Your code starts with
import DomoticzModerator: leecollings
import DomoticzCode: Select all
<plugin key="HivePlug" name="Hive Plugin" author="imcfarla and MikeF" version="0.3" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/">
<params>
<param field="Username" label="Hive Username" width="200px" required="true" default=""/>
<param field="Password" label="Hive Password" width="200px" required="true" default=""/>
<param field="Mode1" label="Heartbeat Multiplier" width="30px" required="true" default="6"/>
<param field="Mode2" label="Domoticz Port" width="30px" required="true" default="8080"/>
<options>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import sys
import json
sys.path.append('/usr/lib/python3/dist-packages')
from urllib.request import Request, urlopen
from urllib.parse import urlencode
class BasePlugin:
enabled = False
def __init__(self):
self.sessionId = ''
self.counter = 0
self.multiplier = 10
self.lightsSet = set()
self.TimedOutAvailable = False
def onStart(self):
Domoticz.Log('Starting')
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
if self.getDomoticzRevision() >= 8651:
# Devices[unit].TimedOut only appears in Revision >= 8651
self.TimedOutAvailable = True
Domoticz.Log("TimedOut available")
else:
Domoticz.Log("TimedOut not available")
self.multiplier = int(Parameters['Mode1'])
self.counter = self.multiplier # update immediately
if self.sessionId == '':
Domoticz.Log('Creating Session')
self.GetSessionID()
Domoticz.Debug(self.sessionId)
self.onHeartbeat()
def onStop(self):
Domoticz.Log('Deleting Session')
headers = {'Content-Type': 'application/vnd.alertme.zoo-6.1+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \
'X-AlertMe-Client': 'Hive Web Dashboard', 'X-Omnia-Access-Token': self.sessionId }
url = 'https://api.prod.bgchprod.info:443/omnia/auth/sessions/' + self.sessionId
req = Request(url, headers = headers)
req.get_method = lambda : 'DELETE'
try:
r = urlopen(req).read()
except Exception as e:
Domoticz.Log(str(e))
def onConnect(self, Connection, Status, Description):
Domoticz.Debug('onConnect called')
def onMessage(self, Connection, Data, Status, Extra):
Domoticz.Debug('onMessage called')
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log('onCommand called for Unit ' + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
Domoticz.Debug(str(Devices[Unit].Type))
Domoticz.Debug(str(Devices[Unit].SubType))
Domoticz.Debug(Devices[Unit].DeviceID)
Domoticz.Debug(str(Devices[Unit].sValue))
headers = {'Content-Type': 'application/vnd.alertme.zoo-6.2+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \
'X-AlertMe-Client': 'swagger', 'X-Omnia-Access-Token': self.sessionId}
url = 'https://api.prod.bgchprod.info:443/omnia/nodes/' + Devices[Unit].DeviceID
if self.isLight(Unit):
Domoticz.Log("Setting Light Parameters")
if str(Command) == "Set Level":
payload = self.CreateLightPayload("ON", Level)
if str(Command) == "On":
payload = self.CreateLightPayload("ON", Devices[Unit].LastLevel)
if str(Command) == "Off":
payload = self.CreateLightPayload("OFF", Devices[Unit].LastLevel)
elif self.isThermostat(Unit):
payload = self.CreateThermostatPayload(Level)
elif self.isActivePlug(Unit):
payload = self.CreateActivePlugPayload(Level)
else:
payload = ""
Domoticz.Log("Unknown Device Type")
if payload != "":
req = Request(url, data = json.dumps(payload).encode('ascii'), headers = headers, unverifiable = True)
req.get_method = lambda : 'PUT'
try:
r = urlopen(req).read().decode('utf-8')
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Debug('Notification: ' + Name + ',' + Subject + ',' + Text + ',' + Status + ',' + str(Priority) + ',' + Sound + ',' + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Debug('onDisconnect called')
def onHeartbeat(self):
Domoticz.Debug('onHeartbeat called')
if self.counter >= self.multiplier:
foundInsideDevice = False
foundTargetDevice = False
foundHeatingDevice = False
foundThermostatDevice = False
Domoticz.Debug('Getting Data')
self.counter = 1
d = self.GetDevices()
Domoticz.Debug('Getting Temperatures')
thermostat = self.GetThermostat(d)
if thermostat:
# get the temperature and heating states
temp = thermostat["attributes"]["temperature"]["reportedValue"]
Domoticz.Debug('Temp = ' + str(temp))
targetTemp = thermostat["attributes"]["targetHeatTemperature"]["reportedValue"]
