Cheap chinese z-wave products
nmaster
Domoticz version: 3.6304
Re: Cheap chinese z-wave products
Post by nmaster »
tonbor wrote: Saturday 16 March 2019 21:33
nmaster wrote: Saturday 22 December 2018 12:33 Hi,
Does someone already used this product ?
https://nl.aliexpress.com/item/Spetu-Z- ... 1edfaMbysE
Did you buy it and was it recognized?
Yes I bought one, just received it.
It's working, but product and manufacturer is unknown.
At include, it actually add a switch, so it can be used.
tonbor
Post by tonbor »
tonbor
Post by tonbor »
coolcamneo2019 wrote: Thursday 28 March 2019 16:10
tonbor wrote: Monday 18 March 2019 20:48 Yes it works, easy setup, AAA batteries, and the discription tells that you need to replace the batteries after 2 to 3 years.
as i know.. the door sensor are not zwave certified.. and price is higher a lot than neo coolcam door sensors
http://bit.ly/2OyaKom
Wrong https://products.z-wavealliance.org/products/2027
krizzz
Post by krizzz »
Anybody here connected their dishwasher to the Neo coolcamplug?
jjnh
Domoticz version: 2026.2
Post by jjnh »
Yep I tried connecting my dishwasher. No joy. The plug went into safe mode (ref flash) because of too much power drain (more than 10 amps). After unplugging the plug was reset and it works fine.
Odroid N2+ 4GB, Updated to 2025.2, with an RfxTrx433E, Zigbee2MQTT with Slaesh's CC2652RB and more than 65 devices active, Zwave-JS-UI, SolarEdge ModBus, Daikin (via Faikin), ESPEasy devices, iRobot and P1 connected.
LouiS22
Post by LouiS22 »
krizzz wrote: Saturday 06 April 2019 14:35 Anybody here connected their dishwasher to the Neo coolcamplug?
I believe Qubino has a 16Amp rated plug. Of course price will be higher than Neo. On the other Qubino is a trusted brand made in EU.
Pandabeer
Domoticz version: 10265
Post by Pandabeer »
I have 4 Heiman HS1SA-Z smart smoke sensor - I try them to include on the Aaotec Zwave USB dongle which is connected to a Raspberry Pi with the latest version of Domoticz (4.10629) All other Zwave sensors (like thermostat, door switch etc) are working - but I keep unknown in the list for these Heiman sensors - I already removed battery and puch the reset button to restore the sensors to factory default as wel I exclude the sensors first from the Aeotec USB - then I try to include - without succes; I can't get Heiman Sensor in the hardware list of Zwave clients ;( - I have also a CO sensor from Heiman - installed a couple of months ago without any problem... can somebody advice me?
Thank you for your time and help
Br.
Peter
Little expert running Domoticz on a Raspberry Pi
Toon Thermostat | Mi-Light | Z-Wave Thermostat valves and CO2 / fire detection units | KiKa | Heat-IT Zwave thermostat |
sincze
Domoticz version: 2024.4
Post by sincze »
https://s.click.aliexpress.com/e/cV9YLDKC
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
xeonpj
Post by xeonpj »
Hi friends, I bought this product on AliExpress, the association with domoticz is correct, but I don't see devices to select. In the hardware part, it appears and assigns its node ID.
NEO Coolcam Smart Home Z Wave Plus interruptor de cortina inteligente para cortina motorizada eléctrica persiana enrollable
https://es.aliexpress.com/item/33040254 ... 63c07lBl9n
Gruzi
Post by Gruzi »
Does anybody have ideas for a cheap zwave dimmer?
For example this one:
https://www.alibaba.com/product-detail/ ... 458bET53H4
lost
Post by lost »
Can't even find the manufacturer in:
domoticz/Config/
So no support. Could be done with full documentation by you, following OZW lib developers directives, but that's an added difficulty. Especially if documentation is bad.
Anyway, my advice is always the same: Avoid 220V powered stuff from pure Chinese manufacturers. Stick to battery ones, less fire prone... Very bad experience with Neo in the past.
