@tunnus : Sorry I do not known Verra
@italoc : I only permit value authorize with the system from 16 degree celius to 31 degree celius. The Melcloud system do not authorize for value like 16.5 degree celius.
2017-06-25 19:49:26.144 (ME) Initialized version 0.4, author 'gysmo'
2017-06-25 19:49:26.199 (ME) Debug log level set to: 'true'.
2017-06-25 19:49:26.600 (ME) MELCloud Login success. Key ID:3889D91ABF5E423xxxxxxxxxxxxx
2017-06-25 19:49:26.926 (ME) Find 4 devices in MELCloud
2017-06-25 19:49:26.926 (ME) Creating device: Dormitorio pequeño with melID 80xxx
2017-06-25 19:49:26.927 (ME) Creating device 'Dormitorio pequeño - Mode'.
2017-06-25 19:49:26.930 (ME) Creating device 'Dormitorio pequeño - Fan'.
2017-06-25 19:49:26.933 (ME) Creating device 'Dormitorio pequeño - Temp'.
2017-06-25 19:49:26.937 (ME) Creating device 'Dormitorio pequeño - Horiontal Vane'.
2017-06-25 19:49:26.941 (ME) Creating device 'Dormitorio pequeño - Vertical Vane'.
2017-06-25 19:49:26.945 (ME) Creating device 'Dormitorio pequeño - Room Temp'.
2017-06-25 19:49:26.948 (ME) Creating device 'Dormitorio pequeño - Unit Infos'.
2017-06-25 19:49:27.181 (ME - Dormitorio pequeño - Mode) Updating device from 0:'' to have values 0:'0'.
2017-06-25 19:49:27.666 (ME - Dormitorio pequeño - Fan) Updating device from 0:'' to have values 0:'50'.
2017-06-25 19:49:27.843 (ME - Dormitorio pequeño - Temp) Updating device from 0:'' to have values 0:'80'.
2017-06-25 19:49:28.024 (ME - Dormitorio pequeño - Horiontal Vane) Updating device from 0:'' to have values 0:'20'.
2017-06-25 19:49:28.185 (ME - Dormitorio pequeño - Vertical Vane) Updating device from 0:'' to have values 0:'60'.
2017-06-25 19:49:28.338 (ME - Dormitorio pequeño - Room Temp) Updating device from 0:'' to have values 1:'30.0'.
2017-06-25 19:49:28.858 (ME) Creating device: Dormitorio Principal with melID 80XXX
2017-06-25 19:49:28.858 Error: CPlugin:CDevice_init, unable to find module for current interpreter.
2017-06-25 19:49:28.858 Error: Device creation failed, Device object is not associated with a plugin.
2017-06-25 19:49:29.118 Error: (ME) 'onStart' failed 'KeyError'.
2017-06-25 19:49:29.118 Error: (ME) ----> Line 315 in /home/beholder/domoticz/plugins/Melcloud/plugin.py, function onStart
2017-06-25 19:49:34.296 Hardware Monitor: Fetching data (System sensors)
2017-06-25 19:49:35.688 (ME) Calling message handler 'onHeartbeat'.
2017-06-25 19:49:35.688 (ME) Current MEL Cloud Key ID:3889D91ABF5XXXXXXXXXXXXXXXX
2017-06-25 19:49:35.688 (ME) Current MEL Building ID:29XXX
2017-06-25 19:49:35.950 (ME) ******** Dormitorio pequeño ********
2017-06-25 19:49:35.950 (ME) Sync POWER False OPERATION MODE 3 FAN SPEED 0 VANE HOZ 3 VANE VER 0 UNIT TEMP 24.0
2017-06-25 19:49:35.950 (ME - Dormitorio pequeño - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-06-25 19:49:36.110 (ME - Dormitorio pequeño - Unit Infos) Updating device from 0:'' to have values 1:'NEXT UPDATE 2017-06-25T17:50:34.03MAC ADDR b0:72:bf:xx:xx:xx S/N 170203xxxx'.
2017-06-25 19:49:36.266 (ME) Infos NEXT UPDATE 2017-06-25T17:50:34.03MAC ADDR b0:72:bf:xx:xx:xx S/N 17020xxxxx
2017-06-25 19:49:36.528 Error: (ME) 'onHeartbeat' failed 'KeyError'.
2017-06-25 19:49:36.528 Error: (ME) ----> Line 406 in /home/beholder/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-06-25 19:49:45.652 (ME) Calling message handler 'onHeartbeat'.
