Lidl now also sells Zigbee smarthome devices Topic is solved
BertB
Re: Lidl now also sells Zigbee smarthome devices
Post by BertB »
Had a major break trough.
I could not see the deCONZ tool via VNC, because I used tightvncserver.
I can now pair with LIDL devices, I think because I use a USB extension cable. This is realy wird, but it works.
Now I have to find out how the get the colors of the lights working.]
Now I get this in my log
2020-12-12 13:55:58.302 (Energie) Usage (Delivery L1)
2020-12-12 13:55:58.962 (Zigbee) onCommand called for Unit 2: Parameter 'Off', Level: 0, Hue:
2020-12-12 13:55:58.934 Status: User: Admin (IP: Domoticz-IP) initiated a switch command (795/Zigbee - Switch/Off)
2020-12-12 13:55:59.019 Error: (Zigbee) Can't Update Unit > 2 (lights) : {'nValue': 0, 'sValue': 'off'}
2020-12-12 13:55:59.020 Error: (Zigbee) Can't Update Unit > 3 (lights) : {'nValue': 0, 'sValue': '9', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":62,"ww":62,"cw":193}'}
2020-12-12 13:55:59.020 Error: (Zigbee) Can't Update Unit > 65520 (groups) : {'nValue': 0, 'sValue': 'off'}
2020-12-12 13:56:01.718 (RFLink) Temp + Humidity (Xiron)
2020-12-12 13:56:01.727 (RFLink2) Temp + Humidity (RFL2BovengangTH)
2020-12-12 13:56:03.289 (Energie) P1 Smart Meter (Energy)
Can I just use:
sudo sh -c "echo 'deb [arch=amd64] http://phoscon.de/apt/deconz \
$(lsb_release -cs)-beta main' > \
/etc/apt/sources.list.d/deconz.list"
sudo apt install deconz
To update with the beta?
Set 1= RPI 3B, latest Beta, RFLink USB, RFLINK WIFI, Zwave
Set 2= RPI 2B, Latest Beta, OTGW (USB), SBFSpot (Bluetooth)
Thorgal789
Post by Thorgal789 »
Ha yes, you need to use the native VNC server (with raspi-config), tightvncserver is not compatible.
Can't Update Unit
Is not a big problem, it just mean the device is not present in domoticz, if you have a recent version of the domoticz plugin, it will be added automaticaly (if it s autorised in domoticz) else just restart the plugin (hardware/deconz/update)
And for color on lidl stuff you need the beta version of the domoticz plugin > https://github.com/Smanar/Domoticz-deCONZ (I will make it official in 2/3 days)
And yes this procedure will make you using the deconz beta branch but the version v2.7.1 is a stable version, you don't need to switch on the beta branch.
BertB
Post by BertB »
So, if I understaand correctly, an update to a new stable with color on LIDL will follow soon?
Thorgal789
Already done ^^, 7 days ago for the plugin.
For deconz new beta around the 15th , new stable around every 1s https://github.com/dresden-elektronik/d ... tag/v2.7.1
BertB
Post by BertB »
Thorgal789 wrote: Sunday 20 December 2020 16:04 Already done ^^, 7 days ago for the plugin.
I see. But the color of the LIDL color light bulds cannot be controlled from Domoticz right now, is IT?
Thorgal789
BertB wrote: Sunday 20 December 2020 20:22 I see. But the color of the LIDL color light bulds cannot be controlled from Domoticz right now, is IT?
Idk for your device, but for at least this one yes viewtopic.php?p=262824#p262824
You still have problem with one of them ?
BertB
Post by BertB »
Thorgal789 wrote: Monday 21 December 2020 16:20
Yes, that is why I am confused.
BertB
Post by BertB »
I re installed everything and now it works. I must have done something wrong last time. But now I can set color and intensity of the lamps.
glory50
Domoticz version: 2022.1
Post by glory50 »
Today, I found surprisingly in Lidl, that they sell Zegbee smart plugs and bulbs with affordable prices. I took them several at once. I tried to connect one plug and the led strip to Domoticz and, hurrray, Zigbee2Mqtt plugin 1.17.0 found them quicly and allowed to pair:
And it works with commands like "state": "ON". The problem is, that the devices don't appear in Domoticz' Devices! But they are on Zigbee2Mqtt GUI's list and work!! Wha could be a problem?
felix63
Domoticz version: 2020.1
Post by felix63 »
Do you have 'Accept new Hardware Devices' in Settings checked? I have the same stuff and the devices for both where added without a problem.