if targetTemp < 7.0: targetTemp = 7.0
Domoticz.Debug('Target = ' + str(targetTemp))
heating = thermostat["attributes"]["stateHeatingRelay"]["reportedValue"]
Domoticz.Debug('Heating = ' + heating)
Domoticz.Debug('Getting Battery Status')
thermostatui = self.GetThermostatUI(d)
# get the battery and rssi values
thermostat_battery = thermostatui["attributes"]["batteryLevel"]["reportedValue"]
Domoticz.Debug('Battery = ' + str(thermostat_battery))
thermostat_rssi = 12*((0 - thermostatui["attributes"]["RSSI"]["reportedValue"])/100)
Domoticz.Debug('RSSI = ' + str(thermostat_rssi))
# Loop through the devices and update temperatures
Domoticz.Debug('Updating Devices')
for unit in Devices:
if Devices[unit].DeviceID == "Hive_Inside":
Devices[unit].Update(nValue=int(temp), sValue=str(temp))
foundInsideDevice = True
if Devices[unit].DeviceID == "Hive_Target":
Devices[unit].Update(nValue=int(targetTemp), sValue=str(targetTemp))
foundTargetDevice = True
if Devices[unit].DeviceID == "Hive_Heating":
foundHeatingDevice = True
if thermostatui["attributes"]["presence"]["reportedValue"] == "ABSENT":
if self.TimedOutAvailable:
Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1)
else:
Domoticz.Log("Device Offline : " + Devices[unit].Name)
else:
if heating == 'ON':
if Devices[unit].nValue == 0:
Devices[unit].Update(nValue=1, sValue='On', TimedOut=0)
else:
Devices[unit].Update(nValue=1, sValue='On')
else:
if Devices[unit].nValue == 1:
Devices[unit].Update(nValue=0, sValue='Off', TimedOut=0)
else:
Devices[unit].Update(nValue=0, sValue='Off')
if Devices[unit].DeviceID == thermostat['id']:
foundThermostatDevice = True
if Devices[unit].Type == 242: #Thermostat
Devices[unit].Update(nValue = int(targetTemp), sValue = str(targetTemp), BatteryLevel = int(thermostat_battery), SignalLevel = int(thermostat_rssi))
if foundInsideDevice == False:
Domoticz.Device(Name = 'Inside', Unit = self.GetNextUnit(False), TypeName = 'Temperature', DeviceID = 'Hive_Inside').Create()
if foundTargetDevice == False:
Domoticz.Device(Name = 'Target', Unit = self.GetNextUnit(False), TypeName = 'Temperature', DeviceID = 'Hive_Target').Create()
if foundHeatingDevice == False:
Domoticz.Device(Name = 'Heating', Unit = self.GetNextUnit(False), TypeName = 'Switch', Switchtype = 0, DeviceID ='Hive_Heating').Create()
if foundThermostatDevice == False:
Domoticz.Device(Name = 'Thermostat', Unit = self.GetNextUnit(False), Type = 242, Subtype = 1, DeviceID = thermostat['id']).Create()
lights = self.GetLights(d)
if lights:
for node in lights:
if node['id'] == Devices[unit].DeviceID:
if unit not in set(self.lightsSet):
self.lightsSet.add(unit)
if node["attributes"]["presence"]["reportedValue"] == "ABSENT":
#Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1)
else:
if node["attributes"]["state"]["reportedValue"] == "OFF":
if Devices[unit].nValue != 0:
else:
else:
Domoticz.Debug("State: " + Devices[unit].sValue)
Domoticz.Debug("Brightness Target: " + str(Devices[unit].LastLevel))
Domoticz.Debug("Brightness: " + str(node["attributes"]["brightness"]["reportedValue"]))
if Devices[unit].LastLevel != int(node["attributes"]["brightness"]["reportedValue"]) or Devices[unit].sValue == 'Off':
Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"]), TimedOut=0) # 2 = Set Level
else:
Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"])) # 2 = Set Level
break
else:
Domoticz.Log("Light not found " + node["name"])
newUnit = self.GetNextUnit(False)
Domoticz.Device(Name = node["name"], Unit = newUnit, Type=244, Subtype=73, Switchtype=7, DeviceID = node['id']).Create()
Devices[newUnit].Update(nValue=0, sValue='Off')
else:
Devices[newUnit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"])) # 2 = Set Level
activeplugs = self.GetActivePlugs(d)
if activeplugs:
for node in activeplugs:
else:
else:
else:
else:
if Devices[unit].nValue != 1:
else:
break
else:
Domoticz.Log("ActivePlug not found " + node["name"])
Domoticz.Device(Name = node["name"], Unit = newUnit, Type=244, Subtype=73, Switchtype=0, DeviceID = node['id']).Create()
else:
else:
self.counter += 1
Domoticz.Debug('Counter = ' + str(self.counter))
def GetSessionID(self):
payload = {'username':Parameters["Username"], 'password':Parameters["Password"]}
headers = {'Content-Type': 'application/json', 'Accept': 'application/json'}
