Page 31 of 31
Re: Cheap chinese z-wave products
Posted: Saturday 30 March 2019 11:44
by nmaster
tonbor wrote: Saturday 16 March 2019 21:33
nmaster wrote: Saturday 22 December 2018 12:33 Hi,
Does someone already used this product ?
https://nl.aliexpress.com/item/Spetu-Z- ... 1edfaMbysE
Did you buy it and was it recognized?
Yes I bought one, just received it.
It's working, but product and manufacturer is unknown.
At include, it actually add a switch, so it can be used.
Posted: Saturday 06 April 2019 11:41
by tonbor
Posted: Saturday 06 April 2019 12:12
by tonbor
coolcamneo2019 wrote: Thursday 28 March 2019 16:10
tonbor wrote: Monday 18 March 2019 20:48 Yes it works, easy setup, AAA batteries, and the discription tells that you need to replace the batteries after 2 to 3 years.
as i know.. the door sensor are not zwave certified.. and price is higher a lot than neo coolcam door sensors
http://bit.ly/2OyaKom
Wrong https://products.z-wavealliance.org/products/2027
Posted: Saturday 06 April 2019 14:35
by krizzz
Anybody here connected their dishwasher to the Neo coolcamplug?
Posted: Saturday 06 April 2019 20:47
by jjnh
Yep I tried connecting my dishwasher. No joy. The plug went into safe mode (ref flash) because of too much power drain (more than 10 amps). After unplugging the plug was reset and it works fine.
Posted: Monday 08 April 2019 10:48
by LouiS22
krizzz wrote: Saturday 06 April 2019 14:35 Anybody here connected their dishwasher to the Neo coolcamplug?
I believe Qubino has a 16Amp rated plug. Of course price will be higher than Neo. On the other Qubino is a trusted brand made in EU.
Posted: Saturday 27 April 2019 18:33
by Pandabeer
I have 4 Heiman HS1SA-Z smart smoke sensor - I try them to include on the Aaotec Zwave USB dongle which is connected to a Raspberry Pi with the latest version of Domoticz (4.10629) All other Zwave sensors (like thermostat, door switch etc) are working - but I keep unknown in the list for these Heiman sensors - I already removed battery and puch the reset button to restore the sensors to factory default as wel I exclude the sensors first from the Aeotec USB - then I try to include - without succes; I can't get Heiman Sensor in the hardware list of Zwave clients ;( - I have also a CO sensor from Heiman - installed a couple of months ago without any problem... can somebody advice me?
Thank you for your time and help
Br.
Peter
Posted: Wednesday 08 May 2019 12:41
by sincze
https://s.click.aliexpress.com/e/cV9YLDKC
Posted: Saturday 14 September 2019 14:46
by xeonpj
Hi friends, I bought this product on AliExpress, the association with domoticz is correct, but I don't see devices to select. In the hardware part, it appears and assigns its node ID.
NEO Coolcam Smart Home Z Wave Plus interruptor de cortina inteligente para cortina motorizada eléctrica persiana enrollable
https://es.aliexpress.com/item/33040254 ... 63c07lBl9n
Posted: Friday 05 June 2020 17:52
by Gruzi
Does anybody have ideas for a cheap zwave dimmer?
For example this one:
https://www.alibaba.com/product-detail/ ... 458bET53H4
Posted: Saturday 06 June 2020 9:46
by lost
Can't even find the manufacturer in:
domoticz/Config/
So no support. Could be done with full documentation by you, following OZW lib developers directives, but that's an added difficulty. Especially if documentation is bad.
Anyway, my advice is always the same: Avoid 220V powered stuff from pure Chinese manufacturers. Stick to battery ones, less fire prone... Very bad experience with Neo in the past.
