Page 4 of 6
Re: Interesting ESP8266 WiFi Module
Posted: Tuesday 17 March 2015 1:13
by ThinkPad
Another ESP8266 (in combination with Arduino) project i finally got working is this one:
http://gizmosnack.blogspot.nl/2014/10/p ... -hack.html
http://gizmosnack.blogspot.nl/2014/11/p ... eless.html
(not my blog)
A cheap power consumption meter that wirelessly sends the actual power consumption of a device to Domoticz!
Data on the SPI-bus between CPU and display is being sniffed by an Arduino. Getting that to work in my own setup was just copy-paste his code.
But i wanted it wireless, with an ESP8266! And this evening i finally got it to work!
It now wirelessly sends the actual power consumption of a device where it is plugged in between to a virtual sensor in Domoticz, very awesome!
See my Arduino code here:
http://pastebin.com/G6dArPfv
Still needs a quite amount of love though, far from perfect. Connecting to wifi isn't even working, i did that by hand (luckily the ESP remembers a network).
The Arduino is already being powered from the meter' own supply (78L05). But that powersupply doesn't have enough juice to also power the ESP8266, so i have to come up with something smart.
Posted: Tuesday 17 March 2015 8:19
by BigDog
i have been reading this tread but isnt the ESP8266 WiFi Module not in the way of the Wifi network ?
i have read that the 2.4 megahertz freq already is to crowded
would it be better to work with other freq?
just thinking out loud
Greetz BigDog / Bob
Posted: Tuesday 17 March 2015 19:15
by gerardvs
"The more the merrier"
Sure you have a point about a crowded WiFi environment. But usually these devices do not send a lot of data unless you use them for streaming audio of video.
I have several ESP devices which report temperature and contact status once or twice every minute and have no issues in my already crowded WiFi environment.
Posted: Saturday 04 April 2015 11:02
by mvdbro
To increment a counter in Domoticz is seems necessary to read/increment/write the value through json.
I'm working on a LUA script to perform these steps. It's just a basic sample script, because it does not actually count something. But that can be done by using gpio.
Sample script:
ip = "192.168.0.8"
port = 8080
idx = 72
increment = 0.1
function getdata()
strData="GET /json.htm?type=devices&rid=" .. idx .. " HTTP/1.1\r\nHost: www.local.home\r\n"
.."Connection: keep-alive\r\nAccept: */*\r\n\r\n"
conn=net.createConnection(net.TCP, 0)
conn:on("receive", function(conn, payload)
pos=string.find(payload,"Data")
if pos ~= nil then
strData=string.sub(payload,pos+9,pos+49)
pos=string.find(strData," ")
if pos ~= nil then
strData=string.sub(strData,1,pos-1)
value=tonumber(strData)
return value
end )
conn:connect(port,ip)
conn:send(strData)
return value
function senddata(value)
strData="GET /json.htm?type=command¶m=udevice&idx=" .. idx .. "&svalue=" .. tostring(value) .. " HTTP/1.1\r\nHost: www.local.home\r\n"
if string.find(payload,"OK") ~= nil then
print("Succes")
end )
conn:send(strData)
function update()
if increment > 0 then
value=getdata()
if value ~= nil then
print(value)
newvalue = (value + increment)*100
print(newvalue)
senddata(newvalue)
print("error getting data")
tmr.alarm(0, 30000, 1, function() update() end)
It will read the current value of the device, increment the value and write back to Domoticz.
Posted: Saturday 04 April 2015 16:04
by mvdbro
Updated version, previous version had some sync issues. Send is now performed after conn.receive
ip = "192.168.0.8"
port = 8080
idx = 72
increment = 1.5
function updatedata()
if pos ~= nil then
if pos ~= nil then
print("Get OK")
print(value)
print(newvalue)
conn:close()
senddata(newvalue)
return value
end )
conn:send(strData)
if string.find(strData,"Infinity") == nil then
print("Send OK")
print(payload)
end )
conn:send(strData)
function update()
updatedata()
Posted: Saturday 04 April 2015 16:10
by ThinkPad
Breaking!
Since a few days ago, native Arduino code (C++) can be executed on the ESP8266. Very interesting!
I already managed to get a basic sketch from someone else working, it reads 2x DS18B20 (or more) and writes the value to a virtual sensor in Domoticz!
You can find that code here:
http://gathering.tweakers.net/forum/lis ... 0#43984260
More information about the Arduino ESP8266 stuff here:
https://github.com/esp8266/Arduino/
Posted: Saturday 04 April 2015 21:20
by mvdbro
ThinkPad wrote:...native Arduino code (C++) can be executed on the ESP8266. Very interesting!
Indeed very interesting. Will try to port the lua stuff to native ESP Arduino and see if it will work...
Posted: Saturday 04 April 2015 22:26
by mvdl
Okay, apparently this is really true... First read about this on wednesday... April 1st...
Haven't tried it yet, though. I do have some ESP8266 modules, but struggling to get communication with them working. Probably a power supply problem - my USB to TTL not able to power the module. Looking forward to get them working, though.
Posted: Saturday 04 April 2015 23:16
by ThinkPad
Use a USB-Serial converter with FTDI chip like this:
http://www.tinytronics.nl/shop/FT232RL- ... rt-Adapter
I have mine from eBay (looks the same), works great. You can also connect the DTR pin to Arduino so it automatically reboots when uploading starts.