url = 'https://beekeeper-uk.hivehome.com/1.0/gateway/login'
self.sessionId = json.loads(r)['token']
def GetDevices(self):
nodes = False
url = 'https://api.prod.bgchprod.info:443/omnia/nodes'
req = Request(url, headers = headers, unverifiable = True)
try:
except urllib.HTTPError as e:
if e.code == 401: # Unauthorised - need new sessionId
self.onStop()
self.GetSessionID()
else:
try:
nodes = json.loads(r)['nodes']
return nodes
def GetThermostat(self, d):
x = find_key_in_list(d, 'http://alertme.com/schema/json/node.class.thermostat.json#')
if x:
k = 'stateHeatingRelay'
if k in x[0]['attributes']:
thermostat = x[0]
elif k in x[1]['attributes']:
thermostat = x[1]
else:
thermostat = False
else:
thermostat = False
return thermostat
def GetThermostatUI(self, d):
thermostatui = False
x = find_key_in_list(d, 'http://alertme.com/schema/json/node.class.thermostatui.json#')
if x:
thermostatui = x[0]
else: # Try a Hive2 thermostat
x = find_key_in_list(d,"Hive2")
if x:
thermostatui = x[0]
return thermostatui
def GetLights(self, d):
lights = False
x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.light.json#")
if x:
lights = x
return lights
def GetActivePlugs(self, d):
plugs = False
x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.smartplug.json#")
if x:
lights = x
return plugs
def GetNextUnit(self, unit):
if not unit:
nextUnit = len(Devices) + 1
else:
nextUnit = unit +1
if nextUnit in Devices or nextUnit <= 1:
nextUnit = self.GetNextUnit(nextUnit)
return nextUnit
def CreateLightPayload(self, State, Brightness):
response = {}
nodes = []
attributes = {}
state = {}
brightness = {}
brightness["targetValue"] = Brightness
state["targetValue"] = State
attributes["attributes"] = {"brightness":brightness,"state":state}
nodes.append(attributes)
response["nodes"] = nodes
return response
def CreateThermostatPayload(self, Temperature):
response = {}
nodes = []
attributes = {}
targetHeatTemperature = {}
targetHeatTemperature["targetValue"] = Temperature
attributes["attributes"] = {"targetHeatTemperature":targetHeatTemperature}
return response
def CreateActivePlugPayload(self, State):
response = {}
nodes = []
attributes = {}
state = {}
attributes["attributes"] = {"state":state}
return response
def isLight(self, Unit):
Domoticz.Debug(str(self.lightsSet))
if Devices[Unit].Type == 244 and Devices[Unit].SubType == 73 and Unit in self.lightsSet:
return True
else:
return False
def isThermostat(self, Unit):
if Devices[Unit].Type == 242:
return True
else:
return False
def isActivePlug(self, Unit):
if Devices[Unit].Type == 244 and Devices[Unit].SubType == 73 and Unit not in self.lightsSet and Devices[Unit].DeviceID != "Hive_Heating":
return True
else:
return False
def getDomoticzRevision(self):
Revision = 0
url = 'http://127.0.0.1:' + Parameters['Mode2'] + '/json.htm?type=command¶m=getversion'
req = Request(url)
try:
Revision = json.loads(r)['Revision']
if e.code == 401:
Domoticz.Error("Ensure you have 127.0.0.1 in your 'Local Networks' selection")
else:
Domoticz.Error(str(e))
return Revision
_plugin = BasePlugin()
def onStart():
_plugin.onStart()
def onStop():
_plugin.onStop()
def onConnect(Connection, Status, Description):
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data, Status, Extra):
_plugin.onMessage(Connection, Data, Status, Extra)
def onCommand(Unit, Command, Level, Hue):
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
_plugin.onDisconnect(Connection)
def onHeartbeat():
_plugin.onHeartbeat()
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != '':
Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug('Device count: ' + str(len(Devices)))
for x in Devices:
Domoticz.Debug('Device: ' + str(x) + ' - ' + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug('Device nValue: ' + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug('Device LastLevel: ' + str(Devices[x].LastLevel))
def find_key_in_list(d, value):
if isinstance(d, list):
t = list(d)
for v in d:
if isinstance(v, dict):
p = find_key(v, value)
if not p:
t.remove(v)
return t
def find_key(d, value):
for (k, v) in d.items():
if p:
return [k] + p
elif v == value:
return [k]
def merge_dicts(*dict_args):
Given any number of dicts, shallow copy and merge into a new dict,
precedence goes to key value pairs in latter dicts.
