Page 4 of 16
Re: Energy Dashboard (Build in)
Posted: Monday 17 June 2024 14:29
by akamming
I think there is still a bug in the cost calculation. This is my current output of the P1 Energy in the energy dashboard:
- kosten.jpg (17.78 KiB) Viewed 1706 times
In my Settings "Kosten R1" is 0.3048 and "Kosten R2" is 0.3228.
So even if i calculate in the worst case (in this case R1 pricing ) the cost should be a least 1.80 (6kwh delivered to the next x 0.3048 R1 cost). The energy dashboard states 1.60. If i caluclate using kosten R2, the differnce would be even bigger...
EDIT: Did a bit more investigation: in the energy report the output is correct, it states -2.09, where the energy dashboard incorrectly still states -1.60, so i would expect these numbers be the same...
- tabel.jpg (25.3 KiB) Viewed 1702 times
Posted: Monday 17 June 2024 15:34
by gizmocuz
akamming wrote: Monday 17 June 2024 8:48
gizmocuz wrote: Sunday 16 June 2024 12:45
I will change it to "(Dynamic) Price calculation" ... maybe that sounds more logical
question, why is the option there? You could also assume that when "not active" is selected, automatically "internal" is assumed...
Yes, BUT... there are users that do not correct these parameters when they install Domoticz... and this will result in bad numbers.
This is more a trigger from '... make sure you got your numbers right'
Posted: Monday 17 June 2024 17:18
by gizmocuz
akamming wrote: Monday 17 June 2024 14:29
That depends...
- Are you using the latest Domoticz beta version from today as there have been some changes to te P1 report.
It will now use/display the internal calculated (dynamic) price instead of a simple multiply
(Also, when you have a dynamic contract, you need to use the latest beta to see the right prices in the report (90% working))
- The internal calculated price (at the moment) was calculated at the end of each hour... so this price is a bit lower than the 'real' price.
I just pushed a new beta that has a 5-minute resolution (beta 16081)
Remember that this is a "Work In Progress"... besides this dashboard, the dynamic price calculation is new as well.
Posted: Monday 17 June 2024 18:52
by akamming
I know it’s bèta, that’s why I give the feedback so you can improve the code
I’ll try to upgrade somewhere this week…
Posted: Monday 17 June 2024 19:14
by Sjonnie2017
The intergrated dashboard is working as expected. Build 16081 shows the correct cost estimates based on the values I entered in the settings. Previous versions showed the cost multiplied by thousand which was a bit confusing
Kudos to @Meneer Klaas and @Gizmocus for this excellent addition to Domoticz!
Posted: Tuesday 18 June 2024 9:11
by akamming
update to 16081 and now indeed cost seems to be correct. Tx @gizmocus (and @meneerklaas)
Posted: Wednesday 19 June 2024 20:48
by Martini77
Nice one this Energy Dashboard!
For the 'Gas' meter, it would be nice to also 'allow' RFX meter devices with a different Type (ie. Custom) to be selected in the settings. Esspecially for the people having District Heat (measured in GJ instead of M3 for Gas) this would be welcome..
I was able to select my RFX meter (Type = Custom) via a workaround and it seems to work properly (except for the costs which are shown as 0.00)
- first change the device type to Gas,
- then select the device in Energy Dashboard settings (it appears now)
- then switch back the device from Type = Gas to Type = Custom (GJ).
Posted: Wednesday 19 June 2024 20:52
by eddieb
Did you change the type manually in the database ?
Posted: Wednesday 19 June 2024 20:55
by Martini77
No, on the device itself. It's device type 'RFXMeter counter' (created via dummy hardware)
Posted: Wednesday 19 June 2024 21:29
by BartSr
I would say that this energy dashboard is one of the best improvements of Domoticz.
Thanks to the developers.
I would do some suggestions to made it even better.
Currently only one of my PV systems can be selected. Would not it be logic to have the opportunity to add several (3) in my case. I believe HA has this option.
I tried to include via free widget 1 my heatpump. For that I created a P1 device but this does not pop up in the combobox .
Than a small nice to have: as I often use my phone to check things it would appreciate a bigger font for the values. Now, also using my glasses, makes it very difficult to read.
Bart
Posted: Wednesday 19 June 2024 22:13
In Domoticz you can easily make a dzvents script for a dummy total PV General kWh device. You have 3 inverters others will have 5... So where will it stop?
Posted: Wednesday 19 June 2024 22:54
by BartSr
Walter, I just checked my test HA. I cannot find a limit in consumers nor power generating systems.
Posted: Thursday 20 June 2024 0:01
Everything can be programmed of course so perhaps Gizmocuz will implement this. In current setup it does not seem to be easy so for you to get a summarize PV in your energy dashboard I would advise you to make a summarize device yourself.
Posted: Thursday 20 June 2024 0:19
by heggink
For those struggling to read on a phone: switch to desktop mode and you can scale.
Posted: Thursday 20 June 2024 7:19
by gizmocuz
In the current beta version (16089) it should now be possible to zoom.
@BartSr, exactly as Walter said, use dzVents to make build a new Watt sensor that adds them all together. Super easy!
Posted: Thursday 20 June 2024 8:19
by BartSr
@gizmocus
if it's that easy to create a total P1-consumers device it would be great to include such in the wiki.
Posted: Thursday 20 June 2024 8:26
by ravaoo
waltervl wrote: Wednesday 12 June 2024 16:19
Check the device log page. It should also show the costs (in the monthly graph)
Thanks Waltervl! This helped finding my problem. I now understand how it works. for gas i selected (internal) and it works (after a day waiting for change in my meter).
Posted: Thursday 20 June 2024 9:32
BartSr wrote: Thursday 20 June 2024 8:19
@gizmocus
Something like this. When more than 2 solar sets you have to add extra Power devices to the calculations.
return
on =
timer = { 'every minute' }
local Solar1Power = domoticz.devices(2013) -- Solar set 1, existing General kwh device
local Solar2Power = domoticz.devices(2039) -- Solar set 2, existing General kwh device
-- Create manually a dummy kWh, Electricity (instant and counter) device in generation mode
local totalPower = domoticz.devices(2037) -- total, to be used in Energy dashboard configuration
totalPower.updateElectricity(
Solar1Power.actualWatt + Solar2Power.actualWatt,
Solar1Power.WhTotal + Solar2Power.WhTotal
Posted: Thursday 20 June 2024 12:26
by Micha123
it would be nice to use an backrdound on the Energy Dashboard,
The dashboard is an verry nice Feature.
the second thing will be fine to have also 2 dashes (if possible) i have an little offgrid (seperated from the home electricity) with own solar panels battery an inverter, wil be verry cool if there wil be more dashboards possible.
but the Dashboard is realy NICE, thats what im always missed, seen it often in Victron systems and now we have it in Domoticz NICE !
Posted: Thursday 20 June 2024 13:17
There is also a wiki page for the Energy Dashboard
https://www.domoticz.com/wiki/Energy_dashboard
And for the costs an entry in the Settings Wiki:
https://www.domoticz.com/wiki/Applicati ... alculation
