Page 4 of 8
Re: enphase envoy with (HTTP) interface
Posted: Saturday 22 April 2023 13:38
by bldewit
Hi, I added the hardware and checked that i have access to the production.json page, all ok. In my log i keep getting the No Session_id error:
Zonnepanelen platdak: Invalid data received! (no session_id)
Also tried a reboot after allowing Basic-auth, no effect.
What could be wrong?
Verstuurd vanaf mijn SM-T590 met Tapatalk
Posted: Wednesday 14 June 2023 8:53
by TurboX
In the past, I have speak about watt production refresh interval issue (software D7).
I have set 60sec of interval request into the domoticz pluging, in the log all is ok (refresh value every 60sec).
The power consumption is well refresh every 60sec but not the power production (more 5-15min). The individual inverter is worst (min 15min).
In parallele I use Home Assistant which is connected to the same enphase gateway, the consumption and production are well refreshed every 60sec approx.
The graph below show the production from HA (lines) et Domoticz (dash).
2023-06-14 08_34_15-Window.png (27.14 KiB) Viewed 25664 times
If i read https:/:IP/production.json, the watt production change very often. It seems that Domoticz doesn't read the correct variable or another .json. No?
Others things:
Why not reporting another values (like inline, voltage, ..) into Domoticz?
Moreover, I would prefer to have an additional device with only the watt of each individual inverter because it generates graphs ot the maximum power each days along a year (permit to detect an issue of production).
Posted: Wednesday 14 June 2023 19:21
by FireWizard
Hello @TurboX,
There has been a long discussion and I did several tests withe the Enphase Envoy_S.
Please read: https://github.com/domoticz/domoticz/issues/5377
60 seconds is fine.
Obviously, you have the metered version of the Envoy. This data is available.
Enphase says the following:
Your IQ Envoy polls your microinverters every 5 minutes and uploads those intervals to Enlighten every 15 minutes, give or take, depending on its WiFi connection speed and stability
So there is no need to poll the Envoy-S faster than every 5 minutes
Domoticz uses that URL.
What is "inline"? . What is the URL for "voltage"? I have never seen it.
One device, containing the data of each individual inverter? This is not clear to me.
If you can collect that data, you can easily create it yourself, either a script or Node-RED.
Posted: Wednesday 14 June 2023 20:51
by TurboX
Hello @FireWizard and thank for your answer.
I have read the discussion of your link. I still don't understand why I can't have the production every 60sec. The gateway produce the data and 60sec is fine to avoid too many request and then reboot. If the plugin read the production.json every 60sec, I don't understand why the domoticz value of the power production (watt) is updated only every 10/15min.
My production.json is the following:
production
0
type	"inverters"
activeCount	3
readingTime	1686766425
wNow	133
whLifetime	514857
1
type	"eim"
activeCount	1
measurementType	"production"
readingTime	1686766878
wNow	114.652
whLifetime	497523.002
varhLeadLifetime	2.012
varhLagLifetime	255499.637
vahLifetime	641277.6
rmsCurrent	0.641
rmsVoltage	232.009
reactPwr	49.412
apprntPwr	148.472
pwrFactor	0.71
whToday	3000.002
whLastSevenDays	24187.002
vahToday	3451.6
varhLeadToday	0.012
varhLagToday	1030.637
consumption
0
type	"eim"
activeCount	1
measurementType	"total-consumption"
wNow	195.001
whLifetime	3634871.996
varhLeadLifetime	1074997.624
varhLagLifetime	416938.662
vahLifetime	4146976.574
rmsCurrent	1.779
rmsVoltage	232.015
reactPwr	-200.16
apprntPwr	412.696
pwrFactor	0.47
whToday	4841.996
whLastSevenDays	56647.996
vahToday	5493.574
varhLeadToday	2763.624
varhLagToday	1079.662
1
type	"eim"
activeCount	1
measurementType	"net-consumption"
wNow	80.349
whLifetime	3140830.161
varhLeadLifetime	1074995.612
varhLagLifetime	161439.025
rmsCurrent	1.137
rmsVoltage	232.022
reactPwr	-150.748
apprntPwr	263.209
pwrFactor	0.33
whToday	0
whLastSevenDays	0
vahToday	0
varhLeadToday	0
varhLagToday	0
storage
0
type	"acb"
activeCount	0
readingTime	0
wNow	0
whNow	0
state	"idle"
Under "production" wNow is the value which is not updated into domoticz (and Home Assistant yes).
