Netatmo thermostat support Topic is solved
zicht
Domoticz version: 2023.1+
Re: Netatmo thermostat support
Post by zicht »
Netatmo changed it again :(
New Netatmo Authentication method implemented from 2023.2 Beta (11-Sep-2023) https://www.domoticz.com/wiki/Netatmo
The wiki is outdated at this stage. I did not manage to find any solution at the moment for myself (homecoach).
What has changed: Netatmo checks the redirect url and hides the code needed with an error url if the redirecturl is not possible.
Due to this the needed code cannot been input in domoticz.
- I tried to see with inspect-> network if the url is reached, but the broweser never hits an URL as suggested in the wiki.
- I tried to see with a network monitor (switch port duplication & packet inspection) if any url with the code is passed, the answer is no.
On the dev site of netatmo you can now gerenrate a token, but when i use that one it does not work ( no access granted) even not if I start with the code quick = within 10-20 secs --> a fast copy paste to the hardware tab
2023-10-19 10:14:54.787 Status: netatmo: Worker stopped...
2023-10-19 10:14:54.787 Status: netatmo: Worker started...
2023-10-19 10:14:59.959 Error: netatmo: No access granted, check credentials...
Question :
Has anyone found another CO2 sensor that is working stable with domoticz ?
I want to use it an a balanced ventilation script based on CO2
So the wiki is up to date with current situation in Domoticz. Domoticz beta is not up to date with the current new Netatmo login situation...
Leat see if Kiddigital will be able to fix this (with your help...)
Or perhaps you are able to change the source code of Domoticz yourself?
By the way, check this topic to see the discussion on the latest changes. Perhaps your perhaps not supported CO2 device could also be the issue..But should not give an authentication error .
viewtopic.php?t=38968&start=40