Version: 2020.2 (build 12847)
Zigbee2MQTT 1.17.1
Matthias
Post by Matthias »
I have a similar problem.
Version plugin zigbee2mqtt : v.1.17.1 (zStack12 20181024)
Version domoticz : 2020.2
When i associate the bulb with my sniffer CC2531, we can see a line with "Livarno Lux E27 bulb RGB" which appears in the top table. But normally when i clic on this line, a second table below have to appears and in my case it don't appear. What is the problem please ?
felix63
Post by felix63 »
Schermafbeelding 2021-02-01 om 22.20.03.jpg (304.05 KiB) Viewed 16647 times
I check and I didn't see the devices either. Then I did a reload and then I saw them again.
glory50
Post by glory50 »
Of cours I did check it!
felix63 wrote: Monday 01 February 2021 20:39 Do you have 'Accept new Hardware Devices' in Settings checked? I have the same stuff and the devices for both where added without a problem.
Zigbee2MQTT 1.17.1
glory50
Post by glory50 »
It's very strange: I upgraded the plugin (git pull), restarted Domoticz and zigbee2mqtt and both devices appeared to Domoticz! What is good, what so ever, BUT the release number of the plugin did not change - it still shows 1.17.0. I don't know why it's so. Anyway, it's good!
Edit: 1.17.0 isn't plugin version, it's zigbee2mqtt version, so it should have not changed!
Cyroq
Post by Cyroq »
I'm having the same problem that 'Livarno Lux E27 bulb RGB' shows up in Zigbee2Mqtt, but there is no 'devices' table when I click on it. Tried to re-pair it several times with 'Accept new Hardware Devices' and 'Allow new zigbee devices to join' selected, but get the same result every time. Reload, reboot and 'git pull' of the plugin didn't do it for me.
Pauluz
Post by Pauluz »
I am still using my "old" Homey as a Zigbee gateway, but since it is getting less and less more functionality because of the "newer" Homey Pro, I need to get rid of it very fast and search myself for a decent replacement...any ideas?
Pauluz wrote: Friday 18 March 2022 20:54 I am still using my "old" Homey as a Zigbee gateway, but since it is getting less and less more functionality because of the "newer" Homey Pro, I need to get rid of it very fast and search myself for a decent replacement...any ideas?
Strange question to start in this topic...
But obviously you can start with a Raspberry Pi, Domoticz and a zigbee is stick. See https://www.domoticz.com/wiki/Zigbee
Pauluz
Post by Pauluz »
[/quote]
[/quote]
Thanks for your awkward answer! ;-)
Didi
Domoticz version: 2024.4
Post by Didi »
Cyroq wrote: Wednesday 17 March 2021 21:14 I'm having the same problem that 'Livarno Lux E27 bulb RGB' shows up in Zigbee2Mqtt, but there is no 'devices' table when I click on it. Tried to re-pair it several times with 'Accept new Hardware Devices' and 'Allow new zigbee devices to join' selected, but get the same result every time. Reload, reboot and 'git pull' of the plugin didn't do it for me.
I had with other zigbee brands the same isseu. After using the steps below, restart off the server, it worked! Worth the try :D
sudo apt-get install -y nodejs npm git make g++ gcc
node --version  # Should output v10.X, v12.X, v14.X, v15.X or V16.X
npm --version  # Should output 6.X or 7.X
git clone https://github.com/Koenkk/zigbee2mqtt.git
sudo mv zigbee2mqtt /opt/zigbee2mqtt
# Install dependencies (as user "pi")
cd /opt/zigbee2mqtt
npm ci
Link with more info https://www.zigbee2mqtt.io/guide/instal ... ermissions
Main: RPI-5 / Zigbee / Sonoff / RFLink433 / Camera's / Wifi / Custom Interface / Alarm / GPS / MQTT / MiLight
