Page 4 of 4
Re: Domoticz version 2024.7 released
Posted: Monday 12 August 2024 14:49
by solarboy
Small issue with this version. In the last version my "Floorplan" would not update in Firefox after the laptop had been asleep without a manual refresh. Now in this version, for the first time, the log page also displays this behaviour.
I found the previous behaviour more useful. Perhaps just a small thing has been overlooked.
Otherwise a great rock solid release.
Posted: Tuesday 13 August 2024 11:45
by gizmocuz
The log page is not displayed without a reason.
Maybe the browser removed the cookie, or you did not enable 'remember me'
'a' solution could be to add the IP address of the laptop in the trusted network so you won't need a username/password
I assume Domoticz is used natively and not behind a (reverse) proxy?
Posted: Tuesday 13 August 2024 12:53
by solarboy
Yes, Domoticz is on the same network and the IP is within the trusted zone. Firefox will connect using https but Edge would only connect with http (I have "Allow basic auto" enabled) and both Edge and Chrome shows a "not secure" warning to the left of the address bar.
All was fine on the previous stable and I obviously cleared cookies and site data.
Posted: Thursday 29 August 2024 11:13
by brugje
When i try to download 2024.7.16140 for windows McAfee finds a threat and place the file in quarantine. Is there a solution to this so I can download the latest version. tried on several computer but all have McAfee on it and won't save the file
groet Jan
Posted: Thursday 29 August 2024 15:25
by WouterO
Who is the boss? You or McAfee? Just disable the scanner for a short time: https://www.wikihow.com/Disable-McAfee
Posted: Sunday 08 September 2024 19:12
by elzorrovega
Hello All,
In release notes Domoticz version 2024.7 I saw that Google Cloud Messaging was fixed. I use an iPhone with latest Domoticz iOS application (Client Ver 0.1.55) for which there has not been an update in years.
In the past, GCM (FCM) notifications worked properly with the possibility to choose which mobile device received the message. Later when I encountered notification issues with GCM, I switched over to Pushover.
In Domoticz settings and setup, GCM Notification are enabled and Mobile setup page show iPhone.
Whenever I use test buttons or DzVents to issue GCM messages, following errors appear in the log.
2024-09-08 17:59:47.674 Status: Notification: Domoticz test
2024-09-08 17:59:48.211 Error: FCM: Could not send message! Errorcode 401 (Auth error from APNS or Web Push Service)
2024-09-08 17:59:48.560 Error: FCM: Could not send message! Errorcode 401 (Auth error from APNS or Web Push Service)
2024-09-08 17:59:48.560 Notification sent (fcm) => Failed
2024-09-08 17:59:48.562 Active notification Subsystems: browser, email, fcm, pushover (4/13)
2024-09-08 18:00:06.713 Status: Notification: Domoticz test
2024-09-08 18:00:07.073 Error: FCM: Could not send message! Errorcode 401 (Auth error from APNS or Web Push Service)
2024-09-08 18:00:07.073 Notification sent (fcm) => Failed
2024-09-08 18:00:07.076 Active notification Subsystems: browser, email, fcm, pushover (4/13)
Is this feature available only for Android phones?
Posted: Tuesday 17 September 2024 10:10
by vwstepha
Hi every body!
Can you confirm that with this last version, Gpio system ( old or newest) is fixed?
I use 6 GPIO (4 OUT for relay and 2 IN) I dont want change that ( but i can change the number of port in configuration files)
I have the 2023.2 domoticz version.
I would have the last version in order to use the new version of PV widget!
Thanks you very munch!! :mrgreen:
Posted: Tuesday 17 September 2024 10:44
GPIO system did not change, only on newer OS'-es the Linux GPIO system has changed and there is a fix for that. I have no idea if this really works.
But as long as you do not upgrade your OS Domoticz new versions will still use the old way of working.
Posted: Friday 18 October 2024 20:54
by tjabas
will there be any support of the sungrow inverter?
Posted: Friday 18 October 2024 22:10
tjabas wrote: Friday 18 October 2024 20:54 will there be any support of the sungrow inverter?
Posting the request here willl not get it in Domoticz. If you are not able te create it yourself you will have to wait until someone shares it's integration. Perhaps look here https://github.com/MickMake/GoSunGrow/ for some integration. mQTT seems promising of it uses MQTT Autodiscover.
But create another topic as this is definitely not the correct topic to discuss this.
Posted: Saturday 19 October 2024 14:40
by tjabas
thanks i will do that.
Posted: Tuesday 29 October 2024 21:19
by teo1966
anyone have this version on it with this Raspberry Pi OS 2024-10-22 together with domoticz 2024.7
Posted: Tuesday 29 October 2024 21:33
by FireWizard
What do you mean with "this version"?
The Raspberry Pi OS from 2024-10-22 is just the latest version of Bookworm with all updates installed until that date.
Yes, Domoticz 2024.7 runs on that version of Raspberry Pi OS.
But, what is your issue or question?
Posted: Tuesday 29 October 2024 23:23
by teo1966
no problem, just wanted to know if the pi could update without any problems
Posted: Tuesday 29 October 2024 23:47
Closing this topic. If you have questions about 2024.7 start a new topic in an appropriate sub forum.