2017-06-25 19:49:45.652 (ME) Current MEL Cloud Key ID:3889D91ABF5E423xxxxxxxx
2017-06-25 19:49:45.652 (ME) Current MEL Building ID:29xxx
2017-06-25 19:49:45.923 (ME) ******** Dormitorio pequeño ********
2017-06-25 19:49:45.923 (ME) Sync POWER False OPERATION MODE 3 FAN SPEED 0 VANE HOZ 3 VANE VER 0 UNIT TEMP 24.0
2017-06-25 19:49:45.923 (ME - Dormitorio pequeño - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-06-25 19:49:46.065 (ME) Infos NEXT UPDATE 2017-06-25T17:50:34.03MAC ADDR b0:72:bf:xx:xx:xx S/N 17020xxxxx
2017-06-25 19:49:46.326 Error: (ME) 'onHeartbeat' failed 'KeyError'.
2017-06-25 19:49:46.326 Error: (ME) ----> Line 406 in /home/beholder/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-07-11 13:19:00.024 (Clim) Initialized version 0.4, author 'gysmo'
2017-07-11 13:19:00.083 (Clim) Debug log level set to: 'true'.
2017-07-11 13:19:00.355 (Clim) MELCloud Login success. Key ID:30E0...2109C5
2017-07-11 13:19:00.591
2017-07-11 13:19:00.668 subtype = Interface Response
Sequence nbr = 2
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1016
Firmware type = Ext2
Hardware version = 1.3
Undec off
X10 enabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech/Atlantic disabled
Oregon Scientific enabled
ATI/Cartelectronic disabled
Visonic disabled
Mertik disabled
AD disabled
Hideki disabled
La Crosse disabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
RUBiCSON disabled
FineOffset disabled
Lighting4 disabled
Conrad RSL disabled
ByronSX disabled
IMAGINTRONIX disabled
KEELOQ disabled
Home Confort disabled
2017-07-11 13:19:06.910 Incoming connection from: 127.0.0.1
2017-07-11 13:19:09.561 (Clim) Calling message handler 'onHeartbeat'.
2017-07-11 13:19:09.561 (Clim) Current MEL Cloud Key ID:30E0...2109C5
2017-07-11 13:19:09.561 (Clim) Current MEL Building ID:31...81
2017-07-11 13:19:11.186 Error: (Clim) 'onHeartbeat' failed 'KeyError'.
2017-07-11 13:19:11.186 Error: (Clim) ----> Line 406 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-07-11 13:19:19.554 (Clim) Calling message handler 'onHeartbeat'.
2017-07-11 13:19:19.555 (Clim) Current MEL Cloud Key ID:30E0...2109C5
2017-07-11 13:19:19.555 (Clim) Current MEL Building ID:31...81
2017-07-11 13:19:26.516 (Clim) ******** Simon ********
2017-07-11 13:19:26.516 (Clim) Sync POWER False OPERATION MODE 3 FAN SPEED 1 VANE HOZ 3 VANE VER 0 UNIT TEMP 16.0
2017-07-11 13:19:26.516 (Clim - Simon - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-07-11 13:19:26.527 (Clim) Infos NEXT UPDATE 2017-07-11T11:23:00.763MAC ADDR 00:1d:c9:...:15:b3 S/N 1605...070
2017-07-11 13:19:28.161 Error: (Clim) 'onHeartbeat' failed 'KeyError'.
2017-07-11 13:19:28.161 Error: (Clim) ----> Line 406 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeatCode: Select all
2017-07-11 14:45:56.239 (Clim) Initialized version 0.4, author 'gysmo'
2017-07-11 14:45:56.293 (Clim) Debug log level set to: 'true'.
2017-07-11 14:45:56.531 (Clim) MELCloud Login success. Key ID:D4F2F25DEA674DCE9608F945939FA9
2017-07-11 14:45:56.761 (Clim) Find 2 devices in MELCloud
2017-07-11 14:45:56.761 (Clim) Creating device: Simon with melID 8...9
2017-07-11 14:45:56.762 (Clim) Creating device 'Simon - Mode'.
2017-07-11 14:45:56.765 (Clim) Creating device 'Simon - Fan'.
2017-07-11 14:45:56.767 (Clim) Creating device 'Simon - Temp'.
2017-07-11 14:45:56.769 (Clim) Creating device 'Simon - Horiontal Vane'.
2017-07-11 14:45:56.771 (Clim) Creating device 'Simon - Vertical Vane'.
2017-07-11 14:45:56.774 (Clim) Creating device 'Simon - Room Temp'.
2017-07-11 14:45:56.775 (Clim) Creating device 'Simon - Unit Infos'.
2017-07-11 14:45:56.998 (Clim - Simon - Mode) Updating device from 0:'' to have values 0:'0'.
2017-07-11 14:45:57.008 (Clim - Simon - Fan) Updating device from 0:'' to have values 0:'60'.
2017-07-11 14:45:57.016 (Clim - Simon - Temp) Updating device from 0:'' to have values 0:'0'.