Never had any issues with Arduino or ESP8266.
Oh, about power: i mostly use my lab powersupply to provide external 3.3V for the ESP8266.
Posted: Sunday 05 April 2015 15:21
by mvdbro
Succesfully ported the LUA script logic to native C code for the ESP-Arduino IDE. Promising development...
Specifically for experienced Arduino developers that do not want to struggle with LUA...
So now we have NodeMCU/LUA and native C choice. Nice!
* This demo sketch gets data from Domotics using json api, increment the value and update Domoticz counter
#define WIFI_SSID "........"
#define WIFI_KEY "........"
#define DOMOTICZ_IDX 72
#define DOMOTICZ_IP "192.168.0.8"
#define DOMOTICZ_PORT 8080
#define INCREMENT 1 // demo value, since there's no actual device attached yet...
#include <ESP8266WiFi.h>
const char* ssid = WIFI_SSID;
const char* password = WIFI_KEY;
const char* host = DOMOTICZ_IP;
const int httpPort = DOMOTICZ_PORT;
float value=0;
void setup() {
Serial.begin(115200);
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void loop() {
delay(5000);
if (getdata(&value))
value=(value + INCREMENT)*100;
Serial.println(value);
senddata(value);
boolean getdata(float *data)
boolean success=false;
Serial.print("connecting to ");
Serial.println(host);
// Use WiFiClient class to create TCP connections
WiFiClient client;
if (!client.connect(host, httpPort)) {
Serial.println("connection failed");
return false;
// We now create a URI for the request
String url = "/json.htm?type=devices&rid=";
url += DOMOTICZ_IDX;
Serial.print("Requesting URL: ");
Serial.println(url);
// This will send the request to the server
client.print(String("GET ") + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timer=millis()+200;
while(!client.available() && millis()<timer) {}
// Read all the lines of the reply from server and print them to Serial
while(client.available()){
String line = client.readStringUntil('\n');
if (line.substring(10,14) == "Data")
String strValue=line.substring(19);
byte pos=strValue.indexOf(' ');
strValue=strValue.substring(0,pos);
strValue.trim();
value = strValue.toFloat();
*data=value;
Serial.println("Succes!");
success=true;
Serial.println("closing connection");
return success;
boolean senddata(float value)
WiFiClient client;
return false;
String url = "/json.htm?type=command¶m=udevice&idx=";
url += "&svalue=";
url += value;
if (line.substring(0,15) == "HTTP/1.0 200 OK")
success=true;
return success;
Posted: Sunday 05 April 2015 15:52
by ThinkPad
Where do you use your code for? Some kind of counter, but in what kind of physical usage?
Posted: Sunday 05 April 2015 21:55
by mvdbro
ThinkPad wrote:Where do you use your code for? Some kind of counter, but in what kind of physical usage?
My first usage will be for my water usage sensor (optical sensor). But i also have electric and gas meter sensors (also optical sensors). So next step is to connect the optical sensor to one of the GPIO pins of the ESP8266.
Posted: Sunday 05 April 2015 22:03
by ThinkPad
For the water you could have a look at:
http://www.mysensors.org/build/pulse_water (see also the other examples at the site). It is Arduino code, so you can probably adopt large pieces of it
Posted: Monday 06 April 2015 11:11
by mvdl
Hi Thinkpad,
ThinkPad wrote:Use a USB-Serial converter with FTDI chip like this:
Thanks. Yeah, I have a USB to TTL converter, like this one:
http://goo.gl/JapNiW. No DTR unfortunately. The VCC is selectable (3.3/5V) but not sure whether that alters the levels of the Tx/Rx pins, though.
And it is probably unable to feed the ESP8266 sufficiently. Alternative was to hook it up to my 3.3V Arduino Nano (328) and then access it through the Arduino Serial terminal. Again, no luck. So, either a) my ESP8266 (ESP01) module is bust or b) the Nano cannot sufficiently power the module either, or c) I should just stop trying to understand electronics (not in favour of this one
Breadboard power supply is being ordered, considering a lab supply.
Posted: Monday 06 April 2015 15:00
by maluko
hi guys
is any changes to put this idea working?
ESP-01(A) on car (Station mode) and other ESP-01(B) (AP mode) doing ping, if B pings A do Open the gate.
or ESP-01 and a arduino.
thanks
Posted: Monday 06 April 2015 15:56
by ThinkPad
Clever idea
Should work i think....
Posted: Monday 06 April 2015 16:56
by mvdbro
mvdl wrote:... or c) I should just stop trying to understand electronics (not in favour of this one
or d) purchase one of these and feed with USB power from your PC or use a cheap USB charger:
- MS1117.png (53.07 KiB) Viewed 6367 times
Posted: Tuesday 07 April 2015 22:42
by mvdl
mvdbro,
Looks promising. Seems to take anything between 4.2V and 10V and converts down to 3.3V. Nice when moving from breadboard to prototyping board, or ...
Have seen these on aliexpress range in price between €0,40 (when ordering at least 10) and €3,46 per piece.
Is the €4,- for 10 too good to be true, or are others trying to make a little extra money at my expense?
Thanks for the tip!
Posted: Tuesday 07 April 2015 22:54
by Raspberry Piet
mvdl wrote:
Is the €4,- for 10 too good to be true?
No, i paid about the same price for ten of them. Works ok.
Posted: Wednesday 08 April 2015 19:24
by mvdl
Ordered...
