Simple LMS LUA volume dimmer
simon_rb
- Target OS: -
Re: Simple LMS LUA volume dimmer
Spot on mate. If I slide it then it crashes. If I just click to the next level then the volume will change but there is a 15-20 sec delay... No as smooth as the original way before we used the JSON.. Not even sure the delay would help! Back to square one with it!
Any ideas? Cheers
Nautilus
I have a couple of dummy dimmers (well, they are based on a hw profile and thus work a bit differently as I described earlier) and I have scripts that react on their status (on/off) and sValue changes. It does not involve any json reading (though I have plenty of other scripts that do, and they take a bit longer to run sometimes) but work very smoothly, no matter if you click it or slide it. So maybe the sValue would be the way to go after all, at least once the switch is already on (you could totally ignore sValue = 0 and in case it is, then read the level with json). Even with reading the level with json I don't think it should take quite that long, it could be there are some issues with the 100 step dummy dimmer implementation as there's the sValue offset etc. Just speculating though...
And maybe the best option would be to test the other type of dummy dimmer (for which the examples in the first posts of this thread refers to). To do this you need to go to the device tab and add manual device (left top). For hardware select the dummy hardware, for switch type select dimmer and for subtype select e.g. LightwaveRF (rest can be default). Then you should have a dimmer that has sValue steps from 0 to 31 and which does not change the sValue to 0 when turned off/on. So you can keep setting the volume with this script:
As suggested by the thread starter, to control the player on/off status you can put to on action of the Lounge Touch V something like this:
"http://192.168.1.10:9000/status.html?p0 ... 2.168.1.10" (change the first address to LMS ip and port and second to player ip). For off action change power_on to power_off. Then the device script can just control the volume.
For time script you should use something like (rounding = math.floor not tested):
if devicechanged['Lounge Touch V'] ~= 'Off' then
volume = otherdevices_svalues['Lounge Touch V']
calcvolume = (volume*100) / 31
commandArray['Lounge Touch']='Set Volume '..calcvolume
return commandArray"http://192.168.1.10:9000/status.html?p0 ... 2.168.1.10" (change the first address to LMS ip and port and second to player ip). For off action change power_on to power_off. Then the device script can just control the volume.
json = (loadfile '/home/pi/domoticz/scripts/lua/json.lua')()
file = assert(io.popen('curl \'http://192.168.1.26:9000/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}\''))
raw = file:read('*all')
file:close()
deviceinfo = json:decode(raw)
volume = deviceinfo.result["mixer volume"]
powerstatus = deviceinfo.result.power
switchVolume = otherdevices_svalues['Lounge Touch V']
calcVolume = math.floor((switchVolume*100 / 31)+0.5)
if tonumber(volume) ~= tonumber(calcVolume) and tonumber(powerstatus) == 1 then
commandArray['OpenURL'] = 'http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=265&switchcmd=Set%20Level&level='..volume
if tonumber(powerstatus) == 1 and otherdevices['Lounge Touch V'] == 'Off' then
if tonumber(powerstatus) == 0 and otherdevices['Lounge Touch V'] ~= 'Off' then
commandArray['Lounge Touch V'] = 'Off'
Last edited by Nautilus on Monday 07 November 2016 13:49, edited 3 times in total.
simon_rb
- Target OS: -
I'll try them and see what happens. I had the power on setup already. I'll let you..
Nautilus
I have one player for outdoor speakers where perhaps this kind of volume switch would be nice as well. So I went ahead and tested and there's some things I did not consider. But this seems to work for setting the volume. You need to create one user variable as well, type integer to store the volume level before "Off" as for some reason this new dummy dimmer seems to set it to 0 when Off. So when turning it back to On, the value will be taken from the uservariable.simon_rb wrote:I'll try them and see what happens. I had the power on setup already. I'll let you..
if devicechanged['Lounge Touch V'] ~= 'Off' and devicechanged['Lounge Touch V'] ~= nil then
if tonumber(otherdevices_svalues['Lounge Touch V']) > 0 then
calcvolume = math.floor((volume*100/32)+0.5)
print('Setting Lounge Touch volume to '..calcvolume)
commandArray['Variable:LoungeTouchVolume'] = otherdevices_svalues['Lounge Touch V']
volume = tonumber(uservariables['LoungeTouchVolume'])
Also note that this cannot be used to mute the player as the switch turns always off when sValue goes to 0 and thus turn the player off.