result = { }
for dictionary in dict_args:
result.update(dictionary)
return result
<plugin key="HivePlug" name="Hive Plugin" author="imcfarla and MikeF" version="0.3.1" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/">
<params>
<options>
</options>
</param>
</params>
</plugin>
import Domoticz
import sys
import json
class BasePlugin:
enabled = False
def __init__(self):
self.sessionId = ''
self.counter = 0
def onStart(self):
if int(self.getDomoticzRevision()) >= 8651:
else:
self.GetSessionID()
self.onHeartbeat()
def onStop(self):
try:
else:
payload = ""
if payload != "":
try:
self.counter = 1
if thermostat:
if Devices[unit].TimedOut == 0:
else:
else:
if heating == 'ON':
else:
else:
else:
if lights:
for node in lights:
Domoticz.Debug(Devices[unit].Name + ": " + node["attributes"]["presence"]["reportedValue"])
else:
else:
else:
else:
else:
break
else:
else:
if activeplugs:
else:
else:
else:
else:
else:
break
else:
else:
else:
self.counter += 1
nodes = False
try:
self.onStop()
self.GetSessionID()
else:
try:
return nodes
if x:
thermostat = x[0]
thermostat = x[1]
else:
thermostat = False
else:
thermostat = False
return thermostat
if x:
thermostatui = x[0]
if x:
thermostatui = x[0]
return thermostatui
lights = False
if x:
lights = x
return lights
plugs = False
if x:
lights = x
return plugs
if not unit:
else:
nextUnit = unit +1
return nextUnit
response = {}
nodes = []
attributes = {}
state = {}
brightness = {}
return response
response = {}
nodes = []
attributes = {}
return response
response = {}
nodes = []
attributes = {}
state = {}
return response
return True
else:
return False
return True
else:
return False
return True
else:
return False
Revision = 0
req = Request(url)
try:
j = json.loads(r)
Revision = j['Revision']
Version = j['version']
Domoticz.Debug("Domoticz Revision: " + str(Revision))
Domoticz.Debug("Domoticz Version: " + Version + '->' + str(int(Version[-4:])))
if int(Version[-4:]) > Revision: # I've managed to create a build that has Version different to Revision so take the highest
Revision = int(Version[-4:])
if e.code == 401:
else:
return Revision
def onStart():
_plugin.onStart()
def onStop():
_plugin.onStop()
def onHeartbeat():
for x in Devices:
t = list(d)
for v in d:
if not p:
t.remove(v)
return t
if p:
return [k] + p
elif v == value:
return [k]
result = { }
return result
2017-12-14 21:27:59.955 PluginSystem: Entering work loop.
2017-12-14 21:28:00.080 Error: (HivePlug) failed to load 'plugin.py', Python Path used was ':/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2017-12-14 21:28:00.080 Error: (Hive) Module Import failed, exception: 'ImportError'
2017-12-14 21:28:00.080 Error: (Hive) Module Import failed: ' Name: plugin'
2017-12-14 21:28:00.080 Error: (Hive) Error Line details not available.Code: Select all
import sys
Is this an official update to this code?imcfarla wrote: Wednesday 13 December 2017 17:02 A bit more debugging and the TimedOut stuff actually works
Hive takes a while to identify the device is offline but once it does...
''' <plugin key="HivePlug" name="Hive Plugin" author="imcfarla and MikeF" version="0.3.1" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://www.google.com/"> <params> <param field="Username" label="Hive Username" width="200px" required="true" default=""/> <param field="Password" label="Hive Password" width="200px" required="true" default=""/> <param field="Mode1" label="Heartbeat Multiplier" width="30px" required="true" default="6"/> <param field="Mode2" label="Domoticz Port" width="30px" required="true" default="8080"/> <param field="Mode6" label="Debug" width="75px"> <options> <option label="True" value="Debug"/> <option label="False" value="Normal" default="true" /> </options> </param> </params> </plugin> ''' import Domoticz import sys import json sys.path.append('/usr/lib/python3/dist-packages') from urllib.request import Request, urlopen from urllib.parse import urlencode class BasePlugin: enabled = False def __init__(self): self.sessionId = '' self.counter = 0 self.multiplier = 10 self.lightsSet = set() self.TimedOutAvailable = False def onStart(self): Domoticz.Log('Starting') if Parameters["Mode6"] == "Debug": Domoticz.Debugging(1) if int(self.getDomoticzRevision()) >= 8651: # Devices[unit].TimedOut only appears in Revision >= 8651 self.TimedOutAvailable = True Domoticz.Log("TimedOut available") else: Domoticz.Log("TimedOut not available") self.multiplier = int(Parameters['Mode1']) self.counter = self.multiplier # update immediately if self.sessionId == '': Domoticz.Log('Creating Session') self.GetSessionID() Domoticz.Debug(self.sessionId) self.onHeartbeat() def onStop(self): Domoticz.Log('Deleting Session') headers = {'Content-Type': 'application/vnd.alertme.zoo-6.1+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \ 'X-AlertMe-Client': 'Hive Web Dashboard', 'X-Omnia-Access-Token': self.sessionId } url = 'https://api.prod.bgchprod.info:443/omnia/auth/sessions/' + self.sessionId req = Request(url, headers = headers) req.get_method = lambda : 'DELETE' try: r = urlopen(req).read() except Exception as e: Domoticz.Log(str(e)) def onConnect(self, Connection, Status, Description): Domoticz.Debug('onConnect called') def onMessage(self, Connection, Data, Status, Extra): Domoticz.Debug('onMessage called') def onCommand(self, Unit, Command, Level, Hue): Domoticz.Log('onCommand called for Unit ' + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level)) Domoticz.Debug(str(Devices[Unit].Type)) Domoticz.Debug(str(Devices[Unit].SubType)) Domoticz.Debug(Devices[Unit].DeviceID) Domoticz.Debug(str(Devices[Unit].sValue)) headers = {'Content-Type': 'application/vnd.alertme.zoo-6.2+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \ 'X-AlertMe-Client': 'swagger', 'X-Omnia-Access-Token': self.sessionId} url = 'https://api.prod.bgchprod.info:443/omnia/nodes/' + Devices[Unit].DeviceID if self.isLight(Unit): Domoticz.Log("Setting Light Parameters") if str(Command) == "Set Level": payload = self.CreateLightPayload("ON", Level) if str(Command) == "On": payload = self.CreateLightPayload("ON", Devices[Unit].LastLevel) if str(Command) == "Off": payload = self.CreateLightPayload("OFF", Devices[Unit].LastLevel) elif self.isThermostat(Unit): payload = self.CreateThermostatPayload(Level) elif self.isActivePlug(Unit): payload = self.CreateActivePlugPayload(Level) else: payload = "" Domoticz.Log("Unknown Device Type") if payload != "": req = Request(url, data = json.dumps(payload).encode('ascii'), headers = headers, unverifiable = True) req.get_method = lambda : 'PUT' try: r = urlopen(req).read().decode('utf-8') except Exception as e: Domoticz.Log(str(e)) def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile): Domoticz.Debug('Notification: ' + Name + ',' + Subject + ',' + Text + ',' + Status + ',' + str(Priority) + ',' + Sound + ',' + ImageFile) def onDisconnect(self, Connection): Domoticz.Debug('onDisconnect called') def onHeartbeat(self): Domoticz.Debug('onHeartbeat called') if self.counter >= self.multiplier: foundInsideDevice = False foundTargetDevice = False foundHeatingDevice = False foundThermostatDevice = False Domoticz.Debug('Getting Data') self.counter = 1 d = self.GetDevices() Domoticz.Debug('Getting Temperatures') thermostat = self.GetThermostat(d) if thermostat: # get the temperature and heating states temp = thermostat["attributes"]["temperature"]["reportedValue"] Domoticz.Debug('Temp = ' + str(temp)) targetTemp = thermostat["attributes"]["targetHeatTemperature"]["reportedValue"] if targetTemp < 7.0: targetTemp = 7.0 Domoticz.Debug('Target = ' + str(targetTemp)) heating = thermostat["attributes"]["stateHeatingRelay"]["reportedValue"] Domoticz.Debug('Heating = ' + heating) Domoticz.Debug('Getting Battery Status') thermostatui = self.GetThermostatUI(d) # get the battery and rssi values thermostat_battery = thermostatui["attributes"]["batteryLevel"]["reportedValue"] Domoticz.Debug('Battery = ' + str(thermostat_battery)) thermostat_rssi = 12*((0 - thermostatui["attributes"]["RSSI"]["reportedValue"])/100) Domoticz.Debug('RSSI = ' + str(thermostat_rssi)) # Loop through the devices and update temperatures Domoticz.Debug('Updating Devices') for unit in Devices: if Devices[unit].DeviceID == "Hive_Inside": Devices[unit].Update(nValue=int(temp), sValue=str(temp)) foundInsideDevice = True if Devices[unit].DeviceID == "Hive_Target": Devices[unit].Update(nValue=int(targetTemp), sValue=str(targetTemp)) foundTargetDevice = True if Devices[unit].DeviceID == "Hive_Heating": foundHeatingDevice = True if thermostatui["attributes"]["presence"]["reportedValue"] == "ABSENT": if self.TimedOutAvailable: if Devices[unit].TimedOut == 0: Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1) else: Domoticz.Log("Device Offline : " + Devices[unit].Name) else: if heating == 'ON': if Devices[unit].nValue == 0: if self.TimedOutAvailable: Devices[unit].Update(nValue=1, sValue='On', TimedOut=0) else: Devices[unit].Update(nValue=1, sValue='On') else: if Devices[unit].nValue == 1: if self.TimedOutAvailable: Devices[unit].Update(nValue=0, sValue='Off', TimedOut=0) else: Devices[unit].Update(nValue=0, sValue='Off') if Devices[unit].DeviceID == thermostat['id']: foundThermostatDevice = True if Devices[unit].Type == 242: #Thermostat Devices[unit].Update(nValue = int(targetTemp), sValue = str(targetTemp), BatteryLevel = int(thermostat_battery), SignalLevel = int(thermostat_rssi)) if foundInsideDevice == False: Domoticz.Device(Name = 'Inside', Unit = self.GetNextUnit(False), TypeName = 'Temperature', DeviceID = 'Hive_Inside').Create() self.counter = self.multiplier if foundTargetDevice == False: Domoticz.Device(Name = 'Target', Unit = self.GetNextUnit(False), TypeName = 'Temperature', DeviceID = 'Hive_Target').Create() self.counter = self.multiplier if foundHeatingDevice == False: Domoticz.Device(Name = 'Heating', Unit = self.GetNextUnit(False), TypeName = 'Switch', Switchtype = 0, DeviceID ='Hive_Heating').Create() self.counter = self.multiplier if foundThermostatDevice == False: Domoticz.Device(Name = 'Thermostat', Unit = self.GetNextUnit(False), Type = 242, Subtype = 1, DeviceID = thermostat['id']).Create() self.counter = self.multiplier lights = self.GetLights(d) if lights: for node in lights: for unit in Devices: if node['id'] == Devices[unit].DeviceID: if unit not in set(self.lightsSet): self.lightsSet.add(unit) Domoticz.Debug(Devices[unit].Name + ": " + node["attributes"]["presence"]["reportedValue"]) if node["attributes"]["presence"]["reportedValue"] == "ABSENT": if self.TimedOutAvailable: if Devices[unit].TimedOut == 0: Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1) else: Domoticz.Log("Device Offline : " + Devices[unit].Name) else: if node["attributes"]["state"]["reportedValue"] == "OFF": if Devices[unit].nValue != 0: if self.TimedOutAvailable: Devices[unit].Update(nValue=0, sValue='Off', TimedOut=0) else: Devices[unit].Update(nValue=0, sValue='Off') else: Domoticz.Debug("State: " + Devices[unit].sValue) Domoticz.Debug("Brightness Target: " + str(Devices[unit].LastLevel)) Domoticz.Debug("Brightness: " + str(node["attributes"]["brightness"]["reportedValue"])) if Devices[unit].LastLevel != int(node["attributes"]["brightness"]["reportedValue"]) or Devices[unit].sValue == 'Off': if self.TimedOutAvailable: Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"]), TimedOut=0) # 2 = Set Level else: Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"])) # 2 = Set Level break else: Domoticz.Log("Light not found " + node["name"]) newUnit = self.GetNextUnit(False) Domoticz.Device(Name = node["name"], Unit = newUnit, Type=244, Subtype=73, Switchtype=7, DeviceID = node['id']).Create() if node["attributes"]["state"]["reportedValue"] == "OFF": Devices[newUnit].Update(nValue=0, sValue='Off') else: Devices[newUnit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"])) # 2 = Set Level activeplugs = self.GetActivePlugs(d) if activeplugs: for node in activeplugs: for unit in Devices: if node['id'] == Devices[unit].DeviceID: if node["attributes"]["presence"]["reportedValue"] == "ABSENT": if self.TimedOutAvailable: if Devices[unit].TimedOut == 0: Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1) else: Domoticz.Log("Device Offline : " + Devices[unit].Name) else: if node["attributes"]["state"]["reportedValue"] == "OFF": if Devices[unit].nValue != 0: if self.TimedOutAvailable: Devices[unit].Update(nValue=0, sValue='Off', TimedOut=0) else: Devices[unit].Update(nValue=0, sValue='Off') else: Domoticz.Debug("State: " + Devices[unit].sValue) if Devices[unit].nValue != 1: if self.TimedOutAvailable: Devices[unit].Update(nValue=1, sValue='On', TimedOut=0) else: Devices[unit].Update(nValue=1, sValue='On') break else: Domoticz.Log("ActivePlug not found " + node["name"]) newUnit = self.GetNextUnit(False) Domoticz.Device(Name = node["name"], Unit = newUnit, Type=244, Subtype=73, Switchtype=0, DeviceID = node['id']).Create() if node["attributes"]["state"]["reportedValue"] == "OFF": Devices[newUnit].Update(nValue=0, sValue='Off') else: Devices[unit].Update(nValue=1, sValue='On') else: self.counter += 1 Domoticz.Debug('Counter = ' + str(self.counter)) def GetSessionID(self): payload = {'username':Parameters["Username"], 'password':Parameters["Password"]} headers = {'Content-Type': 'application/json', 'Accept': 'application/json'} url = 'https://beekeeper-uk.hivehome.com/1.0/gateway/login' req = Request(url, data = json.dumps(payload).encode('ascii'), headers = headers, unverifiable = True) r = urlopen(req).read().decode('utf-8') self.sessionId = json.loads(r)['token'] def GetDevices(self): nodes = False headers = {'Content-Type': 'application/vnd.alertme.zoo-6.2+json', 'Accept': 'application/vnd.alertme.zoo-6.2+json', \ 'X-AlertMe-Client': 'swagger', 'X-Omnia-Access-Token': self.sessionId} url = 'https://api.prod.bgchprod.info:443/omnia/nodes' req = Request(url, headers = headers, unverifiable = True) try: r = urlopen(req).read().decode('utf-8') except urllib.HTTPError as e: if e.code == 401: # Unauthorised - need new sessionId self.onStop() self.GetSessionID() r = urlopen(req).read().decode('utf-8') else: Domoticz.Log(str(e)) try: nodes = json.loads(r)['nodes'] except Exception as e: Domoticz.Log(str(e)) return nodes def GetThermostat(self, d): x = find_key_in_list(d, 'http://alertme.com/schema/json/node.class.thermostat.json#') if