Regarding the Voltage, I mean the rmsVoltage and by "Inline" to check if the system respond (detect system down or reboot).
About the additionals domoticz devices, I mean to associate a power device to each energy inverter. This is what I use from HA to send via MQTT autodiscovery which generates 2 device into domoticz : Energy and power (and automatiquely related, the same power is display on both domoticz device). One example:
inverter power.png (240.13 KiB) Viewed 25650 times
Type:Usage,electric
I don't know how to collect that data, the use of token is completely out of my capabilities (and perhaps I am not alone, why not add these power devices "just" by an option of the plugin?).
Posted: Tuesday 20 June 2023 9:21
by TurboX
I am not coder but I read this on the source code on Github (line 578):
	Json::Value reading = root["production"][0];
	int musage = reading["wNow"].asInt();
I guess it read wNow into production/0 (inverter type) and not production/1 (eim type). Right?
If yes, my issue is here because under production/0 the wNow production is not real time refreshed while under production/1 the wNow is in real time.
Is it possible for me to change the domoticz code (where is located the .cpp file), juste for a test? I have a docker version just for testing, it would be perfect if I can change this value.
Posted: Tuesday 20 June 2023 11:19
by gizmocuz
I have no production/1
  "production": [
      "type": "inverters",
      "activeCount": 13,
      "readingTime": 1687252655,
      "wNow": 2817,
      "whLifetime": 860793
  "storage": [
      "type": "acb",
      "activeCount": 0,
      "readingTime": 0,
      "wNow": 0,
      "whNow": 0,
      "state": "idle"
Sure you are able to tweak the source / compile and test
https://www.domoticz.com/wiki/Build_Dom ... rom_source
Posted: Tuesday 20 June 2023 11:20
by gizmocuz
Talking about the wiki, not that hard to get the token
https://www.domoticz.com/wiki/Enphase
Posted: Tuesday 20 June 2023 13:19
by TurboX
Hello Gizmocuz,
Your production.json file is very light compare to mine. The plugin is based on your file?
I have read your link to compile by myself but this is too complicated for me (and require another raspberry).
Posted: Tuesday 20 June 2023 16:19
by gizmocuz
You can compile on any system (debian/ubuntu or windows)
Can you post your production.json here?
Posted: Wednesday 21 June 2023 7:53
by TurboX
My production.json:
  "production":[
      "type":"inverters",
      "activeCount":3,
      "readingTime":1687238955,
      "wNow":23,
      "whLifetime":531878
      "type":"eim",
      "activeCount":1,
      "measurementType":"production",
      "readingTime":1687239239,
      "wNow":28.008,
      "whLifetime":514118.081,
      "varhLeadLifetime":2.012,
      "varhLagLifetime":262155.23,
      "vahLifetime":661558.741,
      "rmsCurrent":0.284,
      "rmsVoltage":233.224,
      "reactPwr":52.541,
      "apprntPwr":66.08,
      "pwrFactor":0.45,
      "whToday":3.081,
      "whLastSevenDays":23159.081,
      "vahToday":324.741,
      "varhLeadToday":0.012,
      "varhLagToday":392.23,
      "lines":[
          "wNow":28.008,
          "rmsCurrent":0.284,
          "reactPwr":52.541,
          "apprntPwr":66.08,
          "pwrFactor":0.45,
          "whToday":3.081,
          "vahToday":324.741,
  "consumption":[
      "type":"eim",
      "activeCount":1,
      "measurementType":"total-consumption",
      "wNow":234.095,
      "whLifetime":3677800.427,
      "varhLeadLifetime":1092887.378,
      "varhLagLifetime":425695.606,
      "vahLifetime":4194992.577,
      "rmsCurrent":1.714,
      "rmsVoltage":233.33,"reactPwr":-205.665,
