a PHP enabled web server".
I tried to uninstall php-xml, php-curl, php and apache2 and did a new install as mentioned on https://www.domoticz.com/wiki/Dashticz_ ... stallation, but it doesn't change. When I remove the garbage block from the Dashticz screen the error disappears.
I run Dashticz and Domoticz on a RPI with an OSMC image.
Does anyone know how this can be solved?
Posted: Thursday 19 March 2020 13:08
by Lokonli
JanvdW wrote: Thursday 19 March 2020 10:43 When I implement the garbage collector I get a Dashticz message in red at the bottom of the screen: "Domoticz error! Garbage requires a PHP enabled web server".
You are using outdated instructions.
Try this:
https://dashticz.readthedocs.io/en/mast ... ation.html
Posted: Saturday 18 April 2020 15:18
by peerkersezuuker
It seems that Cure has changed to mijnafvalwijzer.nl.
How do i switch to this new garbage data provider ?
Not Working anymore : https://afvalkalender.cure-afvalbeheer. ... n/5731LB-6
Working (at least i get some json data) : http://json.mijnafvalwijzer.nl/?method= ... isnummer=6
Peer
Posted: Saturday 18 April 2020 22:08
by Lokonli
peerkersezuuker wrote: Saturday 18 April 2020 15:18 Hi,
Peer
This one is easy (I hope). Switch to mijnafvalwijzer.nl :)
config['garbage_company'] = 'mijnafvalwijzer';
Posted: Sunday 19 April 2020 11:20
by peerkersezuuker
Hi Lokonli,
Thank you, that made a little fix (i think).
When i connect to /vendor/dashticz/garbage/index.php?service=mijnafvalwijzer&sub=undefined&zipcode=5731LB&nr=6&t=
i get a pretty json response :
date: "2020-04-01",
title: "restafval"
date: "2020-04-06",
title: "pmd"
date: "2020-04-06",
title: "papier"
date: "2020-04-07",
title: "gft"
date: "2020-04-08",
title: "gft"
date: "2020-04-15",
title: "restafval"
date: "2020-04-20",
title: "pmd"
date: "2020-04-21",
title: "gft"
date: "2020-04-29",
title: "restafval"
date: "2020-05-04",
title: "pmd"
date: "2020-05-04",
title: "papier"
date: "2020-05-09",
title: "gft"
date: "2020-05-13",
title: "restafval"
date: "2020-05-18",
title: "pmd"
date: "2020-05-19",
title: "gft"
date: "2020-05-27",
title: "restafval"
date: "2020-06-02",
title: "gft"
date: "2020-06-06",
title: "pmd"
date: "2020-06-10",
title: "restafval"
date: "2020-06-15",
title: "papier"
date: "2020-06-15",
title: "pmd"
date: "2020-06-16",
title: "gft"
date: "2020-06-24",
title: "restafval"
date: "2020-06-29",
title: "pmd"
date: "2020-06-30",
title: "gft"
date: "2020-07-08",
title: "restafval"
date: "2020-07-13",
title: "pmd"
date: "2020-07-13",
title: "papier"
date: "2020-07-14",
title: "gft"
date: "2020-07-22",
title: "restafval"
date: "2020-07-27",
title: "pmd"
date: "2020-07-28",
title: "gft"
date: "2020-08-05",
title: "restafval"
date: "2020-08-10",
title: "pmd"
date: "2020-08-10",
title: "papier"
date: "2020-08-11",
title: "gft"
date: "2020-08-19",
title: "restafval"
date: "2020-08-24",
title: "pmd"
date: "2020-08-25",
title: "gft"
date: "2020-09-02",
title: "restafval"
date: "2020-09-07",
title: "pmd"
date: "2020-09-07",
title: "papier"
date: "2020-09-08",
title: "gft"
date: "2020-09-16",
title: "restafval"
date: "2020-09-21",
title: "pmd"
date: "2020-09-22",
title: "gft"
date: "2020-09-30",
title: "restafval"
date: "2020-10-05",
title: "pmd"
date: "2020-10-05",
title: "papier"
date: "2020-10-06",
title: "gft"
date: "2020-10-14",
title: "restafval"
date: "2020-10-19",
title: "pmd"
date: "2020-10-20",
title: "gft"
date: "2020-10-28",
title: "restafval"
date: "2020-11-02",
title: "pmd"
date: "2020-11-02",
title: "papier"
date: "2020-11-03",
title: "gft"
date: "2020-11-11",
title: "restafval"
date: "2020-11-16",
title: "pmd"
date: "2020-11-17",
title: "gft"
date: "2020-11-25",
title: "restafval"
date: "2020-11-30",
title: "papier"
date: "2020-11-30",
title: "pmd"
date: "2020-12-01",
title: "gft"
date: "2020-12-09",
title: "restafval"
date: "2020-12-14",
title: "pmd"
date: "2020-12-15",
title: "gft"
date: "2020-12-23",
title: "restafval"
date: "2020-12-28",
title: "pmd"
date: "2020-12-28",
title: "papier"
But the icon in my dashboard keeps "Loading" ("Laden" in Dutch)
And when i open inspect is see an error about the mapGarbageType :
bundle.js?t=1:26 Uncaught TypeError: Cannot use 'in' operator to search for 'length' in 1
    at isArrayLike (bundle.js?t=1:26)
    at Function.each (bundle.js?t=1:26)
    at mapGarbageType (<anonymous>:456:11)
    at <anonymous>:233:34
    at Array.map (<anonymous>)
    at Object.success (<anonymous>:229:14)
    at fire (bundle.js?t=1:37)
    at Object.fireWith [as resolveWith] (bundle.js?t=1:37)
    at done (bundle.js?t=1:37)
    at XMLHttpRequest.<anonymous> (bundle.js?t=1:37)
Regards Peer