2017-07-11 14:45:57.025 (Clim - Simon - Horiontal Vane) Updating device from 0:'' to have values 0:'20'.
2017-07-11 14:45:57.033 (Clim - Simon - Vertical Vane) Updating device from 0:'' to have values 0:'60'.
2017-07-11 14:45:57.042 (Clim - Simon - Room Temp) Updating device from 0:'' to have values 1:'23.5'.
2017-07-11 14:45:57.047 (Clim) Creating device: Salle with melID 8...5
2017-07-11 14:45:57.047 Error: CPlugin:CDevice_init, unable to find module for current interpreter.
2017-07-11 14:45:57.047 Error: Device creation failed, Device object is not associated with a plugin.
2017-07-11 14:45:57.048 Error: Device creation failed, Device object is not associated with a plugin.
2017-07-11 14:45:57.048 Error: CPlugin:CDevice_init, unable to find module for current interpreter.
2017-07-11 14:45:57.282 Error: (Clim) 'onStart' failed 'KeyError'.
2017-07-11 14:45:57.282 Error: (Clim) ----> Line 315 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onStart
2017-07-11 14:46:05.750 (Clim) Calling message handler 'onHeartbeat'.
2017-07-11 14:46:05.750 (Clim) Current MEL Cloud Key ID:D4F2F25DEA674DCE9608F945939FA9
2017-07-11 14:46:05.751 (Clim) Current MEL Building ID:3...1
2017-07-11 14:46:05.942 (Clim) ******** Simon ********
2017-07-11 14:46:05.943 (Clim) Sync POWER False OPERATION MODE 3 FAN SPEED 1 VANE HOZ 3 VANE VER 0 UNIT TEMP 16.0
2017-07-11 14:46:05.943 (Clim - Simon - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-07-11 14:46:05.954 (Clim - Simon - Unit Infos) Updating device from 0:'' to have values 1:'NEXT UPDATE 2017-07-11T12:48:00.73MAC ADDR 00:1d:c9:...:15:b3 S/N 1605205070'.
2017-07-11 14:46:05.964 (Clim) Infos NEXT UPDATE 2017-07-11T12:48:00.73MAC ADDR 00:1d:c9:...:15:b3 S/N 1605...70
2017-07-11 14:46:06.161 Error: (Clim) 'onHeartbeat' failed 'KeyError'.
2017-07-11 14:46:06.161 Error: (Clim) ----> Line 406 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-07-11 14:46:15.782 (Clim) Calling message handler 'onHeartbeat'.
2017-07-11 14:46:15.782 (Clim) Current MEL Cloud Key ID:D4F2F25DEA674DCE9608F945939FA9
2017-07-11 14:46:15.782 (Clim) Current MEL Building ID:3...1
2017-07-11 14:46:16.178 (Clim) ******** Simon ********
2017-07-11 14:46:16.178 (Clim) Sync POWER False OPERATION MODE 3 FAN SPEED 1 VANE HOZ 3 VANE VER 0 UNIT TEMP 16.0
2017-07-11 14:46:16.179 (Clim - Simon - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-07-11 14:46:16.190 (Clim) Infos NEXT UPDATE 2017-07-11T12:48:00.73MAC ADDR 00:1d:c9:...:15:b3 S/N 1605...70
2017-07-11 14:46:16.413 Error: (Clim) 'onHeartbeat' failed 'KeyError'.
2017-07-11 14:46:16.413 Error: (Clim) ----> Line 406 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeatCode: Select all
2017-07-12 00:38:36.394 (clim) Initialized version 0.5, author 'gysmo'
2017-07-12 00:38:36.448 (clim) Debug log level set to: 'true'.
2017-07-12 00:38:36.680 (clim) MELCloud Login success. Key ID:1874B4F1F03A4A678F5A327D2B5BEF
2017-07-12 00:38:36.908 (clim) Find 2 devices in MELCloud
2017-07-12 00:38:36.909 (clim) Creating device: Simon with melID 83...59
2017-07-12 00:38:36.909 (clim) Creating device 'Simon - Mode'.
2017-07-12 00:38:36.912 (clim) Creating device 'Simon - Fan'.
2017-07-12 00:38:36.914 (clim) Creating device 'Simon - Temp'.
2017-07-12 00:38:36.917 (clim) Creating device 'Simon - Horiontal Vane'.
2017-07-12 00:38:36.919 (clim) Creating device 'Simon - Vertical Vane'.
2017-07-12 00:38:36.922 (clim) Creating device 'Simon - Room Temp'.
2017-07-12 00:38:36.923 (clim) Creating device 'Simon - Unit Infos'.
2017-07-12 00:38:37.099 (clim - Simon - Mode) Updating device from 0:'' to have values 0:'0'.
2017-07-12 00:38:37.143 (clim - Simon - Fan) Updating device from 0:'' to have values 0:'0'.