      "apprntPwr":399.928,
      "pwrFactor":0.59,
      "whToday":1487.427,
      "whLastSevenDays":52403.427,
      "vahToday":2499.577,
      "varhLeadToday":1252.378,
      "varhLagToday":394.606,
      "lines":[
          "wNow":234.095,
          "rmsCurrent":1.714,
          "pwrFactor":0.59,
          "whToday":1487.427,
        "type":"eim",
        "activeCount":1,
        "measurementType":"net-consumption",
        "wNow":206.087,
        "whLifetime":3167301.465,
        "varhLeadLifetime":1092885.365,
        "varhLagLifetime":163540.377,
        "rmsCurrent":1.43,
        "rmsVoltage":233.435,"reactPwr":-153.124,
        "apprntPwr":332.636,
        "pwrFactor":0.61,
        "whToday":0,
        "whLastSevenDays":0,
        "vahToday":0,
        "varhLeadToday":0,
        "varhLagToday":0,
        "lines":[
          "wNow":206.087,
          "rmsCurrent":1.43,
          "pwrFactor":0.61,
          "whToday":0,
          "vahToday":0,
          "varhLeadToday":0,
          "varhLagToday":0
    "storage":[
        "type":"acb",
        "activeCount":0,
        "readingTime":0,
        "wNow":0,
        "whNow":0,
        "state":"idle"
Posted: Friday 23 June 2023 16:44
by FireWizard
Hello @TurboX and @gizmocuz.
The difference in production.json is caused by the fact that @gizmocuz has a Enphase Envoy S and @TurboX has a Enphse Envoy S metered.
This last version gives you also information about the consumed energy, taken from the grid
I have exactly the same as @gizmocuz. I do not need a metered version, as I get that data from my P1 Smartmeter
Posted: Tuesday 27 June 2023 8:56
by TurboX
Hello @FireWizard,
Yes, you are right, I have the metered version.
I was thinking that only the Envoy S metered was able to measure production/consumption and report it.
Posted: Tuesday 27 June 2023 13:53
by gizmocuz
I am more than happy to check if it's a metered version.
But, I noticed that the value for 'whLifetime' is also different... how is this possible?
production[0] = "whLifetime":531878
production[1] = "whLifetime":514118.081
So it is quite a lot lower....
Do we pick the one from production[0] ? or if there is a production[1] we use this one?
Posted: Tuesday 27 June 2023 16:52
by FireWizard
Hello @gizmocuz,
You asked:
The data, indicated by "eim" is the data from the CT (Current Transformer) devices. It depends on how they are connected.
https://enphase.com/en-ph/download/ct-b ... ices-en-au
If I read the data from @TurboX, I guess that @TurboX has 3 Enphase inverters installed in a Single Phase system.
@TurboX: Can you confirm?
You can either connect a CT in the "Production" circuits or in the "Consumption" circuits or both.
Data is given as a total and in an array of object line for all 3 phases, L1, L2 and L3.
I do not know where the characters eim stands for. Someone?
Inverters is clear and as far as I understand "acb" stands for AC Battery. (Although AC batteries technically do not exist)
Consumption is presented as both "total-consumption" and "net-consumption".
I do not know the difference between those two. Is it a matter of connections or configuration?
But perhaps @turboX can answer.
It is quite easy to check, whether you have an Envoy-S or an Envoy-S metered, by looking to the Envoy and see if you have CT's installed.
If so, then http://IP-address/production.json will give you the details.
If you have the following:
production
0
type	"inverters"
activeCount	22
readingTime	1687876481
wNow	2884
whLifetime	8985367
storage
0
type	"acb"
activeCount	0
readingTime	0
wNow	0
whNow	0
state	"idle"
Then you have the standard version, what I expect.
