Page 4 of 4
Re: Cheap Chinese Power Meter made wireless
Posted: Sunday 20 May 2018 2:25
by tastycarp
Raspberry Piet wrote: Monday 02 October 2017 22:38
Now i flashed espurna 1.9.5 for my ECH1560 Chinese powermeter. (wemos d1-mini inside)
It is showing some values but it is a bit jumpy:
I have done the same mod (wemos mini wired directly) and it is jumpy as well just like your gif. Did you get to the bottom of this?
Posted: Sunday 20 May 2018 9:49
by Raspberry Piet
tastycarp wrote: Sunday 20 May 2018 2:25
No but xoseperez wants to fix it someday
issue 596
Posted: Monday 21 May 2018 8:07
by tastycarp
Ahh Thanks for the info. It sounds like he owns a few ehc1560 now. so hopefully not too far off. I will put mine into the one day project pile!
Posted: Friday 27 July 2018 19:18
by DaNii78
Kapee wrote: Wednesday 20 September 2017 10:37
I ordered three powermeters and all three have a different printed circuit board. The 1st and the 3rd with spi interface, the 2nd with serial interface.
For the 3rd powermeter I made a pcb for the wemos and power supply, it just fitted in height.
How did you wire the 3rd power meter?
Posted: Monday 30 July 2018 13:55
by Kapee
Here is the schematic
Posted: Saturday 04 August 2018 12:34
by DaNii78
Kapee wrote: Monday 30 July 2018 13:55
Thanks you so much!
I just recieved a power meter with an unknown chip. It's labeled with "BL6523GX". Does anybody knows if it's compatible or how can be hacked?
Thanks you!
Posted: Saturday 04 August 2018 12:44
by SweetPants
Just a remark, I made the same 'mistake'
viewtopic.php?f=38&t=7325&start=40#p149833 and added some opto-couplers between the powermeter board and the ESP for safety because I used ESP07 and external antenna's.
Posted: Saturday 04 August 2018 13:38
by DaNii78
SweetPants wrote: Saturday 04 August 2018 12:44
So it's better add the opto-couplers?
Posted: Saturday 04 August 2018 14:19
by SweetPants
DaNii78 wrote: Saturday 04 August 2018 13:38
Only if you have external connections (like a WiFi antenna)
Posted: Saturday 11 August 2018 21:30
by DaNii78
I can't make it work with a ESP-01...
Anybody has tried with this ESP?
Posted: Sunday 12 August 2018 8:50
by SweetPants
ESP-01 has not enough memory i think. You probably get compiler/link errors?
Posted: Sunday 12 August 2018 14:41
by DaNii78
No, I can compile and the code gets uploaded but I always obtain a 0 value in the voltage measure.
