Page 4 of 25
Re: Android app
Posted: Sunday 08 December 2013 21:48
by remb0
My dromotica is crashing while the old version works well.
I use a dyndns port 433 and the fancy username and password.
I use cynogen mod v11 4.4
Re: Android app
Posted: Sunday 08 December 2013 21:51
by Peter112
works ok on my asus transformor TF101 Android 4.0.3
Re: Android app
Posted: Sunday 08 December 2013 22:49
by alfred_j_kwak
I have more than one screen of switches and when app do autorefresh it jumps in the top of switch pages.
-Jussi-
Re: Android app
Posted: Monday 09 December 2013 7:34
by fifise
Thx for this apps.
But I have something weird: it display the good status of the switch but when activate/desactivate one nothing happen in reality ?
Does it use a different port to send than to receive ? ( my domoticz is set on a rasp pi protect by a firewall)
Re: Android app
Posted: Monday 09 December 2013 8:10
by sebas
fifise wrote:Thx for this apps.
The port for sending and receiving is the same. Could be that you slide the switch instead of clicking on it.
Haven't figured that one out yet but when you slide the switch from on to off or off to on nothing happens. When you click on it then the switch will be send to Domoticz.
alfred_j_kwak wrote:I have more than one screen of switches and when app do autorefresh it jumps in the top of switch pages.
-Jussi-
Thanks for mentioning it. I'll see if I can change that.
Re: Android app
Posted: Monday 09 December 2013 8:20
by sebas
remb0 wrote:My dromotica is crashing while the old version works well.
Did you report the crash? If so I can view the details of the crash in the store. I'll see what's going on.
Re: Re : Android app
Posted: Monday 09 December 2013 8:37
by fifise
Oups sorry you are right I was sliding and not clicking.
Work great now thanks a lot for your work.
Just a question are you planning to make it work from internet and if so could you add the option to authenticate on the websever with a certificate (I protect the access to my domotic from internet with the solution given in the wiki of domoticz)
Re: Android app
Posted: Monday 09 December 2013 8:50
by remb0
sebas wrote:remb0 wrote:My dromotica is crashing while the old version works well.
I have used the crash reports indeed.
Posted: Monday 09 December 2013 17:06
by sebas
I'm looking into a way to have both LAN and WAN access configured where the app will switch between the two connections. The two authentication methods currently supported are the two with a username and password. I'll have to see if I can get anything with certificates up and running. Can't give any promises about that
You are using the client certificate option mentioned here?
http://www.domoticz.com/wiki/Secure_Remote_Access
@remb0. Found the crash report. Seems that somethings going wrong with the displaying of errors. The app can't connect to the Domoticz server and then crashes because it can't show the error dialog. I'll fix that but maybe you can fix it for you by checking your server settings.
Posted: Tuesday 10 December 2013 7:08
by fifise
Yes, for me the login/password is too weak to expose my house on the web (working in computer have perhaps make me too paranoid
Once it's set, it simplify a little the use from internet: authentication is done by the certificate user install on my android and there is no more need of typing login/password (so no possibility to brut force), the browser popup the users certificate install on the phone and you just have to choose which one to use (most of the time there is only one).
Re: Android app
Posted: Wednesday 11 December 2013 22:02
by remb0
its crashing when you enter a wrong port number
I've send a crash report.
but now I use the right one: Awesome!.
Re: Android app
Posted: Thursday 12 December 2013 7:52
by sebas
remb0 wrote:its crashing when you enter a wrong port number
Great to hear that you got it to work.
I've found where it crashes and got it to crash less but it's not completely gone. Sometimes it still crashes for some reason. I'll be working on that some more for the next update.
Re: Android app
Posted: Wednesday 18 December 2013 9:53
by NoiseMaker
Hi!
I have yet to get a Domoticz system since I've not moved into my new house yet. I have also not read this entire thread. Still I thought I'd tell you two functions that I will want when I've gotten my system and that is Notifications and Widgets. Both control widgets and information widgets.
Ciao!
Re: Android app
Posted: Wednesday 18 December 2013 21:14
by sebas
I just published a new version to the Play store. You should be receiving it the coming hours.
The update brings better stability in using the app. When Domoticz doesn't return anything the app handles this better and gives better error messages.
Also an about page is added.
Re: Android app
Posted: Wednesday 18 December 2013 23:20
by remb0
I have updated. But u tot only the new ! Sign. No devices etc available. The same settings as the previous version. Something broke since last update.
Re: Android app
Posted: Thursday 19 December 2013 8:05
by XL-Network
Here the same story. I've updated and my settings are correct (and I've resaved them), but the switches (and other) pages gives me an error.
Error loading content
Could not get a response from the Domoticz server.
Please check your settings and Domoticz server.
Re: Android app
Posted: Thursday 19 December 2013 8:07
by sebas
remb0 wrote:I have updated. But u tot only the new ! Sign. No devices etc available. The same settings as the previous version. Something broke since last update.
Did you get a notification of the update? Normally I'm reminded by the Play Store that an update is available but I haven't had that yet. When I go to the app in the store manually it does show the update button.
I'll update the app on my phone and see if I can get a list of switches etc. During testing yesterday it did work.
Re: Android app
Posted: Thursday 19 December 2013 8:15
by sebas
XL-Network wrote:Here the same story. I've updated and my settings are correct (and I've resaved them), but the switches (and other) pages gives me an error.
Checked to see if I can pull the update from the store but that's not possible
Apparently something went really wrong with this. I'll fix it today.
Re: Android app
Posted: Thursday 19 December 2013 8:20
by XL-Network
sebas wrote:XL-Network wrote:Here the same story. I've updated and my settings are correct (and I've resaved them), but the switches (and other) pages gives me an error.
I'll wait and see. I'm not home again until late this evening. Otherwise the other people might also not be able to use the app.
PS. I have an Nexus 4 with Android 4.4.2 and it showed an icon in the notification bar that said I had an update (just to reply to the question you asked remb0). Clicked it in anticipation with the earlier mentioned result. Looks like it cannot reach the server.
PS2. My setup has a Ngnix reverse proxy between the phone and Domoticz. Just basic authentication, nothing fancy. Maybe there is a problem there but I could not imagine it.
TIP. Maybe you want to rename the property 'Domoticz URL' in the Settings page to 'Domoticz hostname' (because that's what it actually is). And you might want to hide the password/change it to stars (now it's readable).
Re: Android app
Posted: Thursday 19 December 2013 8:56
by remb0
I don't saw a notification and went to the playstore manually. there I saw the update.