Nautilus
The timescript which works for me (does not result to 1:1 volume because of 32 steps available only, the first check of uservariable is the same as checking if the player is "On", I turn the volume switch of elsewhere):
if uservariables['SBTerassiStatus'] == 'On' then
file = assert(io.popen('curl \'http://url/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["mac",["status","-","1",""]]}\''))
file:close()
print(switchVolume)
calcVolume = math.floor((volume/100*31)+0.5)
print(calcVolume)
os.execute('curl -s "http://url/json.htm?type=command¶m=switchlight&idx=IDX&switchcmd=Set%20Level&level='..calcVolume..'" &')
os.execute('curl -s "url/json.htm?type=command¶m=switchlight&idx=IDX&switchcmd=Set%20Level&level='..calcVolume..'" &')
simon_rb
- Target OS: -
Cheers dude! Should I use my exiting 100 step dimmer or create a new one with 32 steps?
simon_rb
- Target OS: -
I've added a new 32 step dimmer.. Got the device script to work but not the Time script.. What uservariable should I use? Should it be Lounge Touch V or Lounge Touch for me? I haven't set a user variable so should I just remove it? Here is mine..
The volume changes beautifully from the new 32 step Lounge Touch V switch (Renamed and will delete the original one Lounge Touch V). However if I turn off the dimmer the player doesn't turn off. It doesn't turn on either (basically doesn't reflect the player power status or have control of it) Good news is the On doesn't set the player to 0%
Just tried setting the volume via Siri via eDomoticz/Homebrige and even though it says "On" the volume changes just fine! Super, well done mate thats that bit fixed, can throw away the JSON Level stuff haha. Just need to get the switch to turn on and off and to have it grab the volume from the LMS player
if uservariables['Lounge Touch'] == 'On' then
file:close()
print(switchVolume)
print(calcVolume)
os.execute('curl -s "http://192.168.1.26:8080/json.htm?type=command¶m=switchlight&idx=281&switchcmd=Set%20Level&level='..calcVolume..'" &')
simon_rb
- Target OS: -
I amended the script below to get it running. However every minute it drops the volume by 4-5% by itself and eventually turns off lol!
The Lounge Touch V switch will turn on and off to reflect the players power status however turning off the Lounge Touch V switch will just turn off the switch and the player remains on, then a minute later the Lounge Touch V turns back on lol. I have the turn on action to turn the player on, do I need to set the turn off action to turn the player off. Last time the scripts turned off the player when the Lounge Touch V was turned off.
Cheers
PS. We are SSOOOOOOOO close
Cheers
file:close()
print(switchVolume)
print(calcVolume)
return commandArray-
Nautilus
Yes, as mentioned a few posts earliersimon_rb wrote:The Lounge Touch V switch will turn on and off to reflect the players power status however turning off the Lounge Touch V switch will just turn off the switch and the player remains on, then a minute later the Lounge Touch V turns back on lol. I have the turn on action to turn the player on, do I need to set the turn off action to turn the player off. Last time the scripts turned off the player when the Lounge Touch V was turned off.
(you need to start really paying attention to what there is defined in the script, especially if you see something you are not expecting. Only this way you can learn and amend stuff to work to your likingAs suggested by the thread starter, to control the player on/off status you can put to on action of the Lounge Touch V something like this:
Also, you naturally cannot use any uservariable which you haven't defined. For the time script it is not needed necessarily but for the device script, if you want that turning the volume switch "On" (without touching the slider) will send a valid volume command, you need it. Though I guess you do not need it to send it as it should always be on the same volume as when turned off so plain "On" doesn't necessarily have to do anything. So only this part is really needed:
if devicechanged['Lounge Touch V'] ~= 'Off' and devicechanged['Lounge Touch V'] ~= nil and tonumber(otherdevices_svalues['Lounge Touch V']) > 0 then
end-
Nautilus
Hey, I got it working at least based on quick test by using
In the time script and
on the device script. Now it send always the same volume to player although sValue changes by +/- 1. Need to think something more robust just in case though...
calcVolume = math.floor((volume/100*32)+0.5)Code: Select all
calcvolume = math.floor((volume*100/31)+0.5)-
simon_rb
- Target OS: -
My apologise for the miss understanding with the On and Off, I didn't add the Off as wasn't sure it would create some sort of loop. So the scripts no longer turn off Lounge Touch when Lounge Touch V is off - understood. I have the On already so I can copy that and change it to off. The user variable is understood. Could have it if Lounge Touch V is anything other than Off run the script.