Posted: Wednesday 28 June 2023 9:38
by TurboX
Yes I confirm, I have 3 Enphase micro inverter (IQ7A) with 2 Current Transformer on total production and the other on the net consumption (from Enedis, my energy provider). My total consumption is the whole of energy consumed by the house (produced and imported).
@gizmocuz I don't know why there is a difference between production[0] = "whLifetime":531878 and production[1] = "whLifetime":514118.081 but Home Assitant send to domoticz the production[1] value to Domoticz and I have Domoticz-Linky plugin (official data from my energy provider) and I match perfectly. Perhaps production[0] is an estimation from micro-inverter and production[1] is more real?
In parallele I have compiled domoticz from source (very new for me using virtual debian on synology, not so easy but very interesting) and I have juste modify the line 578 with production[1] and now the production seems updated following pooling rate :) . I will make more longer test to confirm that.
If it works, can we add a parameter into the plugin in order to chose to Envoy gateway (metered or not) or check if production[1] is available and if yes use it? (and why not add voltage RMS value?)
Posted: Wednesday 28 June 2023 11:44
by TurboX
It definitely works with the modification.
Line: data from actual Domoticz plugin with 30s polling rate
Dash: data from Home Assistant plugin (polling rate not configurable)
Dot: data from modified Domoticz plugin with 30s polling rate
Posted: Wednesday 28 June 2023 13:49
by gizmocuz
Great that you can compile now!
Could you replace the parseProduction function with:
void EnphaseAPI::parseProduction(const Json::Value& root)
	if (!IsItSunny())
		m_sql.safe_query(
			"UPDATE DeviceStatus SET LastUpdate='%s' WHERE (HardwareID==%d)", TimeToString(nullptr, TF_DateTime).c_str(), m_HwdID);
		return;
	if (root["production"].empty() == true)
		//No production details available
		return;
	size_t sproduction = root["production"].size();
	bool bIsMeteredVersion = (sproduction > 1);
	if (bIsMeteredVersion)
		bIsMeteredVersion = root["production"][1]["whLifetime"].asInt() != 0;
	Json::Value reading = (bIsMeteredVersion) ? root["production"][1] : root["production"][0];
	int mtotal = reading["whLifetime"].asInt();
	SendKwhMeter(m_HwdID, 1, 255, musage, mtotal / 1000.0, "Enphase kWh Production");
This should automatically detect if you have a metered envoy and that it is also measuring (maybe you can install the metered version without CT clamps?)
I think the value from root["production"][0] should be accurate.... hope so, as I don't have the metered version)
Posted: Wednesday 28 June 2023 18:01
by TurboX
I don't know if it's my paste the cause:
<pre>[ 17%] <span style="color:#26A269">Building CXX object CMakeFiles/domoticz.dir/hardware/EnphaseAPI.cpp.o</span>
<b>c++:</b> <span style="color:#C01C28"><b>fatal error: </b></span>Processus arrĂȘtĂ© signal terminated program cc1plus
compilation terminated.
make[2]: *** [CMakeFiles/domoticz.dir/build.make:1437 : CMakeFiles/domoticz.dir/hardware/EnphaseAPI.cpp.o] Erreur 1
make[1]: *** [CMakeFiles/Makefile2:384 : CMakeFiles/domoticz.dir/all] Erreur 2
make: *** [Makefile:156 : all] Erreur 2
</pre>
Posted: Thursday 29 June 2023 8:26
by TurboX
Sorry, it was probably me the problem :lol: . I succeed to compile again.
It works but is it sure that the old domoticz.sh is erase and rewrited by the "make" command ? Or to be sure, it is better to restart from scratch (remove dev-domoticz folder)?
Posted: Thursday 29 June 2023 13:18
by gizmocuz
Thanks for verifying. I will make the patch/commit/beta
domoticz.sh is not overwritten bij de make command