x: k = 'stateHeatingRelay' if k in x[0]['attributes']: thermostat = x[0] elif k in x[1]['attributes']: thermostat = x[1] else: thermostat = False else: thermostat = False return thermostat def GetThermostatUI(self, d): thermostatui = False x = find_key_in_list(d, 'http://alertme.com/schema/json/node.class.thermostatui.json#') if x: thermostatui = x[0] else: # Try a Hive2 thermostat x = find_key_in_list(d,"Hive2") if x: thermostatui = x[0] return thermostatui def GetLights(self, d): lights = False x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.light.json#") if x: lights = x return lights def GetActivePlugs(self, d): plugs = False x = find_key_in_list(d,"http://alertme.com/schema/json/node.class.smartplug.json#") if x: lights = x return plugs def GetNextUnit(self, unit): if not unit: nextUnit = len(Devices) + 1 else: nextUnit = unit +1 if nextUnit in Devices or nextUnit <= 1: nextUnit = self.GetNextUnit(nextUnit) return nextUnit def CreateLightPayload(self, State, Brightness): response = {} nodes = [] attributes = {} state = {} brightness = {} brightness["targetValue"] = Brightness state["targetValue"] = State attributes["attributes"] = {"brightness":brightness,"state":state} nodes.append(attributes) response["nodes"] = nodes return response def CreateThermostatPayload(self, Temperature): response = {} nodes = [] attributes = {} targetHeatTemperature = {} targetHeatTemperature["targetValue"] = Temperature attributes["attributes"] = {"targetHeatTemperature":targetHeatTemperature} nodes.append(attributes) response["nodes"] = nodes return response def CreateActivePlugPayload(self, State): response = {} nodes = [] attributes = {} state = {} state["targetValue"] = State attributes["attributes"] = {"state":state} nodes.append(attributes) response["nodes"] = nodes return response def isLight(self, Unit): Domoticz.Debug(str(self.lightsSet)) if Devices[Unit].Type == 244 and Devices[Unit].SubType == 73 and Unit in self.lightsSet: return True else: return False def isThermostat(self, Unit): if Devices[Unit].Type == 242: return True else: return False def isActivePlug(self, Unit): if Devices[Unit].Type == 244 and Devices[Unit].SubType == 73 and Unit not in self.lightsSet and Devices[Unit].DeviceID != "Hive_Heating": return True else: return False def getDomoticzRevision(self): Revision = 0 url = 'http://127.0.0.1:' + Parameters['Mode2'] + '/json.htm?type=command¶m=getversion' req = Request(url) try: r = urlopen(req).read().decode('utf-8') j = json.loads(r) Revision = j['Revision'] Version = j['version'] Domoticz.Debug("Domoticz Revision: " + str(Revision)) Domoticz.Debug("Domoticz Version: " + Version + '->' + str(int(Version[-4:]))) if int(Version[-4:]) > Revision: # I've managed to create a build that has Version different to Revision so take the highest Revision = int(Version[-4:]) Domoticz.Debug("Domoticz Revision: " + str(Revision)) except urllib.HTTPError as e: if e.code == 401: Domoticz.Error("Ensure you have 127.0.0.1 in your 'Local Networks' selection") else: Domoticz.Error(str(e)) except Exception as e: Domoticz.Error(str(e)) return Revision _plugin = BasePlugin() def onStart(): _plugin.onStart() def onStop(): _plugin.onStop() def onConnect(Connection, Status, Description): _plugin.onConnect(Connection, Status, Description) def onMessage(Connection, Data, Status, Extra): _plugin.onMessage(Connection, Data, Status, Extra) def onCommand(Unit, Command, Level, Hue): _plugin.onCommand(Unit, Command, Level, Hue) def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile): _plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile) def onDisconnect(Connection): _plugin.onDisconnect(Connection) def onHeartbeat(): _plugin.onHeartbeat() def DumpConfigToLog(): for x in Parameters: if Parameters[x] != '': Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'") Domoticz.Debug('Device count: ' + str(len(Devices))) for x in Devices: Domoticz.Debug('Device: ' + str(x) + ' - ' + str(Devices[x])) Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'") Domoticz.Debug("Device Name: '" + Devices[x].Name + "'") Domoticz.Debug('Device nValue: ' + str(Devices[x].nValue)) Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'") Domoticz.Debug('Device LastLevel: ' + str(Devices[x].LastLevel)) def find_key_in_list(d, value): if isinstance(d, list): t = list(d) for v in d: if isinstance(v, dict): p = find_key(v, value) if not p: t.remove(v) return t def find_key(d, value): for (k, v) in d.items(): if isinstance(v, dict): p = find_key(v, value) if p: return [k] + p elif v == value: return [k] def merge_dicts(*dict_args): ''' Given any number of dicts, shallow copy and merge into a new dict, precedence goes to key value pairs in latter dicts. ''' result = { } for dictionary in dict_args: result.update(dictionary) return result
