MyDomoticz - Testers wanted!
JC38
Re: Testers wanted!
Post by JC38 »
I've stopped to try sharing device remotely for now.
In the other side, I've added all my Domoticz to MyDomoticz, 3 of them are on the same Lan. And with these 3 ones, I can see this :
DZ1 :
2016-01-07 12:45:04.101 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:01:35.641 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:03:54.013 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:38:27.350 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
DZ2 :
2016-01-07 12:45:04.104 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:01:35.696 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:38:27.341 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
DZ3 :
2016-01-07 12:45:04.287 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:01:35.835 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:03:54.206 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-07 13:38:27.545 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
It's just like my router was loosing its connexion but if i look into its dashboard, it says that the connexion is up for more than 15 hours.
Regarding the fourth one, it is in another place using another connexion, it seems to be like a zombie. MyDomoticz dashboard says it is up for more than 1 day but I can't reach it through the proxy. I have checked/unchecked mydomoticz options, rebooted it also many times but it's always seen online for a long time.
In its log :
2016-01-07 14:27:42.660 Proxymanager started.
2016-01-07 14:27:42.843 PROXY: Authenticate result: Maxinstances reached.
2016-01-07 14:28:40.684 Proxymanager started.
2016-01-07 14:28:40.859 PROXY: Authenticate result: Maxinstances reached.
2016-01-07 14:32:02.719 Proxymanager started.
2016-01-07 14:32:02.924 PROXY: Authenticate result: Maxinstances reached.
In its log, there is
Raspberry Pi 3 Domoticz latest public beta + RFXComm Usb + Aeon Labs Z-Stick + Weather Underground
Windows 2012R2 with Essentials + Domoticz Windows (latest) + Open Hardware Monitor
ImperiHome with mdat / Domoticz for Android
maluko
Re: Testers wanted!
Post by maluko »
seems to be a problem for all, it happening to me since this morning.
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
JC38: I restarted the MyDomoticz service. Now you should be able to also log in with the 4th machine.
About the short read error: But you can see them in your dashboard, right? Or not?
It may be harmless and a matter of too much debugging info still.
== Rene
JC38
Re: Testers wanted!
Post by JC38 »
Right
Yes, but i have to directly loggin before.
If would be nice if you add an option to re-order the instances into your dashboard.
Do you have a file to translate your labels into french ?
SQ9MDD
Re: Testers wanted!
Post by SQ9MDD »
Is the proxy alive?
2016-01-08 09:29:08.334 Error: PROXY: Connect failed, reconnecting: Connection refused
maluko
Re: Testers wanted!
Post by maluko »
the same here, have to disable and enable mydomoticz on domoticz to bring back the proxy, but its not good because this service are to reach the server without open port so if proxy off only at home we can do this.
chimit
Re: Testers wanted!
Post by chimit »
True, the proxy was down last night.
I brought it up today and all Domoticz´s should reconnect automatically again. Without user intervention.
Besides having to see why it crashed, we will put it in a monit config file so restarting will go automatically in such a case.
°° Rene
maluko
Re: Testers wanted!
Post by maluko »
chimit wrote:True, the proxy was down last night.
°° Rene
sorry discord, but i have 2 domoticz on my.domoticz and i did what i said to one (its online) and the other still offline :(
still working that, you have did a good job ;)
chimit
Re: Testers wanted!
Post by chimit »
Right
1.
I put the re-ordering your dashboard on our to-do list.
2.
Could you PM me your email address so I can send you the translation file?
I would like to use crowdin.com for translation. But resources (time!) are short at the moment.
== Rene
assenzuid
Re: Testers wanted!
Post by assenzuid »
I still have this error.
2016-01-08 22:32:05.462 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
Also after a fresh reboot just.
One remark, I see this error often, also before yesterday.
chimit
Re: Testers wanted!
Post by chimit »
True, it's not actually an error. Just the log message needs to be removed from the code.
== Rene
Varazir
Re: Testers wanted!
Post by Varazir »
Hello I just saw this nice thing but when I set it up I got this in the error log
2016-01-10 09:10:35.411 Error: SQL Query("ALTER TABLE Scenes ADD COLUMN [Activators] VARCHAR(200) DEFAULT ''") : duplicate column name: Activators
2016-01-10 09:10:35.411 Error: SQL Query("SELECT ID, HardwareID, DeviceID, Unit, [Type], SubType, SceneType, ListenCmd FROM Scenes") : no such column: HardwareID
2016-01-10 09:10:35.436 Error: SQL Query("ALTER TABLE Hardware ADD COLUMN [Extra] VARCHAR(200) DEFAULT ('')") : duplicate column name: Extra
2016-01-10 09:10:35.439 Error: SQL Query("ALTER TABLE MySensors ADD COLUMN [Name] VARCHAR(100) DEFAULT ''") : duplicate column name: Name
2016-01-10 09:10:35.441 Error: SQL Query("ALTER TABLE DeviceStatus ADD COLUMN [Options] VARCHAR(1024) DEFAULT null") : duplicate column name: Options
2016-01-10 09:46:52.465 Error: PROXY: Read failed, code = 336130329. Reconnecting: decryption failed or bad record mac
2016-01-10 09:47:02.469 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-01-10 09:47:02.472 Error: PROXY: Connect failed, reconnecting: Operation canceled
This keeps repeating in the log.
Edit: I found this too
2016-01-10 09:46:52.444 PROXY: We were assigned an instance id: xxxxxxxxxxxxxxxxxxxxxxxx.
2016-01-10 09:46:52.464 PROXY: Authenticate result: success.
Edit 2: I have checked my firewall and no blocks there. I can ping the host my.domoticz.com from my domoticz box
Edit 3: disable the service and enabled and now it's working.
chimit
Re: Testers wanted!
Post by chimit »
Varazir, thanks for reporting anyway.
Varazir
Re: Testers wanted!
Post by Varazir »
chimit wrote:Varazir, thanks for reporting anyway.
Np, as it's beta(?) I report all anomalies I get.
What type of auth is used to login on the page? Can I use the api key for login?
Why I'm asking is due to I use a tasker plugin called AutoWeb to control my system locally.
Skickat från min Nexus 5 via Tapatalk
chimit
Re: Testers wanted!
Post by chimit »
If the service mimics a browser, they can log in just like you would do manually.
There is going to be an API for app support especially for that kind of things.
But we don't have a target date yet for when it will be ready.
Varazir
Re: Testers wanted!
Post by Varazir »
chimit wrote:If the service mimics a browser, they can log in just like you would do manually.
Local api say http://username@password:hostname: port
chimit
Re: Testers wanted!
Post by chimit »
In that case, no.
We don't do basic authentication because that would interfere with the Domoticz login itself.
== Rene
Varazir
Re: Testers wanted!
Post by Varazir »
chimit wrote:In that case, no.
== Rene
Okay,
I have this options in the plugin
https://goo.gl/photos/cwMgd6kt9z6bnahn9
I have to wait on the api key login
ben92
Re: Testers wanted!
Post by ben92 »
Nice feature,
Dont know if its a bug or if someone report it..... I cant see blocky ou lua script via mydomoticz.
Its normal ?
deejc
Domoticz version: 3.5641
Re: Testers wanted!
Post by deejc »
2FA error :
I am using this service fora while now and i find its very good with the off glitch but i would like to use 2FA, if i scan the bar code with google authenticator i get an error .:
Invalid Barcode
the barcode 'optauth://totp/
Domoproxy:<MYUSERID>@my.
domoticz.com?
secret=<SECRETKEY SHOWN>&issuer=Domo
Proxy' is not a valid authentication token barcode
any ideas why ?
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