2017-07-12 00:38:37.152 (clim - Simon - Temp) Updating device from 0:'' to have values 0:'0'.
2017-07-12 00:38:37.161 (clim - Simon - Horiontal Vane) Updating device from 0:'' to have values 0:'20'.
2017-07-12 00:38:37.169 (clim - Simon - Vertical Vane) Updating device from 0:'' to have values 0:'60'.
2017-07-12 00:38:37.177 (clim - Simon - Room Temp) Updating device from 0:'' to have values 1:'24.0'.
2017-07-12 00:38:37.183 (clim) Creating device: Salle with melID 83...55
2017-07-12 00:38:37.183 Error: CPlugin:CDevice_init, unable to find module for current interpreter.
2017-07-12 00:38:37.183 Error: Device creation failed, Device object is not associated with a plugin.
2017-07-12 00:38:37.184 Error: CPlugin:CDevice_init, unable to find module for current interpreter.
2017-07-12 00:38:37.184 Error: Device creation failed, Device object is not associated with a plugin.
2017-07-12 00:38:37.398 Error: (clim) 'onStart' failed 'KeyError'.
2017-07-12 00:38:37.398 Error: (clim) ----> Line 492 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onStart
2017-07-12 00:38:37.398 Error: (clim) ----> Line 124 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onStart
2017-07-12 00:38:37.399 (clim) Heartbeat interval set to: 25.
2017-07-12 00:38:45.918 (clim) Calling message handler 'onHeartbeat'.
2017-07-12 00:38:45.918 (clim) Current MEL Cloud Key ID:1874B4F1F03A4A678F5A327D2B5BEF
2017-07-12 00:38:45.919 (clim) Current MEL Building ID:31...81
2017-07-12 00:38:46.119 (clim) ******** Simon ********
2017-07-12 00:38:46.120 (clim) Sync POWER False OPERATION MODE 3 FAN SPEED 1 VANE HOZ 3 VANE VER 0 UNIT TEMP 16.0
2017-07-12 00:38:46.120 (clim - Simon - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-07-12 00:38:46.131 (clim - Simon - Unit Infos) Updating device from 0:'' to have values 1:'NEXT UPDATE 2017-07-11T22:43:00.43MAC ADDR 00:1d:...:b3 S/N 1605205070'.
2017-07-12 00:38:46.142 (clim) Infos NEXT UPDATE 2017-07-11T22:43:00.43MAC ADDR 00:1d:...:b3 S/N 1605...70
2017-07-12 00:38:46.338 Error: (clim) 'onHeartbeat' failed 'KeyError'.
2017-07-12 00:38:46.338 Error: (clim) ----> Line 520 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-07-12 00:38:46.338 Error: (clim) ----> Line 227 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-07-12 00:39:10.940 (clim) Calling message handler 'onHeartbeat'.
2017-07-12 00:39:10.940 (clim) Current MEL Cloud Key ID:1874B4F1F03A4A678F5A327D2B5BEF
2017-07-12 00:39:10.940 (clim) Current MEL Building ID:31...81
2017-07-12 00:39:11.158 (clim) ******** Simon ********
2017-07-12 00:39:11.158 (clim) Sync POWER False OPERATION MODE 3 FAN SPEED 1 VANE HOZ 3 VANE VER 0 UNIT TEMP 16.0
2017-07-12 00:39:11.158 (clim - Simon - Vertical Vane) Updating device from 0:'60' to have values 0:'60'.
2017-07-12 00:39:11.169 (clim) Infos NEXT UPDATE 2017-07-11T22:43:00.43MAC ADDR 00:1d:...:b3 S/N 1605...070
2017-07-12 00:39:11.363 Error: (clim) 'onHeartbeat' failed 'KeyError'.
2017-07-12 00:39:11.363 Error: (clim) ----> Line 520 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-07-12 00:39:11.363 Error: (clim) ----> Line 227 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeatHi bro! Nothing new? did not they answer you? Too bad, I'd be happy to run your plugin !!!gysmo38 wrote: Sunday 20 August 2017 13:40 Hello,
I think you use a raspberry for Domoticz.
There is a bug with my MELCloud plugin and raspberry prebuild version.
I send a message to the creator of domoticz pyhton framework. I hope he will find a solution.
if(melDeviceStatus['VaneVertical'] != domCurrentVaneH):Code: Select all
2017-11-18 23:47:51.285 Error: (MELCloud) 'onHeartbeat' failed 'KeyError'.
2017-11-18 23:47:51.285 Error: (MELCloud) ----> Line 520 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
2017-11-18 23:47:51.285 Error: (MELCloud) ----> Line 227 in /home/pi/domoticz/plugins/Melcloud/plugin.py, function onHeartbeat