<plugin key="HivePlug" name="Hive Plugin" author="imcfarla and MikeF" version="0.3.2" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://my.hivehome.com/login/">
<params>
<param field="Mode2" label="Domoticz Port - only needed prior to version 3.8791" width="40px" required="false" default="8080"/>
<options>
</options>
</param>
</params>
</plugin>
import Domoticz
import json
class BasePlugin:
enabled = False
def __init__(self):
self.sessionId = ''
self.counter = 0
def onStart(self):
else:
self.GetSessionID()
self.onHeartbeat()
def onStop(self):
try:
else:
payload = ""
if payload != "":
try:
self.counter = 1
if thermostat:
else:
else:
if heating == 'ON':
else:
else:
else:
if lights:
for node in lights:
rssi = 12*((0 - node["attributes"]["RSSI"]["reportedValue"])/100)
Devices[unit].Update(nValue=Devices[unit].nValue, sValue=Devices[unit].sValue, TimedOut=1, SignalLevel=0)
else:
else:
Devices[unit].Update(nValue=0, sValue='Off', TimedOut=0, SignalLevel=int(rssi))
else:
Devices[unit].Update(nValue=0, sValue='Off', SignalLevel=int(rssi))
else:
Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"]), TimedOut=0, SignalLevel=int(rssi)) # 2 = Set Level
else:
Devices[unit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"]), SignalLevel=int(rssi)) # 2 = Set Level
break
else:
#light_rssi = 12*((0 - node["attributes"]["RSSI"]["reportedValue"])/100)
Devices[newUnit].Update(nValue=0, sValue='Off', SignalLevel=int(rssi))
else:
Devices[newUnit].Update(nValue=2, sValue=str(node["attributes"]["brightness"]["reportedValue"]), SignalLevel=int(rssi)) # 2 = Set Level
if activeplugs:
else:
else:
else:
else:
Devices[unit].Update(nValue=1, sValue='On', TimedOut=0, SignalLevel=int(rssi))
else:
Devices[unit].Update(nValue=1, sValue='On', SignalLevel=int(rssi))
break
else:
else:
else:
self.counter += 1
nodes = False
try:
self.onStop()
self.GetSessionID()
else:
try:
return nodes
if x:
thermostat = x[0]
thermostat = x[1]
else:
thermostat = False
else:
thermostat = False
return thermostat
if x:
thermostatui = x[0]
if x:
thermostatui = x[0]
return thermostatui
lights = False
if x:
lights = x
return lights
plugs = False
if x:
lights = x
return plugs
if not unit:
else:
nextUnit = unit +1
return nextUnit
response = {}
nodes = []
attributes = {}
state = {}
brightness = {}
return response
response = {}
nodes = []
attributes = {}
return response
response = {}
nodes = []
attributes = {}
state = {}
return response
return True
else:
return False
return True
else:
return False
return True
else:
return False
Revision = 0
if 'DomoticzVersion' in Parameters:
Domoticz.Log("DomoticzVersion Available")
Revision = Parameters['DomoticzVersion'][-4:]
else:
Domoticz.Log("DomoticzVersion Not Available - Using JSON")
Domoticz.Log("Version URL: " + url)
req = Request(url)
try:
j = json.loads(r)
if e.code == 401:
else:
return Revision
def onStart():
_plugin.onStart()
def onStop():
_plugin.onStop()
def onHeartbeat():
for x in Devices:
t = list(d)
for v in d:
if not p:
t.remove(v)
return t
if p:
return [k] + p
elif v == value:
return [k]
result = { }
return result
2018-01-04 11:23:46.177 (Hive Devices) Initialized version 0.3.2, author 'imcfarla and MikeF'
2018-01-04 11:23:46.239 (Hive Devices) Starting
2018-01-04 11:23:46.240 (Hive Devices) Debug log level set to: 'true'.
2018-01-04 11:23:46.240 (Hive Devices) DomoticzVersion Not Available - Using JSON
2018-01-04 11:23:46.240 (Hive Devices) Version URL: http://127.0.0.1:8080/json.htm?type=command∂m=getversion
2018-01-04 11:23:46.360 Error: (Hive Devices) 'onStart' failed 'NameError'.
2018-01-04 11:23:46.361 Error: (Hive Devices) ----> Line 425 in /home/pi/domoticz/plugins/Hive/plugin.py, function onStart
2018-01-04 11:23:46.361 Error: (Hive Devices) ----> Line 36 in /home/pi/domoticz/plugins/Hive/plugin.py, function onStart
2018-01-04 11:23:46.361 Error: (Hive Devices) ----> Line 412 in /home/pi/domoticz/plugins/Hive/plugin.py, function getDomoticzRevision
2018-01-04 11:23:51.275 (Hive Devices) Deleting Session
2018-01-04 11:23:51.515 (Hive Devices) HTTP Error 401: Unauthorized
2018-01-04 11:23:51.588 (Hive Devices) Exiting work loop...
2018-01-04 11:23:51.876 (Hive Devices) Stopped.
2018-01-04 11:23:55.714 (Hive Devices) Calling message handler 'onHeartbeat'.
2018-01-04 11:23:55.715 (Hive Devices) onHeartbeat called
2018-01-04 11:23:55.715 (Hive Devices) Counter = 1
2018-01-04 11:24:05.693 (Hive Devices) Calling message handler 'onHeartbeat'.
2018-01-04 11:24:05.694 (Hive Devices) onHeartbeat called
2018-01-04 11:24:05.694 (Hive Devices) Counter = 2
2018-01-04 11:24:15.723 (Hive Devices) Calling message handler 'onHeartbeat'.
2018-01-04 11:24:15.723 (Hive Devices) onHeartbeat called
2018-01-04 11:24:15.723 (Hive Devices) Counter = 3