You have just changed the 32 & 31s around? Unfortunately it doesn't work my end.. its still going down lolHey, I got it working at least based on quick test by using
CODE: SELECT ALL
CODE: SELECT ALL
Nautilus
Yes, noticed it only worked with big enough levels. With small sValue levels it started going down. Tried it the other way around and this seems to work with both big and small levelssimon_rb wrote:My apologise for the miss understanding with the On and Off, I didn't add the Off as wasn't sure it would create some sort of loop. So the scripts no longer turn off Lounge Touch when Lounge Touch V is off - understood. I have the On already so I can copy that and change it to off. The user variable is understood. Could have it if Lounge Touch V is anything other than Off run the script.
CODE: SELECT ALL
CODE: SELECT ALL
playervolume = deviceinfo.result["mixer volume"]
playercalc = math.floor((playervolume/100*31)+0.5)
switchvolume = otherdevices_svalues['Terassin äänenvoimakkuus']
switchcalc = math.floor((switchvolume*100/31)+0.5)
difference = math.abs(switchcalc - playervolume)
if difference > 2 and tonumber(powerstatus) == 1 then
os.execute('curl -s "http://url/json.htm?type=command¶m=switchlight&idx=314&switchcmd=Set%20Level&level='..playercalc..'" &')
if tonumber(powerstatus) == 1 and otherdevices['Terassin äänenvoimakkuus'] == 'Off' then
if tonumber(powerstatus) == 0 and otherdevices['Terassin äänenvoimakkuus'] ~= 'Off' then
commandArray['Terassin äänenvoimakkuus'] = 'Off'
end-
simon_rb
- Target OS: -
Excellent - I shall give it ago.. It looks like you have changed quite a lot! lol Terassin äänenvoimakkuus = Lounge Touch V, that right?
- G3rard
- Target OS: -
- Domoticz version: No
Very nice this topic
Going to use this for my Sonos volume so that I can also control the volume via Siri.
I found that it is possible to update the dimmer switch in Domoticz without triggering the script (to avoid the volume loop) with
where 409 is the idx, 2 is status on (with showing the % in stead of On) and 60 is the %. The % value of the dimmer is updated, but the only thing is that the slider isn't.
Will post my script here once it is finished.
commandArray['UpdateDevice'] = '409|2|60'Will post my script here once it is finished.
Not using Domoticz anymore
simon_rb
- Target OS: -
Off to bed as had 3 hours sleep and up early tomorrow, will try again then. I currently have this script running but its not updating my Lounge Touch V at all even though I have the player set to 80 and Lounge Touch V to 21.
Can't quite see what's wrong lol
file:close()
switchvolume = otherdevices_svalues['Lounge Touch V']
os.execute('curl -s "http://192.168.1.26:8080/json.htm?type=command¶m=switchlight&idx=281&switchcmd=Set%20Level&level='..playercalc..'" &')
simon_rb
- Target OS: -
Cheers G3rard. It's pretty much all NautilusG3rard wrote:Will post my script here once it is finished.
- G3rard
- Target OS: -
I know, but my script is a bit different as I have a Sonossimon_rb wrote: Cheers G3rard. It's pretty much all Nautilus
Nautilus
Correct - didn't have time to change them nowsimon_rb wrote:Excellent - I shall give it ago.. It looks like you have changed quite a lot! lol Terassin äänenvoimakkuus = Lounge Touch V, that right?
Yes, this is something I was thinking earlier (viewtopic.php?f=23&t=9638#p101592) as well, just didn't know about the option"2" for nValue for not triggering the script. I had earlier played with the same (using json / udevice though, i.e. /json.htm?type=command¶m=udevice&idx=IDX&nvalue=NVALUE&svalue=SVALUE) and managed to change status without triggering the On/Off scripts but LUA would still be executed on devicechange. But good to know this.G3rard wrote:I found that it is possible to update the dimmer switch in Domoticz without triggering the script (to avoid the volume loop) withCode: Select all
It was only yesterday when I actually created the volume switch for me as well and I think the latest approach where player volume is compared to converted sValue volume works quite well, at least doesn't create a loop. Although, when the update comes from the player via the time script it send the volume back to the player once which slightly changes it and would not be necessary of course. So maybe I'll change it to this nValue = 2 option in any case (and probably also a 100 step dimmer now that I know how to create one
simon_rb
- Target OS: -
Is it worth going back to the 100 step dimmer then? Is yours working yet?
Nautilus
Yes, I guess it is. Though I first want to make sure the current script works properly and once I feel confident it does, then maybe change the dimmer type...simon_rb wrote:Is it worth going back to the 100 step dimmer then?
